[SCM] PostGIS branch master updated. 3.7.0alpha1-86-g63345d444
Thu Jul 9 03:46:13 PDT 2026
the project "PostGIS".
       via  63345d444bdb865524444eb0f4a4189a0890cf0a (commit)
       via  09f9558ae04577e6277b3c1c30cbb8921ea58a71 (commit)
       via  9c931e6fcdcf78a5d605a0d445b4a51564f78ff5 (commit)
       via  ca3323d8c748dd806bab188028bb61c5f67b39af (commit)
      from  ec3216f2897fa8dccf7db5750e38653f9b012261 (commit)
revisions in full, below.
commit 63345d444bdb865524444eb0f4a4189a0890cf0a
Merge: ec3216f28 09f9558ae
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Thu Jul 9 14:11:48 2026 +0400
    Merge pull request #1160 from Komzpa/codex/ci-wrapx-collection-output
    Stabilize GEOS main linework handling
commit 09f9558ae04577e6277b3c1c30cbb8921ea58a71
Date:   Thu Jul 9 11:33:15 2026 +0400
    Keep manual examples stable across GEOS linework merging
    Use disjoint lines in the ST_Union array example and avoid a vertex
    inside a straight shared stretch in the ST_SharedPaths examples, so
    the documented outputs are identical across GEOS versions. Document
    that ST_SharedPaths segmentation may vary with the GEOS version.
diff --git a/doc/reference_overlay.xml b/doc/reference_overlay.xml
index 64a20bbf2..8e96c75bf 100644
--- a/doc/reference_overlay.xml
+++ b/doc/reference_overlay.xml
@@ -1056,9 +1056,9 @@ FROM (
 <para>This example unions an array of linestrings.</para>
 <programlisting>SELECT ST_AsText(ST_Union(ARRAY[
     ST_GeomFromText('LINESTRING(1 2, 3 4)'),
-    ST_GeomFromText('LINESTRING(3 4, 4 5)')
+    ST_GeomFromText('LINESTRING(4 5, 5 6)')
 ])) As wktunion;</programlisting>
-<screen>MULTILINESTRING((1 2,3 4),(3 4,4 5))</screen>
+<screen>MULTILINESTRING((1 2,3 4),(4 5,5 6))</screen>
       </refsection>
       <refsection>
         <title>See Also</title>
diff --git a/doc/reference_processing.xml b/doc/reference_processing.xml
index 72e46b615..ffa35213f 100644
--- a/doc/reference_processing.xml
+++ b/doc/reference_processing.xml
@@ -2596,6 +2596,8 @@ FROM (SELECT ST_Polygonize(geom_4269) AS polycoll
       </refsection>
       <refsection>
         <title>Examples: Finding shared paths</title>
+        <para>Adjacent shared path segments may be returned as separate or merged LineStrings
+          depending on the GEOS version.</para>
         <informaltable>
           <tgroup cols="1">
             <tbody>
@@ -2622,11 +2624,11 @@ FROM (SELECT ST_Polygonize(geom_4269) AS polycoll
                   <programlisting>
  SELECT ST_AsText(ST_SharedPaths(ST_GeomFromText('MULTILINESTRING((26 125,26 200,126 200,126 125,26 125),
        (51 150,101 150,76 175,51 150))'),
-    ST_GeomFromText('LINESTRING(151 100,126 156.25,126 125,90 161, 76 175)')
+    ST_GeomFromText('LINESTRING(151 100,126 156.25,126 125,101 150, 76 175)')
   )</programlisting>
 <screen>GEOMETRYCOLLECTION(MULTILINESTRING((126 156.25,126 125),
- (101 150,90 161),(90 161,76 175)),MULTILINESTRING EMPTY)</screen>
+ (101 150,76 175)),MULTILINESTRING EMPTY)</screen>
             </para>
             </entry>
         </row>
@@ -2636,13 +2638,13 @@ FROM (SELECT ST_Polygonize(geom_4269) AS polycoll
 <lineannotation>
 same example but linestring orientation flipped
 </lineannotation>
-SELECT ST_AsText(ST_SharedPaths(ST_GeomFromText('LINESTRING(76 175,90 161,126 125,126 156.25,151 100)'),
+SELECT ST_AsText(ST_SharedPaths(ST_GeomFromText('LINESTRING(76 175,101 150,126 125,126 156.25,151 100)'),
   )</programlisting>
 <screen>GEOMETRYCOLLECTION(MULTILINESTRING EMPTY,
-MULTILINESTRING((76 175,90 161),(90 161,101 150),(126 125,126 156.25)))</screen>
+MULTILINESTRING((76 175,101 150),(126 125,126 156.25)))</screen>
             </para>
             </entry>
         </row>
commit 9c931e6fcdcf78a5d605a0d445b4a51564f78ff5
    Fix GEOS version parser in wrapx regression
    A stray ']' made the regexp never match, so the GEOS >= 3.15
    expected outputs were never selected.
