[SCM] PostGIS branch master updated. 3.7.0alpha1-595-g9d142afa7
git at osgeo.org
git at osgeo.org
Sat Jul 18 11:56:22 PDT 2026
the project "PostGIS".
via 9d142afa7d7b6bc11e73059f2ce71e5252be7395 (commit)
from 76b5538cca7434f6ec94075e3fe99ac99cd86884 (commit)
revisions in full, below.
commit 9d142afa7d7b6bc11e73059f2ce71e5252be7395
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Sat Jul 18 11:56:21 2026 -0700
ci: split long regress checks (!362)
This refactors the Woodpecker regress pipeline so the current long poles report independently and pull requests finish a bounded upgrade sweep.
Observed failure:
- regress pipeline 5097 reached `upgradecheck-pg16-postgis`, then Woodie killed the container wait after about 66 minutes with `context deadline exceeded`
- the step reported exit code 0, so this was an infrastructure timeout rather than a PostGIS assertion failure
Changes:
- keep the split PostgreSQL 14/16/18 installcheck jobs and serialize jobs sharing one build tree
- build a separate PostgreSQL 16 upgrade tree immediately after `autogen`
- prepare that isolated tree with `make staged-install`, which script upgrades require
- split the all-upgrades sweep by extension with `--extension`
- add `--oldest`, which semantically sorts sources and runs the oldest compatible, non-skipped source with an update path
- use `--oldest` only for pull-request pipelines; master and tag pipelines keep the exhaustive sweep
- serialize the four extension sweeps because they share the installed PostgreSQL instance
- give each serialized extension sweep its own FIFO and summary log
Checks:
- `python3 utils/test_check_all_upgrades.py` (7 tests)
- `sh -n utils/check_all_upgrades.sh`
- `sh -n ci/dronie/postgis_tools.sh`
- `shellcheck -S error utils/check_all_upgrades.sh ci/dronie/postgis_tools.sh`
- `woodpecker-cli:v3 lint .woodpecker/regress.yml`
- `git diff --check`
Co-authored-by: Darafei Praliaskouski <me at komzpa.net>
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/362
diff --git a/.woodpecker/regress.yml b/.woodpecker/regress.yml
index 2cdaa2cc4..666b16fea 100644
--- a/.woodpecker/regress.yml
+++ b/.woodpecker/regress.yml
@@ -6,6 +6,7 @@ variables:
test-image: &test-image repo.osgeo.org/postgis/build-test:debian13
steps-env: &steps-env
- export PATH=/usr/lib/postgresql/$${PGVER}/bin:$${PATH}
+ - export PGHOST=/tmp
- export PGPORT=$$(grep ^port /etc/postgresql/$${PGVER}/main/postgresql.conf | awk '{print $$3}')
- export POSTGIS_REGRESS_DB_OWNER=postgis_reg_unprivileged_user
- export RUNTESTFLAGS="-v
@@ -16,7 +17,14 @@ variables:
- export CURRENTVERSION=$$(grep '^POSTGIS_' $${SRCDIR}/Version.config | cut -d= -f2 | paste -sd '.')
- pg_config --version
steps-start-postgresql: &steps-start-postgresql
- - service postgresql start $${PGVER}
+ # The test image can need crash recovery after clone-local startup. Under
+ # multi-workflow I/O load, Debian's default 60-second pg_ctl wait is short.
+ # Use /tmp for the socket: runner-specific /run mounts are not portable.
+ - runuser -u postgres -- pg_ctl
+ -D /var/lib/postgresql/$${PGVER}/main
+ -l /tmp/postgresql-$${PGVER}.log
+ -o "-c config_file=/etc/postgresql/$${PGVER}/main/postgresql.conf -c unix_socket_directories=/tmp"
+ -t 300 start
- psql -c 'select version()' template1
steps-pg-build: &steps-pg-build
- mkdir -p "$${BUILDDIR}"
@@ -26,27 +34,24 @@ variables:
--disable-spellcheck-tests
--enable-lto
--without-interrupt-tests
- --disable-spellcheck-tests
CFLAGS="-O2 -Wall -fno-omit-frame-pointer -Werror"
- - make -j
- steps-pg-test-preinstall: &steps-pg-test-preinstall
- - cd build/pg$${PGVER}
- - make check
- - make check-double-upgrade
- - make check-locked-upgrade
- steps-pg-install: &steps-pg-install
- - make -C build/pg$${PGVER} install
- steps-pg-test-install: &steps-pg-test-install
- - make -C build/pg$${PGVER} installcheck
+ # Matrix jobs provide the parallelism. Keep each build serial: the PostGIS
+ # make graph can otherwise race generation of files such as postgis.control.
