[SCM] PostGIS branch master updated. 3.6.0rc2-714-g3d021d32b
git at osgeo.org
git at osgeo.org
Wed Jul 1 22:08:42 PDT 2026
the project "PostGIS".
via 3d021d32b46336463576654c4817d6e1f58721a8 (commit)
from 1a6911201c37ad9dfcdaeddf0d21b90da20a72e9 (commit)
revisions in full, below.
commit 3d021d32b46336463576654c4817d6e1f58721a8
Author: Sandro Santilli <strk at kbt.io>
Date: Thu Jul 2 07:08:22 2026 +0200
Move Makefile target documentation from README to `make help`
diff --git a/doc/Makefile.in b/doc/Makefile.in
index b7f684108..a24f92c9f 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -159,7 +159,7 @@ endif
# TODO: add "html" to the BUILD_TARGET if it can be built
-all: $(BUILD_TARGET)
+all: $(BUILD_TARGET) ## Build all buildable documentation
XML_SOURCES = \
administration.xml \
@@ -351,7 +351,7 @@ $(XML_UNIFIED_POT): $(XML_SOURCE_POTS)
fi;
# Creates or updates translation files
-update-po: $(PO_FILES)
+update-po: $(PO_FILES) ## Update translation files to be in sync with the source XML files (see check-localized)
$(PO_FILES): $(XML_UNIFIED_POT)
@mkdir -p `dirname $@`
@@ -403,6 +403,8 @@ postgis-out.xml: postgis.xml Makefile $(XML_INPUTS) Makefile
$(PERL) -lpe "s'@@LAST_RELEASE_VERSION@@'${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}'g;s'@@POSTGIS_DOWNLOAD_URL@@'${POSTGIS_DOWNLOAD_URL}'g;" $< > $@.in
$(XMLLINT) $(XSLTPROC_PATH_OPT) --noent -o $@ $@.in
+chunked-html: ## Generate multi-file html in html/postgis-en/
chunked-html: $(html_builddir)/postgis$(DOCSUFFIX)/index.html
$(html_builddir)/postgis$(DOCSUFFIX)/index.html: postgis-out.xml Makefile
$(XSLTPROC) $(XSLTPROC_COMMONOPTS) \
@@ -412,7 +414,11 @@ $(html_builddir)/postgis$(DOCSUFFIX)/index.html: postgis-out.xml Makefile
$(CHUNK_HTML_DOCBOOK_XSL) \
-html: $(html_builddir)/postgis$(DOCSUFFIX).html
+html: $(html_builddir)/postgis$(DOCSUFFIX).html ## Generate a single-file html/postgis-en.html
+html-localized: ## Generate a single-file html/postgis-<lang>.html for supported languages
+pdf-localized: ## Generate a postgis-<version>-<lang>.pdf for supported languages
+check-localized: ## Check structural correctness of localized (translated) XML documentation.
%-localized:
rule=$(patsubst %-localized,%,$@); \
@@ -483,14 +489,16 @@ epub-uninstall:
epub: postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}$(DOCSUFFIX).epub
-pdf: postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}$(DOCSUFFIX).pdf
+pdf: postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}$(DOCSUFFIX).pdf ## Generate postgis-<version>-en.pdf
doxygen.cfg: doxygen.cfg.in
$(PERL) -lpe "s'@@LAST_RELEASE_VERSION@@'${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}'g" $< > $@
-doxygen: doxygen.cfg
+doxygen: doxygen.cfg ## Generate developer's documentation using Doxygen
doxygen $<
+images: ## Generate images used in html and pdf targets
images images-install images-uninstall images-clean:
$(MAKE) -C $(images_builddir) $@
@@ -515,7 +523,7 @@ cheatsheet-install: $(GENERATED_CHEATSHEET_FILES)
cheatsheet-clean:
rm -f $(GENERATED_CHEATSHEET_FILES)
-clean: images-clean html-clean pdf-clean epub-clean cheatsheet-clean clean-pot
+clean: images-clean html-clean pdf-clean epub-clean cheatsheet-clean clean-pot ## Remove generated files except comments
rm -f images # work around https://trac.osgeo.org/postgis/ticket/5422
rm -f $(XML_GENERATED_SOURCES)
rm -f postgis-nospecial.xml postgis-nospecial.xml.in
@@ -537,9 +545,11 @@ distclean: clean
$(MAKE) distclean-localized
rm -f Makefile Makefile.comments
-maintainer-clean: distclean
+maintainer-clean: distclean ## Remove all generated files (including comments)
rm -f $(GENERATED_COMMENT_FILES)
+comments: ## Generate SQL scripts that add COMMENTs for every function (derived from the documentation)
ifneq ($(CAN_BUILD_COMMENTS),yes)
comments:
else
@@ -548,6 +558,8 @@ endif
cheatsheets: $(GENERATED_CHEATSHEET_FILES)
+comments-install: ## Install the SQL comment scripts to the PostgreSQL contrib directory
comments-install:
if test -e postgis_comments.sql -a \
@@ -561,7 +573,7 @@ comments-install: comments
$(MAKE) -f Makefile.comments install
endif
-comments-uninstall:
+comments-uninstall: ## Removes the SQL comment scripts from the PostgreSQL contrib directory
$(MAKE) -f Makefile.comments uninstall
man-install: man/shp2pgsql.1 man/pgsql2shp.1 man/raster2pgsql.1 man/pgtopo_export.1 man/pgtopo_import.1 man/postgis.1 man/postgis_restore.1
@@ -606,9 +618,9 @@ docs-install: html-install html-assets-install
docs-uninstall: html-uninstall html-assets-uninstall
rm -f $(DESTDIR)$(PGSQL_DOCDIR)/postgis/README.postgis
-install: comments-install man-install
+install: comments-install man-install ## Install sql comments and man pages
-uninstall: comments-uninstall man-uninstall
+uninstall: comments-uninstall man-uninstall ## Uninstall sql comments and man pages
ifeq ($(XSLTPROC),)
garden: requirements_not_met_xsltproc
@@ -619,7 +631,7 @@ endif
%_gardentest_${POSTGIS_MAJOR_VERSION}${POSTGIS_MINOR_VERSION}.sql: xsl/%_gardentest.sql.xsl postgis-out.xml
$(XSLTPROC) -o $@ $(XSLTPROC_PATH_OPT) $^
-check: check-unit
+check: check-unit ## Check structural correctness of XML documentation with DocBook DTD, RelaxNG, and XMLSchema validation
check-regress:
check-unit: $(CHECK_UNIT_TARGET)
@@ -703,3 +715,6 @@ requirements_not_met_xml2pot:
@echo "configure was unable to find the 'xml2pot' utility program."
