[SCM] PostGIS branch master updated. 3.7.0alpha1-79-g63de00830
git at osgeo.org
git at osgeo.org
Wed Jul 8 14:10:49 PDT 2026
the project "PostGIS".
via 63de00830dc7afb6102a095cb1a41514e9064c1f (commit)
from dc565b619633d15b2ccd262ca70b00c1f5ee6c4d (commit)
revisions in full, below.
commit 63de00830dc7afb6102a095cb1a41514e9064c1f
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed Jul 8 14:10:37 2026 -0700
Fix non-topology regression tests for GEOS >= 3.15
diff --git a/liblwgeom/cunit/cu_wrapx.c b/liblwgeom/cunit/cu_wrapx.c
index a5ca09a28..79e707238 100644
--- a/liblwgeom/cunit/cu_wrapx.c
+++ b/liblwgeom/cunit/cu_wrapx.c
@@ -83,9 +83,11 @@ static void test_lwgeom_wrapx(void)
lwgeom_free(tmp);
CU_ASSERT_FATAL(ret != NULL);
obt_wkt = lwgeom_to_ewkt(ret);
- tmp = lwgeom_from_wkt(
- "MULTILINESTRING((0 0,8 0),(-2 0,0 0))",
- LW_PARSER_CHECK_NONE);
+#if POSTGIS_GEOS_VERSION < 31500
+ tmp = lwgeom_from_wkt("MULTILINESTRING((0 0,8 0),(-2 0,0 0))",LW_PARSER_CHECK_NONE);
+#else
+ tmp = lwgeom_from_wkt("LINESTRING(-2 0,0 0,8 0)",LW_PARSER_CHECK_NONE);
+#endif
tmp2 = lwgeom_normalize(tmp);
lwgeom_free(tmp);
exp_wkt = lwgeom_to_ewkt(tmp2);
diff --git a/regress/core/fixedoverlay.sql b/regress/core/fixedoverlay.sql
index 45d3b8979..2377f5667 100644
--- a/regress/core/fixedoverlay.sql
+++ b/regress/core/fixedoverlay.sql
@@ -1,3 +1,9 @@
+CREATE OR REPLACE FUNCTION geos_version()
+RETURNS integer AS $$
+ SELECT (matches[1]::integer * 100) + matches[2]::integer
+ FROM regexp_match(postgis_geos_version(), E'^([0-9]+)]\\.([0-9]+)') AS matches;
+$$ LANGUAGE 'sql' IMMUTABLE;
SELECT 'intersection', ST_AsText(ST_Intersection(
'LINESTRING(0 0, 9 0)'::geometry,
'LINESTRING(7 0, 13.2 0)'::geometry,
@@ -13,14 +19,7 @@ SELECT 'symdifference', ST_AsText(ST_SymDifference(
2));
-SELECT 'union', ST_AsText(ST_Union(
- 'LINESTRING(0.5 0, 9 0)'::geometry,
- 'LINESTRING(7 0, 13.2 0)'::geometry,
- 2));
-SELECT 'unaryunion', ST_AsText(ST_UnaryUnion(
- 'GEOMETRYCOLLECTION(LINESTRING(0.5 0, 9 0), LINESTRING(7 0, 13.2 0))'::geometry,
-2));
WITH n AS (SELECT geom
FROM ST_Subdivide(
@@ -28,3 +27,6 @@ FROM ST_Subdivide(
6, 1) AS geom)
SELECT 'subdivide', count(geom), ST_AsText(ST_Normalize(ST_Union(geom)))
FROM n;
+DROP FUNCTION geos_version();
diff --git a/regress/core/fixedoverlay_expected b/regress/core/fixedoverlay_expected
index 4f03bb27b..835d8b92c 100644
--- a/regress/core/fixedoverlay_expected
+++ b/regress/core/fixedoverlay_expected
@@ -1,6 +1,4 @@
intersection|LINESTRING(8 0,10 0)
difference|LINESTRING(0 0,8 0)
symdifference|MULTILINESTRING((0 0,8 0),(10 0,14 0))
-union|MULTILINESTRING((0 0,8 0),(8 0,10 0),(10 0,14 0))
-unaryunion|MULTILINESTRING((0 0,8 0),(8 0,10 0),(10 0,14 0))
