[SCM] PostGIS branch master updated. 3.6.0rc2-723-g1386a7b21
Sun Jul 5 00:06:22 PDT 2026
the project "PostGIS".
       via  1386a7b21adb127818b215521509f0a0e729a2ec (commit)
      from  7d3e202d3db1b718adafc7fc0bbf22f57460b35f (commit)
revisions in full, below.
commit 1386a7b21adb127818b215521509f0a0e729a2ec
Author: Regina Obe <lr at pcorp.us>
Date:   Sun Jul 5 03:04:29 2026 -0400
    Updates for NEWS
     - Move some news items from Bug fixes to
       Enhancements / Breaking Changes
     - Add news to release_notes
     - Update pot
diff --git a/NEWS b/NEWS
index 6453e122b..1a7f8db0a 100644
--- a/NEWS
+++ b/NEWS
@@ -18,6 +18,7 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
           https://git.osgeo.org/postgis/postgis_tiger_geocoder (Regina Obe)
  - #6079, Remove support for GEOS < 3.10 (Sandro Santilli)
  - #1793, Remove ST_MemCollect aggregate (Darafei Praliaskouski)
+ - GH-848, CG_AlphaShape now returns a MultiPolygon (Jean Felder)
 * New Features *
@@ -56,6 +57,10 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
  - GT-270, Add NURBSCurve (Loïc Bartoletti)
  - #2863, Add ST_XSize, ST_YSize, ST_ZSize, and ST_MSize dimension helpers
+ - [fuzzers] Centralize OSS-Fuzz build/dependency logic in PostGIS scripts,
+          prefer requested CXX over pg_config --cc for internal C++ checks, and
+          make fuzzer linking/runtime dependency packaging portable
+          (Darafei Praliaskouski)
 * Enhancements *
@@ -86,23 +91,42 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
  - #6087, Add a repository-owned CI status checker and static dashboard
           generator (Darafei Praliaskouski)
-* Bug Fixes *
  - #2807, [raster] Preserve missing NODATA values in ST_MapAlgebra outputs
  - #2832, [raster] Avoid padding single-tile raster2pgsql overviews
           when padding is not requested (Darafei Praliaskouski)
  - #2623, Generate a pgsql2shp GID field when exporting geometry-only
           shapefiles (Darafei Praliaskouski)
+ - #2850, Preserve pgsql2shp numeric precision and scale in DBF metadata
+ - #2386, Add raster2pgsql man page (Darafei Praliaskouski)
+ - Build PostgreSQL extension modules with `-fno-semantic-interposition` when
+          available so LTO can optimize same-DSO calls to exported PostGIS
+          entry points directly instead of routing through the module PLT; in
+          a local PostgreSQL 18 `pgbench` microbenchmark over 100k four-point
+          groups this reduced `ST_Collect` aggregate latency by about 4%
+ - #5973, Install PostGIS utilities under `pg_config --bindir` by default
+          and document `pg_config`-derived install paths more accurately
+ - #2808, Clarify postgis_full_version() output when installed component
+          scripts are newer than core scripts (Darafei Praliaskouski)
+ - #5593, Docs: render manual images with GraphicsMagick without temporary files,
+          enabling parallel builds, keeping ImageMagick fallbacks working, and
+          documenting the generator workflow for contributors (Darafei Praliaskouski)
+ - #5645, Docs: keep code operators ("=>") intact in translated manuals
+          by enforcing verbatim CSS (Darafei Praliaskouski)
+ - #1408, Docs: flatten transparent manual images onto white backgrounds for
+          PDF builds while keeping HTML images transparent (Darafei Praliaskouski)
+* Bug Fixes *
  - #4616, Detect pgsql2shp query keywords case-insensitively
  - #2838, Emit valid X3D Coordinate nodes for 2D polygon output
  - Fix WKB and TWKB parser resource exhaustion on malformed input
- - #2850, Preserve pgsql2shp numeric precision and scale in DBF metadata
-          (Darafei Praliaskouski)
  - #6083, Pass configured dependency include paths to fuzzer smoke builds
  - #3103, Add regression coverage for exact-schema find_srid and
@@ -117,15 +141,12 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
           deprecated-function cleanup (Darafei Praliaskouski)
  - GH-899, [raster] Honor PostgreSQL interrupts in long-running GDAL
           progress callbacks (Darafei Praliaskouski)
- - #2386, Add missing raster2pgsql man page (Darafei Praliaskouski)
  - #5975, Initialize skipped union-find cluster ids deterministically
  - #5904, [topology] Avoid MinGW format warnings when logging topology ids
  - GH-885, [topology] Avoid GMP overflow in ring orientation for very large
