[SCM] PostGIS branch master updated. 3.7.0alpha1-266-g05dee3c02
git at osgeo.org
git at osgeo.org
Sun Jul 12 18:39:15 PDT 2026
the project "PostGIS".
via 05dee3c02ffc350df5f5f7e9f00c0d02810bc8c1 (commit)
from 321c33cc45c83e5c8faf032fb59b61df4fa1fc63 (commit)
revisions in full, below.
commit 05dee3c02ffc350df5f5f7e9f00c0d02810bc8c1
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date: Mon Jul 13 01:38:32 2026 +0000
Translated PostGIS Manual using Weblate (Japanese)
Currently translated at 95.2% (5764 of 6049 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/ja/
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index f27f0c2b7..e691836ef 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -10,7 +10,7 @@ msgstr ""
"Project-Id-Version: postgis 3.5\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2026-07-05 04:20+0000\n"
-"PO-Revision-Date: 2026-07-10 10:39+0000\n"
+"PO-Revision-Date: 2026-07-13 01:39+0000\n"
"Last-Translator: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>\n"
"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/postgis-"
"manual/ja/>\n"
@@ -23217,7 +23217,7 @@ msgstr "例: 3版"
#. Tag: para
#, no-c-format
msgid "Flip coordinates and output extended EPSG (16 | 1)"
-msgstr ""
+msgstr "X値とY値を入れ替えて空間参照系に関するオプションを (16 | 1)で指定した出力"
#. Tag: refpurpose
#, no-c-format
@@ -23528,6 +23528,12 @@ msgid ""
"detail before tile conversion, simplify the geometry in map coordinates "
"before calling <function>ST_AsMVTGeom</function>."
msgstr ""
+"この関数は整数タイル座標空間に適切なジオメトリーの単純化を行います。タイル座"
+"標への変換の後、整数グリッドに座標値をスナップさせ、重複ポイントは除去され、"
+"直線上のポイントも除去されます。この関数は <xref linkend=\"ST_Simplify\"/>.の"
+"ような多目的、縮尺依存の単純化関数とは異なります。タイル変換前に細かい物を減"
+"らすには、<function>ST_AsMVTGeom</function>の前に地図の座標系のジオメトリーを"
+"単純化します。"
#. Tag: para
#, no-c-format
@@ -24302,6 +24308,8 @@ msgid ""
"This example shows that the GeoHash for a line containing a point is a "
"prefix of the point code."
msgstr ""
+"この例ではポイントを含むラインのGeoHashはポイントをすべて含む最長のコードにな"
+"ることを示しています。"
#. Tag: para
#, no-c-format
@@ -24352,6 +24360,8 @@ msgid ""
"This example relies on the implicit cast from geometry to box2d for the "
"second parameter."
msgstr ""
+"この例では第2パラメーターは、ジオメトリーからbox2dへの暗黙のキャストに頼って"
+"います。"
#. Tag: para
#, no-c-format
@@ -25212,22 +25222,22 @@ msgstr "非集約関数の例"
#. Tag: para
#, no-c-format
msgid "3D example - sort of supports 3D (and with mixed geometry types!)"
-msgstr ""
+msgstr "3次元の例 - 3次元対応のです (そしてジオメトリータイプが混在します!)"
#. Tag: para
#, no-c-format
msgid "This 3D example does not mix dimensions."
-msgstr ""
+msgstr "この3次元の例では座標次元の混在はありません。"
#. Tag: para
#, no-c-format
msgid "This example unions an array built from a query."
-msgstr ""
+msgstr "この例ではクエリーから構築された配列を結合しています。"
#. Tag: para
#, no-c-format
msgid "This example unions an array of linestrings."
-msgstr ""
+msgstr "この例ではラインストリングの配列を結合しています。"
#. Tag: para
#, no-c-format
@@ -25508,6 +25518,8 @@ msgid ""
"A lighter, less smooth circle using only 2 points per quarter circle is an "
"octagon."
msgstr ""
+"四分円に2ポイントだけ使うようにすると、より軽くなるけど円が角張って八角形にな"
+"ります。"
#. Tag: para
#, no-c-format
@@ -25516,6 +25528,8 @@ msgid ""
"latitude by transforming to the Massachusetts state plane meter projection "
"and then buffering."
msgstr ""
+"次の例では、NAD83経度緯度での100メートルの八角形を生成します。"
+"マサチューセッツ州メートル単位平面に投影変換してバッファーを生成しています。"
#. Tag: para
#, no-c-format
@@ -26001,6 +26015,9 @@ msgid ""
"geometries use <xref linkend=\"ST_Collect\"/> (e.g. "
"<code>ST_ConcaveHull(ST_Collect(geom ), 0.80)</code>."
msgstr ""
+"これは集約関数ではありません。ジオメトリー集合の凹包を計算するには<xref "
+"linkend=\"ST_Collect\"/>を使います (例: <code>ST_ConcaveHull(ST_Collect"
+"(geom ), 0.80)</code>)。"
#. Tag: para
#, no-c-format
@@ -26035,7 +26052,7 @@ msgstr "ST_Collectの併用でジオメトリ集合の凹包の計算。"
#. Tag: para
#, no-c-format
msgid "This example estimates an infected area from point observations."
-msgstr ""
+msgstr "この例ではポイント観察から汚染領域を見積もっています。"
#. Tag: para
#, no-c-format
@@ -26114,7 +26131,7 @@ msgstr "ST_Collectを使ってジオメトリ集合の凸包を計算します
#, no-c-format
msgid ""
"This example returns an estimated infected area from point observations."
-msgstr ""
+msgstr "この例ではポイント観察から感染領域の見積もりを返します。"
#. Tag: para
#, no-c-format
@@ -26181,12 +26198,12 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid "Delaunay triangles as a MultiLineString"
-msgstr ""
+msgstr "マルチストリングのドロネー三角形"
#. Tag: para
#, no-c-format
msgid "Delaunay triangles of 45 points as 55 triangle polygons"
-msgstr ""
+msgstr "55個の三角形ポリゴンの45ポイントのドロネー三角形"
#. Tag: para
#, no-c-format
@@ -27320,6 +27337,8 @@ msgid ""
"For the same example as <xref linkend=\"ST_Simplify\"/>, "
"ST_SimplifyPreserveTopology prevents the geometry from disappearing."
msgstr ""
+"<xref linkend=\"ST_Simplify\"/>の例と同じくST_SimplifyPreserveTopologyは"
+"ジオメトリーの消滅を予防しています。"
#. Tag: para
#, no-c-format
Summary of changes:
doc/po/ja/postgis-manual.po | 39 +++++++++++++++++++++++++++++----------
1 file changed, 29 insertions(+), 10 deletions(-)
hooks/post-receive
