[SCM] PostGIS branch master updated. 3.6.0rc2-709-gb12a6286a
git at osgeo.org
git at osgeo.org
Wed Jul 1 03:39:18 PDT 2026
the project "PostGIS".
via b12a6286a3f9d84f7458281dc6a1cab14cd070c9 (commit)
from cb9ded03db4abfd2055c7cbb274b3411852a35a1 (commit)
revisions in full, below.
commit b12a6286a3f9d84f7458281dc6a1cab14cd070c9
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date: Wed Jul 1 09:34:36 2026 +0000
Translated PostGIS Manual using Weblate (Japanese)
Currently translated at 99.1% (5534 of 5579 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/ja/
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index 15e542bef..0ce97a723 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -10,7 +10,7 @@ msgstr ""
"Project-Id-Version: postgis 3.5\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2026-06-12 20:29+0000\n"
-"PO-Revision-Date: 2026-07-01 07:39+0000\n"
+"PO-Revision-Date: 2026-07-01 10:39+0000\n"
"Last-Translator: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>\n"
"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/postgis-"
"manual/ja/>\n"
@@ -4021,10 +4021,10 @@ msgid ", <xref linkend=\"GetRingEdges\"/>, <xref linkend=\"ST_Azimuth\"/>"
msgstr ", <xref linkend=\"GetRingEdges\"/>, <xref linkend=\"ST_Azimuth\"/>"
#. Tag: refpurpose
-#, no-c-format
+#, fuzzy, no-c-format
msgid ""
"Find pairs of topology vertex/segment that are closer than tolerated distance"
-msgstr ""
+msgstr "許容距離内にあるトポロジーの頂点/辺の組を検索します。"
#. Tag: para
@@ -24163,6 +24163,13 @@ msgid ""
"original vertices, <varname>nSegments</varname> - 1 new intermediate points "
"are inserted."
msgstr ""
+"<link xlink:href=\"https://ja.wikipedia.org/wiki/Catmull-"
+"Rom%E3%82%B9%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E6%9B%B2%E7%B7%9A\">Catmull-"
+"Romスプライン</link>アルゴリズムを用いた、ラインまたはポリゴンジオメトリーの"
+"平滑化を行います。<xref linkend=\"ST_ChaikinSmoothing\"/>と違い、これ"
+"は<emphasis>補間</emphasis> スプラインで、出力曲線は元の頂点の全てを通ります"
+"。連続する頂点の間には<varname>nSegments</varname> - 1個の補間ポイントが挿入"
+"されます。"
#. Tag: para
@@ -24183,6 +24190,9 @@ msgid ""
"fewer vertices are returned unchanged. Points and multipoints are always "
"returned unchanged."
msgstr ""
+"平滑化には少なくとも4個の頂点が必要です。頂点数が少ないジオメトリーが与えられ"
+"ると変更せずに返します。ポイントとマルチポイントが与えられると、常に変更せず"
+"に返します。"
#. Tag: para
#, no-c-format
@@ -24195,31 +24205,37 @@ msgid ""
"linkend=\"ST_SimplifyPreserveTopology\"/> and <xref "
"linkend=\"ST_SimplifyVW\"/>)."
msgstr ""
+"出力曲線の頂点数は、閉じていないラインストリングの場合は<literal>1 + (N-1) * "
+"nSegments</literal>で、閉じてリングになっている場合には <literal>1 + N * "
+"nSegments</literal>です。ここでNは入力頂点数です。大きなジオメトリの場合には"
+"、ポイント数を減らすために結果に対して単純化を施します (<xref "
+"linkend=\"ST_Simplify\"/>, <xref linkend=\"ST_SimplifyPreserveTopology\"/>, "
+"<xref linkend=\"ST_SimplifyVW\"/>を参照して下さい)。"
#. Tag: para
#, no-c-format
msgid "Smoothing a 4-point collinear line with default nSegments=5:"
-msgstr ""
+msgstr "4点が共線であるラインストリングの平滑化 (nSegments=5):"
#. Tag: para
#, no-c-format
msgid "Smoothing a Polygon using nSegments = 5 and 10:"
-msgstr ""
+msgstr "ポリゴンの平滑化 (nSegments = 5 と 10):"
#. Tag: para
#, no-c-format
msgid "nSegments = 5"
-msgstr ""
+msgstr "nSegments = 5"
#. Tag: para
#, no-c-format
msgid "nSegments = 10"
-msgstr ""
+msgstr "nSegments = 10"
#. Tag: para
#, no-c-format
msgid "Smoothing a LineString using nSegments = 5 and 10:"
-msgstr ""
+msgstr "ラインストリングの平滑化 (nSegments = 5 と 10):"
#. Tag: para
#, no-c-format
@@ -24227,6 +24243,8 @@ msgid ""
", <xref linkend=\"ST_Simplify\"/>, <xref "
"linkend=\"ST_SimplifyPreserveTopology\"/>, <xref linkend=\"ST_SimplifyVW\"/>"
msgstr ""
+", <xref linkend=\"ST_Simplify\"/>, <xref "
+"linkend=\"ST_SimplifyPreserveTopology\"/>, <xref linkend=\"ST_SimplifyVW\"/>"
#. Tag: refpurpose
#, no-c-format
@@ -37811,6 +37829,10 @@ msgid ""
"version, a notice is emitted and the non-projected result is returned "
"instead."
