[PostGIS] #6034: Missing node when adding overlapping line
trac at osgeo.org
Mon Jan 26 11:32:19 PST 2026
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone:
Component: topology | Version: 3.6.x
Resolution: | Keywords:
Comment (by strk):
Simplified test, with less vertices:
SELECT topology.CreateTopology ('t6034', 0 , 1e-06);
-- Add edge 1
SELECT * FROM topology.TopoGeo_addLinestring('t6034',
'LINESTRING(15.030538394371618 67.34781748364921,15.026524176871614
67.34727999614921,15.030014036871616 67.3471448261492,15.031642706871615
67.34714451614921)'
-- Add edge 2
'LINESTRING(15.031642706871615 67.34714451614921,15.030538394371618
67.34714472634334,15.030538394371618 67.34781748364921)'
-- This would "snap" edge 1
--select TopoGeo_addPoint('t6034', ( select ST_PointN(geom, 2) from
t6034.edge_data where edge_id = 2 ) );
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6034#comment:13>
