[PostGIS] #6038: Using public.geometry_columns causes 'could not open relation with OID 188954716' after drop geometry tables
trac at osgeo.org
Tue Jan 20 03:11:36 PST 2026
Reporter: Lars Aksel Opsahl | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone:
Component: postgis | Version: master
Keywords: |
I import the attached file to at database with postgis topology installed
pgtopo_import -f /tmp/test_data.gz gsk_utdata_25_784|psql t1
Then I create a new topology (may not be needed)
SELECT topology.createtopology('t1',4258);
-- check that you have this the database
SELECT * from topology.topology;
id | name | srid | precision | hasz | useslargeids
3 | gsk_utdata_25_784 | 4258 | 0 | f | f
4 | t1 | 4258 | 0 | f | f
(2 rows)
The I close all sessions to database and start two new session and starts
two transactions.
Session 1
[local] lop at t1=# BEGIN;
BEGIN
[local] lop at t1=#
Session 2
BEGIN
[local] lop at t1=#
Then in session one drop the imported topology schema
[local] lop at t1=# SELECT topology.droptopology('gsk_utdata_25_784');
NOTICE: 00000: Dropping all layers from topology 'gsk_utdata_25_784' (3)
NOTICE: 00000: drop cascades to 8 other objects
DETAIL: drop cascades to table gsk_utdata_25_784.face
drop cascades to table gsk_utdata_25_784.node
drop cascades to table gsk_utdata_25_784.edge_data
drop cascades to view gsk_utdata_25_784.edge
drop cascades to sequence gsk_utdata_25_784.layer_id_seq
drop cascades to table gsk_utdata_25_784.relation
drop cascades to table gsk_utdata_25_784.edge_attributes
drop cascades to table gsk_utdata_25_784.face_attributes
droptopology
Topology 'gsk_utdata_25_784' dropped
(1 row)
In session two run this command inside the transaction and this hangs for
ever.
select SRID from public.geometry_columns where (f_table_schema = 't1') and
f_table_name = 'edge_data' and f_geometry_column = 'geom';
Go back two session one run commit
[local] lop at t1=# commit;
COMMIT
[local] lop at t1=#
Go back to session two and you see this error message
ERROR: XX000: could not open relation with OID 188955003
This is tested on different servers with configs
PostgreSQL 16.10 (Homebrew) on aarch64-apple-darwin23.6.0, compiled by
Apple clang version 16.0.0 (clang-1600.0.26.6), 64-bit
POSTGIS="3.7.0dev 3.6.0rc2-152-g19e25a659" [EXTENSION] PGSQL="160"
GEOS="3.14.0-CAPI-1.20.4" PROJ="9.7.0 NETWORK_ENABLED=OFF
URL_ENDPOINT=https://cdn.proj.org
USER_WRITABLE_DIRECTORY=/Users/lop/Library/Application Support/proj
DATABASE_PATH=/opt/homebrew/Cellar/proj/9.7.0/sharpr
PostgreSQL 16.4 (Ubuntu 16.4-1.pgdg20.04+1) on x86_64-pc-linux-gnu,
compiled by gcc (Ubuntu 9.4.0-1ubuntu1~20.04.2) 9.4.0, 64-bit
POSTGIS="3.7.0dev 3.6.0rc2-284-g013e9b0fd" [EXTENSION] PGSQL="160"
GEOS="3.14.0-CAPI-1.20.4" (compiled against GEOS 3.13.1) PROJ="8.2.1
NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
USER_WRITABLE_DIRECTORY=/var/lib/postgresql/.local/share/proj
DATABASE_PATH=/usr/share/oj
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6038>