subdivide|3|MULTIPOLYGON(((0 0,0 10,10 10,10 6,100 5,10 5,10 0,0 0)),((100 0,100 5,100 10,110 10,110 0,100 0)))
diff --git a/regress/core/geos315.sql b/regress/core/geos315.sql
index b30f0657a..5391bc22f 100644
--- a/regress/core/geos315.sql
+++ b/regress/core/geos315.sql
@@ -3,43 +3,43 @@
-- Connected graph (all one cluster)
SELECT 'connected', id, ST_MinimumSpanningTree(geom) OVER (ORDER BY id) FROM (VALUES
- (1, 'LINESTRING(0 0,1 0)'::geometry),
- (2, 'LINESTRING(0 0,0 1)'::geometry),
- (3, 'LINESTRING(1 1,0 1)'::geometry),
- (4, 'LINESTRING(1 1,1 0)'::geometry),
- (5, 'LINESTRING(0 0,1 1)'::geometry),
- (6, 'LINESTRING(1 0,0 1)'::geometry)
+ (1, 'LINESTRING(0 0,1 0)'::geometry),
+ (2, 'LINESTRING(0 0,0 1)'::geometry),
+ (3, 'LINESTRING(1 1,0 1)'::geometry),
+ (4, 'LINESTRING(1 1,1 0)'::geometry),
+ (5, 'LINESTRING(0 0,1 1)'::geometry),
+ (6, 'LINESTRING(1 0,0 1)'::geometry)
) AS t(id, geom);
-- Disconnected graph (two clusters)
SELECT 'disconnected', id, ST_MinimumSpanningTree(geom) OVER (ORDER BY id) FROM (VALUES
- (4, 'LINESTRING(11 11,11 10)'::geometry),
- (5, 'LINESTRING(10 10,11 11)'::geometry),
- (6, 'LINESTRING(11 10,10 11)'::geometry)
+ (4, 'LINESTRING(11 11,11 10)'::geometry),
+ (5, 'LINESTRING(10 10,11 11)'::geometry),
+ (6, 'LINESTRING(11 10,10 11)'::geometry)
) AS t(id, geom);
-- NULL handling
SELECT 'nulls', id, ST_MinimumSpanningTree(geom) OVER (ORDER BY id), ST_AsText(geom) FROM (VALUES
- (3, NULL::geometry),
+ (3, NULL::geometry),
) AS t(id, geom);
-- Empty geometry handling
SELECT 'empty', id, ST_MinimumSpanningTree(geom) OVER (ORDER BY id), ST_AsText(geom) FROM (VALUES
- (2, 'LINESTRING EMPTY'::geometry),
- (3, 'LINESTRING EMPTY'::geometry),
+ (2, 'LINESTRING EMPTY'::geometry),
+ (3, 'LINESTRING EMPTY'::geometry),
) AS t(id, geom);
-- ST_CoverageEdges
@@ -67,3 +67,14 @@ SELECT 'coverage edges array' AS test,
FROM coverage_edges WHERE id = 6;
DROP TABLE coverage_edges;
+-- FROM fixedoverlay
+SELECT 'union', ST_AsText(ST_Union(
+ 'LINESTRING(0.5 0, 9 0)'::geometry,
+ 'LINESTRING(7 0, 13.2 0)'::geometry,
+ 2));
+SELECT 'unaryunion', ST_AsText(ST_UnaryUnion(
+ 'GEOMETRYCOLLECTION(LINESTRING(0.5 0, 9 0), LINESTRING(7 0, 13.2 0))'::geometry,
+2));
diff --git a/regress/core/geos315_expected b/regress/core/geos315_expected
index 9eae3c024..8df98e9fb 100644
--- a/regress/core/geos315_expected
+++ b/regress/core/geos315_expected
@@ -26,3 +26,5 @@ coverage edges all|MULTILINESTRING((10 10,10 0),(10 0,0 0,0 10,10 10),(10 10,20
coverage edges exterior|MULTILINESTRING((10 0,0 0,0 10,10 10),(10 10,20 10,20 0,10 0))
coverage edges interior|MULTILINESTRING((10 10,10 0))
