[SCM] PostGIS branch master updated. 3.6.0rc2-313-ga499e6aad
git at osgeo.org
git at osgeo.org
Mon Jan 26 12:35:08 PST 2026
the project "PostGIS".
via a499e6aad103ecd73be69eca090ab50db9d6bd4f (commit)
via ccf2a8ae4a1c40316f8096ca339a25abb59be9bc (commit)
via 18d4a506c2ab4048b8421dd92f4fc30083ea84be (commit)
via f07827d46867580713eff4d4bc3be8e0fbd85dab (commit)
from 2861e6f495ce37385f33b43abd75212cfee8126a (commit)
revisions in full, below.
commit a499e6aad103ecd73be69eca090ab50db9d6bd4f
Merge: 2861e6f49 ccf2a8ae4
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Mon Jan 26 12:34:51 2026 -0800
Merge branch 'ProjectMutilation-geography_centroid-replace-null-check'
commit ccf2a8ae4a1c40316f8096ca339a25abb59be9bc
Author: Maksim Korotkov <m.korotkov at postgrespro.ru>
Date: Mon Jan 26 12:30:55 2026 +0300
shp2pgsql-gui: fix use after free
The ShpLoaderDestroy() free the pointer state,
that was dereferenced later.
Found by PostgresPro with Svace Static Analyzer.
Fixes: 4daaecbc8 ("Commit reworked version of shp2pgsql-gui to the repository.")
Signed-off-by: Maksim Korotkov <m.korotkov at postgrespro.ru>
diff --git a/loader/shp2pgsql-gui.c b/loader/shp2pgsql-gui.c
index 847e69af7..00ffda526 100644
--- a/loader/shp2pgsql-gui.c
+++ b/loader/shp2pgsql-gui.c
@@ -1215,6 +1215,7 @@ validate_remote_loader_columns(SHPLOADERCONFIG *config, PGresult *result)
pgui_logf(_("Warning: Could not load shapefile %s"), config->shp_file);
ShpLoaderDestroy(state);
+ return SHPLOADERERR;
/* Find each column based upon its name and then validate type separately... */
commit 18d4a506c2ab4048b8421dd92f4fc30083ea84be
Author: Regina Obe <lr at pcorp.us>
Date: Mon Jan 26 02:53:22 2026 -0500
Put in PG_MODULE_MAGIC in address_standardizer for PG < 18
Closes #6039 for PostGIS 3.7.0
diff --git a/extensions/address_standardizer/address_standardizer.c b/extensions/address_standardizer/address_standardizer.c
index f4170b4a7..5d4483d32 100644
--- a/extensions/address_standardizer/address_standardizer.c
+++ b/extensions/address_standardizer/address_standardizer.c
@@ -21,6 +21,8 @@ PG_MODULE_MAGIC_EXT(
.name = "address_standardizer",
.version = POSTGIS_LIB_VERSION
+#else
+ PG_MODULE_MAGIC;
#endif
Datum debug_standardize_address(PG_FUNCTION_ARGS);
commit f07827d46867580713eff4d4bc3be8e0fbd85dab
Date: Mon Jan 26 17:41:52 2026 +0300
Replace check for avoiding NULL dereference
Fixes: 9726c4770 ("missed file commit for ST_Centroid Geography support references #2951")
diff --git a/postgis/geography_centroid.c b/postgis/geography_centroid.c
index 386e029ba..8a4881671 100644
--- a/postgis/geography_centroid.c
+++ b/postgis/geography_centroid.c
@@ -63,13 +63,13 @@ Datum geography_centroid(PG_FUNCTION_ARGS)
/* Get our geometry object loaded into memory. */
g = PG_GETARG_GSERIALIZED_P(0);
- lwgeom = lwgeom_from_gserialized(g);
if (g == NULL)
PG_RETURN_NULL();
+ lwgeom = lwgeom_from_gserialized(g);
srid = lwgeom_get_srid(lwgeom);
/* on empty input, return empty output */
Summary of changes:
postgis/geography_centroid.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
hooks/post-receive