@echo "To update the translation templates, install poxml and then re-run configure."
@echo
+help: ## Print this help message
+ @grep -E '^[a-zA-Z._-]+:.*?## .*$$' $(MAKEFILE_LIST) | sort | awk 'BEGIN {FS = ":.*## "}; {printf "\033[36m%-30s\033[0m %s\n", $$1, $$2}'
diff --git a/doc/README b/doc/README
index 865190eb3..6e99f44fc 100644
--- a/doc/README
+++ b/doc/README
@@ -8,74 +8,13 @@ PostGIS documentation is written in DocBook XML. The input file is
``postgis.xml``, which in turn includes all the individual chapter XML files.
From that file we can publish several formats, including HTML and PDF.
+The documentation can be translated to multiple languages, see po/README for
+instructions about how to do that.
Make targets
-``make``
- same as ``make comments``
-``make install``
- same as ``make comments-install``
-``make uninstall``
- same as ``make comments-uninstall``
-``make html``
- generates a single-file ``html/postgis.html``
-``make html-localized``
- generates single-file ``html/postgis-<lang>.html`` for
- each supported language
-``make chunked-html``
- generates a separate html file for every chapter or section break
- You can use CHUNKED_HTML_USER_OPTS environment variable to tweak
- the output, for example:
- > make chunked-html XSLTPROCFLAGS="--stringparam html.script custom.js
-``make pdf``
- generates a single PDF file with the PostGIS version as a filename
-``make pdf-localized``
- and ``-<lang>`` suffix for each supported language
-``make images``
- generates all the images used in the HTML and PDF targets
-``make comments``
- generates an SQL script that add COMMENTs for every function (derived from
- the documentation)
-``make doxygen``
- generates the developer's documentation using Doxygen
-``make comments-install``
- copies the ``postgis-comments.sql`` script to the PostgreSQL ``contrib``
- directory
-``make comments-uninstall``
- removes the ``postgis-comments.sql`` script from the ``contrib`` directory
-``make clean``
- removes generated files except comments
-``make maintainer-clean``
- removes all generated files (including comments)
-``make update-po``
- update translation files to be in sync with the source
- XML files. See ``make check-localized``
-``make check``
- check structural correctness of XML documentation with DocBook DTD,
- RelaxNG, and XMLSchema validation
-``make check-localized``
- check structural correctness of localized (translated)
- XML documentation. Remember to run this before committing
- updates to translation files (see ``make update-po``)
+Run `make help` to get help on notable targets.
Requirements
diff --git a/doc/po/README b/doc/po/README
index b38e3203a..447de9efb 100644
--- a/doc/po/README
+++ b/doc/po/README
@@ -7,9 +7,9 @@ In language subdirectories, run ``make`` to build localized manual and
comments, ``make local-pdf`` for the pdf.
In parent directory (doc), run ``make update-po`` to update the translation
-files to be in sync with the source code, ``make html-localized`` or
-``make pdf-localized`` to build the localized html or pdf manual for
-all enabled languages
+files to be in sync with the source code, ``make check-localized`` to verify
+structural correctness, ``make html-localized`` or ``make pdf-localized``
+to build the localized html or pdf manual for all enabled languages
Adding languages
@@ -28,7 +28,7 @@ Adding new languages implies (relative to doc/ dir):
- Running `make update-po`
- Check the new language works:
- make -C po/<newlanguage>
+ make -C po/<newlanguage> local-check html pdf
- Add to the git repository the changes in the Makefile.in
and all the new files in the po/<newlanguage>/
Summary of changes:
doc/Makefile.in | 37 ++++++++++++++++++++++---------
doc/README | 69 ++++-----------------------------------------------------
doc/po/README | 8 +++----
3 files changed, 34 insertions(+), 80 deletions(-)
hooks/post-receive