+ - make -j1
steps-pg-test-all-upgrades: &steps-pg-test-all-upgrades
- - mkfifo check.fifo
- - tee check.log < check.fifo &
- - $${SRCDIR}/utils/check_all_upgrades.sh -s $${CURRENTVERSION}! > check.fifo
+ - cd "$${BUILDDIR}"
+ - export CHECK_FIFO=check-$${UPGRADE_EXTENSION}.fifo
+ - export CHECK_LOG=check-$${UPGRADE_EXTENSION}.log
+ - rm -f "$${CHECK_FIFO}"
+ - mkfifo "$${CHECK_FIFO}"
+ - tee "$${CHECK_LOG}" < "$${CHECK_FIFO}" &
+ - UPGRADECHECK_ARGS=
+ - if test "$${CI_PIPELINE_EVENT}" = pull_request; then UPGRADECHECK_ARGS=--oldest; fi
+ - $${SRCDIR}/utils/check_all_upgrades.sh -s $${UPGRADECHECK_ARGS} --extension $${UPGRADE_EXTENSION} $${CURRENTVERSION}! > "$${CHECK_FIFO}"
- wait # for tee process to flush its buffers
- echo "-- Summary of upgrade tests --"
- - egrep '(PASS|FAIL|SKIP|INFO|ERROR)' check.log
+ - egrep '(PASS|FAIL|SKIP|INFO|ERROR)' "$${CHECK_LOG}"
clone:
git:
@@ -56,108 +61,194 @@ clone:
partial: false
steps:
autogen:
image: *test-image
pull: true
commands:
- ./autogen.sh
- build-pg14:
+ build:
image: *test-image
depends_on: autogen
- environment:
- PGVER: 14
commands:
- <<: *steps-env
- <<: *steps-pg-build
- build-pg16:
+ build-second-postgresql:
image: *test-image
depends_on: autogen
- environment:
- PGVER: 16
+ when:
+ - matrix:
+ REGRESS_SUITE: cluster-upgrade
commands:
+ - export PGVER=$${SECOND_PGVER}
- <<: *steps-env
- build-pg18:
+ test-preinstall:
image: *test-image
- depends_on: autogen
- environment:
- PGVER: 18
- commands:
- - <<: *steps-env
- - <<: *steps-pg-build
- check-pg14:
- image: *test-image
- depends_on: build-pg14
- environment:
- PGVER: 14
+ depends_on: build
+ when:
+ - matrix:
+ REGRESS_SUITE: preinstall
commands:
- <<: *steps-env
- <<: *steps-start-postgresql
- - <<: *steps-pg-test-preinstall
+ - make -C "$${BUILDDIR}" $${REGRESS_TARGET}
- check-pg18:
+ test-install:
image: *test-image
- depends_on: build-pg18
- environment:
- PGVER: 18
+ depends_on: build
+ when:
+ - matrix:
+ REGRESS_SUITE: install
commands:
- <<: *steps-env
+ - make -C "$${BUILDDIR}" install
- installcheck-pg14:
+ test-upgrades:
image: *test-image
- environment:
- PGVER: 14
+ depends_on: build
+ when:
+ - matrix:
+ REGRESS_SUITE: extension-upgrade
commands:
- <<: *steps-env
- - <<: *steps-pg-install
- - <<: *steps-pg-test-install
- installcheck-pg16:
- depends_on: build-pg16
- environment:
- PGVER: 16
- commands:
- - <<: *steps-env
- - <<: *steps-start-postgresql
- installcheck-pg18:
- environment:
- PGVER: 18
- commands:
- - <<: *steps-env
- upgradecheck-pg16:
- depends_on: installcheck-pg16
- environment:
- PGVER: 16
- commands:
- - <<: *steps-env
+ - make -C "$${BUILDDIR}" staged-install
- <<: *steps-pg-test-all-upgrades
- cluster-upgradecheck-pg14-to-pg18:
+ test-cluster-upgrade:
image: *test-image
