[SCM] PostGIS branch master updated. 3.7.0alpha1-31-gfabbc2cc3
Tue Jul 7 01:32:24 PDT 2026
the project "PostGIS".
       via  fabbc2cc36bd515fc8299597c2ad2af74deffff0 (commit)
       via  12d4908ee624b5add8ef9ad8012dc6a7a023bffc (commit)
       via  80c2372aa4d03414276596f74167db9212f7bc72 (commit)
       via  b277b71697392b450884f07f1db2c673431203b2 (commit)
       via  e994aef350aacc5f9558fc47a7fa9f6dfb5c759e (commit)
       via  a09a9f3a75eea082f7d2484965bc4faea312724a (commit)
      from  642a42d9056248081dc124de07d1987667277ce8 (commit)
revisions in full, below.
commit fabbc2cc36bd515fc8299597c2ad2af74deffff0
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Tue Jul 7 12:15:39 2026 +0400
    topology: quote TotalTopologySize regclasses safely
    Closes https://github.com/postgis/postgis/pull/1154
diff --git a/NEWS b/NEWS
index 1526ecf5c..15ac2f4d8 100644
--- a/NEWS
+++ b/NEWS
@@ -32,6 +32,8 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
           TopoGeometry construction (Darafei Praliaskouski)
  - GH-1152, [topology] Enforce max edge limits from reported
           TopoGeo_AddLinestring edge creation (Darafei Praliaskouski)
+ - GH-1154, [topology] Quote TotalTopologySize catalog regclasses
+          safely (Darafei Praliaskouski)
 PostGIS 3.7.0dev
diff --git a/topology/sql/manage/TotalTopologySize.sql.in b/topology/sql/manage/TotalTopologySize.sql.in
index d68989c97..09166180b 100644
--- a/topology/sql/manage/TotalTopologySize.sql.in
+++ b/topology/sql/manage/TotalTopologySize.sql.in
@@ -24,12 +24,15 @@ BEGIN
   sql := format(
 SELECT
-pg_catalog.pg_total_relation_size('%1$I.edge_data') +
-pg_catalog.pg_total_relation_size('%1$I.node') +
-pg_catalog.pg_total_relation_size('%1$I.face') +
-pg_catalog.pg_total_relation_size('%1$I.relation')
+pg_catalog.pg_total_relation_size(%1$L) +
+pg_catalog.pg_total_relation_size(%2$L) +
+pg_catalog.pg_total_relation_size(%3$L) +
+pg_catalog.pg_total_relation_size(%4$L)
-    toponame
+    format('%I.edge_data', toponame),
+    format('%I.node', toponame),
+    format('%I.face', toponame),
+    format('%I.relation', toponame)
   EXECUTE sql INTO total_size;
commit 12d4908ee624b5add8ef9ad8012dc6a7a023bffc
Date:   Tue Jul 7 12:15:08 2026 +0400
    topology: count created edges for max edge limits
    Closes https://github.com/postgis/postgis/pull/1152
index 82807a98d..1526ecf5c 100644
--- a/NEWS
+++ b/NEWS
@@ -30,6 +30,8 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
           segment counts (Darafei Praliaskouski)
  - GH-1151, [topology] Preserve exact zero tolerance in
+ - GH-1152, [topology] Enforce max edge limits from reported
+          TopoGeo_AddLinestring edge creation (Darafei Praliaskouski)
 PostGIS 3.7.0dev
diff --git a/liblwgeom/topo/lwgeom_topo.c b/liblwgeom/topo/lwgeom_topo.c
index 92681813e..815711980 100644
--- a/liblwgeom/topo/lwgeom_topo.c
+++ b/liblwgeom/topo/lwgeom_topo.c
@@ -7683,23 +7683,23 @@ _lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges,
     forward = -1; /* will be set to either 0 or 1 if the edge already existed */
     id = _lwt_AddLineEdge( topo, lwgeom_as_lwline(g), tol, handleFaceSplit, &forward, &edgeNewEdges );
-    num_new_edges += edgeNewEdges;
-    /* if forward is still == -1 this was NOT an existing edge ? */
-    if ( forward == -1 )
-      ++num_new_edges;
-    LWDEBUGF(1, "_lwt_AddLineEdge returned %" LWTFMT_ELEMID
-      " (forward ? %d), reported to create %d new edges (total new edges: %d)",
-      id, forward, edgeNewEdges, num_new_edges);
-    if ( id < 0 )
+    if (id < 0)
       lwgeom_free(noded);
       lwfree(ids);
       return NULL;
+    num_new_edges += edgeNewEdges;
+    LWDEBUGF(1,
+	     "_lwt_AddLineEdge returned %" LWTFMT_ELEMID
+	     " (forward ? %d), reported to create %d new edges (total new edges: %d)",
+	     id,
+	     forward,
+	     edgeNewEdges,
+	     num_new_edges);
     if ( maxNewEdges >= 0 && num_new_edges > maxNewEdges )
       lwgeom_free(noded);
commit 80c2372aa4d03414276596f74167db9212f7bc72
Date:   Tue Jul 7 12:14:35 2026 +0400
    topology: preserve zero tolerance semantics
    Closes https://github.com/postgis/postgis/pull/1151
index f8ae406d1..82807a98d 100644
--- a/NEWS
+++ b/NEWS
@@ -28,6 +28,8 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
  - GH-1141, [liblwgeom] Reject overflowing NURBS linearization
+ - GH-1151, [topology] Preserve exact zero tolerance in
+          TopoGeometry construction (Darafei Praliaskouski)
 PostGIS 3.7.0dev
index c7bfe1cee..92681813e 100644
@@ -7106,6 +7106,7 @@ _lwt_AddLineEdge( LWT_TOPOLOGY* topo, LWLINE* edge, double tol,
   uint64_t nn, i;
   int moved=0, mm;
   int pointSplitEdges = -666;
+  double endpoint_tol;
   if ( numNewEdges ) *numNewEdges = 0;
@@ -7118,9 +7119,8 @@ _lwt_AddLineEdge( LWT_TOPOLOGY* topo, LWLINE* edge, double tol,
     lwnotice("Empty component of noded line");
     return 0; /* must be empty */
-  nid[0] = _lwt_AddPoint( topo, start_point,
-                          _lwt_minTolerance(lwpoint_as_lwgeom(start_point)),
-                          handleFaceSplit, &mm, &pointSplitEdges );
+  endpoint_tol = tol == 0.0 ? 0.0 : _lwt_minTolerance(lwpoint_as_lwgeom(start_point));
+  nid[0] = _lwt_AddPoint(topo, start_point, endpoint_tol, handleFaceSplit, &mm, &pointSplitEdges);
   lwpoint_free(start_point); /* too late if lwt_AddPoint calls lwerror */
   if ( nid[0] == -1 ) return -1; /* lwerror should have been called */
   if ( numNewEdges ) *numNewEdges += pointSplitEdges;
@@ -7135,9 +7135,8 @@ _lwt_AddLineEdge( LWT_TOPOLOGY* topo, LWLINE* edge, double tol,
             "after successfully getting first point !?");
     return -1;
-  nid[1] = _lwt_AddPoint( topo, end_point,
-                          _lwt_minTolerance(lwpoint_as_lwgeom(end_point)),
+  endpoint_tol = tol == 0.0 ? 0.0 : _lwt_minTolerance(lwpoint_as_lwgeom(end_point));
+  nid[1] = _lwt_AddPoint(topo, end_point, endpoint_tol, handleFaceSplit, &mm, &pointSplitEdges);
   lwpoint_free(end_point); /* too late if lwt_AddPoint calls lwerror */
   if ( nid[1] == -1 ) return -1; /* lwerror should have been called */
diff --git a/topology/postgis_topology.c b/topology/postgis_topology.c
index 41491d080..907c88dca 100644
--- a/topology/postgis_topology.c
+++ b/topology/postgis_topology.c
@@ -4965,7 +4965,7 @@ Datum GetNodeByPoint(PG_FUNCTION_ARGS)
   tol = PG_GETARG_FLOAT8(2);
-  if ( tol < -1 )
+  if (tol < -1 || (tol < 0 && tol != -1))
     PG_FREE_IF_COPY(geom, 1);
     lwpgerror("Tolerance must be -1 or >=0 ");
@@ -5035,7 +5035,7 @@ Datum GetEdgeByPoint(PG_FUNCTION_ARGS)
-  if ( tol < -1 )
@@ -5107,7 +5107,7 @@ Datum GetFaceByPoint(PG_FUNCTION_ARGS)
-  if ( tol < -1 )
@@ -5188,7 +5188,7 @@ Datum TopoGeo_AddPoint(PG_FUNCTION_ARGS)
-  if ( tol < -1 )
@@ -5299,7 +5299,7 @@ Datum TopoGeo_AddLinestring(PG_FUNCTION_ARGS)
-    if ( tol < -1 )
       lwgeom_free(lwgeom);
@@ -5419,7 +5419,7 @@ Datum TopoGeo_AddLinestringNoFace(PG_FUNCTION_ARGS)
-  if ( tol < -1 )
@@ -5510,7 +5510,7 @@ Datum TopoGeo_AddPolygon(PG_FUNCTION_ARGS)
-    if ( tol < -1 )
@@ -5860,7 +5860,7 @@ Datum TopoGeo_LoadGeometry(PG_FUNCTION_ARGS)
   geom = PG_GETARG_GSERIALIZED_P(1);
-  if ( tol < -1 )
diff --git a/topology/sql/topogeometry/totopogeom.sql.in b/topology/sql/topogeometry/totopogeom.sql.in
index f943028bd..58d6e94de 100644
--- a/topology/sql/topogeometry/totopogeom.sql.in
+++ b/topology/sql/topogeometry/totopogeom.sql.in
@@ -156,8 +156,8 @@ BEGIN
   alayer := layer_id(tg);
   atopology := topology_info.name;
-  -- Get tolerance, if 0 was given
-  tolerance := COALESCE( NULLIF(atolerance, 0), topology._st_mintolerance(topology_info.name, ageom) );
+  -- Preserve exact and automatic tolerance semantics for each dumped component.