diff --git a/regress/core/wrapx.sql b/regress/core/wrapx.sql
index 321958d52..b35504961 100644
--- a/regress/core/wrapx.sql
+++ b/regress/core/wrapx.sql
@@ -15,7 +15,7 @@ $$ LANGUAGE 'plpgsql';
 CREATE OR REPLACE FUNCTION geos_version()
 RETURNS integer AS $$
     SELECT (matches[1]::integer * 100) + matches[2]::integer
-    FROM regexp_match(postgis_geos_version(), E'^([0-9]+)]\\.([0-9]+)') AS matches;
+    FROM regexp_match(postgis_geos_version(), E'^([0-9]+)\\.([0-9]+)') AS matches;
 $$ LANGUAGE 'sql' IMMUTABLE;
commit ca3323d8c748dd806bab188028bb61c5f67b39af
    Preserve topology overlay junctions under GEOS >= 3.15 line merging
    GEOS >= 3.15 returns overlay output line-merged, hiding the junctions
    between the shared and non-shared linework of a new line inside line
    interiors. Collect the crossing points and the mod-2 boundary of the
    shared linework from the intersection, and re-split the noded line at
    them: a no-op with older GEOS, which keeps them as component
    boundaries.
    Assert edge count instead of edge ids in the snap regression: the
    final topology is identical but edge id assignment depends on GEOS
    overlay output ordering.
    References https://github.com/postgis/postgis/pull/1160
diff --git a/NEWS b/NEWS
index 4fa4d414c..d101510e3 100644
--- a/NEWS
+++ b/NEWS
@@ -7,6 +7,8 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
 * Bug Fixes *
+ - GH-1160, [topology] Preserve overlay intersection boundaries when
+          noding lines with GEOS main (Darafei Praliaskouski)
  - #6093, Fix SQL generation on ppc64el when NURBS comments are
           preprocessed with AltiVec vector macros (Darafei Praliaskouski)
  - #6094, [upgrade] Avoid legacy string literal warnings in downgrade checks
diff --git a/liblwgeom/topo/lwgeom_topo.c b/liblwgeom/topo/lwgeom_topo.c
index b119d5dae..a8d00c108 100644
--- a/liblwgeom/topo/lwgeom_topo.c
+++ b/liblwgeom/topo/lwgeom_topo.c
@@ -7379,6 +7379,57 @@ _lwt_split_by_nodes(const LWGEOM *g, const LWGEOM *nodes)
   return bg;
+ * Compute the junction points between the overlay intersection linework
+ * (shared paths and crossings between the noded line and nearby edges)
+ * and the rest of the noded line: the 0-dimensional intersection
+ * components plus the mod-2 boundary of the 1-dimensional ones.
+ * These junctions must become topology nodes. GEOS >= 3.15 returns
+ * overlay output line-merged, which would otherwise hide them inside
+ * line interiors. Older GEOS keeps them as boundaries of the overlay
+ * output components, making a split at them a no-op.
+ * Returns a MULTIPOINT.
+static LWGEOM *
+_lwt_overlay_split_points(const LWGEOM *xset)
+  LWGEOM *multi = lwgeom_as_multi(xset);
+  LWCOLLECTION *xcol = lwgeom_as_lwcollection(multi);
+  LWCOLLECTION *epoints = lwcollection_extract(xcol, POINTTYPE);
+  LWCOLLECTION *points = lwcollection_construct_empty(MULTIPOINTTYPE, xset->srid,
+    FLAGS_GET_Z(xset->flags), FLAGS_GET_M(xset->flags));
+  LWCOLLECTION *lines = lwcollection_extract(xcol, LINETYPE);
+  LWGEOM *bnd = lwgeom_boundary(lwcollection_as_lwgeom(lines));
+  uint32_t i;
+  for (i = 0; i < epoints->ngeoms; i++)
+    lwcollection_add_lwgeom(points, lwgeom_clone_deep(epoints->geoms[i]));
+  if (bnd)
+    LWCOLLECTION *bcol = lwgeom_as_lwcollection(bnd);
+    if (bcol)
+      for (i = 0; i < bcol->ngeoms; i++)
+        lwcollection_add_lwgeom(points, lwgeom_clone_deep(bcol->geoms[i]));
+    else if (!lwgeom_is_empty(bnd))
+      lwcollection_add_lwgeom(points, lwgeom_clone_deep(bnd));
+    lwgeom_free(bnd);
+  lwcollection_release(epoints);
+  lwcollection_release(lines);
+  lwgeom_release(multi);
+  points->srid = xset->srid;
+  return lwcollection_as_lwgeom(points);
 static LWT_ELEMID*
 _lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges,
             int handleFaceSplit, int maxNewEdges)
@@ -7386,7 +7437,7 @@ _lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges,
   LWGEOM *geomsbuf[1];
   LWGEOM **geoms;
   uint32_t ngeoms;
-  LWGEOM *noded, *tmp;
+  LWGEOM *noded, *tmp, *xsplit = NULL;
   LWCOLLECTION *col;
   LWT_ELEMID *ids;
   LWT_ISO_EDGE *edges;
@@ -7601,6 +7652,9 @@ _lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges,
     xset = lwgeom_intersection(noded, iedges);
     LWDEBUGG(1, xset, "Intersected");
     lwgeom_free(noded);
+    /* Collect the junctions between shared and non-shared linework
+     * before line merging can hide them (see step 2.5) */
+    xsplit = _lwt_overlay_split_points(xset);
     /* We linemerge here because INTERSECTION, as of GEOS 3.8,
      * will result in shared segments being output as multiple
@@ -7691,6 +7745,25 @@ _lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges,
     lwcollection_release(col);
+  /* 2.5. Split by overlay junctions
+   * GEOS >= 3.15 returns line-merged overlay output, hiding the
+   * junctions between shared and non-shared linework inside line
+   * interiors. Splitting restores them; older GEOS keeps them as
+   * component boundaries and the split is a no-op.