- depends_on: [ installcheck-pg14, installcheck-pg18 ]
+ depends_on: [ build, build-second-postgresql ]
+ when:
+ - matrix:
commands:
- - make -C build/pg14 install
- - make -C build/pg18 install
- - su postgres -c 'utils/check_cluster_upgrade.sh -i regress/hooks/cluster-upgrade-geography.sql /usr/lib/postgresql/14/bin/pg_config /usr/lib/postgresql/18/bin/pg_config'
+ - make -C build/pg$${PGVER} install
+ - make -C build/pg$${SECOND_PGVER} install
+ - su postgres -c 'utils/check_cluster_upgrade.sh -i regress/hooks/cluster-upgrade-geography.sql /usr/lib/postgresql/'$${PGVER}'/bin/pg_config /usr/lib/postgresql/'$${SECOND_PGVER}'/bin/pg_config'
+# Every entry is an independent workflow with its own clone, workspace,
+# containers, PostgreSQL instance, and regression database. Splitting at this
+# boundary lets Woodpecker schedule the long suites across agents safely.
+matrix:
+ include:
+ - PGVER: "14"
+ SECOND_PGVER: "0"
+ REGRESS_TARGET: check
+ UPGRADE_EXTENSION: none
+ - PGVER: "14"
+ SECOND_PGVER: "0"
+ REGRESS_TARGET: check-double-upgrade
+ - PGVER: "14"
+ SECOND_PGVER: "0"
+ REGRESS_TARGET: check-locked-upgrade
+ - PGVER: "18"
+ SECOND_PGVER: "0"
+ - PGVER: "18"
+ SECOND_PGVER: "0"
+ - PGVER: "18"
+ SECOND_PGVER: "0"
+ - PGVER: "14"
+ SECOND_PGVER: "0"
+ REGRESS_TARGET: installcheck-base
+ - PGVER: "14"
+ SECOND_PGVER: "0"
+ REGRESS_TARGET: installcheck-upgrade-from-unpackaged
+ - PGVER: "14"
+ SECOND_PGVER: "0"
+ REGRESS_TARGET: installcheck-upgrade-from-unpackaged-by-func
+ - PGVER: "14"
+ SECOND_PGVER: "0"
+ REGRESS_TARGET: installcheck-upgrade-from-packaged-by-func
+ - PGVER: "16"
+ SECOND_PGVER: "0"
+ - PGVER: "16"
+ SECOND_PGVER: "0"
+ - PGVER: "16"
+ SECOND_PGVER: "0"
+ - PGVER: "16"
+ SECOND_PGVER: "0"
+ - PGVER: "18"
+ SECOND_PGVER: "0"
+ - PGVER: "18"
+ SECOND_PGVER: "0"
+ - PGVER: "18"
+ SECOND_PGVER: "0"
+ - PGVER: "18"
+ SECOND_PGVER: "0"
+ - PGVER: "16"
+ SECOND_PGVER: "0"
+ REGRESS_TARGET: none
+ UPGRADE_EXTENSION: postgis
+ - PGVER: "16"
+ SECOND_PGVER: "0"
+ UPGRADE_EXTENSION: postgis_topology
+ - PGVER: "16"
+ SECOND_PGVER: "0"
+ UPGRADE_EXTENSION: postgis_raster
+ - PGVER: "16"
+ SECOND_PGVER: "0"
+ UPGRADE_EXTENSION: postgis_sfcgal
+ - PGVER: "14"
+ SECOND_PGVER: "18"
diff --git a/ci/dronie/postgis_tools.sh b/ci/dronie/postgis_tools.sh
index b8f01a188..ae3e36ae4 100644
--- a/ci/dronie/postgis_tools.sh
+++ b/ci/dronie/postgis_tools.sh
@@ -1,4 +1,4 @@
- #!/usr/bin/env bash
+#!/usr/bin/env bash
# Exit on first error
set -e
@@ -11,3 +11,4 @@ make install
/tmp/pgx/bin/postgis help
/tmp/pgx/bin/shp2pgsql
/tmp/pgx/bin/raster2pgsql
+python3 utils/test_check_all_upgrades.py
diff --git a/regress/core/regress_index.sql b/regress/core/regress_index.sql
index 09c71254d..4b0ea9676 100644
--- a/regress/core/regress_index.sql
