[SCM] PostGIS branch master updated. 3.6.0rc2-715-g1cc22bee3
git at osgeo.org
git at osgeo.org
Wed Jul 1 22:16:05 PDT 2026
the project "PostGIS".
via 1cc22bee30384622c4fa3601408d5e56ef03126a (commit)
from 3d021d32b46336463576654c4817d6e1f58721a8 (commit)
revisions in full, below.
commit 1cc22bee30384622c4fa3601408d5e56ef03126a
Author: Sandro Santilli <strk at kbt.io>
Date: Thu Jul 2 07:14:45 2026 +0200
Add epub make target documentation, tweak order of make help output
diff --git a/doc/Makefile.in b/doc/Makefile.in
index a24f92c9f..c8255543b 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -158,8 +158,10 @@ endif
# TODO: add "html" to the BUILD_TARGET if it can be built
+all: $(BUILD_TARGET) ## Build any buildable documentation assets except html (comments, pdf, epub)
-all: $(BUILD_TARGET) ## Build all buildable documentation
+help: ## Print this help message
+ @grep -E '^[a-zA-Z._-]+:.*?## .*$$' $(MAKEFILE_LIST) | awk 'BEGIN {FS = ":.*## "}; {printf "\033[36m%-30s\033[0m %s\n", $$1, $$2}'
XML_SOURCES = \
administration.xml \
@@ -415,10 +417,7 @@ $(html_builddir)/postgis$(DOCSUFFIX)/index.html: postgis-out.xml Makefile
html: $(html_builddir)/postgis$(DOCSUFFIX).html ## Generate a single-file html/postgis-en.html
html-localized: ## Generate a single-file html/postgis-<lang>.html for supported languages
-pdf-localized: ## Generate a postgis-<version>-<lang>.pdf for supported languages
-check-localized: ## Check structural correctness of localized (translated) XML documentation.
%-localized:
rule=$(patsubst %-localized,%,$@); \
@@ -487,9 +486,11 @@ epub-install: postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGI
epub-uninstall:
rm -f $(DESTDIR)$(docdir)/postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}$(DOCSUFFIX).epub
-epub: postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}$(DOCSUFFIX).epub
+epub: postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}$(DOCSUFFIX).epub ## Generate postgis-<version>-en.epub
+pdf-localized: ## Generate a postgis-<version>-<lang>.epub for supported languages
pdf: postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}$(DOCSUFFIX).pdf ## Generate postgis-<version>-en.pdf
+pdf-localized: ## Generate a postgis-<version>-<lang>.pdf for supported languages
doxygen.cfg: doxygen.cfg.in
$(PERL) -lpe "s'@@LAST_RELEASE_VERSION@@'${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}'g" $< > $@
@@ -632,6 +633,8 @@ endif
$(XSLTPROC) -o $@ $(XSLTPROC_PATH_OPT) $^
check: check-unit ## Check structural correctness of XML documentation with DocBook DTD, RelaxNG, and XMLSchema validation
+check-localized: ## Check structural correctness of localized (translated) XML documentation.
check-regress:
check-unit: $(CHECK_UNIT_TARGET)
@@ -715,6 +718,3 @@ requirements_not_met_xml2pot:
@echo "configure was unable to find the 'xml2pot' utility program."
@echo "To update the translation templates, install poxml and then re-run configure."
@echo
-help: ## Print this help message
- @grep -E '^[a-zA-Z._-]+:.*?## .*$$' $(MAKEFILE_LIST) | sort | awk 'BEGIN {FS = ":.*## "}; {printf "\033[36m%-30s\033[0m %s\n", $$1, $$2}'
Summary of changes:
doc/Makefile.in | 16 ++++++++--------
1 file changed, 8 insertions(+), 8 deletions(-)
hooks/post-receive