+  tolerance := atolerance;
   -- Get layer information
   BEGIN
commit b277b71697392b450884f07f1db2c673431203b2
Date:   Tue Jul 7 12:14:04 2026 +0400
    liblwgeom: reject overflowing NURBS segment counts
    Closes https://github.com/postgis/postgis/pull/1141
index 7b06489fe..f8ae406d1 100644
--- a/NEWS
+++ b/NEWS
@@ -26,6 +26,8 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
           proximity helper (Darafei Praliaskouski)
  - GH-1140, [liblwgeom] Cap NURBS WKT knot multiplicity
+ - GH-1141, [liblwgeom] Reject overflowing NURBS linearization
+          segment counts (Darafei Praliaskouski)
 PostGIS 3.7.0dev
diff --git a/liblwgeom/lwstroke.c b/liblwgeom/lwstroke.c
index 1e7cf6618..a6395a2fd 100644
--- a/liblwgeom/lwstroke.c
+++ b/liblwgeom/lwstroke.c
@@ -899,6 +899,7 @@ lwnurbscurve_linearize(const LWNURBSCURVE *curve, double tol,
                         int flags)
 	uint32_t num_segments;
+	const double max_segments = (double)UINT32_MAX - 1.0;
 	LWDEBUG(2, "lwnurbscurve_linearize called.");
@@ -926,13 +927,13 @@ lwnurbscurve_linearize(const LWNURBSCURVE *curve, double tol,
 		num_segments = (uint32_t)(tol * 4);
 		break;
-	case LW_LINEARIZE_TOLERANCE_TYPE_MAX_DEVIATION:
+	case LW_LINEARIZE_TOLERANCE_TYPE_MAX_DEVIATION: {
 		GBOX box;
 		double width = 0.0;
 		double height = 0.0;
 		double depth = 0.0;
 		double diagonal = 0.0;
+		double segments_required;
 		if (!curve->points || curve->points->npoints == 0)
 			return lwnurbscurve_to_linestring(curve, NURBS_MIN_LINEARIZE_SEGMENTS);
@@ -946,16 +947,17 @@ lwnurbscurve_linearize(const LWNURBSCURVE *curve, double tol,
 			diagonal = sqrt(width * width + height * height + depth * depth);
-		if (diagonal > tol * UINT32_MAX)
+		segments_required = diagonal / tol;
+		if (!isfinite(segments_required) || segments_required > max_segments)
 			lwerror("%s: max deviation is too small, got %.15g", __func__, tol);
 			return NULL;
-		num_segments = diagonal > 0.0 ? (uint32_t)ceil(diagonal / tol) : NURBS_MIN_LINEARIZE_SEGMENTS;
+		num_segments = diagonal > 0.0 ? (uint32_t)ceil(segments_required) : NURBS_MIN_LINEARIZE_SEGMENTS;
 		break;
 	case LW_LINEARIZE_TOLERANCE_TYPE_MAX_ANGLE:
-		if (tol < (2.0 * M_PI) / UINT32_MAX)
+		if (tol < (2.0 * M_PI) / max_segments)
 			lwerror("%s: max angle is too small, got %.15g", __func__, tol);
 			return NULL;
commit e994aef350aacc5f9558fc47a7fa9f6dfb5c759e
Date:   Tue Jul 7 12:13:30 2026 +0400
    liblwgeom: cap NURBS WKT knot multiplicity
    Closes https://github.com/postgis/postgis/pull/1140
index 22f579b9e..7b06489fe 100644
--- a/NEWS
+++ b/NEWS
@@ -24,6 +24,8 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
  - GH-1139, [topology] Preserve large edge ids from vertex-segment
+ - GH-1140, [liblwgeom] Cap NURBS WKT knot multiplicity
+          (Darafei Praliaskouski)
 PostGIS 3.7.0dev
diff --git a/liblwgeom/lwin_wkt_parse.c b/liblwgeom/lwin_wkt_parse.c
index d6e0c8b60..83fec3dec 100644
--- a/liblwgeom/lwin_wkt_parse.c
+++ b/liblwgeom/lwin_wkt_parse.c
@@ -189,6 +189,8 @@ int lwgeom_parse_wkt(LWGEOM_PARSER_RESULT *parser_result, const char *wktstr, in
 #define WKT_ERROR() { if ( global_parser_result.errcode != 0 ) { YYERROR; } }
+#define WKT_NURBS_MAX_KNOT_COUNT 10000
 struct WKT_NURBS_CONTROLPOINTS
 	POINTARRAY *points;
@@ -304,6 +306,7 @@ wkt_parser_knot_list_add_repeated(POINTARRAY *knots, double value, double multip
 	uint32_t repeat_count;
 	if (!isfinite(value) || !isfinite(multiplicity) || multiplicity < 1.0 ||
+	    multiplicity > WKT_NURBS_MAX_KNOT_COUNT ||
 	    fabs(multiplicity - round(multiplicity)) >= 1e-10)
 		if (knots)
@@ -313,6 +316,13 @@ wkt_parser_knot_list_add_repeated(POINTARRAY *knots, double value, double multip
 	repeat_count = (uint32_t)round(multiplicity);
+	if (knots && knots->npoints > WKT_NURBS_MAX_KNOT_COUNT - repeat_count)
+		ptarray_free(knots);
+		SET_PARSER_ERROR(PARSER_ERROR_OTHER);
+		return NULL;
 	for (uint32_t i = 0; i < repeat_count; i++)
 		POINT knot = wkt_parser_coord_2(value, 0);
@@ -324,7 +334,7 @@ wkt_parser_knot_list_add_repeated(POINTARRAY *knots, double value, double multip
-#line 328 "lwin_wkt_parse.c"
+#line 338 "lwin_wkt_parse.c"
 # ifndef YY_CAST
 #  ifdef __cplusplus
@@ -824,23 +834,23 @@ static const yytype_int8 yytranslate[] =
 /* YYRLINE[YYN] -- Source line where rule number YYN was defined.  */
 static const yytype_int16 yyrline[] =
-       0,   377,   377,   379,   383,   384,   385,   386,   387,   388,
-     389,   390,   391,   392,   393,   394,   395,   396,   397,   398,
-     401,   403,   405,   407,   411,   413,   417,   419,   421,   423,
-     427,   429,   431,   433,   435,   437,   441,   443,   445,   447,
-     451,   453,   455,   457,   461,   463,   465,   467,   471,   473,
-     477,   479,   483,   485,   487,   489,   493,   495,   499,   502,
-     504,   506,   508,   512,   514,   518,   519,   520,   521,   522,
-     525,   527,   531,   533,   537,   540,   543,   545,   547,   549,
-     553,   555,   557,   559,   561,   563,   565,   567,   571,   573,
-     575,   577,   581,   583,   585,   587,   589,   591,   593,   595,
-     597,   599,   603,   605,   607,   609,   613,   615,   619,   621,
-     623,   625,   629,   631,   633,   635,   639,   641,   645,   647,
-     651,   653,   655,   657,   661,   665,   667,   669,   671,   675,
-     677,   681,   683,   685,   689,   691,   693,   695,   699,   701,
-     705,   707,   709,   713,   715,   719,   728,   738,   740,   743,
-     745,   748,   750,   754,   756,   761,   766,   768,   773,   775,
-     780,   785,   793,   798
+       0,   387,   387,   389,   393,   394,   395,   396,   397,   398,
+     399,   400,   401,   402,   403,   404,   405,   406,   407,   408,
+     411,   413,   415,   417,   421,   423,   427,   429,   431,   433,
+     437,   439,   441,   443,   445,   447,   451,   453,   455,   457,
+     461,   463,   465,   467,   471,   473,   475,   477,   481,   483,
+     487,   489,   493,   495,   497,   499,   503,   505,   509,   512,
+     514,   516,   518,   522,   524,   528,   529,   530,   531,   532,
+     535,   537,   541,   543,   547,   550,   553,   555,   557,   559,
+     563,   565,   567,   569,   571,   573,   575,   577,   581,   583,
+     585,   587,   591,   593,   595,   597,   599,   601,   603,   605,
+     607,   609,   613,   615,   617,   619,   623,   625,   629,   631,
+     633,   635,   639,   641,   643,   645,   649,   651,   655,   657,
+     661,   663,   665,   667,   671,   675,   677,   679,   681,   685,
+     687,   691,   693,   695,   699,   701,   703,   705,   709,   711,
+     715,   717,   719,   723,   725,   729,   738,   748,   750,   753,
+     755,   758,   760,   764,   766,   771,   776,   778,   783,   785,
+     790,   795,   803,   808
 #endif
@@ -1471,261 +1481,261 @@ yydestruct (const char *yymsg,
   switch (yykind)
     case YYSYMBOL_geometry_no_srid: /* geometry_no_srid  */
-#line 353 "lwin_wkt_parse.y"
+#line 363 "lwin_wkt_parse.y"
             { lwgeom_free(((*yyvaluep).geometryvalue)); }
-#line 1477 "lwin_wkt_parse.c"
+#line 1487 "lwin_wkt_parse.c"
         break;
     case YYSYMBOL_geometrycollection: /* geometrycollection  */
-#line 354 "lwin_wkt_parse.y"
+#line 364 "lwin_wkt_parse.y"
-#line 1483 "lwin_wkt_parse.c"
+#line 1493 "lwin_wkt_parse.c"
         break;
     case YYSYMBOL_geometry_list: /* geometry_list  */
-#line 355 "lwin_wkt_parse.y"
+#line 365 "lwin_wkt_parse.y"
-#line 1489 "lwin_wkt_parse.c"
+#line 1499 "lwin_wkt_parse.c"
         break;
     case YYSYMBOL_multisurface: /* multisurface  */
-#line 362 "lwin_wkt_parse.y"
+#line 372 "lwin_wkt_parse.y"
-#line 1495 "lwin_wkt_parse.c"
+#line 1505 "lwin_wkt_parse.c"
         break;
     case YYSYMBOL_surface_list: /* surface_list  */
-#line 340 "lwin_wkt_parse.y"
+#line 350 "lwin_wkt_parse.y"
-#line 1501 "lwin_wkt_parse.c"
+#line 1511 "lwin_wkt_parse.c"
         break;
     case YYSYMBOL_tin: /* tin  */
-#line 370 "lwin_wkt_parse.y"
+#line 380 "lwin_wkt_parse.y"
-#line 1507 "lwin_wkt_parse.c"
+#line 1517 "lwin_wkt_parse.c"
         break;
     case YYSYMBOL_polyhedralsurface: /* polyhedralsurface  */
-#line 368 "lwin_wkt_parse.y"
+#line 378 "lwin_wkt_parse.y"
-#line 1513 "lwin_wkt_parse.c"
+#line 1523 "lwin_wkt_parse.c"
         break;
     case YYSYMBOL_multipolygon: /* multipolygon  */
-#line 361 "lwin_wkt_parse.y"
+#line 371 "lwin_wkt_parse.y"
-#line 1519 "lwin_wkt_parse.c"
+#line 1529 "lwin_wkt_parse.c"
         break;
     case YYSYMBOL_polygon_list: /* polygon_list  */
-#line 341 "lwin_wkt_parse.y"
+#line 351 "lwin_wkt_parse.y"
-#line 1525 "lwin_wkt_parse.c"
+#line 1535 "lwin_wkt_parse.c"
         break;
     case YYSYMBOL_patch_list: /* patch_list  */
-#line 342 "lwin_wkt_parse.y"
+#line 352 "lwin_wkt_parse.y"
-#line 1531 "lwin_wkt_parse.c"
+#line 1541 "lwin_wkt_parse.c"
         break;
     case YYSYMBOL_polygon: /* polygon  */
-#line 365 "lwin_wkt_parse.y"
+#line 375 "lwin_wkt_parse.y"
-#line 1537 "lwin_wkt_parse.c"
+#line 1547 "lwin_wkt_parse.c"
         break;
     case YYSYMBOL_polygon_untagged: /* polygon_untagged  */
-#line 367 "lwin_wkt_parse.y"
+#line 377 "lwin_wkt_parse.y"
-#line 1543 "lwin_wkt_parse.c"
+#line 1553 "lwin_wkt_parse.c"
         break;
     case YYSYMBOL_patch: /* patch  */
-#line 366 "lwin_wkt_parse.y"
+#line 376 "lwin_wkt_parse.y"
-#line 1549 "lwin_wkt_parse.c"
+#line 1559 "lwin_wkt_parse.c"
         break;
     case YYSYMBOL_curvepolygon: /* curvepolygon  */
-#line 351 "lwin_wkt_parse.y"
+#line 361 "lwin_wkt_parse.y"
-#line 1555 "lwin_wkt_parse.c"
+#line 1565 "lwin_wkt_parse.c"
         break;
