[SCM] PostGIS branch master updated. 3.6.0rc2-290-g6388f5be6
Tue Jan 20 12:34:05 PST 2026
the project "PostGIS".
       via  6388f5be621ac58fb49b39ab098ed49d7d826fec (commit)
      from  0a5d1263b5b75114b15e8915e4ecce2827c08476 (commit)
revisions in full, below.
commit 6388f5be621ac58fb49b39ab098ed49d7d826fec
Author: Loïc Bartoletti <loic.bartoletti at oslandia.com>
Date:   Fri Dec 19 07:30:24 2025 +0100
    Convert PolyhedralSurface/TIN to MultiPolygon
diff --git a/liblwgeom/lwgeom.c b/liblwgeom/lwgeom.c
index a2d65dc0f..c6562b5fa 100644
--- a/liblwgeom/lwgeom.c
+++ b/liblwgeom/lwgeom.c
@@ -414,6 +414,43 @@ lwgeom_as_multi(const LWGEOM *lwgeom)
 	type = lwgeom->type;
+	* PolyhedralSurface and MultiPolygon have identical structures
+	* (both are collections of LWPOLY). Convert PolyhedralSurface
+	* to MultiPolygon by cloning and changing the type.
+	if (type == POLYHEDRALSURFACETYPE)
+		ogeom = (LWGEOM *)lwcollection_clone((LWCOLLECTION *)lwgeom);
+		ogeom->type = MULTIPOLYGONTYPE;
+		return ogeom;
+	* TIN to MultiPolygon: convert each triangle to a polygon.
+	* LWTRIANGLE and LWLINE have compatible memory layouts,
+	* so we can use lwpoly_from_lwlines to create polygons.
+	if (type == TINTYPE)
+		uint32_t i;
+		LWCOLLECTION *col = (LWCOLLECTION *)lwgeom;
+		LWMPOLY *mpoly = lwmpoly_construct_empty(lwgeom->srid,
+			FLAGS_GET_Z(lwgeom->flags),
+			FLAGS_GET_M(lwgeom->flags));
+		for (i = 0; i < col->ngeoms; i++)
+			LWPOLY *poly = lwpoly_from_lwlines((LWLINE *)col->geoms[i], 0, NULL);
+			lwmpoly_add_lwpoly(mpoly, poly);
+		if (lwgeom->bbox)
+			mpoly->bbox = gbox_clone(lwgeom->bbox);
+		return lwmpoly_as_lwgeom(mpoly);
 	if ( ! MULTITYPE[type] ) return lwgeom_clone(lwgeom);
 	if( lwgeom_is_empty(lwgeom) )
diff --git a/postgis/lwgeom_functions_basic.c b/postgis/lwgeom_functions_basic.c
index ed5f076f2..0cfa08da7 100644
--- a/postgis/lwgeom_functions_basic.c
+++ b/postgis/lwgeom_functions_basic.c
@@ -532,7 +532,6 @@ Datum LWGEOM_force_multi(PG_FUNCTION_ARGS)
 		case COLLECTIONTYPE:
 		case MULTICURVETYPE:
 		case MULTISURFACETYPE:
-		case TINTYPE:
 			PG_RETURN_POINTER(geom);
 		default:
 			break;
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index eec195810..4c1fcb862 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -67,6 +67,14 @@ SELECT '#80', ST_AsText(ST_Multi('MULTILINESTRING((0 0,1 1))'));
 -- #83 --
 SELECT '#83', ST_AsText(ST_Multi(ST_GeomFromText('CIRCULARSTRING(220268 150415,220227 150505,220227 150406)')));
+-- ST_Multi with PolyhedralSurface -> MultiPolygon
+SELECT 'ST_Multi_psurface', ST_GeometryType(ST_Multi('POLYHEDRALSURFACE Z(((0 0 0,0 1 0,1 1 0,1 0 0,0 0 0)),((0 0 0,0 1 0,0 1 1,0 0 1,0 0 0)))'::geometry));
+SELECT 'ST_Multi_psurface_empty', ST_GeometryType(ST_Multi('POLYHEDRALSURFACE EMPTY'::geometry));
+-- ST_Multi with TIN -> MultiPolygon
+SELECT 'ST_Multi_tin', ST_GeometryType(ST_Multi('TIN Z(((0 0 0,0 0 1,0 1 0,0 0 0)),((0 0 0,0 1 0,1 1 0,0 0 0)))'::geometry));
+SELECT 'ST_Multi_tin_empty', ST_GeometryType(ST_Multi('TIN EMPTY'::geometry));
 -- #85 --
 SELECT '#85', ST_Distance(ST_GeomFromText('CIRCULARSTRING(220268 150415,220227 150505,220227 150406)'), ST_Point(220268, 150415));
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index d8f7f5cf5..76ea65e71 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -14,6 +14,10 @@ ERROR:  lwgeom_longitude_shift: unsupported geom type: CircularString
 #73|GEOMETRYCOLLECTION(CIRCULARSTRING(1 1,2 3,4 5,6 7,5 6))
 #80|MULTILINESTRING((0 0,1 1))
 #83|MULTICURVE(CIRCULARSTRING(220268 150415,220227 150505,220227 150406))
+ST_Multi_psurface|ST_MultiPolygon
+ST_Multi_psurface_empty|ST_MultiPolygon
+ST_Multi_tin|ST_MultiPolygon
+ST_Multi_tin_empty|ST_MultiPolygon
 #85|0
 #112|GEOMETRYCOLLECTION(POINT(-10 50))
 ERROR:  Input geometry does not have a measure dimension
Summary of changes:
 liblwgeom/lwgeom.c               | 37 +++++++++++++++++++++++++++++++++++++
 postgis/lwgeom_functions_basic.c |  1 -
 regress/core/tickets.sql         |  8 ++++++++
 regress/core/tickets_expected    |  4 ++++
 4 files changed, 49 insertions(+), 1 deletion(-)
hooks/post-receive