           finite coordinates (Darafei Praliaskouski)
- - GH-892, Add OSS-Fuzz coverage for TWKB and serialized raster inputs,
-          including guards for malformed TWKB reads and counts (Darafei Praliaskouski)
  - #6073, #6074, Stabilize geography LRS endpoint interpolation and pole
           centroid regressions on 32-bit systems (Darafei Praliaskouski)
  - #6082, Fix Japanese PDF build by avoiding non-ASCII arrows in SQL
@@ -133,8 +154,6 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
  - GH-888, [sfcgal] Avoid stale detoasted geometry access in
           CG_Visibility empty-input handling for SFCGAL < 2.2
- - #2808, Clarify postgis_full_version() output when installed component
-          scripts are newer than core scripts (Darafei Praliaskouski)
  - #3179, Mark truncated libpgcommon PostgreSQL messages instead of silently
           dropping the tail (Darafei Praliaskouski)
  - #6003, Avoid size_t formats in liblwgeom logging/error wrappers for
@@ -145,20 +164,9 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
           short DE-9IM patterns (Darafei Praliaskouski)
  - GH-890, Avoid GIDX BRIN summary merges across mismatched dimensions
- - Build PostgreSQL extension modules with `-fno-semantic-interposition` when
-          available so LTO can optimize same-DSO calls to exported PostGIS
-          entry points directly instead of routing through the module PLT; in
-          a local PostgreSQL 18 `pgbench` microbenchmark over 100k four-point
-          groups this reduced `ST_Collect` aggregate latency by about 4%
- - #5973, Install PostGIS utilities under `pg_config --bindir` by default
-          and document `pg_config`-derived install paths more accurately
  - #5948, [topology] Prevent MakeTopologyPrecise from erasing edges when
           grid size exceeds their extent (Darafei Praliaskouski)
  - #5959, Prevent histogram target overflow when analysing massive tables (Darafei Praliaskouski)
- - GH-901, Stop loader upgrade helper from marking postgis_tiger_geocoder
-          for extension upgrade (Darafei Praliaskouski)
  - #6080, Avoid out-of-bounds hex WKB lookup for high-bit input bytes
  - GH-895, Qualify pg_class lookup during SRID/PROJ validation
@@ -169,18 +177,6 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
  - GH-894, [raster] Fix Float16 import, mixed nodata warping,
           band replacement cleanup, GDAL credential redaction, and Python
           GDAL compatibility (Darafei Praliaskouski)
- - #5645, Docs: keep code operators ("=>") intact in translated manuals
-          by enforcing verbatim CSS (Darafei Praliaskouski)
- - #5593, Docs: render manual images with GraphicsMagick without temporary files,
-          enabling parallel builds, keeping ImageMagick fallbacks working, and
-          documenting the generator workflow for contributors (Darafei Praliaskouski)
- - #1408, Docs: flatten transparent manual images onto white backgrounds for
-          PDF builds while keeping HTML images transparent (Darafei Praliaskouski)
- - [fuzzers] Centralize OSS-Fuzz build/dependency logic in PostGIS scripts,
-          prefer requested CXX over pg_config --cc for internal C++ checks, and
-          make fuzzer linking/runtime dependency packaging portable
- - GH-848, CG_AlphaShape now returns a MultiPolygon (Jean Felder)
  - Flatgeobuf schema mismatch vulnerability (NeuroWinter)
  - #5899, pg_upgrade issue for non-standard geography SRID (Paul Ramsey)
  - #2583, Preserve Z/ZM dimensional qualifiers in ST_AsEWKT output for TIN
diff --git a/doc/po/templates/postgis-manual.pot b/doc/po/templates/postgis-manual.pot
index 9336fecfc..a411023e1 100644
--- a/doc/po/templates/postgis-manual.pot
+++ b/doc/po/templates/postgis-manual.pot
@@ -35639,21 +35639,21 @@ msgstr ""
 #. Tag: title
 #, no-c-format
-msgid "PostGIS 3.7.0beta1"
+msgid "PostGIS 3.7.0alpha1"
 msgstr ""
-#. Tag: para
+#. Tag: subtitle
 #, no-c-format
-msgid "2026/06/xx"
+msgid "2026/07/05"
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-"This version requires GEOS 3.10 or higher. PostgreSQL 14-19beta1 required. "
-"Proj 6.1+ required. To take advantage of all features postgis extension "
-"features, GEOS 3.15+ is needed. To take advantage of all postgis_sfcgal "
-"extension features SFCGAL 2.2+ is needed."