+++ b/regress/core/regress_index.sql
@@ -132,14 +132,13 @@ SELECT 'expr &&', id, estimate_error(
SELECT 'st_orderingequals_idx',
qnodes('select * from test where ST_OrderingEquals(the_geom, ST_MakePoint(0,0))');
-CREATE TABLE st_orderingequals_volatile_calls (num integer);
-INSERT INTO st_orderingequals_volatile_calls VALUES (0);
+CREATE SEQUENCE st_orderingequals_volatile_calls;
CREATE OR REPLACE FUNCTION st_orderingequals_volatile_geom(g geometry)
RETURNS geometry
LANGUAGE 'plpgsql' VOLATILE AS $$
BEGIN
- UPDATE st_orderingequals_volatile_calls SET num = num + 1;
+ PERFORM nextval('st_orderingequals_volatile_calls');
RETURN g;
END;
@@ -148,10 +147,10 @@ SELECT 'st_orderingequals_volatile_count', count(*)
FROM (VALUES (ST_MakePoint(0,0))) AS q(g)
JOIN test t ON ST_OrderingEquals(st_orderingequals_volatile_geom(t.the_geom), q.g);
-SELECT 'st_orderingequals_volatile', num FROM st_orderingequals_volatile_calls;
+SELECT 'st_orderingequals_volatile', last_value FROM st_orderingequals_volatile_calls;
DROP FUNCTION st_orderingequals_volatile_geom(geometry);
-DROP TABLE st_orderingequals_volatile_calls;
+DROP SEQUENCE st_orderingequals_volatile_calls;
CREATE SCHEMA st_orderingequals_search_path;
CREATE FUNCTION st_orderingequals_search_path.geometry_bbox_false(geometry, geometry)
diff --git a/utils/check_all_upgrades.sh b/utils/check_all_upgrades.sh
index 8e02e21a1..85edc853a 100755
--- a/utils/check_all_upgrades.sh
+++ b/utils/check_all_upgrades.sh
@@ -7,6 +7,8 @@ TMPDIR=$(mktemp -d "${TMPDIR:-/tmp}/check_all_upgrades.XXXXXX") || exit 1
PGVER=`pg_config --version | awk '{print $2}'`
PGVER_MAJOR=$(echo "${PGVER}" | sed 's/\.[^\.]*//' | sed 's/\(alpha\|beta\|rc\).*//' )
SKIP_LABEL_REGEXP=
+ONLY_EXTENSION=
+ONLY_OLDEST=0
echo "INFO: PostgreSQL version: ${PGVER} [${PGVER_MAJOR}]"
MAKE=$(which gmake make | head -1)
BUILDDIR=$PWD # TODO: allow override ?
@@ -24,6 +26,8 @@ usage() {
echo "\t--help|-h Print this usage text"
echo "\t-s Stop on first failure"
echo "\t--skip <regexp> Do not run tests with label matching given extended regexp"
+ echo "\t--extension <name> Only run upgrade tests for the named extension"
+ echo "\t--oldest Only run the oldest compatible upgrade source"
echo "Positional parameters:"
echo "\t<to_version> Target upgrade version. See regress/run_test.pl help on --upgrade-path <to> parameter."
@@ -34,6 +38,11 @@ while test -n "$1"; do
elif test "$1" = "--skip"; then
shift
SKIP_LABEL_REGEXP=$1
+ elif test "$1" = "--extension"; then
+ shift
+ ONLY_EXTENSION=$1
+ elif test "$1" = "--oldest"; then
+ ONLY_OLDEST=1
elif test "$1" = "-h" -o "$1" = "--help"; then
usage
exit 0
@@ -89,6 +98,28 @@ semver_compare()
echo 0; return;
+# Emit versions in ascending semantic-version order without relying on GNU sort.
