[PostGIS] #5790: Postgis-functions in Materialized views fail in Postgres 17 due to not fully qualified search path
trac at osgeo.org
Thu Jan 29 08:21:22 PST 2026
Reporter: maxbo | Owner: robe
Type: defect | Status: closed
Priority: high | Milestone: PostGIS 3.4.4
Component: postgis | Version: 3.4.x
Resolution: fixed | Keywords:
Comment (by robe):
Replying to [comment:11 landry]:
> i've tried your testcase, and it works here. now that i look again at
the MV definition, something feels.. wrong with the type ?
The type is fine. It shows it like that if you search_path doesn't
include public.
For example if you do
set search_path=public;
\d+ public.pictures
It will probably show just plain geometry.
So only thing I can think of is something fishy with the permissions of
your app.
Do you get the same issue when you select from your mat view in PSQL?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5790#comment:12>
