[PostGIS] #6038: Using public.geometry_columns causes 'could not open relation with OID 188954716' after drop geometry tables
PostGIS trac at osgeo.org
Tue Jan 20 03:24:51 PST 2026
  Reporter:  Lars Aksel Opsahl  |      Owner:  pramsey
      Type:  defect             |     Status:  new
  Priority:  blocker            |  Milestone:
 Component:  postgis            |    Version:  master
Resolution:                     |   Keywords:
Old description:
> I import the attached file to at database with postgis topology installed
> pgtopo_import -f /tmp/test_data.gz gsk_utdata_25_784|psql t1
> Then I create a new topology (may not be needed)
> SELECT topology.createtopology('t1',4258);
> -- check that you have this the database
> SELECT * from topology.topology;
>  id |       name        | srid | precision | hasz | useslargeids
>   3 | gsk_utdata_25_784 | 4258 |         0 | f    | f
>   4 | t1                | 4258 |         0 | f    | f
> (2 rows)
> The I close all sessions to database and start two new session and starts
> two transactions.
> Session 1
> [local] lop at t1=# BEGIN;
> BEGIN
> [local] lop at t1=#
> Session 2
> BEGIN
> [local] lop at t1=#
> Then in session one drop the imported topology schema
> [local] lop at t1=# SELECT topology.droptopology('gsk_utdata_25_784');
> NOTICE:  00000: Dropping all layers from topology 'gsk_utdata_25_784' (3)
> LOCATION:  exec_stmt_raise, pl_exec.c:3925
> NOTICE:  00000: drop cascades to 8 other objects
> DETAIL:  drop cascades to table gsk_utdata_25_784.face
> drop cascades to table gsk_utdata_25_784.node
> drop cascades to table gsk_utdata_25_784.edge_data
> drop cascades to view gsk_utdata_25_784.edge
> drop cascades to sequence gsk_utdata_25_784.layer_id_seq
> drop cascades to table gsk_utdata_25_784.relation
> drop cascades to table gsk_utdata_25_784.edge_attributes
> drop cascades to table gsk_utdata_25_784.face_attributes
> LOCATION:  reportDependentObjects, dependency.c:1227
>              droptopology
>  Topology 'gsk_utdata_25_784' dropped
> (1 row)
> In session two run this command inside the transaction and this hangs for
> ever.
> select SRID from public.geometry_columns where (f_table_schema = 't1')
> and f_table_name = 'edge_data' and f_geometry_column = 'geom';
> Go back two session one run commit
> [local] lop at t1=# commit;
> COMMIT
> [local] lop at t1=#
> Go back to session two and you see this error message
> ERROR:  XX000: could not open relation with OID 188955003
> LOCATION:  relation_open, relation.c:62
> This is tested on different servers with configs
> PostgreSQL 16.10 (Homebrew) on aarch64-apple-darwin23.6.0, compiled by
> Apple clang version 16.0.0 (clang-1600.0.26.6), 64-bit
> POSTGIS="3.7.0dev 3.6.0rc2-152-g19e25a659" [EXTENSION] PGSQL="160"
> GEOS="3.14.0-CAPI-1.20.4" PROJ="9.7.0 NETWORK_ENABLED=OFF
> URL_ENDPOINT=https://cdn.proj.org
> USER_WRITABLE_DIRECTORY=/Users/lop/Library/Application Support/proj
> DATABASE_PATH=/opt/homebrew/Cellar/proj/9.7.0/sharpr
> PostgreSQL 16.4 (Ubuntu 16.4-1.pgdg20.04+1) on x86_64-pc-linux-gnu,
> compiled by gcc (Ubuntu 9.4.0-1ubuntu1~20.04.2) 9.4.0, 64-bit
>  POSTGIS="3.7.0dev 3.6.0rc2-284-g013e9b0fd" [EXTENSION] PGSQL="160"
> GEOS="3.14.0-CAPI-1.20.4" (compiled against GEOS 3.13.1) PROJ="8.2.1
> NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
> USER_WRITABLE_DIRECTORY=/var/lib/postgresql/.local/share/proj
> DATABASE_PATH=/usr/share/oj
New description:
 (2 rows)
 two transactions.
 Session 1
 BEGIN
 [local] lop at t1=#
 Session 2
 BEGIN
 [local] lop at t1=#
              droptopology
 (1 row)
 ever.
 select SRID from public.geometry_columns where (f_table_schema = 't1') and
 COMMIT
 [local] lop at t1=#
Comment (by Lars Aksel Opsahl):
 And after commit in session I have to run a new select to the data and
 then works OK again
  srid
  4258
 (1 row)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6038#comment:1>