+  if ( xsplit )
+    if ( !lwgeom_is_empty(xsplit) )
+      tmp = _lwt_split_by_nodes(noded, xsplit);
+      lwgeom_free(noded);
+      noded = tmp;
+      LWDEBUGG(1, noded, "Overlay-junction-split");
+    lwgeom_free(xsplit);
   LWDEBUG(1, "Freeing up nearby elements");
diff --git a/topology/test/regress/topogeo_addlinestring.sql b/topology/test/regress/topogeo_addlinestring.sql
index 5946ceec0..1f67b7198 100644
--- a/topology/test/regress/topogeo_addlinestring.sql
+++ b/topology/test/regress/topogeo_addlinestring.sql
@@ -99,9 +99,9 @@ SELECT 'cross', TopoGeo_addLineString('city_data', 'SRID=4326;LINESTRING(49 18,
 SELECT check_changes('cross');
 -- Snapping (and splitting a face)
-SELECT 'snap', TopoGeo_addLineString('city_data', 'SRID=4326;LINESTRING(18 22.2, 22.5 22.2, 21.2 20.5)', 1) ORDER BY 2;
+SELECT 'snap', COUNT(*) FROM TopoGeo_addLineString('city_data', 'SRID=4326;LINESTRING(18 22.2, 22.5 22.2, 21.2 20.5)', 1);
 SELECT check_changes('snap');
-SELECT 'snap_again', TopoGeo_addLineString('city_data', 'SRID=4326;LINESTRING(18 22.2, 22.5 22.2, 21.2 20.5)', 1) ORDER BY 2;
+SELECT 'snap_again', COUNT(*) FROM TopoGeo_addLineString('city_data', 'SRID=4326;LINESTRING(18 22.2, 22.5 22.2, 21.2 20.5)', 1);
 SELECT check_changes('snap_again');
 -- A mix of crossing and overlapping, splitting another face
diff --git a/topology/test/regress/topogeo_addlinestring_expected b/topology/test/regress/topogeo_addlinestring_expected
index 5035a8654..957ed5f3c 100644
--- a/topology/test/regress/topogeo_addlinestring_expected
+++ b/topology/test/regress/topogeo_addlinestring_expected
@@ -38,9 +38,7 @@ cross|E|LINESTRING(47 14,47 17.6)
 cross|E|LINESTRING(47 17.6,47 22)
 cross|E|LINESTRING(47 17.6,44 17)
 cross|E|LINESTRING(49 18,47 17.6)
-snap|7
-snap|36
-snap|38
+snap|3
 snap|N||POINT(21.2 20.5)
 snap|N||POINT(22.35 22)
 snap|N||POINT(18 22.2)
@@ -48,9 +46,7 @@ snap|E|LINESTRING(22.35 22,35 22)
 snap|E|LINESTRING(22.35 22,21.2 20.5)
 snap|E|LINESTRING(21 22,22.35 22)
 snap|E|LINESTRING(18 22.2,21 22)
-snap_again|7
-snap_again|36
-snap_again|38
+snap_again|3
 crossover|4
 crossover|N||POINT(21 10)
 crossover|N||POINT(16.2 14)
Summary of changes:
 NEWS                                               |  2 +
 doc/reference_overlay.xml                          |  4 +-
 doc/reference_processing.xml                       | 10 +--
 liblwgeom/topo/lwgeom_topo.c                       | 75 +++++++++++++++++++++-
 regress/core/wrapx.sql                             |  2 +-
 topology/test/regress/topogeo_addlinestring.sql    |  4 +-
 .../test/regress/topogeo_addlinestring_expected    |  8 +--
 7 files changed, 89 insertions(+), 16 deletions(-)
hooks/post-receive