coverage edges array|MULTILINESTRING((10 10,10 0),(10 0,0 0,0 10,10 10),(10 10,20 10,20 0,10 0))
+union|LINESTRING(0 0,8 0,10 0,14 0)
+unaryunion|LINESTRING(0 0,8 0,10 0,14 0)
diff --git a/regress/core/wrapx.sql b/regress/core/wrapx.sql
index d08dc9c9c..321958d52 100644
--- a/regress/core/wrapx.sql
+++ b/regress/core/wrapx.sql
@@ -1,94 +1,112 @@
-CREATE FUNCTION test(geom geometry, wrap float8, amount float8, exp geometry)
+CREATE FUNCTION test_wrapx(geom geometry, wrap float8, amount float8, exp geometry)
RETURNS text AS $$
DECLARE
- obt geometry;
+ obt geometry;
BEGIN
- obt = ST_Normalize(ST_WrapX(geom, wrap, amount));
- IF ST_OrderingEquals(obt, exp) THEN
- RETURN 'OK';
- ELSE
- RETURN 'KO:' || ST_AsEWKT(obt) || ' != ' || ST_AsEWKT(exp);
- END IF;
+ obt = ST_Normalize(ST_WrapX(geom, wrap, amount));
+ IF ST_OrderingEquals(obt, exp) THEN
+ RETURN 'OK';
+ ELSE
+ RETURN 'KO:' || ST_AsEWKT(obt) || ' != ' || ST_AsEWKT(exp);
+ END IF;
END
-$$ LANGUAGE plpgsql;
+$$ LANGUAGE 'plpgsql';
-SELECT 'P1', test(
- 'POINT(0 0)', 2, 10,
- 'POINT(10 0)');
-SELECT 'P2', test(
- 'POINT(0 0)', 2, -10,
- 'POINT(0 0)');
-SELECT 'P3', test(
- 'POINT(0 0)', -2, -10,
- 'POINT(-10 0)');
+SELECT 'P1', test_wrapx(
+ 'POINT(0 0)', 2, 10,
+ 'POINT(10 0)');
-SELECT 'L1', test(
- 'LINESTRING(0 0,10 0)', 2, 10,
- --'LINESTRING(2 0,12 0)');
- 'MULTILINESTRING((10 0,12 0),(2 0,10 0))');
+SELECT 'P2', test_wrapx(
+ 'POINT(0 0)', 2, -10,
+ 'POINT(0 0)');
-SELECT 'L2', test(
- 'LINESTRING(0 0,10 0)', 8, -10,
- 'MULTILINESTRING((0 0,8 0),(-2 0,0 0))');
+SELECT 'P3', test_wrapx(
+ 'POINT(0 0)', -2, -10,
+ 'POINT(-10 0)');
-SELECT 'L3', test(
- 'LINESTRING(0 0,10 0)', 0, 10,
- 'LINESTRING(0 0,10 0)');
+SELECT 'L1', test_wrapx(
+ 'LINESTRING(0 0,10 0)', 2, 10,
+ CASE WHEN geos_version() >= 315
+ THEN 'LINESTRING(2 0,10 0,12 0)'
+ ELSE 'MULTILINESTRING((10 0,12 0),(2 0,10 0))'
+ END);
-SELECT 'L4', test(
- 'LINESTRING(0 0,10 0)', 10, -10,
+SELECT 'L2', test_wrapx(
+ 'LINESTRING(0 0,10 0)', 8, -10,
+ THEN 'LINESTRING(-2 0,0 0,8 0)'
+ ELSE 'MULTILINESTRING((0 0,8 0),(-2 0,0 0))'
+ END);
-SELECT 'ML1', test(
- 'MULTILINESTRING((-10 0,0 0),(0 0,10 0))', 0, 20,
- 'MULTILINESTRING((10 0,20 0),(0 0,10 0))');
+SELECT 'L3', test_wrapx(
+ 'LINESTRING(0 0,10 0)', 0, 10,
+ 'LINESTRING(0 0,10 0)');
-SELECT 'ML2', test(
- 'MULTILINESTRING((-10 0,0 0),(0 0,10 0))', 0, -20,
- 'MULTILINESTRING((-10 0,0 0),(-20 0,-10 0))');
+SELECT 'L4', test_wrapx(
+ 'LINESTRING(0 0,10 0)', 10, -10,
-SELECT 'ML3', test(
- 'MULTILINESTRING((10 0,5 0),(-10 0,0 0),(0 0,5 0))', 0, -20,
- 'MULTILINESTRING((-10 0,0 0),(-15 0,-10 0),(-20 0,-15 0))');
+SELECT 'ML1', test_wrapx(
+ 'MULTILINESTRING((-10 0,0 0),(0 0,10 0))', 0, 20,