+"This version requires GEOS 3.10+, PostgreSQL 14-19beta1, Proj 6.1+, libgmp. "
+"To take advantage of all features postgis extension features, GEOS 3.15+ is "
+"needed. To take advantage of all postgis_sfcgal extension features SFCGAL "
+"2.3+ is needed."
 msgstr ""
 #. Tag: title
@@ -35663,7 +35663,64 @@ msgstr ""
 #. Tag: para
 #, no-c-format
-msgid "Place holder"
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/5688\">#5688</ulink>, "
+"[topology] topology building functions now interpret tolerance 0 (old "
+"default) to really mean 0 and want -1 (new default) to mean "use "
+"topology precision" (Sandro Santilli)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/6024\">#6024</ulink>, "
+"Remove support for PostgreSQL 12 and 13 (Regina Obe)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/6040\">#6040</ulink>, "
+"ST_GeoHash round trip through ST_GeomFromGeoHash (Paul Ramsey)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/6053\">#6053</ulink>, "
+"[address_standardizer] Extension removed and moved to <ulink url=\"https://"
+"github.com/postgis/address_standardizer\">https://github.com/postgis/"
+"address_standardizer</ulink> (Paul Ramsey)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/6052\">#6052</ulink>, "
+"[tiger_geocoder] Extension removed and moved to <ulink url=\"https://git."
+"osgeo.org/postgis/postgis_tiger_geocoder\">https://git.osgeo.org/postgis/"
+"postgis_tiger_geocoder</ulink> (Regina Obe)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/6079\">#6079</ulink>, "
+"Remove support for GEOS < 3.10 (Sandro Santilli)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/1793\">#1793</ulink>, "
+"Remove ST_MemCollect aggregate (Darafei Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://github.com/postgis/postgis/pull/848\">GH-848</ulink>, "
+"CG_AlphaShape now returns a MultiPolygon (Jean Felder)"
 msgstr ""
 #. Tag: title
@@ -35671,6 +35728,662 @@ msgstr ""
 msgid "New Features"
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/1124\">#1124</ulink>, "
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/2935\">#2935</ulink>, "
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/3033\">#3033</ulink>, "
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/4658\">#4658</ulink>, "
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/4659\">#4659</ulink>, "
+"[loader] Rework loader arguments: shp2pgsql can create UNLOGGED tables and "
+"choose the feature id column name, shp2pgsql --drop-table can emit DROP "
+"TABLE before prepare output, raster2pgsql/shp2pgsql expose loader actions as "
+"long options, both loaders accept long aliases for existing options, and"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"-if-not-exists makes creation actions idempotent (Darafei Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/4208\">#4208</ulink>, Add "
+"single-geometry variants of ST_MaxDistance and ST_LongestLine (Darafei "
+"Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"[topology] FindVertexSegmentPairsBelowDistance function (Sandro Santilli)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"ST_CoverageEdges, returns MultiLinestring of distinct shared edges in "
+"polygonal coverage (Paul Ramsey)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "ST_MinimumSpanningTree, window function to calculate MST (Paul Ramsey)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/5993\">#5993</ulink>, "
+"[topology] Add max_edges parameter to TopoGeo_AddLinestring (Sandro Santilli)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/6001\">#6001</ulink>, "
+"support MultiLineString in ST_MakeLine (Paul Ramsey)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/2858\">#2858</ulink>, "
+"ST_MMin and ST_MMax (Paul Ramsey)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/5941\">#5941</ulink>, "
+"[raster] Support GDT_Float16 pixel type (Darafei Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/5992\">#5992</ulink>, "
+"Optimize GiST index for repeated edge subdivision in topology (Darafei "
+"Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/5702\">#5702</ulink>, "
+"Allow the compiler to detect the parallelism -flto=auto (Darafei "
+"Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/4798\">#4798</ulink>, "
+"ST_AsGeoJSON warns about duplicate property keys (Darafei Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/5950\">#5950</ulink>, "
+"Document POSTGIS_REGRESS_DB_OWNER for sandboxed regression roles (Darafei "
+"Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/4332\">#4332</ulink>, "
+"Clarify the scope of several Function Reference categories (Darafei "
+"Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/4222\">#4222</ulink>, "
+"[raster] ST_DumpAsPolygons honours PostgreSQL interrupts (Darafei "
+"Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/5109\">#5109</ulink>, "
+"Document the meaning of topology.next_left_edge and topology.next_right_edge "
+"links (Darafei Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/5889\">#5889</ulink>, "
+"[topology] Include representative locations in topology build errors "
+"(Darafei Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/2614\">#2614</ulink>, Use "
+"GEOSPreparedDistance and caching to accelerate ST_DWithin (Paul Ramsey)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/6022\">#6022</ulink>, "
+"Document ST_AsMVTGeom tile-coordinate simplification (Darafei Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://github.com/postgis/postgis/pull/839\">GH-839</ulink>, "
+"ST_Multi support for TIN and surfaces (Loïc Bartoletti)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/4398\">#4398</ulink>, Add "
+"ST_CatmullSmoothing smoothes but retains original vertices (Paul Ramsey)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/4560\">#4560</ulink>, "
