[SCM] PostGIS branch master updated. 3.7.0alpha1-16-g333d896e7
git at osgeo.org
git at osgeo.org
Mon Jul 6 03:56:14 PDT 2026
the project "PostGIS".
via 333d896e75c3d61887e80c506f5879fd558b1a2c (commit)
from 19ed1e12471723eb21184b1ea64429a219db6534 (commit)
revisions in full, below.
commit 333d896e75c3d61887e80c506f5879fd558b1a2c
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Mon Jul 6 14:14:20 2026 +0400
NEWS: start 3.7.0beta1 section
Closes https://github.com/postgis/postgis/pull/898
Closes https://github.com/postgis/postgis/pull/1143
Closes https://github.com/postgis/postgis/pull/1147
Closes https://github.com/postgis/postgis/pull/1148
Closes https://github.com/postgis/postgis/pull/1149
Closes https://github.com/postgis/postgis/pull/1153
References https://github.com/postgis/postgis/pull/897
diff --git a/NEWS b/NEWS
index 6fda3ea30..78ad37d49 100644
--- a/NEWS
+++ b/NEWS
@@ -1,3 +1,25 @@
+PostGIS 3.7.0beta1
+2026/xx/xx
+This version requires GEOS 3.10+, PostgreSQL 14-19beta1, Proj 6.1+, libgmp.
+To take advantage of all features postgis extension features, GEOS 3.15+ is needed.
+To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed.
+* Bug Fixes *
+ - GH-898, Fix ST_DFullyWithin indexed plans and large-coordinate
+ ring-orientation precision regressions (Darafei Praliaskouski)
+ - GH-1143, [topology] Clean up TopoRingIsCCW early returns
+ (Darafei Praliaskouski)
+ - GH-1147, [doc] Fix localized EPUB help target (Darafei Praliaskouski)
+ - GH-1148, [utils] Create upgrade-check tempdir safely
+ - GH-1149, [topology] Fix corrupt column fallback variables
+ - GH-1153, [topology] Preserve large ids from edge wrappers
PostGIS 3.7.0alpha1
2026/07/05
@@ -171,11 +193,6 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
- GH-895, Qualify pg_class lookup during SRID/PROJ validation
- - GH-897, [topology] Harden topology helper functions and
- maintenance SQL against identifier, tolerance, bigint, and cleanup
- regressions (Darafei Praliaskouski)
- - GH-898, Fix ST_DFullyWithin indexed plans and large-coordinate
- ring-orientation precision regressions (Darafei Praliaskouski)
- #4828, geometry_columns handles NOT VALID SRID checks without errors (Darafei Praliaskouski)
- #6048, [raster] ST_Clip no longer crashes when clipping sparse band
selections (Darafei Praliaskouski)
Summary of changes:
NEWS | 27 ++++++++++++++++++++++-----
1 file changed, 22 insertions(+), 5 deletions(-)
hooks/post-receive
