[SCM] PostGIS branch master updated. 3.7.0alpha1-32-ga5411841b
git at osgeo.org
git at osgeo.org
Tue Jul 7 04:12:46 PDT 2026
the project "PostGIS".
via a5411841bd4b063d4c7ca6e371e14eaae61af85a (commit)
from fabbc2cc36bd515fc8299597c2ad2af74deffff0 (commit)
revisions in full, below.
commit a5411841bd4b063d4c7ca6e371e14eaae61af85a
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Tue Jul 7 15:07:59 2026 +0400
upgrade: escape version regex literals
Use explicit escape string syntax for the version parsing regular expressions emitted by create_upgrade.pl. This keeps downgrade checks quiet and parser-stable when standard_conforming_strings is off.
Closes #6094 for PostGIS 3.7
Closes https://github.com/postgis/postgis/pull/1158
diff --git a/NEWS b/NEWS
index 15ac2f4d8..e3e6a72a6 100644
--- a/NEWS
+++ b/NEWS
@@ -7,6 +7,8 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
* Bug Fixes *
+ - #6094, [upgrade] Avoid legacy string literal warnings in downgrade checks
+ with standard_conforming_strings off (Darafei Praliaskouski)
- GH-898, Fix ST_DFullyWithin indexed plans and large-coordinate
ring-orientation precision regressions (Darafei Praliaskouski)
- GH-1143, [topology] Clean up TopoRingIsCCW early returns
diff --git a/utils/create_upgrade.pl b/utils/create_upgrade.pl
index b10ecc61e..22d24a52d 100644
--- a/utils/create_upgrade.pl
+++ b/utils/create_upgrade.pl
@@ -1028,11 +1028,11 @@ BEGIN
) SELECT
upgraded as scripts_upgraded,
installed as scripts_installed,
- pg_catalog.substring(upgraded, '([0-9]+)\.')::int * 100 +
- pg_catalog.substring(upgraded, '[0-9]+\.([0-9]+)(\.|$)')::int
+ pg_catalog.substring(upgraded, E'([0-9]+)\\.')::int * 100 +
+ pg_catalog.substring(upgraded, E'[0-9]+\\.([0-9]+)(\\.|$)')::int
as version_to_num,
- pg_catalog.substring(installed, '([0-9]+)\.')::int * 100 +
- pg_catalog.substring(installed, '[0-9]+\.([0-9]+)(\.|$)')::int
+ pg_catalog.substring(installed, E'([0-9]+)\\.')::int * 100 +
+ pg_catalog.substring(installed, E'[0-9]+\\.([0-9]+)(\\.|$)')::int
as version_from_num,
installed ~ 'dev|alpha|beta'
as version_from_isdev
Summary of changes:
NEWS | 2 ++
utils/create_upgrade.pl | 8 ++++----
2 files changed, 6 insertions(+), 4 deletions(-)
hooks/post-receive