+"ST_3DInterpolatePoint for M interpolation from XYZ inputs (Paul Ramsey)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/1291\">#1291</ulink>, "
+"ST_MakePolygon support for curved rings (Darafei Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://gitea.osgeo.org/postgis/postgis/pulls/270\">GT-270</"
+"ulink>, Add NURBSCurve (Loïc Bartoletti)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/2863\">#2863</ulink>, Add "
+"ST_XSize, ST_YSize, ST_ZSize, and ST_MSize dimension helpers (Darafei "
+"Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"[fuzzers] Centralize OSS-Fuzz build/dependency logic in PostGIS scripts, "
+"prefer requested CXX over pg_config --cc for internal C++ checks, and make "
+"fuzzer linking/runtime dependency packaging portable (Darafei Praliaskouski)"
+msgstr ""
+#. Tag: title
+#, no-c-format
+msgid "Enhancements"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/2045\">#2045</ulink>, "
+"pgsql2shp query dumps no longer require temporary table privileges (Darafei "
+"Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/1577\">#1577</ulink>, "
+"[loader] Report unsupported .zip archive input before trying to open "
+"shapefile sidecar files (Darafei Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/3158\">#3158</ulink>, "
+"Move geometry and geography typmod bit helpers out of the public liblwgeom "
+"header (Darafei Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/4678\">#4678</ulink>, "
+"[raster] Move st_sum4ma neighborhood callback to C (Darafei Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/2116\">#2116</ulink>, "
+"[raster] Add ST_Value nearest-neighbor boundary options (Darafei "
+"Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/2804\">#2804</ulink>, "
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/4315\">#4315</ulink>, "
+"[raster] Support two-argument ST_MapAlgebra callbacks and pass callback call "
+"data as actual arguments (Darafei Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/2898\">#2898</ulink>, "
+"Document SQL function cost tiers for contributors"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/6062\">#6062</ulink>, "
+"[topology] Stop using recursive snapping, for improved robustness (Sandro "
+"Santilli)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/6065\">#6065</ulink>, "
+"Improved winding order computation robustness for rings having collapsed "
+"elements (Sandro Santilli)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/3743\">#3743</ulink>, "
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/4385\">#4385</ulink>, "
+"[raster loader] Document raster2pgsql -s FROM_SRID:SRID reprojection support "
+"and clarify index creation timing for append loads (Darafei Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/2137\">#2137</ulink>, "
+"[raster] Reuse matching source raster overviews in raster2pgsql -l (Darafei "
+"Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/4749\">#4749</ulink>, Use "
+"point-in-polygon predicate fast paths for point-only GeometryCollections "
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/5532\">#5532</ulink>, "
+"Validate the manual against DocBook XMLSchema in check-xml (Darafei "
+"Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/6087\">#6087</ulink>, Add "
+"a repository-owned CI status checker and static dashboard generator (Darafei "
+"Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/2807\">#2807</ulink>, "
+"[raster] Preserve missing NODATA values in ST_MapAlgebra outputs (Darafei "
+"Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/2832\">#2832</ulink>, "
+"[raster] Avoid padding single-tile raster2pgsql overviews when padding is "
+"not requested (Darafei Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/2623\">#2623</ulink>, "
+"Generate a pgsql2shp GID field when exporting geometry-only shapefiles "
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/2850\">#2850</ulink>, "
+"Preserve pgsql2shp numeric precision and scale in DBF metadata (Darafei "
+"Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/2386\">#2386</ulink>, Add "
+"raster2pgsql man page (Darafei Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Build PostgreSQL extension modules with `-fno-semantic-interposition` when "
+"available so LTO can optimize same-DSO calls to exported PostGIS entry "
+"points directly instead of routing through the module PLT; in a local "
+"PostgreSQL 18 `pgbench` microbenchmark over 100k four-point groups this "
+"reduced `ST_Collect` aggregate latency by about 4% (Darafei Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/5973\">#5973</ulink>, "
+"Install PostGIS utilities under `pg_config --bindir` by default and document "
+"`pg_config`-derived install paths more accurately (Darafei Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/2808\">#2808</ulink>, "
+"Clarify postgis_full_version() output when installed component scripts are "
+"newer than core scripts (Darafei Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/5593\">#5593</ulink>, "
+"Docs: render manual images with GraphicsMagick without temporary files, "
+"enabling parallel builds, keeping ImageMagick fallbacks working, and "
+"documenting the generator workflow for contributors (Darafei Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/5645\">#5645</ulink>, "
+"Docs: keep code operators ("=>") intact in translated manuals "
+"by enforcing verbatim CSS (Darafei Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/1408\">#1408</ulink>, "
+"Docs: flatten transparent manual images onto white backgrounds for PDF "
+"builds while keeping HTML images transparent (Darafei Praliaskouski)"
+msgstr ""
+#. Tag: title
+#, no-c-format
+msgid "Bug Fixes"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/4616\">#4616</ulink>, "
+"Detect pgsql2shp query keywords case-insensitively (Darafei Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/2838\">#2838</ulink>, "
