[SCM] PostGIS branch master updated. 3.6.0rc2-708-gcb9ded03d
git at osgeo.org
git at osgeo.org
Wed Jul 1 00:39:16 PDT 2026
the project "PostGIS".
via cb9ded03db4abfd2055c7cbb274b3411852a35a1 (commit)
from 8c9f8a7342ad924ab0c65f0d412b72f39cdb80ee (commit)
revisions in full, below.
commit cb9ded03db4abfd2055c7cbb274b3411852a35a1
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date: Wed Jul 1 05:55:13 2026 +0000
Translated PostGIS Manual using Weblate (Japanese)
Currently translated at 98.8% (5514 of 5579 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/ja/
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index 9bdfe070a..15e542bef 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -10,7 +10,7 @@ msgstr ""
"Project-Id-Version: postgis 3.5\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2026-06-12 20:29+0000\n"
-"PO-Revision-Date: 2026-06-22 06:39+0000\n"
+"PO-Revision-Date: 2026-07-01 07:39+0000\n"
"Last-Translator: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>\n"
"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/postgis-"
"manual/ja/>\n"
@@ -4027,12 +4027,14 @@ msgid ""
msgstr ""
#. Tag: para
-#, no-c-format
+#, fuzzy, no-c-format
msgid ""
"Returns a relation in which each tuple is a pair of vertex/segment where the "
"vertex is NOT an endpoint of the segment but the distance between them is "
"below the given tolerance."
msgstr ""
+"個々のタプルが頂点/辺の組合せで、頂点は辺の終端でなく、かつ頂点と辺の間の距離"
+"が指定した許容値より小さくなるリレーションを返します。"
#. Tag: para
#, no-c-format
@@ -24163,13 +24165,16 @@ msgid ""
msgstr ""
#. Tag: para
-#, no-c-format
msgid ""
"The <varname>nSegments</varname> parameter controls the density of the "
"output. With <varname>nSegments</varname> = 5 (the default), each original "
"span is divided into 5 sub-segments (inserting 4 new points per span). The "
"minimum value is 2."
msgstr ""
+"<varname>nSegments</varname>パラメーターで出力の密度を制御します。<varname>"
+"nSegments</varname> = 5 (デフォルト)では、スパンごとに5個の辺に分かれます "
+"(スパンごとに4個のポイントが新設されます)。最小値は2です。"
#. Tag: para
#, no-c-format
Summary of changes:
doc/po/ja/postgis-manual.po | 11 ++++++++---
1 file changed, 8 insertions(+), 3 deletions(-)
hooks/post-receive