     case YYSYMBOL_curvering_list: /* curvering_list  */
-#line 338 "lwin_wkt_parse.y"
+#line 348 "lwin_wkt_parse.y"
-#line 1561 "lwin_wkt_parse.c"
+#line 1571 "lwin_wkt_parse.c"
         break;
     case YYSYMBOL_curvering: /* curvering  */
-#line 352 "lwin_wkt_parse.y"
+#line 362 "lwin_wkt_parse.y"
-#line 1567 "lwin_wkt_parse.c"
+#line 1577 "lwin_wkt_parse.c"
         break;
     case YYSYMBOL_patchring_list: /* patchring_list  */
-#line 348 "lwin_wkt_parse.y"
+#line 358 "lwin_wkt_parse.y"
-#line 1573 "lwin_wkt_parse.c"
+#line 1583 "lwin_wkt_parse.c"
         break;
     case YYSYMBOL_ring_list: /* ring_list  */
-#line 347 "lwin_wkt_parse.y"
+#line 357 "lwin_wkt_parse.y"
-#line 1579 "lwin_wkt_parse.c"
+#line 1589 "lwin_wkt_parse.c"
         break;
     case YYSYMBOL_patchring: /* patchring  */
-#line 332 "lwin_wkt_parse.y"
+#line 342 "lwin_wkt_parse.y"
             { ptarray_free(((*yyvaluep).ptarrayvalue)); }
-#line 1585 "lwin_wkt_parse.c"
+#line 1595 "lwin_wkt_parse.c"
         break;
     case YYSYMBOL_ring: /* ring  */
-#line 331 "lwin_wkt_parse.y"
+#line 341 "lwin_wkt_parse.y"
-#line 1591 "lwin_wkt_parse.c"
+#line 1601 "lwin_wkt_parse.c"
         break;
     case YYSYMBOL_compoundcurve: /* compoundcurve  */
-#line 350 "lwin_wkt_parse.y"
+#line 360 "lwin_wkt_parse.y"
-#line 1597 "lwin_wkt_parse.c"
+#line 1607 "lwin_wkt_parse.c"
         break;
     case YYSYMBOL_compound_list: /* compound_list  */
-#line 346 "lwin_wkt_parse.y"
+#line 356 "lwin_wkt_parse.y"
-#line 1603 "lwin_wkt_parse.c"
+#line 1613 "lwin_wkt_parse.c"
         break;
     case YYSYMBOL_multicurve: /* multicurve  */
-#line 358 "lwin_wkt_parse.y"
+#line 368 "lwin_wkt_parse.y"
-#line 1609 "lwin_wkt_parse.c"
+#line 1619 "lwin_wkt_parse.c"
         break;
     case YYSYMBOL_curve_list: /* curve_list  */
-#line 345 "lwin_wkt_parse.y"
+#line 355 "lwin_wkt_parse.y"
-#line 1615 "lwin_wkt_parse.c"
+#line 1625 "lwin_wkt_parse.c"
         break;
     case YYSYMBOL_multilinestring: /* multilinestring  */
-#line 359 "lwin_wkt_parse.y"
+#line 369 "lwin_wkt_parse.y"
-#line 1621 "lwin_wkt_parse.c"
+#line 1631 "lwin_wkt_parse.c"
         break;
     case YYSYMBOL_linestring_list: /* linestring_list  */
-#line 344 "lwin_wkt_parse.y"
+#line 354 "lwin_wkt_parse.y"
-#line 1627 "lwin_wkt_parse.c"
+#line 1637 "lwin_wkt_parse.c"
         break;
     case YYSYMBOL_circularstring: /* circularstring  */
-#line 349 "lwin_wkt_parse.y"
+#line 359 "lwin_wkt_parse.y"
-#line 1633 "lwin_wkt_parse.c"
+#line 1643 "lwin_wkt_parse.c"
         break;
     case YYSYMBOL_linestring: /* linestring  */
-#line 356 "lwin_wkt_parse.y"
+#line 366 "lwin_wkt_parse.y"
-#line 1639 "lwin_wkt_parse.c"
+#line 1649 "lwin_wkt_parse.c"
         break;
     case YYSYMBOL_linestring_untagged: /* linestring_untagged  */
-#line 357 "lwin_wkt_parse.y"
+#line 367 "lwin_wkt_parse.y"
-#line 1645 "lwin_wkt_parse.c"
+#line 1655 "lwin_wkt_parse.c"
         break;
     case YYSYMBOL_triangle_list: /* triangle_list  */
-#line 339 "lwin_wkt_parse.y"
+#line 349 "lwin_wkt_parse.y"
-#line 1651 "lwin_wkt_parse.c"
+#line 1661 "lwin_wkt_parse.c"
         break;
     case YYSYMBOL_triangle: /* triangle  */
-#line 371 "lwin_wkt_parse.y"
+#line 381 "lwin_wkt_parse.y"
-#line 1657 "lwin_wkt_parse.c"
+#line 1667 "lwin_wkt_parse.c"
         break;
     case YYSYMBOL_triangle_untagged: /* triangle_untagged  */
-#line 372 "lwin_wkt_parse.y"
+#line 382 "lwin_wkt_parse.y"
-#line 1663 "lwin_wkt_parse.c"
+#line 1673 "lwin_wkt_parse.c"
         break;
     case YYSYMBOL_multipoint: /* multipoint  */
-#line 360 "lwin_wkt_parse.y"
+#line 370 "lwin_wkt_parse.y"
-#line 1669 "lwin_wkt_parse.c"
+#line 1679 "lwin_wkt_parse.c"
         break;
     case YYSYMBOL_point_list: /* point_list  */
-#line 343 "lwin_wkt_parse.y"
+#line 353 "lwin_wkt_parse.y"
-#line 1675 "lwin_wkt_parse.c"
+#line 1685 "lwin_wkt_parse.c"
         break;
     case YYSYMBOL_point_untagged: /* point_untagged  */
-#line 364 "lwin_wkt_parse.y"
+#line 374 "lwin_wkt_parse.y"
-#line 1681 "lwin_wkt_parse.c"
+#line 1691 "lwin_wkt_parse.c"
         break;
     case YYSYMBOL_point: /* point  */
-#line 363 "lwin_wkt_parse.y"
+#line 373 "lwin_wkt_parse.y"
-#line 1687 "lwin_wkt_parse.c"
+#line 1697 "lwin_wkt_parse.c"
         break;
     case YYSYMBOL_ptarray: /* ptarray  */
-#line 330 "lwin_wkt_parse.y"
+#line 340 "lwin_wkt_parse.y"
-#line 1693 "lwin_wkt_parse.c"
+#line 1703 "lwin_wkt_parse.c"
         break;
     case YYSYMBOL_nurbscurve: /* nurbscurve  */
-#line 369 "lwin_wkt_parse.y"
+#line 379 "lwin_wkt_parse.y"
-#line 1699 "lwin_wkt_parse.c"
+#line 1709 "lwin_wkt_parse.c"
         break;
     case YYSYMBOL_iso_controlpoint: /* iso_controlpoint  */
-#line 336 "lwin_wkt_parse.y"
+#line 346 "lwin_wkt_parse.y"
             { wkt_parser_nurbs_controlpoints_free(((*yyvaluep).nurbscontrolpointsvalue)); }
-#line 1705 "lwin_wkt_parse.c"
+#line 1715 "lwin_wkt_parse.c"
         break;
     case YYSYMBOL_iso_controlpoint_list: /* iso_controlpoint_list  */
-#line 337 "lwin_wkt_parse.y"
+#line 347 "lwin_wkt_parse.y"
-#line 1711 "lwin_wkt_parse.c"
+#line 1721 "lwin_wkt_parse.c"
         break;
     case YYSYMBOL_iso_knot_list: /* iso_knot_list  */
-#line 335 "lwin_wkt_parse.y"
+#line 345 "lwin_wkt_parse.y"
-#line 1717 "lwin_wkt_parse.c"
+#line 1727 "lwin_wkt_parse.c"
         break;
     case YYSYMBOL_weight_list: /* weight_list  */
-#line 333 "lwin_wkt_parse.y"
+#line 343 "lwin_wkt_parse.y"
-#line 1723 "lwin_wkt_parse.c"
+#line 1733 "lwin_wkt_parse.c"
         break;
     case YYSYMBOL_knot_list: /* knot_list  */
-#line 334 "lwin_wkt_parse.y"
+#line 344 "lwin_wkt_parse.y"
-#line 1729 "lwin_wkt_parse.c"
+#line 1739 "lwin_wkt_parse.c"
         break;
       default:
@@ -2018,865 +2028,865 @@ yyreduce:
   switch (yyn)
   case 2: /* geometry: geometry_no_srid  */
-#line 378 "lwin_wkt_parse.y"
+#line 388 "lwin_wkt_parse.y"
                 { wkt_parser_geometry_new((yyvsp[0].geometryvalue), SRID_UNKNOWN); WKT_ERROR(); }
-#line 2024 "lwin_wkt_parse.c"
+#line 2034 "lwin_wkt_parse.c"
     break;
   case 3: /* geometry: SRID_TOK SEMICOLON_TOK geometry_no_srid  */
-#line 380 "lwin_wkt_parse.y"
+#line 390 "lwin_wkt_parse.y"
                 { wkt_parser_geometry_new((yyvsp[0].geometryvalue), (yyvsp[-2].integervalue)); WKT_ERROR(); }
-#line 2030 "lwin_wkt_parse.c"
+#line 2040 "lwin_wkt_parse.c"
     break;
   case 4: /* geometry_no_srid: point  */
-#line 383 "lwin_wkt_parse.y"
+#line 393 "lwin_wkt_parse.y"
               { (yyval.geometryvalue) = (yyvsp[0].geometryvalue); }
-#line 2036 "lwin_wkt_parse.c"
+#line 2046 "lwin_wkt_parse.c"
     break;
   case 5: /* geometry_no_srid: linestring  */
-#line 384 "lwin_wkt_parse.y"
+#line 394 "lwin_wkt_parse.y"
-#line 2042 "lwin_wkt_parse.c"
+#line 2052 "lwin_wkt_parse.c"
     break;
   case 6: /* geometry_no_srid: circularstring  */
-#line 385 "lwin_wkt_parse.y"
+#line 395 "lwin_wkt_parse.y"
-#line 2048 "lwin_wkt_parse.c"
+#line 2058 "lwin_wkt_parse.c"
     break;
   case 7: /* geometry_no_srid: compoundcurve  */
-#line 386 "lwin_wkt_parse.y"
+#line 396 "lwin_wkt_parse.y"
-#line 2054 "lwin_wkt_parse.c"
+#line 2064 "lwin_wkt_parse.c"
     break;
   case 8: /* geometry_no_srid: polygon  */
-#line 387 "lwin_wkt_parse.y"
+#line 397 "lwin_wkt_parse.y"
-#line 2060 "lwin_wkt_parse.c"
+#line 2070 "lwin_wkt_parse.c"
     break;
   case 9: /* geometry_no_srid: curvepolygon  */
-#line 388 "lwin_wkt_parse.y"
+#line 398 "lwin_wkt_parse.y"
-#line 2066 "lwin_wkt_parse.c"
+#line 2076 "lwin_wkt_parse.c"
     break;
   case 10: /* geometry_no_srid: multipoint  */
-#line 389 "lwin_wkt_parse.y"
+#line 399 "lwin_wkt_parse.y"
-#line 2072 "lwin_wkt_parse.c"
+#line 2082 "lwin_wkt_parse.c"
     break;
   case 11: /* geometry_no_srid: multilinestring  */
-#line 390 "lwin_wkt_parse.y"
+#line 400 "lwin_wkt_parse.y"
-#line 2078 "lwin_wkt_parse.c"
+#line 2088 "lwin_wkt_parse.c"
     break;
   case 12: /* geometry_no_srid: multipolygon  */
-#line 391 "lwin_wkt_parse.y"
+#line 401 "lwin_wkt_parse.y"
-#line 2084 "lwin_wkt_parse.c"
+#line 2094 "lwin_wkt_parse.c"
     break;
   case 13: /* geometry_no_srid: multisurface  */
-#line 392 "lwin_wkt_parse.y"
+#line 402 "lwin_wkt_parse.y"
-#line 2090 "lwin_wkt_parse.c"
+#line 2100 "lwin_wkt_parse.c"
     break;
   case 14: /* geometry_no_srid: multicurve  */
-#line 393 "lwin_wkt_parse.y"
+#line 403 "lwin_wkt_parse.y"
-#line 2096 "lwin_wkt_parse.c"
+#line 2106 "lwin_wkt_parse.c"
     break;
   case 15: /* geometry_no_srid: tin  */
-#line 394 "lwin_wkt_parse.y"
+#line 404 "lwin_wkt_parse.y"
-#line 2102 "lwin_wkt_parse.c"
+#line 2112 "lwin_wkt_parse.c"
     break;
   case 16: /* geometry_no_srid: polyhedralsurface  */
-#line 395 "lwin_wkt_parse.y"
+#line 405 "lwin_wkt_parse.y"
-#line 2108 "lwin_wkt_parse.c"
+#line 2118 "lwin_wkt_parse.c"
     break;
   case 17: /* geometry_no_srid: triangle  */
-#line 396 "lwin_wkt_parse.y"
+#line 406 "lwin_wkt_parse.y"
-#line 2114 "lwin_wkt_parse.c"
+#line 2124 "lwin_wkt_parse.c"
     break;
   case 18: /* geometry_no_srid: nurbscurve  */
-#line 397 "lwin_wkt_parse.y"
+#line 407 "lwin_wkt_parse.y"
-#line 2120 "lwin_wkt_parse.c"
+#line 2130 "lwin_wkt_parse.c"
     break;
   case 19: /* geometry_no_srid: geometrycollection  */
-#line 398 "lwin_wkt_parse.y"
+#line 408 "lwin_wkt_parse.y"
-#line 2126 "lwin_wkt_parse.c"
+#line 2136 "lwin_wkt_parse.c"
     break;
   case 20: /* geometrycollection: COLLECTION_TOK LBRACKET_TOK geometry_list RBRACKET_TOK  */
-#line 402 "lwin_wkt_parse.y"
+#line 412 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_collection_finalize(COLLECTIONTYPE, (yyvsp[-1].geometryvalue), NULL); WKT_ERROR(); }
-#line 2132 "lwin_wkt_parse.c"