+"Emit valid X3D Coordinate nodes for 2D polygon output (Darafei Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Fix WKB and TWKB parser resource exhaustion on malformed input (Darafei "
+"Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/6083\">#6083</ulink>, "
+"Pass configured dependency include paths to fuzzer smoke builds (Darafei "
+"Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/3103\">#3103</ulink>, Add "
+"regression coverage for exact-schema find_srid and geometry_columns lookups "
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/1705\">#1705</ulink>, "
+"Infer constraint metadata for direct view and materialized view geometry "
+"columns (Darafei Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/6038\">#6038</ulink>, "
+"Avoid stale relation lookups in geometry_columns after topology objects are "
+"dropped (Darafei Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/5655\">#5655</ulink>, "
+"[doc] Skip XML validation during `make check` when xsltproc is unavailable "
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/5487\">#5487</ulink>, "
+"Improve error detail for repeated upgrades after an incomplete deprecated-"
+"function cleanup (Darafei Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://github.com/postgis/postgis/pull/899\">GH-899</ulink>, "
+"[raster] Honor PostgreSQL interrupts in long-running GDAL progress callbacks "
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/5975\">#5975</ulink>, "
+"Initialize skipped union-find cluster ids deterministically (Darafei "
+"Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/5904\">#5904</ulink>, "
+"[topology] Avoid MinGW format warnings when logging topology ids (Darafei "
+"Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://github.com/postgis/postgis/pull/885\">GH-885</ulink>, "
+"[topology] Avoid GMP overflow in ring orientation for very large finite "
+"coordinates (Darafei Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/6073\">#6073</ulink>, "
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/6074\">#6074</ulink>, "
+"Stabilize geography LRS endpoint interpolation and pole centroid regressions "
+"on 32-bit systems (Darafei Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/6082\">#6082</ulink>, Fix "
+"Japanese PDF build by avoiding non-ASCII arrows in SQL program listings "
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://github.com/postgis/postgis/pull/888\">GH-888</ulink>, "
+"[sfcgal] Avoid stale detoasted geometry access in CG_Visibility empty-input "
+"handling for SFCGAL < 2.2 (Darafei Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/3179\">#3179</ulink>, "
+"Mark truncated libpgcommon PostgreSQL messages instead of silently dropping "
+"the tail (Darafei Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/6003\">#6003</ulink>, "
+"Avoid size_t formats in liblwgeom logging/error wrappers for MinGW builds "
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://github.com/postgis/postgis/pull/886\">GH-886</ulink>, "
+"ST_ClusterRelateWin validates NULL relate matrices before detoasting them "
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://github.com/postgis/postgis/pull/889\">GH-889</ulink>, "
+"ST_Relate pattern inversion avoids out-of-bounds access on short DE-9IM "
+"patterns (Darafei Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://github.com/postgis/postgis/pull/890\">GH-890</ulink>, "
+"Avoid GIDX BRIN summary merges across mismatched dimensions (Darafei "
+"Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/5948\">#5948</ulink>, "
+"[topology] Prevent MakeTopologyPrecise from erasing edges when grid size "
+"exceeds their extent (Darafei Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/5959\">#5959</ulink>, "
+"Prevent histogram target overflow when analysing massive tables (Darafei "
+"Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/6080\">#6080</ulink>, "
+"Avoid out-of-bounds hex WKB lookup for high-bit input bytes (Darafei "
+"Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://github.com/postgis/postgis/pull/895\">GH-895</ulink>, "
+"Qualify pg_class lookup during SRID/PROJ validation (Darafei Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/4828\">#4828</ulink>, "
+"geometry_columns handles NOT VALID SRID checks without errors (Darafei "
+"Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/6048\">#6048</ulink>, "
+"[raster] ST_Clip no longer crashes when clipping sparse band selections "
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://github.com/postgis/postgis/pull/894\">GH-894</ulink>, "
+"[raster] Fix Float16 import, mixed nodata warping, band replacement cleanup, "
+"GDAL credential redaction, and Python GDAL compatibility (Darafei "
+"Praliaskouski)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Flatgeobuf schema mismatch vulnerability (NeuroWinter)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/5899\">#5899</ulink>, "
+"pg_upgrade issue for non-standard geography SRID (Paul Ramsey)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/2583\">#2583</ulink>, "
+"Preserve Z/ZM dimensional qualifiers in ST_AsEWKT output for TIN (Darafei "
+"Praliaskouski)"
+msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "Reporting Problems"
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index 7336bf631..d46b71987 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -2,19 +2,112 @@
 <appendix xmlns:xlink="http://www.w3.org/1999/xlink" xmlns="http://docbook.org/ns/docbook" version="5.0" xml:id="release_notes">
   <title>Appendix</title>
     <subtitle>Release Notes</subtitle>
-        <section>
-            <title>PostGIS 3.7.0beta1</title>
-            <para>2026/06/xx</para>
-            <para>This version requires GEOS 3.10 or higher. PostgreSQL 14-19beta1 required. Proj 6.1+ required.
