[PostGIS] #6031: CG_Extrude /ST_Extrude fails on MULITPOLYGON that has an Empty ring
trac at osgeo.org
Thu Jan 22 05:30:39 PST 2026
Reporter: robe | Owner: Loïc Bartoletti
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS SFCGAL
Component: sfcgal | Version: 3.5.x
Resolution: | Keywords:
Comment (by Loïc Bartoletti):
for reference (using SFCGAL master):
SELECT CG_Extrude(ST_GeomFromText('MULTIPOLYGON (((9 9, 9 1, 1 1, 2 4, 7
7, 9 9)), EMPTY)', 4326), 20.1, 20.1, 20.1) As result;
ERREUR: lwcollection_construct: mixed dimension geometries: 2/0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6031#comment:1>