+sort_versions()
+ unsorted="$*"
+ while test -n "${unsorted}"; do
+ oldest=
+ remaining=
+ for version in ${unsorted}; do
+ if test -z "${oldest}"; then
+ oldest=${version}
+ elif test "`semver_compare "${version}" "${oldest}"`" -lt 0; then
+ remaining="${remaining} ${oldest}"
+ oldest=${version}
+ else
+ remaining="${remaining} ${version}"
+ fi
+ done
+ echo "${oldest}"
+ unsorted=${remaining}
+ done
failed()
failures=$((failures+1))
@@ -248,6 +279,20 @@ if test -f postgis_sfcgal--${to_version}.sql; then
INSTALLED_EXTENSIONS="$INSTALLED_EXTENSIONS postgis_sfcgal"
fi
+if test -n "${ONLY_EXTENSION}"; then
+ selected_extensions=
+ for EXT in ${INSTALLED_EXTENSIONS}; do
+ if test "${EXT}" = "${ONLY_EXTENSION}"; then
+ selected_extensions="${EXT}"
+ fi
+ done
+ if test -z "${selected_extensions}"; then
+ echo "SKIP: extension ${ONLY_EXTENSION} is not installed for target ${to_version}"
+ exit 0
+ fi
+ INSTALLED_EXTENSIONS=${selected_extensions}
+fi
echo "INFO: installed extensions: $INSTALLED_EXTENSIONS"
USERTESTFLAGS=${RUNTESTFLAGS}
@@ -275,6 +320,9 @@ for EXT in ${INSTALLED_EXTENSIONS}; do #{
# Check extension->extension upgrades
files=`'ls' ${EXT}--* | grep -v -- '--.*--' | sed "s/^${EXT}--\(.*\)\.sql/\1/"`
+ if test ${ONLY_OLDEST} != 0; then
+ files=`sort_versions ${files}`
+ fi
for fname in $files; do
from_version="$fname"
if test "$from_version" = "unpackaged"; then
@@ -290,6 +338,11 @@ for EXT in ${INSTALLED_EXTENSIONS}; do #{
continue;
fi
+ if test ${ONLY_OLDEST} != 0 -a $cmp -gt 0; then
+ echo "SKIP: ${from_version} -> ${to_version} (--oldest only tests upgrades)"
+ continue;
+ fi
if test $cmp -lt 0; then
test_label="${EXT} extension upgrade ${UPGRADE_PATH}"
else
@@ -337,6 +390,10 @@ for EXT in ${INSTALLED_EXTENSIONS}; do #{
" check_downgrade
fi
+ break
+ fi
done
if ! kept_label "unpackaged"; then
@@ -345,7 +402,11 @@ for EXT in ${INSTALLED_EXTENSIONS}; do #{
fi
# Check unpackaged->extension upgrades
- for majmin in `'ls' -d ${CTBDIR}/postgis-* | sed 's/.*postgis-//'`; do
+ unpackaged_versions=`'ls' -d ${CTBDIR}/postgis-* | sed 's/.*postgis-//'`
+ unpackaged_versions=`sort_versions ${unpackaged_versions}`
+ fi
+ for majmin in ${unpackaged_versions}; do
UPGRADE_PATH="unpackaged${majmin}--${to_version_param}"
if expr $to_version_param : ':auto' >/dev/null; then
@@ -371,6 +432,9 @@ for EXT in ${INSTALLED_EXTENSIONS}; do #{
echo "FAIL: ${test_label}"
failed
+ break
+ fi
done
# Check unpackaged->unpackaged upgrades (if target version == current version)
@@ -382,7 +446,7 @@ for EXT in ${INSTALLED_EXTENSIONS}; do #{
continue
fi #}
do #{
UPGRADE_PATH="unpackaged${majmin}--:auto"
test_label="${EXT} script soft upgrade ${UPGRADE_PATH}"
@@ -392,7 +456,9 @@ for EXT in ${INSTALLED_EXTENSIONS}; do #{
compatible_upgrade "${test_label}" ${majmin} ${to_version} || continue
- if kept_label "${test_label}"; then #{
+ run_soft_upgrade=1
+ kept_label "${test_label}" || run_soft_upgrade=0
+ if test ${run_soft_upgrade} != 0; then #{
echo "Testing ${test_label}"