-To take advantage of all features postgis extension features, GEOS 3.15+ is needed.
-To take advantage of all postgis_sfcgal extension features SFCGAL 2.2+ is needed.</para>
-            <simplesect><title>Breaking Changes</title>
-                <para>Place holder</para>
-            </simplesect>
-            <simplesect><title>New Features</title>
-            </simplesect>
-        </section>
+    <section id="release_notes_3_7_0">
+    <title>PostGIS 3.7.0alpha1</title>
+    <subtitle>2026/07/05</subtitle>
+    <para>This version requires GEOS 3.10+, PostgreSQL 14-19beta1, Proj 6.1+, libgmp. To take advantage of all features postgis extension features, GEOS 3.15+ is needed. To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed.</para>
+    <simplesect>
+      <title>Breaking Changes</title>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/5688">#5688</ulink>, [topology] topology building functions now interpret tolerance 0 (old default) to really mean 0 and want -1 (new default) to mean "use topology precision" (Sandro Santilli)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/6024">#6024</ulink>, Remove support for PostgreSQL 12 and 13 (Regina Obe)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/6040">#6040</ulink>, ST_GeoHash round trip through ST_GeomFromGeoHash (Paul Ramsey)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/6053">#6053</ulink>, [address_standardizer] Extension removed and moved to <ulink url="https://github.com/postgis/address_standardizer">https://github.com/postgis/address_standardizer</ulink> (Paul Ramsey)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/6052">#6052</ulink>, [tiger_geocoder] Extension removed and moved to <ulink url="https://git.osgeo.org/postgis/postgis_tiger_geocoder">https://git.osgeo.org/postgis/postgis_tiger_geocoder</ulink> (Regina Obe)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/6079">#6079</ulink>, Remove support for GEOS < 3.10 (Sandro Santilli)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/1793">#1793</ulink>, Remove ST_MemCollect aggregate (Darafei Praliaskouski)</para>
+      <para><ulink url="https://github.com/postgis/postgis/pull/848">GH-848</ulink>, CG_AlphaShape now returns a MultiPolygon (Jean Felder)</para>
+    </simplesect>
+    <simplesect>
+      <title>New Features</title>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/1124">#1124</ulink>, <ulink url="https://trac.osgeo.org/postgis/ticket/2935">#2935</ulink>, <ulink url="https://trac.osgeo.org/postgis/ticket/3033">#3033</ulink>, <ulink url="https://trac.osgeo.org/postgis/ticket/4658">#4658</ulink>, <ulink url="https://trac.osgeo.org/postgis/ticket/4659">#4659</ulink>, [loader] Rework loader arguments: shp2pgsql can create UNLOGGED tables and choose the feature id column name, shp2pgsql --drop-table can emit DROP TABLE before prepare output, raster2pgsql/shp2pgsql expose loader actions as long options, both loaders accept long aliases for existing options, and</para>
+      <para>-if-not-exists makes creation actions idempotent (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/4208">#4208</ulink>, Add single-geometry variants of ST_MaxDistance and ST_LongestLine (Darafei Praliaskouski)</para>
+      <para>[topology] FindVertexSegmentPairsBelowDistance function (Sandro Santilli)</para>
+      <para>ST_CoverageEdges, returns MultiLinestring of distinct shared edges in polygonal coverage (Paul Ramsey)</para>
+      <para>ST_MinimumSpanningTree, window function to calculate MST (Paul Ramsey)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/5993">#5993</ulink>, [topology] Add max_edges parameter to TopoGeo_AddLinestring (Sandro Santilli)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/6001">#6001</ulink>, support MultiLineString in ST_MakeLine (Paul Ramsey)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/2858">#2858</ulink>, ST_MMin and ST_MMax (Paul Ramsey)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/5941">#5941</ulink>, [raster] Support GDT_Float16 pixel type (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/5992">#5992</ulink>, Optimize GiST index for repeated edge subdivision in topology (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/5702">#5702</ulink>, Allow the compiler to detect the parallelism -flto=auto (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/4798">#4798</ulink>, ST_AsGeoJSON warns about duplicate property keys (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/5950">#5950</ulink>, Document POSTGIS_REGRESS_DB_OWNER for sandboxed regression roles (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/4332">#4332</ulink>, Clarify the scope of several Function Reference categories (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/4222">#4222</ulink>, [raster] ST_DumpAsPolygons honours PostgreSQL interrupts (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/5109">#5109</ulink>, Document the meaning of topology.next_left_edge and topology.next_right_edge links (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/5889">#5889</ulink>, [topology] Include representative locations in topology build errors (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/2614">#2614</ulink>, Use GEOSPreparedDistance and caching to accelerate ST_DWithin (Paul Ramsey)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/6022">#6022</ulink>, Document ST_AsMVTGeom tile-coordinate simplification (Darafei Praliaskouski)</para>
