[PostGIS] #6090: proj 9.8.1 not being completely detected under mingw64 windows
PostGIS trac at osgeo.org
Sat Jul 4 16:22:38 PDT 2026
  Reporter:  robe          |      Owner:  robe
      Type:  defect        |     Status:  new
  Priority:  medium        |  Milestone:  PostGIS 3.7.0
 Component:  QA/buildbots  |    Version:  master
Resolution:                |   Keywords:  windows
Comment (by robe):
 My pkg_config_path looks like this:
  /projects/sqlite/rel-
 sqlite3w64/lib/pkgconfig:/projects/protobuf/rel-3.2.0w64/lib/pkgconfig:/projects/json-c/rel-0.16w64/lib/pkgconfig:/projects/proj
 /rel-
 proj-9.8.1w64/lib/pkgconfig:/projects/gdal/rel-3.13.1w64/lib/pkgconfig:/projects/zlib
 /rel-
 zlib-1.2.13w64/lib/pkgconfig:/projects/gtkw64/lib/pkgconfig:/mingw/x86_64-w64-mingw32/lib/pkgconfig
 and /projects/proj/rel-proj-9.8.1w64/lib/pkgconfig is the config folder
 for my proj.  I did have to fix paths in the proj.pc which I also did for
 the 8.2.1 but that did not fix the issue.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6090#comment:1>