+#line 2142 "lwin_wkt_parse.c"
     break;
   case 21: /* geometrycollection: COLLECTION_TOK DIMENSIONALITY_TOK LBRACKET_TOK geometry_list RBRACKET_TOK  */
-#line 404 "lwin_wkt_parse.y"
+#line 414 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_collection_finalize(COLLECTIONTYPE, (yyvsp[-1].geometryvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2138 "lwin_wkt_parse.c"
+#line 2148 "lwin_wkt_parse.c"
     break;
   case 22: /* geometrycollection: COLLECTION_TOK DIMENSIONALITY_TOK EMPTY_TOK  */
-#line 406 "lwin_wkt_parse.y"
+#line 416 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_collection_finalize(COLLECTIONTYPE, NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2144 "lwin_wkt_parse.c"
+#line 2154 "lwin_wkt_parse.c"
     break;
   case 23: /* geometrycollection: COLLECTION_TOK EMPTY_TOK  */
-#line 408 "lwin_wkt_parse.y"
+#line 418 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_collection_finalize(COLLECTIONTYPE, NULL, NULL); WKT_ERROR(); }
-#line 2150 "lwin_wkt_parse.c"
+#line 2160 "lwin_wkt_parse.c"
     break;
   case 24: /* geometry_list: geometry_list COMMA_TOK geometry_no_srid  */
-#line 412 "lwin_wkt_parse.y"
+#line 422 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_collection_add_geom((yyvsp[-2].geometryvalue),(yyvsp[0].geometryvalue)); WKT_ERROR(); }
-#line 2156 "lwin_wkt_parse.c"
+#line 2166 "lwin_wkt_parse.c"
     break;
   case 25: /* geometry_list: geometry_no_srid  */
-#line 414 "lwin_wkt_parse.y"
+#line 424 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_collection_new((yyvsp[0].geometryvalue)); WKT_ERROR(); }
-#line 2162 "lwin_wkt_parse.c"
+#line 2172 "lwin_wkt_parse.c"
     break;
   case 26: /* multisurface: MSURFACE_TOK LBRACKET_TOK surface_list RBRACKET_TOK  */
-#line 418 "lwin_wkt_parse.y"
+#line 428 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTISURFACETYPE, (yyvsp[-1].geometryvalue), NULL); WKT_ERROR(); }
-#line 2168 "lwin_wkt_parse.c"
+#line 2178 "lwin_wkt_parse.c"
     break;
   case 27: /* multisurface: MSURFACE_TOK DIMENSIONALITY_TOK LBRACKET_TOK surface_list RBRACKET_TOK  */
-#line 420 "lwin_wkt_parse.y"
+#line 430 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTISURFACETYPE, (yyvsp[-1].geometryvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2174 "lwin_wkt_parse.c"
+#line 2184 "lwin_wkt_parse.c"
     break;
   case 28: /* multisurface: MSURFACE_TOK DIMENSIONALITY_TOK EMPTY_TOK  */
-#line 422 "lwin_wkt_parse.y"
+#line 432 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTISURFACETYPE, NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2180 "lwin_wkt_parse.c"
+#line 2190 "lwin_wkt_parse.c"
     break;
   case 29: /* multisurface: MSURFACE_TOK EMPTY_TOK  */
-#line 424 "lwin_wkt_parse.y"
+#line 434 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTISURFACETYPE, NULL, NULL); WKT_ERROR(); }
-#line 2186 "lwin_wkt_parse.c"
+#line 2196 "lwin_wkt_parse.c"
     break;
   case 30: /* surface_list: surface_list COMMA_TOK polygon  */
-#line 428 "lwin_wkt_parse.y"
+#line 438 "lwin_wkt_parse.y"
-#line 2192 "lwin_wkt_parse.c"
+#line 2202 "lwin_wkt_parse.c"
     break;
   case 31: /* surface_list: surface_list COMMA_TOK curvepolygon  */
-#line 430 "lwin_wkt_parse.y"
+#line 440 "lwin_wkt_parse.y"
-#line 2198 "lwin_wkt_parse.c"
+#line 2208 "lwin_wkt_parse.c"
     break;
   case 32: /* surface_list: surface_list COMMA_TOK polygon_untagged  */
-#line 432 "lwin_wkt_parse.y"
+#line 442 "lwin_wkt_parse.y"
-#line 2204 "lwin_wkt_parse.c"
+#line 2214 "lwin_wkt_parse.c"
     break;
   case 33: /* surface_list: polygon  */
-#line 434 "lwin_wkt_parse.y"
+#line 444 "lwin_wkt_parse.y"
-#line 2210 "lwin_wkt_parse.c"
+#line 2220 "lwin_wkt_parse.c"
     break;
   case 34: /* surface_list: curvepolygon  */
-#line 436 "lwin_wkt_parse.y"
+#line 446 "lwin_wkt_parse.y"
-#line 2216 "lwin_wkt_parse.c"
+#line 2226 "lwin_wkt_parse.c"
     break;
   case 35: /* surface_list: polygon_untagged  */
-#line 438 "lwin_wkt_parse.y"
+#line 448 "lwin_wkt_parse.y"
-#line 2222 "lwin_wkt_parse.c"
+#line 2232 "lwin_wkt_parse.c"
     break;
   case 36: /* tin: TIN_TOK LBRACKET_TOK triangle_list RBRACKET_TOK  */
-#line 442 "lwin_wkt_parse.y"
+#line 452 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_collection_finalize(TINTYPE, (yyvsp[-1].geometryvalue), NULL); WKT_ERROR(); }
-#line 2228 "lwin_wkt_parse.c"
+#line 2238 "lwin_wkt_parse.c"
     break;
   case 37: /* tin: TIN_TOK DIMENSIONALITY_TOK LBRACKET_TOK triangle_list RBRACKET_TOK  */
-#line 444 "lwin_wkt_parse.y"
+#line 454 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_collection_finalize(TINTYPE, (yyvsp[-1].geometryvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2234 "lwin_wkt_parse.c"
+#line 2244 "lwin_wkt_parse.c"
     break;
   case 38: /* tin: TIN_TOK DIMENSIONALITY_TOK EMPTY_TOK  */
-#line 446 "lwin_wkt_parse.y"
+#line 456 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_collection_finalize(TINTYPE, NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2240 "lwin_wkt_parse.c"
+#line 2250 "lwin_wkt_parse.c"
     break;
   case 39: /* tin: TIN_TOK EMPTY_TOK  */
-#line 448 "lwin_wkt_parse.y"
+#line 458 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_collection_finalize(TINTYPE, NULL, NULL); WKT_ERROR(); }
-#line 2246 "lwin_wkt_parse.c"
+#line 2256 "lwin_wkt_parse.c"
     break;
   case 40: /* polyhedralsurface: POLYHEDRALSURFACE_TOK LBRACKET_TOK patch_list RBRACKET_TOK  */
-#line 452 "lwin_wkt_parse.y"
+#line 462 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_collection_finalize(POLYHEDRALSURFACETYPE, (yyvsp[-1].geometryvalue), NULL); WKT_ERROR(); }
-#line 2252 "lwin_wkt_parse.c"
+#line 2262 "lwin_wkt_parse.c"
     break;
   case 41: /* polyhedralsurface: POLYHEDRALSURFACE_TOK DIMENSIONALITY_TOK LBRACKET_TOK patch_list RBRACKET_TOK  */
-#line 454 "lwin_wkt_parse.y"
+#line 464 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_collection_finalize(POLYHEDRALSURFACETYPE, (yyvsp[-1].geometryvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2258 "lwin_wkt_parse.c"
+#line 2268 "lwin_wkt_parse.c"
     break;
   case 42: /* polyhedralsurface: POLYHEDRALSURFACE_TOK DIMENSIONALITY_TOK EMPTY_TOK  */
-#line 456 "lwin_wkt_parse.y"
+#line 466 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_collection_finalize(POLYHEDRALSURFACETYPE, NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2264 "lwin_wkt_parse.c"
+#line 2274 "lwin_wkt_parse.c"
     break;
   case 43: /* polyhedralsurface: POLYHEDRALSURFACE_TOK EMPTY_TOK  */
-#line 458 "lwin_wkt_parse.y"
+#line 468 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_collection_finalize(POLYHEDRALSURFACETYPE, NULL, NULL); WKT_ERROR(); }
-#line 2270 "lwin_wkt_parse.c"
+#line 2280 "lwin_wkt_parse.c"
     break;
   case 44: /* multipolygon: MPOLYGON_TOK LBRACKET_TOK polygon_list RBRACKET_TOK  */
-#line 462 "lwin_wkt_parse.y"
+#line 472 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTIPOLYGONTYPE, (yyvsp[-1].geometryvalue), NULL); WKT_ERROR(); }
-#line 2276 "lwin_wkt_parse.c"
+#line 2286 "lwin_wkt_parse.c"
     break;
   case 45: /* multipolygon: MPOLYGON_TOK DIMENSIONALITY_TOK LBRACKET_TOK polygon_list RBRACKET_TOK  */
-#line 464 "lwin_wkt_parse.y"
+#line 474 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTIPOLYGONTYPE, (yyvsp[-1].geometryvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2282 "lwin_wkt_parse.c"
+#line 2292 "lwin_wkt_parse.c"
     break;
   case 46: /* multipolygon: MPOLYGON_TOK DIMENSIONALITY_TOK EMPTY_TOK  */
-#line 466 "lwin_wkt_parse.y"
+#line 476 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTIPOLYGONTYPE, NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2288 "lwin_wkt_parse.c"
+#line 2298 "lwin_wkt_parse.c"
     break;
   case 47: /* multipolygon: MPOLYGON_TOK EMPTY_TOK  */
-#line 468 "lwin_wkt_parse.y"
+#line 478 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTIPOLYGONTYPE, NULL, NULL); WKT_ERROR(); }
-#line 2294 "lwin_wkt_parse.c"
+#line 2304 "lwin_wkt_parse.c"
     break;
   case 48: /* polygon_list: polygon_list COMMA_TOK polygon_untagged  */
-#line 472 "lwin_wkt_parse.y"
+#line 482 "lwin_wkt_parse.y"
-#line 2300 "lwin_wkt_parse.c"
+#line 2310 "lwin_wkt_parse.c"
     break;
   case 49: /* polygon_list: polygon_untagged  */
-#line 474 "lwin_wkt_parse.y"
+#line 484 "lwin_wkt_parse.y"
-#line 2306 "lwin_wkt_parse.c"
+#line 2316 "lwin_wkt_parse.c"
     break;
   case 50: /* patch_list: patch_list COMMA_TOK patch  */
-#line 478 "lwin_wkt_parse.y"
+#line 488 "lwin_wkt_parse.y"
-#line 2312 "lwin_wkt_parse.c"
+#line 2322 "lwin_wkt_parse.c"
     break;
   case 51: /* patch_list: patch  */
-#line 480 "lwin_wkt_parse.y"
+#line 490 "lwin_wkt_parse.y"
-#line 2318 "lwin_wkt_parse.c"
+#line 2328 "lwin_wkt_parse.c"
     break;
   case 52: /* polygon: POLYGON_TOK LBRACKET_TOK ring_list RBRACKET_TOK  */
-#line 484 "lwin_wkt_parse.y"
+#line 494 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_polygon_finalize((yyvsp[-1].geometryvalue), NULL); WKT_ERROR(); }
-#line 2324 "lwin_wkt_parse.c"
+#line 2334 "lwin_wkt_parse.c"
     break;
   case 53: /* polygon: POLYGON_TOK DIMENSIONALITY_TOK LBRACKET_TOK ring_list RBRACKET_TOK  */
-#line 486 "lwin_wkt_parse.y"
+#line 496 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_polygon_finalize((yyvsp[-1].geometryvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2330 "lwin_wkt_parse.c"
+#line 2340 "lwin_wkt_parse.c"
     break;
   case 54: /* polygon: POLYGON_TOK DIMENSIONALITY_TOK EMPTY_TOK  */
-#line 488 "lwin_wkt_parse.y"
+#line 498 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_polygon_finalize(NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2336 "lwin_wkt_parse.c"