RUNTESTFLAGS="-v --upgrade-path=${UPGRADE_PATH} ${USERTESTFLAGS}" \
${MAKE} -C ${REGDIR} check ${MAKE_ARGS} && {
@@ -404,7 +470,9 @@ for EXT in ${INSTALLED_EXTENSIONS}; do #{
fi #}
test_label="${EXT} script hard upgrade ${UPGRADE_PATH}"
+ run_hard_upgrade=1
+ kept_label "${test_label}" || run_hard_upgrade=0
+ if test ${run_hard_upgrade} != 0; then #{
RUNTESTFLAGS="-v --dumprestore --upgrade-path=${UPGRADE_PATH} ${USERTESTFLAGS}" \
@@ -415,6 +483,12 @@ for EXT in ${INSTALLED_EXTENSIONS}; do #{
fi #}
+ if test ${run_soft_upgrade} != 0 || test ${run_hard_upgrade} != 0; then
+ break
+ fi
+ fi
done #}
done #}
diff --git a/utils/test_check_all_upgrades.py b/utils/test_check_all_upgrades.py
new file mode 100644
index 000000000..3b8633d56
--- /dev/null
+++ b/utils/test_check_all_upgrades.py
@@ -0,0 +1,345 @@
+#!/usr/bin/env python3
+import json
+import os
+import re
+import subprocess
+import tempfile
+from pathlib import Path
+import unittest
+class FakePostgresTools:
+ def __init__(self, repo_root):
+ self.repo_root = repo_root
+ self.temp_dir = tempfile.TemporaryDirectory()
+ self.root = Path(self.temp_dir.name)
+ self.sharedir = self.root / "pg_sharedir"
+ self.extension_dir = self.sharedir / "extension"
+ self.contrib_dir = self.sharedir / "contrib"
+ self.bin_dir = self.root / "bin"
+ self.gmake_log = self.root / "gmake.log"
+ self.psql_log = self.root / "psql.log"
+ self.extension_dir.mkdir(parents=True)
+ self.contrib_dir.mkdir(parents=True)
+ self.bin_dir.mkdir(parents=True)
+ self.path_map = {}
+ self.fail_patterns = {}
+ self._write_fake_commands()
+ def _write_fake_commands(self):
+ pg_config = """#!/usr/bin/env bash
+set -eu
+case "$1" in
+ --version)
+ echo "$CHECK_ALL_UPGRADES_PG_VERSION"
+ --sharedir)
+ echo "$CHECK_ALL_UPGRADES_SHAREDIR"
+esac
+ psql = """#!/usr/bin/env python3
+import json
+import os
+import re
+import sys
+args = sys.argv[1:]
+query = ""
+for i, arg in enumerate(args):
+ if arg in ("-c", "--command") and i + 1 < len(args):
+ query = args[i + 1]
+ break
+if not query:
+ query = " ".join(args).strip()
+query = " ".join(query.split())
+log = os.environ.get("CHECK_ALL_UPGRADES_PSQL_LOG")
+if log:
+ with open(log, "a", encoding="utf-8") as fp:
+ fp.write(query + "\\n")
+if re.search("select default_version", query, flags=re.I):
+ print(os.environ["CHECK_ALL_UPGRADES_AUTO_VERSION"])
+ sys.exit(0)
+m = re.search(
+ r"pg_extension_update_paths\\(\\s*'([^']+)'\\s*\\)\\s*.*\\s*source\\s*=\\s*'([^']+)'\\s*.*\\s*target\\s*=\\s*'([^']+)'",
+ query,
+ flags=re.I | re.S,
+if not m:
+ print(query)
+ sys.exit(1)
+extension, source, target = m.groups()
+path_map = json.loads(os.environ.get("CHECK_ALL_UPGRADES_PSQL_PATH_MAP", "{}"))
+path = path_map.get(f"{extension}|{source}|{target}")
+if path is not None:
+ print(path)
+ sys.exit(0)
+sys.exit(0)
+ gmake = """#!/usr/bin/env python3
+import json
+import os
+import sys
+argv = sys.argv[1:]
+cmd = " ".join(argv)
+runflags = os.environ.get("RUNTESTFLAGS", "")
+full = " ".join([cmd, runflags]).strip()
+log = os.environ.get("CHECK_ALL_UPGRADES_GMAKE_LOG")