msgstr ""
+"<varname>projected</varname>が<varname>true</varname>の場合には、中心軸の自由"
+"端点がポリゴン境界に届くよう延長されます (投影中心軸)。SFCGAL 2.3.0以上が必要"
+"です。古いバージョンのSFCGALでビルドされている場合には、通知が出され、非投影"
+"の結果が返されます。"
#. Tag: para
#, no-c-format
@@ -37819,6 +37841,9 @@ msgid ""
"SFCGAL >= 2.3.0 for projected result; falls back to non-projected with a "
"notice on older versions."
msgstr ""
+"Availability: 3.7.0 - <varname>projected</varname>パラメーター。投影された結"
+"果を得るには SFCGAL >= 2.3.0 が必要。古いバージョンでは通知が出力され、非"
+"投影の結果になります。"
#. Tag: para
#, no-c-format
@@ -37833,7 +37858,7 @@ msgstr ", <xref linkend=\"CG_StraightSkeletonPartition\"/>"
#. Tag: refpurpose
#, no-c-format
msgid "Generate a flat (box) roof from a footprint polygon."
-msgstr ""
+msgstr "接地部ポリゴンから平らな (箱の)屋根を生成します。"
#. Tag: para
#, no-c-format
@@ -37842,11 +37867,14 @@ msgid ""
"varname> from a 2D footprint polygon. The roof height above the ground plane "
"is given by <varname>height</varname> (default 3.0)."
msgstr ""
+"2次元接地部ポリゴンから平らな (箱状の)屋根を3次元 <varname>PolyhedralSurface "
+"Z</varname>で生成します。屋根の高さは地平面から <varname>height</varname>で指"
+"定した値です (デフォルト 3.0)。"
#. Tag: para
#, no-c-format
msgid "Availability: 3.7.0 - requires SFCGAL >= 2.3.0."
-msgstr ""
+msgstr "Availability: 3.7.0 - SFCGAL >= 2.3.0 が必要。"
#. Tag: para
#, no-c-format
@@ -37854,11 +37882,13 @@ msgid ""
", <xref linkend=\"CG_GenerateGableRoof\"/>, <xref "
"linkend=\"CG_GenerateSkillionRoof\"/>, <xref linkend=\"CG_GenerateRoof\"/>"
msgstr ""
+", <xref linkend=\"CG_GenerateGableRoof\"/>, <xref "
+"linkend=\"CG_GenerateSkillionRoof\"/>, <xref linkend=\"CG_GenerateRoof\"/>"
#. Tag: refpurpose
#, no-c-format
msgid "Generate a hipped roof from a footprint polygon."
-msgstr ""
+msgstr "接地部ポリゴンから寄棟屋根を生成する。"
#. Tag: para
#, no-c-format
@@ -37867,11 +37897,14 @@ msgid ""
"2D footprint polygon. All sides slope upward to meet at a ridge or apex. The "
"roof height is given by <varname>height</varname> (default 3.0)."
msgstr ""
+"2次元接地部ポリゴンから寄棟屋根を3次元 <varname>PolyhedralSurface Z</varname>"
+"で生成します。全側面の傾斜は頂部が合うように上がります。屋根の高さは地平面か"
+"ら <varname>height</varname>で指定した値です (デフォルト 3.0)。"
#. Tag: refpurpose
#, no-c-format
msgid "Generate a gable roof from a footprint polygon."
-msgstr ""
+msgstr "接地部ポリゴンから切妻屋根を生成します。"
#. Tag: para
#, no-c-format
@@ -37883,6 +37916,12 @@ msgid ""
"varname> controls the pitch in degrees (default 30.0). The SRID of the input "
"geometry is preserved."
msgstr ""
+"2次元接地部ポリゴンから切妻屋根を3次元 <varname>PolyhedralSurface Z</varname>"
+"で生成します。一方の対辺は棟に対して垂直になっている終端です。もう一方の対辺"
+"は棟に平行に上がっていきます。屋根の高さは地平面から <varname>height</"
+"varname>で指定した値です (デフォルト 3.0)。<varname>slope_angle</varname>で仰"
+"角を度単位で指定します (デフォルト 30.0)。入力ジオメトリーのSRIDは保存されま"
+"す。"
#. Tag: para
#, no-c-format
@@ -37890,6 +37929,8 @@ msgid ""
", <xref linkend=\"CG_GenerateHippedRoof\"/>, <xref "
msgstr ""
+", <xref linkend=\"CG_GenerateHippedRoof\"/>, <xref "
#. Tag: refpurpose
#, no-c-format
Summary of changes:
doc/po/ja/postgis-manual.po | 65 ++++++++++++++++++++++++++++++++++++---------
1 file changed, 53 insertions(+), 12 deletions(-)
hooks/post-receive