+#line 2346 "lwin_wkt_parse.c"
     break;
   case 55: /* polygon: POLYGON_TOK EMPTY_TOK  */
-#line 490 "lwin_wkt_parse.y"
+#line 500 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_polygon_finalize(NULL, NULL); WKT_ERROR(); }
-#line 2342 "lwin_wkt_parse.c"
+#line 2352 "lwin_wkt_parse.c"
     break;
   case 56: /* polygon_untagged: LBRACKET_TOK ring_list RBRACKET_TOK  */
-#line 494 "lwin_wkt_parse.y"
+#line 504 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = (yyvsp[-1].geometryvalue); }
-#line 2348 "lwin_wkt_parse.c"
+#line 2358 "lwin_wkt_parse.c"
     break;
   case 57: /* polygon_untagged: EMPTY_TOK  */
-#line 496 "lwin_wkt_parse.y"
+#line 506 "lwin_wkt_parse.y"
-#line 2354 "lwin_wkt_parse.c"
+#line 2364 "lwin_wkt_parse.c"
     break;
   case 58: /* patch: LBRACKET_TOK patchring_list RBRACKET_TOK  */
-#line 499 "lwin_wkt_parse.y"
+#line 509 "lwin_wkt_parse.y"
-#line 2360 "lwin_wkt_parse.c"
+#line 2370 "lwin_wkt_parse.c"
     break;
   case 59: /* curvepolygon: CURVEPOLYGON_TOK LBRACKET_TOK curvering_list RBRACKET_TOK  */
-#line 503 "lwin_wkt_parse.y"
+#line 513 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_curvepolygon_finalize((yyvsp[-1].geometryvalue), NULL); WKT_ERROR(); }
-#line 2366 "lwin_wkt_parse.c"
+#line 2376 "lwin_wkt_parse.c"
     break;
   case 60: /* curvepolygon: CURVEPOLYGON_TOK DIMENSIONALITY_TOK LBRACKET_TOK curvering_list RBRACKET_TOK  */
-#line 505 "lwin_wkt_parse.y"
+#line 515 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_curvepolygon_finalize((yyvsp[-1].geometryvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2372 "lwin_wkt_parse.c"
+#line 2382 "lwin_wkt_parse.c"
     break;
   case 61: /* curvepolygon: CURVEPOLYGON_TOK DIMENSIONALITY_TOK EMPTY_TOK  */
-#line 507 "lwin_wkt_parse.y"
+#line 517 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_curvepolygon_finalize(NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2378 "lwin_wkt_parse.c"
+#line 2388 "lwin_wkt_parse.c"
     break;
   case 62: /* curvepolygon: CURVEPOLYGON_TOK EMPTY_TOK  */
-#line 509 "lwin_wkt_parse.y"
+#line 519 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_curvepolygon_finalize(NULL, NULL); WKT_ERROR(); }
-#line 2384 "lwin_wkt_parse.c"
+#line 2394 "lwin_wkt_parse.c"
     break;
   case 63: /* curvering_list: curvering_list COMMA_TOK curvering  */
-#line 513 "lwin_wkt_parse.y"
+#line 523 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_curvepolygon_add_ring((yyvsp[-2].geometryvalue),(yyvsp[0].geometryvalue)); WKT_ERROR(); }
-#line 2390 "lwin_wkt_parse.c"
+#line 2400 "lwin_wkt_parse.c"
     break;
   case 64: /* curvering_list: curvering  */
-#line 515 "lwin_wkt_parse.y"
+#line 525 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_curvepolygon_new((yyvsp[0].geometryvalue)); WKT_ERROR(); }
-#line 2396 "lwin_wkt_parse.c"
+#line 2406 "lwin_wkt_parse.c"
     break;
   case 65: /* curvering: linestring_untagged  */
-#line 518 "lwin_wkt_parse.y"
+#line 528 "lwin_wkt_parse.y"
-#line 2402 "lwin_wkt_parse.c"
+#line 2412 "lwin_wkt_parse.c"
     break;
   case 66: /* curvering: linestring  */
-#line 519 "lwin_wkt_parse.y"
+#line 529 "lwin_wkt_parse.y"
-#line 2408 "lwin_wkt_parse.c"
+#line 2418 "lwin_wkt_parse.c"
     break;
   case 67: /* curvering: compoundcurve  */
-#line 520 "lwin_wkt_parse.y"
+#line 530 "lwin_wkt_parse.y"
-#line 2414 "lwin_wkt_parse.c"
+#line 2424 "lwin_wkt_parse.c"
     break;
   case 68: /* curvering: nurbscurve  */
-#line 521 "lwin_wkt_parse.y"
+#line 531 "lwin_wkt_parse.y"
-#line 2420 "lwin_wkt_parse.c"
+#line 2430 "lwin_wkt_parse.c"
     break;
   case 69: /* curvering: circularstring  */
-#line 522 "lwin_wkt_parse.y"
+#line 532 "lwin_wkt_parse.y"
-#line 2426 "lwin_wkt_parse.c"
+#line 2436 "lwin_wkt_parse.c"
     break;
   case 70: /* patchring_list: patchring_list COMMA_TOK patchring  */
-#line 526 "lwin_wkt_parse.y"
+#line 536 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_polygon_add_ring((yyvsp[-2].geometryvalue),(yyvsp[0].ptarrayvalue),'Z'); WKT_ERROR(); }
-#line 2432 "lwin_wkt_parse.c"
+#line 2442 "lwin_wkt_parse.c"
     break;
   case 71: /* patchring_list: patchring  */
-#line 528 "lwin_wkt_parse.y"
+#line 538 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_polygon_new((yyvsp[0].ptarrayvalue),'Z'); WKT_ERROR(); }
-#line 2438 "lwin_wkt_parse.c"
+#line 2448 "lwin_wkt_parse.c"
     break;
   case 72: /* ring_list: ring_list COMMA_TOK ring  */
-#line 532 "lwin_wkt_parse.y"
+#line 542 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_polygon_add_ring((yyvsp[-2].geometryvalue),(yyvsp[0].ptarrayvalue),'2'); WKT_ERROR(); }
-#line 2444 "lwin_wkt_parse.c"
+#line 2454 "lwin_wkt_parse.c"
     break;
   case 73: /* ring_list: ring  */
-#line 534 "lwin_wkt_parse.y"
+#line 544 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_polygon_new((yyvsp[0].ptarrayvalue),'2'); WKT_ERROR(); }
-#line 2450 "lwin_wkt_parse.c"
+#line 2460 "lwin_wkt_parse.c"
     break;
   case 74: /* patchring: LBRACKET_TOK ptarray RBRACKET_TOK  */
-#line 537 "lwin_wkt_parse.y"
+#line 547 "lwin_wkt_parse.y"
                                           { (yyval.ptarrayvalue) = (yyvsp[-1].ptarrayvalue); }
-#line 2456 "lwin_wkt_parse.c"
+#line 2466 "lwin_wkt_parse.c"
     break;
   case 75: /* ring: LBRACKET_TOK ptarray RBRACKET_TOK  */
-#line 540 "lwin_wkt_parse.y"
+#line 550 "lwin_wkt_parse.y"
-#line 2462 "lwin_wkt_parse.c"
+#line 2472 "lwin_wkt_parse.c"
     break;
   case 76: /* compoundcurve: COMPOUNDCURVE_TOK LBRACKET_TOK compound_list RBRACKET_TOK  */
-#line 544 "lwin_wkt_parse.y"
+#line 554 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_compound_finalize((yyvsp[-1].geometryvalue), NULL); WKT_ERROR(); }
-#line 2468 "lwin_wkt_parse.c"
+#line 2478 "lwin_wkt_parse.c"
     break;
   case 77: /* compoundcurve: COMPOUNDCURVE_TOK DIMENSIONALITY_TOK LBRACKET_TOK compound_list RBRACKET_TOK  */
-#line 546 "lwin_wkt_parse.y"
+#line 556 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_compound_finalize((yyvsp[-1].geometryvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2474 "lwin_wkt_parse.c"
+#line 2484 "lwin_wkt_parse.c"
     break;
   case 78: /* compoundcurve: COMPOUNDCURVE_TOK DIMENSIONALITY_TOK EMPTY_TOK  */
-#line 548 "lwin_wkt_parse.y"
+#line 558 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_compound_finalize(NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2480 "lwin_wkt_parse.c"
+#line 2490 "lwin_wkt_parse.c"
     break;
   case 79: /* compoundcurve: COMPOUNDCURVE_TOK EMPTY_TOK  */
-#line 550 "lwin_wkt_parse.y"
+#line 560 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_compound_finalize(NULL, NULL); WKT_ERROR(); }
-#line 2486 "lwin_wkt_parse.c"
+#line 2496 "lwin_wkt_parse.c"
     break;
   case 80: /* compound_list: compound_list COMMA_TOK circularstring  */
-#line 554 "lwin_wkt_parse.y"
+#line 564 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_compound_add_geom((yyvsp[-2].geometryvalue),(yyvsp[0].geometryvalue)); WKT_ERROR(); }
-#line 2492 "lwin_wkt_parse.c"
+#line 2502 "lwin_wkt_parse.c"
     break;
   case 81: /* compound_list: compound_list COMMA_TOK nurbscurve  */
-#line 556 "lwin_wkt_parse.y"
+#line 566 "lwin_wkt_parse.y"
-#line 2498 "lwin_wkt_parse.c"
+#line 2508 "lwin_wkt_parse.c"
     break;
   case 82: /* compound_list: compound_list COMMA_TOK linestring  */
-#line 558 "lwin_wkt_parse.y"
+#line 568 "lwin_wkt_parse.y"
-#line 2504 "lwin_wkt_parse.c"
+#line 2514 "lwin_wkt_parse.c"
     break;
   case 83: /* compound_list: compound_list COMMA_TOK linestring_untagged  */
-#line 560 "lwin_wkt_parse.y"
+#line 570 "lwin_wkt_parse.y"
-#line 2510 "lwin_wkt_parse.c"
+#line 2520 "lwin_wkt_parse.c"
     break;
   case 84: /* compound_list: circularstring  */
-#line 562 "lwin_wkt_parse.y"
+#line 572 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_compound_new((yyvsp[0].geometryvalue)); WKT_ERROR(); }
-#line 2516 "lwin_wkt_parse.c"
+#line 2526 "lwin_wkt_parse.c"
     break;
   case 85: /* compound_list: nurbscurve  */
-#line 564 "lwin_wkt_parse.y"
+#line 574 "lwin_wkt_parse.y"
-#line 2522 "lwin_wkt_parse.c"
+#line 2532 "lwin_wkt_parse.c"
     break;
   case 86: /* compound_list: linestring  */
-#line 566 "lwin_wkt_parse.y"
+#line 576 "lwin_wkt_parse.y"
-#line 2528 "lwin_wkt_parse.c"
+#line 2538 "lwin_wkt_parse.c"
     break;
   case 87: /* compound_list: linestring_untagged  */
-#line 568 "lwin_wkt_parse.y"
+#line 578 "lwin_wkt_parse.y"
-#line 2534 "lwin_wkt_parse.c"
+#line 2544 "lwin_wkt_parse.c"
     break;
   case 88: /* multicurve: MCURVE_TOK LBRACKET_TOK curve_list RBRACKET_TOK  */
-#line 572 "lwin_wkt_parse.y"
+#line 582 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTICURVETYPE, (yyvsp[-1].geometryvalue), NULL); WKT_ERROR(); }
-#line 2540 "lwin_wkt_parse.c"
+#line 2550 "lwin_wkt_parse.c"
     break;
   case 89: /* multicurve: MCURVE_TOK DIMENSIONALITY_TOK LBRACKET_TOK curve_list RBRACKET_TOK  */
-#line 574 "lwin_wkt_parse.y"
+#line 584 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTICURVETYPE, (yyvsp[-1].geometryvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2546 "lwin_wkt_parse.c"
+#line 2556 "lwin_wkt_parse.c"
     break;
   case 90: /* multicurve: MCURVE_TOK DIMENSIONALITY_TOK EMPTY_TOK  */
-#line 576 "lwin_wkt_parse.y"
+#line 586 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTICURVETYPE, NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2552 "lwin_wkt_parse.c"
+#line 2562 "lwin_wkt_parse.c"
     break;
   case 91: /* multicurve: MCURVE_TOK EMPTY_TOK  */
-#line 578 "lwin_wkt_parse.y"
+#line 588 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTICURVETYPE, NULL, NULL); WKT_ERROR(); }