+ 'MULTILINESTRING((10 0,20 0),(0 0,10 0))');
-SELECT 'A1', test(
- 'POLYGON((0 0,10 0,10 10,0 10,0 0),
- (1 2,3 2,3 4,1 4,1 2),
- (4 2,6 2,6 4,4 4,4 2),
- (7 2,9 2,9 4,7 4,7 2))', 5, 10,
- 'POLYGON((5 0,5 2,6 2,6 4,5 4,5 10,10 10,15 10,15 4,14 4,14 2,15 2,15 0,10 0,5 0),
- (11 2,13 2,13 4,11 4,11 2),
- (7 2,9 2,9 4,7 4,7 2))');
+SELECT 'ML2', test_wrapx(
+ 'MULTILINESTRING((-10 0,0 0),(0 0,10 0))', 0, -20,
+ 'MULTILINESTRING((-10 0,0 0),(-20 0,-10 0))');
-SELECT 'A2', test(
- (7 2,9 2,9 4,7 4,7 2))', 5, -10,
- 'POLYGON((-5 0,-5 2,-4 2,-4 4,-5 4,-5 10,0 10,5 10,5 4,4 4,4 2,5 2,5 0,0 0,-5 0),
- (-3 2,-1 2,-1 4,-3 4,-3 2))');
+SELECT 'ML3', test_wrapx(
+ 'MULTILINESTRING((10 0,5 0),(-10 0,0 0),(0 0,5 0))', 0, -20,
+ 'MULTILINESTRING((-10 0,0 0),(-15 0,-10 0),(-20 0,-15 0))');
-SELECT 'C1', test(
- POLYGON((0 0,10 0,10 10,0 10,0 0),
- (7 2,9 2,9 4,7 4,7 2)),
- POINT(2 20),
- POINT(7 -20),
- LINESTRING(0 40,10 40)
- 5, -10,
- POLYGON((-5 0,-5 2,-4 2,-4 4,-5 4,-5 10,0 10,5 10,5 4,4 4,4 2,5 2,5 0,0 0,-5 0),
- (-3 2,-1 2,-1 4,-3 4,-3 2)),
- MULTILINESTRING((0 40,5 40),(-5 40,0 40)),
- POINT(2 20),
- POINT(-3 -20)
+SELECT 'A1', test_wrapx(
+ 'POLYGON((0 0,10 0,10 10,0 10,0 0),
+ (1 2,3 2,3 4,1 4,1 2),
+ (4 2,6 2,6 4,4 4,4 2),
+ (7 2,9 2,9 4,7 4,7 2))', 5, 10,
+ 'POLYGON((5 0,5 2,6 2,6 4,5 4,5 10,10 10,15 10,15 4,14 4,14 2,15 2,15 0,10 0,5 0),
+ (11 2,13 2,13 4,11 4,11 2),
+ (7 2,9 2,9 4,7 4,7 2))');
-DROP FUNCTION test(geometry, float8, float8, geometry);
+SELECT 'A2', test_wrapx(
+ (7 2,9 2,9 4,7 4,7 2))', 5, -10,
+ 'POLYGON((-5 0,-5 2,-4 2,-4 4,-5 4,-5 10,0 10,5 10,5 4,4 4,4 2,5 2,5 0,0 0,-5 0),
+ (-3 2,-1 2,-1 4,-3 4,-3 2))');
+SELECT 'C1', test_wrapx(
+ POLYGON((0 0,10 0,10 10,0 10,0 0),
+ (7 2,9 2,9 4,7 4,7 2)),
+ POINT(2 20),
+ POINT(7 -20),
+ LINESTRING(0 40,10 40)
+ 5, -10,
+ THEN 'GEOMETRYCOLLECTION(POLYGON((-5 0,-5 2,-4 2,-4 4,-5 4,-5 10,0 10,5 10,5 4,4 4,4 2,5 2,5 0,0 0,-5 0),(1 2,3 2,3 4,1 4,1 2),(-3 2,-1 2,-1 4,-3 4,-3 2)),LINESTRING(-5 40,0 40,5 40),POINT(2 20),POINT(-3 -20))'
+ ELSE 'GEOMETRYCOLLECTION(
+ POLYGON((-5 0,-5 2,-4 2,-4 4,-5 4,-5 10,0 10,5 10,5 4,4 4,4 2,5 2,5 0,0 0,-5 0),
+ (-3 2,-1 2,-1 4,-3 4,-3 2)),
+ MULTILINESTRING((0 40,5 40),(-5 40,0 40)),
+ POINT(2 20),
+ POINT(-3 -20)
+ END);
+DROP FUNCTION test_wrapx(geometry, float8, float8, geometry);
Summary of changes:
liblwgeom/cunit/cu_wrapx.c | 8 +-
regress/core/fixedoverlay.sql | 16 +--
regress/core/fixedoverlay_expected | 2 -
regress/core/geos315.sql | 59 ++++++-----
regress/core/geos315_expected | 2 +
regress/core/wrapx.sql | 198 ++++++++++++++++++++-----------------
6 files changed, 159 insertions(+), 126 deletions(-)
hooks/post-receive