+      <para><ulink url="https://github.com/postgis/postgis/pull/839">GH-839</ulink>, ST_Multi support for TIN and surfaces (Loïc Bartoletti)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/4398">#4398</ulink>, Add ST_CatmullSmoothing smoothes but retains original vertices (Paul Ramsey)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/4560">#4560</ulink>, ST_3DInterpolatePoint for M interpolation from XYZ inputs (Paul Ramsey)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/1291">#1291</ulink>, ST_MakePolygon support for curved rings (Darafei Praliaskouski)</para>
+      <para><ulink url="https://gitea.osgeo.org/postgis/postgis/pulls/270">GT-270</ulink>, Add NURBSCurve (Loïc Bartoletti)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/2863">#2863</ulink>, Add ST_XSize, ST_YSize, ST_ZSize, and ST_MSize dimension helpers (Darafei Praliaskouski)</para>
+      <para>[fuzzers] Centralize OSS-Fuzz build/dependency logic in PostGIS scripts, prefer requested CXX over pg_config --cc for internal C++ checks, and make fuzzer linking/runtime dependency packaging portable (Darafei Praliaskouski)</para>
+    </simplesect>
+    <simplesect>
+      <title>Enhancements</title>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/2045">#2045</ulink>, pgsql2shp query dumps no longer require temporary table privileges (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/1577">#1577</ulink>, [loader] Report unsupported .zip archive input before trying to open shapefile sidecar files (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/3158">#3158</ulink>, Move geometry and geography typmod bit helpers out of the public liblwgeom header (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/4678">#4678</ulink>, [raster] Move st_sum4ma neighborhood callback to C (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/2116">#2116</ulink>, [raster] Add ST_Value nearest-neighbor boundary options (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/2804">#2804</ulink>, <ulink url="https://trac.osgeo.org/postgis/ticket/4315">#4315</ulink>, [raster] Support two-argument ST_MapAlgebra callbacks and pass callback call data as actual arguments (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/2898">#2898</ulink>, Document SQL function cost tiers for contributors</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/6062">#6062</ulink>, [topology] Stop using recursive snapping, for improved robustness (Sandro Santilli)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/6065">#6065</ulink>, Improved winding order computation robustness for rings having collapsed elements (Sandro Santilli)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/3743">#3743</ulink>, <ulink url="https://trac.osgeo.org/postgis/ticket/4385">#4385</ulink>, [raster loader] Document raster2pgsql -s FROM_SRID:SRID reprojection support and clarify index creation timing for append loads (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/2137">#2137</ulink>, [raster] Reuse matching source raster overviews in raster2pgsql -l (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/4749">#4749</ulink>, Use point-in-polygon predicate fast paths for point-only GeometryCollections (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/5532">#5532</ulink>, Validate the manual against DocBook XMLSchema in check-xml (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/6087">#6087</ulink>, Add a repository-owned CI status checker and static dashboard generator (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/2807">#2807</ulink>, [raster] Preserve missing NODATA values in ST_MapAlgebra outputs (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/2832">#2832</ulink>, [raster] Avoid padding single-tile raster2pgsql overviews when padding is not requested (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/2623">#2623</ulink>, Generate a pgsql2shp GID field when exporting geometry-only shapefiles (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/2850">#2850</ulink>, Preserve pgsql2shp numeric precision and scale in DBF metadata (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/2386">#2386</ulink>, Add raster2pgsql man page (Darafei Praliaskouski)</para>
+      <para>Build PostgreSQL extension modules with `-fno-semantic-interposition` when available so LTO can optimize same-DSO calls to exported PostGIS entry points directly instead of routing through the module PLT; in a local PostgreSQL 18 `pgbench` microbenchmark over 100k four-point groups this reduced `ST_Collect` aggregate latency by about 4% (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/5973">#5973</ulink>, Install PostGIS utilities under `pg_config --bindir` by default and document `pg_config`-derived install paths more accurately (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/2808">#2808</ulink>, Clarify postgis_full_version() output when installed component scripts are newer than core scripts (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/5593">#5593</ulink>, Docs: render manual images with GraphicsMagick without temporary files, enabling parallel builds, keeping ImageMagick fallbacks working, and documenting the generator workflow for contributors (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/5645">#5645</ulink>, Docs: keep code operators ("=>") intact in translated manuals by enforcing verbatim CSS (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/1408">#1408</ulink>, Docs: flatten transparent manual images onto white backgrounds for PDF builds while keeping HTML images transparent (Darafei Praliaskouski)</para>