-#line 2558 "lwin_wkt_parse.c"
+#line 2568 "lwin_wkt_parse.c"
     break;
   case 92: /* curve_list: curve_list COMMA_TOK circularstring  */
-#line 582 "lwin_wkt_parse.y"
+#line 592 "lwin_wkt_parse.y"
-#line 2564 "lwin_wkt_parse.c"
+#line 2574 "lwin_wkt_parse.c"
     break;
   case 93: /* curve_list: curve_list COMMA_TOK compoundcurve  */
-#line 584 "lwin_wkt_parse.y"
+#line 594 "lwin_wkt_parse.y"
-#line 2570 "lwin_wkt_parse.c"
+#line 2580 "lwin_wkt_parse.c"
     break;
   case 94: /* curve_list: curve_list COMMA_TOK nurbscurve  */
-#line 586 "lwin_wkt_parse.y"
+#line 596 "lwin_wkt_parse.y"
-#line 2576 "lwin_wkt_parse.c"
+#line 2586 "lwin_wkt_parse.c"
     break;
   case 95: /* curve_list: curve_list COMMA_TOK linestring  */
-#line 588 "lwin_wkt_parse.y"
+#line 598 "lwin_wkt_parse.y"
-#line 2582 "lwin_wkt_parse.c"
+#line 2592 "lwin_wkt_parse.c"
     break;
   case 96: /* curve_list: curve_list COMMA_TOK linestring_untagged  */
-#line 590 "lwin_wkt_parse.y"
+#line 600 "lwin_wkt_parse.y"
-#line 2588 "lwin_wkt_parse.c"
+#line 2598 "lwin_wkt_parse.c"
     break;
   case 97: /* curve_list: circularstring  */
-#line 592 "lwin_wkt_parse.y"
+#line 602 "lwin_wkt_parse.y"
-#line 2594 "lwin_wkt_parse.c"
+#line 2604 "lwin_wkt_parse.c"
     break;
   case 98: /* curve_list: compoundcurve  */
-#line 594 "lwin_wkt_parse.y"
+#line 604 "lwin_wkt_parse.y"
-#line 2600 "lwin_wkt_parse.c"
+#line 2610 "lwin_wkt_parse.c"
     break;
   case 99: /* curve_list: nurbscurve  */
-#line 596 "lwin_wkt_parse.y"
+#line 606 "lwin_wkt_parse.y"
-#line 2606 "lwin_wkt_parse.c"
+#line 2616 "lwin_wkt_parse.c"
     break;
   case 100: /* curve_list: linestring  */
-#line 598 "lwin_wkt_parse.y"
+#line 608 "lwin_wkt_parse.y"
-#line 2612 "lwin_wkt_parse.c"
+#line 2622 "lwin_wkt_parse.c"
     break;
   case 101: /* curve_list: linestring_untagged  */
-#line 600 "lwin_wkt_parse.y"
+#line 610 "lwin_wkt_parse.y"
-#line 2618 "lwin_wkt_parse.c"
+#line 2628 "lwin_wkt_parse.c"
     break;
   case 102: /* multilinestring: MLINESTRING_TOK LBRACKET_TOK linestring_list RBRACKET_TOK  */
-#line 604 "lwin_wkt_parse.y"
+#line 614 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTILINETYPE, (yyvsp[-1].geometryvalue), NULL); WKT_ERROR(); }
-#line 2624 "lwin_wkt_parse.c"
+#line 2634 "lwin_wkt_parse.c"
     break;
   case 103: /* multilinestring: MLINESTRING_TOK DIMENSIONALITY_TOK LBRACKET_TOK linestring_list RBRACKET_TOK  */
-#line 606 "lwin_wkt_parse.y"
+#line 616 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTILINETYPE, (yyvsp[-1].geometryvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2630 "lwin_wkt_parse.c"
+#line 2640 "lwin_wkt_parse.c"
     break;
   case 104: /* multilinestring: MLINESTRING_TOK DIMENSIONALITY_TOK EMPTY_TOK  */
-#line 608 "lwin_wkt_parse.y"
+#line 618 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTILINETYPE, NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2636 "lwin_wkt_parse.c"
+#line 2646 "lwin_wkt_parse.c"
     break;
   case 105: /* multilinestring: MLINESTRING_TOK EMPTY_TOK  */
-#line 610 "lwin_wkt_parse.y"
+#line 620 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTILINETYPE, NULL, NULL); WKT_ERROR(); }
-#line 2642 "lwin_wkt_parse.c"
+#line 2652 "lwin_wkt_parse.c"
     break;
   case 106: /* linestring_list: linestring_list COMMA_TOK linestring_untagged  */
-#line 614 "lwin_wkt_parse.y"
+#line 624 "lwin_wkt_parse.y"
-#line 2648 "lwin_wkt_parse.c"
+#line 2658 "lwin_wkt_parse.c"
     break;
   case 107: /* linestring_list: linestring_untagged  */
-#line 616 "lwin_wkt_parse.y"
+#line 626 "lwin_wkt_parse.y"
-#line 2654 "lwin_wkt_parse.c"
+#line 2664 "lwin_wkt_parse.c"
     break;
   case 108: /* circularstring: CIRCULARSTRING_TOK LBRACKET_TOK ptarray RBRACKET_TOK  */
-#line 620 "lwin_wkt_parse.y"
+#line 630 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_circularstring_new((yyvsp[-1].ptarrayvalue), NULL); WKT_ERROR(); }
-#line 2660 "lwin_wkt_parse.c"
+#line 2670 "lwin_wkt_parse.c"
     break;
   case 109: /* circularstring: CIRCULARSTRING_TOK DIMENSIONALITY_TOK LBRACKET_TOK ptarray RBRACKET_TOK  */
-#line 622 "lwin_wkt_parse.y"
+#line 632 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_circularstring_new((yyvsp[-1].ptarrayvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2666 "lwin_wkt_parse.c"
+#line 2676 "lwin_wkt_parse.c"
     break;
   case 110: /* circularstring: CIRCULARSTRING_TOK DIMENSIONALITY_TOK EMPTY_TOK  */
-#line 624 "lwin_wkt_parse.y"
+#line 634 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_circularstring_new(NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2672 "lwin_wkt_parse.c"
+#line 2682 "lwin_wkt_parse.c"
     break;
   case 111: /* circularstring: CIRCULARSTRING_TOK EMPTY_TOK  */
-#line 626 "lwin_wkt_parse.y"
+#line 636 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_circularstring_new(NULL, NULL); WKT_ERROR(); }
-#line 2678 "lwin_wkt_parse.c"
+#line 2688 "lwin_wkt_parse.c"
     break;
   case 112: /* linestring: LINESTRING_TOK LBRACKET_TOK ptarray RBRACKET_TOK  */
-#line 630 "lwin_wkt_parse.y"
+#line 640 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_linestring_new((yyvsp[-1].ptarrayvalue), NULL); WKT_ERROR(); }
-#line 2684 "lwin_wkt_parse.c"
+#line 2694 "lwin_wkt_parse.c"
     break;
   case 113: /* linestring: LINESTRING_TOK DIMENSIONALITY_TOK LBRACKET_TOK ptarray RBRACKET_TOK  */
-#line 632 "lwin_wkt_parse.y"
+#line 642 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_linestring_new((yyvsp[-1].ptarrayvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2690 "lwin_wkt_parse.c"
+#line 2700 "lwin_wkt_parse.c"
     break;
   case 114: /* linestring: LINESTRING_TOK DIMENSIONALITY_TOK EMPTY_TOK  */
-#line 634 "lwin_wkt_parse.y"
+#line 644 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_linestring_new(NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2696 "lwin_wkt_parse.c"
+#line 2706 "lwin_wkt_parse.c"
     break;
   case 115: /* linestring: LINESTRING_TOK EMPTY_TOK  */
-#line 636 "lwin_wkt_parse.y"
+#line 646 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_linestring_new(NULL, NULL); WKT_ERROR(); }
-#line 2702 "lwin_wkt_parse.c"
+#line 2712 "lwin_wkt_parse.c"
     break;
   case 116: /* linestring_untagged: LBRACKET_TOK ptarray RBRACKET_TOK  */
-#line 640 "lwin_wkt_parse.y"
+#line 650 "lwin_wkt_parse.y"
-#line 2708 "lwin_wkt_parse.c"
+#line 2718 "lwin_wkt_parse.c"
     break;
   case 117: /* linestring_untagged: EMPTY_TOK  */
-#line 642 "lwin_wkt_parse.y"
+#line 652 "lwin_wkt_parse.y"
-#line 2714 "lwin_wkt_parse.c"
+#line 2724 "lwin_wkt_parse.c"
     break;
   case 118: /* triangle_list: triangle_list COMMA_TOK triangle_untagged  */
-#line 646 "lwin_wkt_parse.y"
+#line 656 "lwin_wkt_parse.y"
-#line 2720 "lwin_wkt_parse.c"
+#line 2730 "lwin_wkt_parse.c"
     break;
   case 119: /* triangle_list: triangle_untagged  */
-#line 648 "lwin_wkt_parse.y"
+#line 658 "lwin_wkt_parse.y"
-#line 2726 "lwin_wkt_parse.c"
+#line 2736 "lwin_wkt_parse.c"
     break;
   case 120: /* triangle: TRIANGLE_TOK LBRACKET_TOK LBRACKET_TOK ptarray RBRACKET_TOK RBRACKET_TOK  */
-#line 652 "lwin_wkt_parse.y"
+#line 662 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_triangle_new((yyvsp[-2].ptarrayvalue), NULL); WKT_ERROR(); }
-#line 2732 "lwin_wkt_parse.c"
+#line 2742 "lwin_wkt_parse.c"
     break;
   case 121: /* triangle: TRIANGLE_TOK DIMENSIONALITY_TOK LBRACKET_TOK LBRACKET_TOK ptarray RBRACKET_TOK RBRACKET_TOK  */
-#line 654 "lwin_wkt_parse.y"
+#line 664 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_triangle_new((yyvsp[-2].ptarrayvalue), (yyvsp[-5].stringvalue)); WKT_ERROR(); }
-#line 2738 "lwin_wkt_parse.c"
+#line 2748 "lwin_wkt_parse.c"
     break;
   case 122: /* triangle: TRIANGLE_TOK DIMENSIONALITY_TOK EMPTY_TOK  */
-#line 656 "lwin_wkt_parse.y"
+#line 666 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_triangle_new(NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2744 "lwin_wkt_parse.c"
+#line 2754 "lwin_wkt_parse.c"
     break;
   case 123: /* triangle: TRIANGLE_TOK EMPTY_TOK  */
-#line 658 "lwin_wkt_parse.y"
+#line 668 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_triangle_new(NULL, NULL); WKT_ERROR(); }
-#line 2750 "lwin_wkt_parse.c"
+#line 2760 "lwin_wkt_parse.c"
     break;
   case 124: /* triangle_untagged: LBRACKET_TOK LBRACKET_TOK ptarray RBRACKET_TOK RBRACKET_TOK  */
-#line 662 "lwin_wkt_parse.y"
+#line 672 "lwin_wkt_parse.y"
-#line 2756 "lwin_wkt_parse.c"
+#line 2766 "lwin_wkt_parse.c"
     break;
   case 125: /* multipoint: MPOINT_TOK LBRACKET_TOK point_list RBRACKET_TOK  */
-#line 666 "lwin_wkt_parse.y"
+#line 676 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTIPOINTTYPE, (yyvsp[-1].geometryvalue), NULL); WKT_ERROR(); }
-#line 2762 "lwin_wkt_parse.c"
+#line 2772 "lwin_wkt_parse.c"
     break;
   case 126: /* multipoint: MPOINT_TOK DIMENSIONALITY_TOK LBRACKET_TOK point_list RBRACKET_TOK  */
-#line 668 "lwin_wkt_parse.y"
+#line 678 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTIPOINTTYPE, (yyvsp[-1].geometryvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2768 "lwin_wkt_parse.c"
+#line 2778 "lwin_wkt_parse.c"
     break;
   case 127: /* multipoint: MPOINT_TOK DIMENSIONALITY_TOK EMPTY_TOK  */
-#line 670 "lwin_wkt_parse.y"
+#line 680 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTIPOINTTYPE, NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2774 "lwin_wkt_parse.c"
+#line 2784 "lwin_wkt_parse.c"
     break;
   case 128: /* multipoint: MPOINT_TOK EMPTY_TOK  */
-#line 672 "lwin_wkt_parse.y"
+#line 682 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTIPOINTTYPE, NULL, NULL); WKT_ERROR(); }
-#line 2780 "lwin_wkt_parse.c"
+#line 2790 "lwin_wkt_parse.c"
     break;
   case 129: /* point_list: point_list COMMA_TOK point_untagged  */
-#line 676 "lwin_wkt_parse.y"
+#line 686 "lwin_wkt_parse.y"
-#line 2786 "lwin_wkt_parse.c"
+#line 2796 "lwin_wkt_parse.c"
     break;
   case 130: /* point_list: point_untagged  */
-#line 678 "lwin_wkt_parse.y"
+#line 688 "lwin_wkt_parse.y"
-#line 2792 "lwin_wkt_parse.c"
+#line 2802 "lwin_wkt_parse.c"
     break;
   case 131: /* point_untagged: coordinate  */
-#line 682 "lwin_wkt_parse.y"
+#line 692 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_point_new(wkt_parser_ptarray_new((yyvsp[0].coordinatevalue)),NULL); WKT_ERROR(); }
-#line 2798 "lwin_wkt_parse.c"
+#line 2808 "lwin_wkt_parse.c"
     break;
   case 132: /* point_untagged: LBRACKET_TOK coordinate RBRACKET_TOK  */
-#line 684 "lwin_wkt_parse.y"
+#line 694 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_point_new(wkt_parser_ptarray_new((yyvsp[-1].coordinatevalue)),NULL); WKT_ERROR(); }
-#line 2804 "lwin_wkt_parse.c"
+#line 2814 "lwin_wkt_parse.c"
     break;
   case 133: /* point_untagged: EMPTY_TOK  */
-#line 686 "lwin_wkt_parse.y"
+#line 696 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_point_new(NULL, NULL); WKT_ERROR(); }
-#line 2810 "lwin_wkt_parse.c"
+#line 2820 "lwin_wkt_parse.c"
     break;
   case 134: /* point: POINT_TOK LBRACKET_TOK ptarray RBRACKET_TOK  */
-#line 690 "lwin_wkt_parse.y"
+#line 700 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_point_new((yyvsp[-1].ptarrayvalue), NULL); WKT_ERROR(); }
-#line 2816 "lwin_wkt_parse.c"
+#line 2826 "lwin_wkt_parse.c"
     break;
   case 135: /* point: POINT_TOK DIMENSIONALITY_TOK LBRACKET_TOK ptarray RBRACKET_TOK  */
-#line 692 "lwin_wkt_parse.y"
+#line 702 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_point_new((yyvsp[-1].ptarrayvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2822 "lwin_wkt_parse.c"
+#line 2832 "lwin_wkt_parse.c"
     break;
   case 136: /* point: POINT_TOK DIMENSIONALITY_TOK EMPTY_TOK  */
-#line 694 "lwin_wkt_parse.y"
+#line 704 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_point_new(NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2828 "lwin_wkt_parse.c"
+#line 2838 "lwin_wkt_parse.c"
     break;
   case 137: /* point: POINT_TOK EMPTY_TOK  */
-#line 696 "lwin_wkt_parse.y"
+#line 706 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_point_new(NULL,NULL); WKT_ERROR(); }
-#line 2834 "lwin_wkt_parse.c"
+#line 2844 "lwin_wkt_parse.c"
     break;
   case 138: /* ptarray: ptarray COMMA_TOK coordinate  */
-#line 700 "lwin_wkt_parse.y"
+#line 710 "lwin_wkt_parse.y"
                 { (yyval.ptarrayvalue) = wkt_parser_ptarray_add_coord((yyvsp[-2].ptarrayvalue), (yyvsp[0].coordinatevalue)); WKT_ERROR(); }
-#line 2840 "lwin_wkt_parse.c"
+#line 2850 "lwin_wkt_parse.c"
     break;
   case 139: /* ptarray: coordinate  */
-#line 702 "lwin_wkt_parse.y"
+#line 712 "lwin_wkt_parse.y"
                 { (yyval.ptarrayvalue) = wkt_parser_ptarray_new((yyvsp[0].coordinatevalue)); WKT_ERROR(); }
-#line 2846 "lwin_wkt_parse.c"
+#line 2856 "lwin_wkt_parse.c"
     break;
   case 140: /* coordinate: DOUBLE_TOK DOUBLE_TOK  */
-#line 706 "lwin_wkt_parse.y"
+#line 716 "lwin_wkt_parse.y"
                 { (yyval.coordinatevalue) = wkt_parser_coord_2((yyvsp[-1].doublevalue), (yyvsp[0].doublevalue)); WKT_ERROR(); }
-#line 2852 "lwin_wkt_parse.c"
+#line 2862 "lwin_wkt_parse.c"
     break;
   case 141: /* coordinate: DOUBLE_TOK DOUBLE_TOK DOUBLE_TOK  */
-#line 708 "lwin_wkt_parse.y"
+#line 718 "lwin_wkt_parse.y"
                 { (yyval.coordinatevalue) = wkt_parser_coord_3((yyvsp[-2].doublevalue), (yyvsp[-1].doublevalue), (yyvsp[0].doublevalue)); WKT_ERROR(); }
-#line 2858 "lwin_wkt_parse.c"
+#line 2868 "lwin_wkt_parse.c"
     break;
   case 142: /* coordinate: DOUBLE_TOK DOUBLE_TOK DOUBLE_TOK DOUBLE_TOK  */
-#line 710 "lwin_wkt_parse.y"
+#line 720 "lwin_wkt_parse.y"
                 { (yyval.coordinatevalue) = wkt_parser_coord_4((yyvsp[-3].doublevalue), (yyvsp[-2].doublevalue), (yyvsp[-1].doublevalue), (yyvsp[0].doublevalue)); WKT_ERROR(); }
-#line 2864 "lwin_wkt_parse.c"
+#line 2874 "lwin_wkt_parse.c"
     break;
   case 143: /* opt_dimensionality: DIMENSIONALITY_TOK  */
-#line 714 "lwin_wkt_parse.y"
+#line 724 "lwin_wkt_parse.y"
                 { (yyval.stringvalue) = (yyvsp[0].stringvalue); }
-#line 2870 "lwin_wkt_parse.c"
+#line 2880 "lwin_wkt_parse.c"
     break;
   case 144: /* opt_dimensionality: %empty  */
-#line 715 "lwin_wkt_parse.y"
+#line 725 "lwin_wkt_parse.y"
                 { (yyval.stringvalue) = NULL; }
-#line 2876 "lwin_wkt_parse.c"
+#line 2886 "lwin_wkt_parse.c"
     break;
   case 145: /* nurbscurve: NURBSCURVE_TOK LBRACKET_TOK DEGREE_TOK DOUBLE_TOK COMMA_TOK CONTROLPOINTS_TOK opt_dimensionality LBRACKET_TOK iso_controlpoint_list RBRACKET_TOK COMMA_TOK KNOTS_TOK LBRACKET_TOK iso_knot_list RBRACKET_TOK RBRACKET_TOK  */
-#line 720 "lwin_wkt_parse.y"
+#line 730 "lwin_wkt_parse.y"
 				(yyval.geometryvalue) = wkt_parser_nurbscurve_new((yyvsp[-12].doublevalue), (yyvsp[-7].nurbscontrolpointsvalue)->points, (yyvsp[-7].nurbscontrolpointsvalue)->weights, (yyvsp[-2].ptarrayvalue),
 					wkt_parser_nurbscurve_iso_dimensionality(NULL, (yyvsp[-9].stringvalue)));
@@ -2885,11 +2895,11 @@ yyreduce:
 				wkt_parser_nurbs_controlpoints_free((yyvsp[-7].nurbscontrolpointsvalue));
 			WKT_ERROR();
-#line 2889 "lwin_wkt_parse.c"
+#line 2899 "lwin_wkt_parse.c"
     break;
   case 146: /* nurbscurve: NURBSCURVE_TOK DIMENSIONALITY_TOK LBRACKET_TOK DEGREE_TOK DOUBLE_TOK COMMA_TOK CONTROLPOINTS_TOK opt_dimensionality LBRACKET_TOK iso_controlpoint_list RBRACKET_TOK COMMA_TOK KNOTS_TOK LBRACKET_TOK iso_knot_list RBRACKET_TOK RBRACKET_TOK  */
-#line 729 "lwin_wkt_parse.y"
+#line 739 "lwin_wkt_parse.y"
 					wkt_parser_nurbscurve_iso_dimensionality((yyvsp[-15].stringvalue), (yyvsp[-9].stringvalue)));
@@ -2898,125 +2908,125 @@ yyreduce:
 			WKT_ERROR();
-#line 2902 "lwin_wkt_parse.c"
+#line 2912 "lwin_wkt_parse.c"
     break;
   case 147: /* nurbscurve: NURBSCURVE_TOK LBRACKET_TOK DOUBLE_TOK COMMA_TOK LBRACKET_TOK ptarray RBRACKET_TOK COMMA_TOK LBRACKET_TOK weight_list RBRACKET_TOK COMMA_TOK LBRACKET_TOK knot_list RBRACKET_TOK RBRACKET_TOK  */
-#line 739 "lwin_wkt_parse.y"
+#line 749 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_nurbscurve_new((yyvsp[-13].doublevalue), (yyvsp[-10].ptarrayvalue), (yyvsp[-6].ptarrayvalue), (yyvsp[-2].ptarrayvalue), NULL); WKT_ERROR(); }
-#line 2908 "lwin_wkt_parse.c"
+#line 2918 "lwin_wkt_parse.c"
     break;
   case 148: /* nurbscurve: NURBSCURVE_TOK DIMENSIONALITY_TOK LBRACKET_TOK DOUBLE_TOK COMMA_TOK LBRACKET_TOK ptarray RBRACKET_TOK COMMA_TOK LBRACKET_TOK weight_list RBRACKET_TOK COMMA_TOK LBRACKET_TOK knot_list RBRACKET_TOK RBRACKET_TOK  */
-#line 741 "lwin_wkt_parse.y"
+#line 751 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_nurbscurve_new((yyvsp[-13].doublevalue), (yyvsp[-10].ptarrayvalue), (yyvsp[-6].ptarrayvalue), (yyvsp[-2].ptarrayvalue), (yyvsp[-15].stringvalue)); WKT_ERROR(); }
-#line 2914 "lwin_wkt_parse.c"
+#line 2924 "lwin_wkt_parse.c"
     break;
   case 149: /* nurbscurve: NURBSCURVE_TOK LBRACKET_TOK DOUBLE_TOK COMMA_TOK LBRACKET_TOK ptarray RBRACKET_TOK COMMA_TOK LBRACKET_TOK weight_list RBRACKET_TOK RBRACKET_TOK  */
-#line 744 "lwin_wkt_parse.y"
+#line 754 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_nurbscurve_new((yyvsp[-9].doublevalue), (yyvsp[-6].ptarrayvalue), (yyvsp[-2].ptarrayvalue), NULL, NULL); WKT_ERROR(); }
-#line 2920 "lwin_wkt_parse.c"
+#line 2930 "lwin_wkt_parse.c"
     break;
   case 150: /* nurbscurve: NURBSCURVE_TOK DIMENSIONALITY_TOK LBRACKET_TOK DOUBLE_TOK COMMA_TOK LBRACKET_TOK ptarray RBRACKET_TOK COMMA_TOK LBRACKET_TOK weight_list RBRACKET_TOK RBRACKET_TOK  */
-#line 746 "lwin_wkt_parse.y"
+#line 756 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_nurbscurve_new((yyvsp[-9].doublevalue), (yyvsp[-6].ptarrayvalue), (yyvsp[-2].ptarrayvalue), NULL, (yyvsp[-11].stringvalue)); WKT_ERROR(); }
-#line 2926 "lwin_wkt_parse.c"
+#line 2936 "lwin_wkt_parse.c"
     break;
   case 151: /* nurbscurve: NURBSCURVE_TOK LBRACKET_TOK DOUBLE_TOK COMMA_TOK LBRACKET_TOK ptarray RBRACKET_TOK RBRACKET_TOK  */
-#line 749 "lwin_wkt_parse.y"
+#line 759 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_nurbscurve_new((yyvsp[-5].doublevalue), (yyvsp[-2].ptarrayvalue), NULL, NULL, NULL); WKT_ERROR(); }
-#line 2932 "lwin_wkt_parse.c"
+#line 2942 "lwin_wkt_parse.c"
     break;
   case 152: /* nurbscurve: NURBSCURVE_TOK DIMENSIONALITY_TOK LBRACKET_TOK DOUBLE_TOK COMMA_TOK LBRACKET_TOK ptarray RBRACKET_TOK RBRACKET_TOK  */
-#line 751 "lwin_wkt_parse.y"
+#line 761 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_nurbscurve_new((yyvsp[-5].doublevalue), (yyvsp[-2].ptarrayvalue), NULL, NULL, (yyvsp[-7].stringvalue)); WKT_ERROR(); }
-#line 2938 "lwin_wkt_parse.c"
+#line 2948 "lwin_wkt_parse.c"
     break;
   case 153: /* nurbscurve: NURBSCURVE_TOK DIMENSIONALITY_TOK EMPTY_TOK  */
-#line 755 "lwin_wkt_parse.y"
+#line 765 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_nurbscurve_empty((yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2944 "lwin_wkt_parse.c"
+#line 2954 "lwin_wkt_parse.c"
     break;
   case 154: /* nurbscurve: NURBSCURVE_TOK EMPTY_TOK  */
-#line 757 "lwin_wkt_parse.y"
+#line 767 "lwin_wkt_parse.y"
                 { (yyval.geometryvalue) = wkt_parser_nurbscurve_empty(NULL); WKT_ERROR(); }
-#line 2950 "lwin_wkt_parse.c"
+#line 2960 "lwin_wkt_parse.c"
     break;