+    </simplesect>
+    <simplesect>
+      <title>Bug Fixes</title>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/4616">#4616</ulink>, Detect pgsql2shp query keywords case-insensitively (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/2838">#2838</ulink>, Emit valid X3D Coordinate nodes for 2D polygon output (Darafei Praliaskouski)</para>
+      <para>Fix WKB and TWKB parser resource exhaustion on malformed input (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/6083">#6083</ulink>, Pass configured dependency include paths to fuzzer smoke builds (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/3103">#3103</ulink>, Add regression coverage for exact-schema find_srid and geometry_columns lookups (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/1705">#1705</ulink>, Infer constraint metadata for direct view and materialized view geometry columns (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/6038">#6038</ulink>, Avoid stale relation lookups in geometry_columns after topology objects are dropped (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/5655">#5655</ulink>, [doc] Skip XML validation during `make check` when xsltproc is unavailable (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/5487">#5487</ulink>, Improve error detail for repeated upgrades after an incomplete deprecated-function cleanup (Darafei Praliaskouski)</para>
+      <para><ulink url="https://github.com/postgis/postgis/pull/899">GH-899</ulink>, [raster] Honor PostgreSQL interrupts in long-running GDAL progress callbacks (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/5975">#5975</ulink>, Initialize skipped union-find cluster ids deterministically (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/5904">#5904</ulink>, [topology] Avoid MinGW format warnings when logging topology ids (Darafei Praliaskouski)</para>
+      <para><ulink url="https://github.com/postgis/postgis/pull/885">GH-885</ulink>, [topology] Avoid GMP overflow in ring orientation for very large finite coordinates (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/6073">#6073</ulink>, <ulink url="https://trac.osgeo.org/postgis/ticket/6074">#6074</ulink>, Stabilize geography LRS endpoint interpolation and pole centroid regressions on 32-bit systems (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/6082">#6082</ulink>, Fix Japanese PDF build by avoiding non-ASCII arrows in SQL program listings (Darafei Praliaskouski)</para>
+      <para><ulink url="https://github.com/postgis/postgis/pull/888">GH-888</ulink>, [sfcgal] Avoid stale detoasted geometry access in CG_Visibility empty-input handling for SFCGAL < 2.2 (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/3179">#3179</ulink>, Mark truncated libpgcommon PostgreSQL messages instead of silently dropping the tail (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/6003">#6003</ulink>, Avoid size_t formats in liblwgeom logging/error wrappers for MinGW builds (Darafei Praliaskouski)</para>
+      <para><ulink url="https://github.com/postgis/postgis/pull/886">GH-886</ulink>, ST_ClusterRelateWin validates NULL relate matrices before detoasting them (Darafei Praliaskouski)</para>
+      <para><ulink url="https://github.com/postgis/postgis/pull/889">GH-889</ulink>, ST_Relate pattern inversion avoids out-of-bounds access on short DE-9IM patterns (Darafei Praliaskouski)</para>
+      <para><ulink url="https://github.com/postgis/postgis/pull/890">GH-890</ulink>, Avoid GIDX BRIN summary merges across mismatched dimensions (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/5948">#5948</ulink>, [topology] Prevent MakeTopologyPrecise from erasing edges when grid size exceeds their extent (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/5959">#5959</ulink>, Prevent histogram target overflow when analysing massive tables (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/6080">#6080</ulink>, Avoid out-of-bounds hex WKB lookup for high-bit input bytes (Darafei Praliaskouski)</para>
+      <para><ulink url="https://github.com/postgis/postgis/pull/895">GH-895</ulink>, Qualify pg_class lookup during SRID/PROJ validation (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/4828">#4828</ulink>, geometry_columns handles NOT VALID SRID checks without errors (Darafei Praliaskouski)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/6048">#6048</ulink>, [raster] ST_Clip no longer crashes when clipping sparse band selections (Darafei Praliaskouski)</para>
+      <para><ulink url="https://github.com/postgis/postgis/pull/894">GH-894</ulink>, [raster] Fix Float16 import, mixed nodata warping, band replacement cleanup, GDAL credential redaction, and Python GDAL compatibility (Darafei Praliaskouski)</para>
+      <para>Flatgeobuf schema mismatch vulnerability (NeuroWinter)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/5899">#5899</ulink>, pg_upgrade issue for non-standard geography SRID (Paul Ramsey)</para>
+      <para><ulink url="https://trac.osgeo.org/postgis/ticket/2583">#2583</ulink>, Preserve Z/ZM dimensional qualifiers in ST_AsEWKT output for TIN (Darafei Praliaskouski)</para>
+    </simplesect>
+  </section>
 </appendix>
Summary of changes:
 NEWS                                |  62 ++-
 doc/po/templates/postgis-manual.pot | 729 +++++++++++++++++++++++++++++++++++-
 doc/release_notes.xml               | 123 +++++-
 3 files changed, 858 insertions(+), 56 deletions(-)
hooks/post-receive