   case 155: /* iso_controlpoint: NURBSPOINT_TOK LBRACKET_TOK WEIGHTEDPOINT_TOK opt_dimensionality LBRACKET_TOK coordinate RBRACKET_TOK COMMA_TOK WEIGHT_TOK DOUBLE_TOK RBRACKET_TOK  */
-#line 762 "lwin_wkt_parse.y"
+#line 772 "lwin_wkt_parse.y"
                 { (yyval.nurbscontrolpointsvalue) = wkt_parser_nurbs_controlpoints_new((yyvsp[-5].coordinatevalue), (yyvsp[-1].doublevalue), (yyvsp[-7].stringvalue)); WKT_ERROR(); }
-#line 2956 "lwin_wkt_parse.c"
+#line 2966 "lwin_wkt_parse.c"
     break;
   case 156: /* iso_controlpoint_list: iso_controlpoint_list COMMA_TOK iso_controlpoint  */
-#line 767 "lwin_wkt_parse.y"
+#line 777 "lwin_wkt_parse.y"
                 { (yyval.nurbscontrolpointsvalue) = wkt_parser_nurbs_controlpoints_add((yyvsp[-2].nurbscontrolpointsvalue), (yyvsp[0].nurbscontrolpointsvalue)); WKT_ERROR(); }
-#line 2962 "lwin_wkt_parse.c"
+#line 2972 "lwin_wkt_parse.c"
     break;
   case 157: /* iso_controlpoint_list: iso_controlpoint  */
-#line 769 "lwin_wkt_parse.y"
+#line 779 "lwin_wkt_parse.y"
                 { (yyval.nurbscontrolpointsvalue) = (yyvsp[0].nurbscontrolpointsvalue); }
-#line 2968 "lwin_wkt_parse.c"
+#line 2978 "lwin_wkt_parse.c"
     break;
   case 158: /* iso_knot_list: iso_knot_list COMMA_TOK KNOT_TOK LBRACKET_TOK DOUBLE_TOK COMMA_TOK DOUBLE_TOK RBRACKET_TOK  */
-#line 774 "lwin_wkt_parse.y"
+#line 784 "lwin_wkt_parse.y"
                 { (yyval.ptarrayvalue) = wkt_parser_knot_list_add_repeated((yyvsp[-7].ptarrayvalue), (yyvsp[-3].doublevalue), (yyvsp[-1].doublevalue)); WKT_ERROR(); }
-#line 2974 "lwin_wkt_parse.c"
+#line 2984 "lwin_wkt_parse.c"
     break;
   case 159: /* iso_knot_list: KNOT_TOK LBRACKET_TOK DOUBLE_TOK COMMA_TOK DOUBLE_TOK RBRACKET_TOK  */
-#line 776 "lwin_wkt_parse.y"
+#line 786 "lwin_wkt_parse.y"
                 { (yyval.ptarrayvalue) = wkt_parser_knot_list_add_repeated(NULL, (yyvsp[-3].doublevalue), (yyvsp[-1].doublevalue)); WKT_ERROR(); }
-#line 2980 "lwin_wkt_parse.c"
+#line 2990 "lwin_wkt_parse.c"
     break;
   case 160: /* weight_list: weight_list COMMA_TOK DOUBLE_TOK  */
-#line 781 "lwin_wkt_parse.y"
+#line 791 "lwin_wkt_parse.y"
 			(yyval.ptarrayvalue) = wkt_parser_ptarray_add_coord((yyvsp[-2].ptarrayvalue), wkt_parser_coord_2((yyvsp[0].doublevalue), 0));
 			WKT_ERROR();
-#line 2989 "lwin_wkt_parse.c"
+#line 2999 "lwin_wkt_parse.c"
     break;
   case 161: /* weight_list: DOUBLE_TOK  */
-#line 786 "lwin_wkt_parse.y"
+#line 796 "lwin_wkt_parse.y"
 			(yyval.ptarrayvalue) = wkt_parser_ptarray_new(wkt_parser_coord_2((yyvsp[0].doublevalue), 0));
 			WKT_ERROR();
-#line 2998 "lwin_wkt_parse.c"
+#line 3008 "lwin_wkt_parse.c"
     break;
   case 162: /* knot_list: knot_list COMMA_TOK DOUBLE_TOK  */
-#line 794 "lwin_wkt_parse.y"
+#line 804 "lwin_wkt_parse.y"
 			WKT_ERROR();
-#line 3007 "lwin_wkt_parse.c"
+#line 3017 "lwin_wkt_parse.c"
     break;
   case 163: /* knot_list: DOUBLE_TOK  */
-#line 799 "lwin_wkt_parse.y"
+#line 809 "lwin_wkt_parse.y"
 			WKT_ERROR();
-#line 3016 "lwin_wkt_parse.c"
+#line 3026 "lwin_wkt_parse.c"
     break;
-#line 3020 "lwin_wkt_parse.c"
+#line 3030 "lwin_wkt_parse.c"
       default: break;
diff --git a/liblwgeom/lwin_wkt_parse.h b/liblwgeom/lwin_wkt_parse.h
index 2724e0a1c..3108ea75d 100644
--- a/liblwgeom/lwin_wkt_parse.h
+++ b/liblwgeom/lwin_wkt_parse.h
@@ -45,7 +45,7 @@
 extern int wkt_yydebug;
 #endif
 /* "%code requires" blocks.  */
-#line 250 "lwin_wkt_parse.y"
+#line 260 "lwin_wkt_parse.y"
 typedef struct WKT_NURBS_CONTROLPOINTS WKT_NURBS_CONTROLPOINTS;
@@ -99,7 +99,7 @@ typedef struct WKT_NURBS_CONTROLPOINTS WKT_NURBS_CONTROLPOINTS;
 #if ! defined YYSTYPE && ! defined YYSTYPE_IS_DECLARED
 union YYSTYPE
-#line 256 "lwin_wkt_parse.y"
+#line 266 "lwin_wkt_parse.y"
 	int integervalue;
 	double doublevalue;
diff --git a/liblwgeom/lwin_wkt_parse.y b/liblwgeom/lwin_wkt_parse.y
index 8e7b1cbe4..15471ba9b 100644
--- a/liblwgeom/lwin_wkt_parse.y
+++ b/liblwgeom/lwin_wkt_parse.y
@@ -111,6 +111,8 @@ int lwgeom_parse_wkt(LWGEOM_PARSER_RESULT *parser_result, const char *wktstr, in
 	POINTARRAY *points;
@@ -226,6 +228,7 @@ wkt_parser_knot_list_add_repeated(POINTARRAY *knots, double value, double multip
 		if (knots)
@@ -235,6 +238,13 @@ wkt_parser_knot_list_add_repeated(POINTARRAY *knots, double value, double multip
+		return NULL;
diff --git a/regress/core/nurbs_wkt.sql b/regress/core/nurbs_wkt.sql
index d12078848..b1d4902ce 100644
--- a/regress/core/nurbs_wkt.sql
+++ b/regress/core/nurbs_wkt.sql
@@ -57,3 +57,5 @@ SELECT 56, ST_AsEWKT(ST_GeomFromText('NURBSCURVE(DEGREE 2, CONTROLPOINTS (NURBSP
 SELECT 57, ST_AsText(ST_GeomFromText('NURBSCURVE(1, (0 0, 10 10), (1, 1), (0, 0, 1, 1))'));
 SELECT 58, ST_AsText(ST_GeomFromText('NURBSCURVE(2, (0 0, 5 10, 10 0), (1, 2, 1), (0, 0, 0, 1, 1, 1))'));
 SELECT 59, ST_AsText(ST_GeomFromText('NURBSCURVE Z(3, (0 0 0, 3 10 3, 7 10 7, 10 0 10), (1, 1.5, 1.5, 1), (0, 0, 0, 0, 1, 1, 1, 1))'));
+SELECT 60, ST_GeomFromText('NURBSCURVE(DEGREE 2, CONTROLPOINTS (NURBSPOINT(WEIGHTEDPOINT(0 0), WEIGHT 1), NURBSPOINT(WEIGHTEDPOINT(5 10), WEIGHT 1), NURBSPOINT(WEIGHTEDPOINT(10 0), WEIGHT 1)), KNOTS (KNOT(0,10001)))');
+SELECT 61, ST_GeomFromText('NURBSCURVE(DEGREE 2, CONTROLPOINTS (NURBSPOINT(WEIGHTEDPOINT(0 0), WEIGHT 1), NURBSPOINT(WEIGHTEDPOINT(5 10), WEIGHT 1), NURBSPOINT(WEIGHTEDPOINT(10 0), WEIGHT 1)), KNOTS (KNOT(0,6000), KNOT(1,6000)))');
diff --git a/regress/core/nurbs_wkt_expected b/regress/core/nurbs_wkt_expected
index 3e1aa47ba..1b85d711b 100644
--- a/regress/core/nurbs_wkt_expected
+++ b/regress/core/nurbs_wkt_expected
@@ -57,3 +57,5 @@
 57|NURBSCURVE(DEGREE 1,CONTROLPOINTS(NURBSPOINT(WEIGHTEDPOINT(0 0),WEIGHT 1),NURBSPOINT(WEIGHTEDPOINT(10 10),WEIGHT 1)),KNOTS (KNOT(0,2),KNOT(1,2)))
 58|NURBSCURVE(DEGREE 2,CONTROLPOINTS(NURBSPOINT(WEIGHTEDPOINT(0 0),WEIGHT 1),NURBSPOINT(WEIGHTEDPOINT(5 10),WEIGHT 2),NURBSPOINT(WEIGHTEDPOINT(10 0),WEIGHT 1)),KNOTS (KNOT(0,3),KNOT(1,3)))
 59|NURBSCURVE Z (DEGREE 3,CONTROLPOINTS Z (NURBSPOINT(WEIGHTEDPOINT Z (0 0 0),WEIGHT 1),NURBSPOINT(WEIGHTEDPOINT Z (3 10 3),WEIGHT 1.5),NURBSPOINT(WEIGHTEDPOINT Z (7 10 7),WEIGHT 1.5),NURBSPOINT(WEIGHTEDPOINT Z (10 0 10),WEIGHT 1)),KNOTS (KNOT(0,4),KNOT(1,4)))
+ERROR:  parse error - invalid geometry
commit a09a9f3a75eea082f7d2484965bc4faea312724a
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Tue Jul 7 12:12:43 2026 +0400
    topology: return large edge ids from proximity helper
    Closes https://github.com/postgis/postgis/pull/1139
diff --git a/NEWS b/NEWS
index 088a507c1..22f579b9e 100644
--- a/NEWS
+++ b/NEWS
@@ -22,6 +22,8 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
  - GH-1153, [topology] Preserve large ids from edge wrappers
+ - GH-1139, [topology] Preserve large edge ids from vertex-segment
+          proximity helper (Darafei Praliaskouski)
 PostGIS 3.7.0dev
diff --git a/topology/sql/query/FindVertexSegmentPairsBelowDistance.sql.in b/topology/sql/query/FindVertexSegmentPairsBelowDistance.sql.in
index 8d5096235..4383b484c 100644
--- a/topology/sql/query/FindVertexSegmentPairsBelowDistance.sql.in
+++ b/topology/sql/query/FindVertexSegmentPairsBelowDistance.sql.in
@@ -9,16 +9,16 @@
 -- WHERE edge_id = v.vert_edge;
 CREATE OR REPLACE FUNCTION topology.findVertexSegmentPairsBelowDistance(toponame varchar, tolerance float8)
-RETURNS TABLE (seg_edge int, segno int, vert_edge int, vertno int, vert_geom geometry)
+RETURNS TABLE (seg_edge bigint, segno int, vert_edge bigint, vertno int, vert_geom geometry)
 AS $BODY$
 DECLARE
   sql text;
 BEGIN
   sql := format($$
     SELECT
-      e1.edge_id seg_edge,
+      e1.edge_id::bigint seg_edge,
       s.path[1] segno,
-      e2.edge_id vert_edge,
+      e2.edge_id::bigint vert_edge,
       p.path[1] vertno,
       p.geom vert_geom
     FROM
diff --git a/topology/topology_before_upgrade.sql.in b/topology/topology_before_upgrade.sql.in
index 6c66266ac..4265264ac 100644
--- a/topology/topology_before_upgrade.sql.in
+++ b/topology/topology_before_upgrade.sql.in
@@ -46,3 +46,18 @@ SELECT _postgis_topology_upgrade_domain_type('topoelement','integer[]','bigint[]
 SELECT _postgis_topology_upgrade_domain_type('topoelementarray','integer[][]','bigint[][]','3.6.0');
 SELECT _postgis_add_column_to_table('topology.topology', 'useslargeids', 'BOOLEAN', true, 'false','3.6.0');
+-- 3.7.0
+-- Return edge identifiers as bigint instead of integer
+DO $postgis_upgrade$
+DECLARE
+	old_result text;
+BEGIN
+	old_result := pg_get_function_result('topology.findVertexSegmentPairsBelowDistance(varchar, float8)'::regprocedure);
+	IF old_result LIKE '%seg_edge integer%' AND old_result LIKE '%vert_edge integer%' THEN
+		PERFORM _postgis_drop_function_by_signature('topology.findVertexSegmentPairsBelowDistance(varchar, float8)', '3.7.0');
+	END IF;
+EXCEPTION
+	WHEN undefined_function THEN
+		NULL;
+END
+$postgis_upgrade$;
Summary of changes:
 NEWS                                               |  12 +
 liblwgeom/lwin_wkt_parse.c                         | 868 +++++++++++----------
 liblwgeom/lwin_wkt_parse.h                         |   4 +-
 liblwgeom/lwin_wkt_parse.y                         |  10 +
 liblwgeom/lwstroke.c                               |  12 +-
 liblwgeom/topo/lwgeom_topo.c                       |  33 +-
 regress/core/nurbs_wkt.sql                         |   2 +
 regress/core/nurbs_wkt_expected                    |   2 +
 topology/postgis_topology.c                        |  16 +-
 topology/sql/manage/TotalTopologySize.sql.in       |  13 +-
 .../FindVertexSegmentPairsBelowDistance.sql.in     |   6 +-
 topology/sql/topogeometry/totopogeom.sql.in        |   4 +-
 topology/topology_before_upgrade.sql.in            |  15 +
 13 files changed, 526 insertions(+), 471 deletions(-)
hooks/post-receive