+if log:
+ json.dump({"argv": argv, "cmd": cmd}, fp)
+ fp.write("\\n")
+fail_patterns = os.environ.get("CHECK_ALL_UPGRADES_GMAKE_FAIL", "{}")
+for fragment, code in json.loads(fail_patterns).items():
+ if fragment in full:
+ sys.exit(int(code))
+sys.exit(0)
+ for name, body in {
+ "pg_config": pg_config,
+ "psql": psql,
+ "gmake": gmake,
+ "make": gmake,
+ }.items():
+ script = self.bin_dir / name
+ script.write_text(body + "\n", encoding="utf-8")
+ script.chmod(0o755)
+ def create_extension_files(self, extension, versions):
+ for version in versions:
+ (self.extension_dir / f"{extension}--{version}.sql").write_text("--", encoding="utf-8")
+ def create_contrib_files(self, versions):
+ (self.contrib_dir / f"postgis-{version}").write_text("--", encoding="utf-8")
+ def set_path_map(self, mapping):
+ self.path_map = mapping
+ def set_fail_patterns(self, mapping):
+ self.fail_patterns = mapping
+ def env(self):
+ env = os.environ.copy()
+ env["PATH"] = f"{self.bin_dir}:{env['PATH']}"
+ env["CHECK_ALL_UPGRADES_SHAREDIR"] = str(self.sharedir)
+ env["CHECK_ALL_UPGRADES_PG_VERSION"] = "PostgreSQL 16.2 (Debian)"
+ env["CHECK_ALL_UPGRADES_AUTO_VERSION"] = "3.7.0dev"
+ env["CHECK_ALL_UPGRADES_PSQL_PATH_MAP"] = json.dumps(self.path_map)
+ env["CHECK_ALL_UPGRADES_GMAKE_FAIL"] = json.dumps(self.fail_patterns)
+ env["CHECK_ALL_UPGRADES_PSQL_LOG"] = str(self.psql_log)
+ env["CHECK_ALL_UPGRADES_GMAKE_LOG"] = str(self.gmake_log)
+ return env
+ def run(self, to_version, args=(), extra_env=None):
+ if self.gmake_log.exists():
+ self.gmake_log.unlink()
+ if self.psql_log.exists():
+ self.psql_log.unlink()
+ env = self.env()
+ if extra_env:
+ env.update(extra_env)
+ return subprocess.run(
+ ["bash", str(self.repo_root / "utils/check_all_upgrades.sh"), *args, to_version],
+ cwd=self.repo_root,
+ env=env,
+ text=True,
+ capture_output=True,
+ def make_calls(self):
+ if not self.gmake_log.exists():
+ return []
+ return [json.loads(line) for line in self.gmake_log.read_text(encoding="utf-8").splitlines() if line.strip()]
+ def close(self):
+ self.temp_dir.cleanup()
+class CheckAllUpgradesHarnessTest(unittest.TestCase):
+ def setUp(self):
+ self.repo_root = Path(__file__).resolve().parents[1]
+ self.harness = FakePostgresTools(self.repo_root)
+ def tearDown(self):
+ self.harness.close()
+ def test_default_exhaustive_runs_packaged_and_unpacked_paths(self):
+ self.harness.create_extension_files("postgis", ["3.5.0", "3.6.0", "3.7.0dev"])
+ self.harness.create_extension_files("postgis_topology", ["3.7.0dev"])
+ self.harness.create_contrib_files(["3.6.0"])
+ self.harness.set_path_map(
+ "postgis|3.5.0|3.7.0dev": "up",
+ "postgis|3.6.0|3.7.0dev": "up",
+ "postgis|unpackaged|3.7.0dev": "up",
+ "postgis_topology|3.7.0dev|3.7.0dev": "up",
+ "postgis_topology|unpackaged|3.7.0dev": "up",
+ result = self.harness.run("3.7.0dev")
+ output = result.stdout + result.stderr
+ self.assertEqual(0, result.returncode)
+ self.assertIn("Testing postgis extension upgrade 3.5.0--3.7.0dev", output)
+ self.assertIn("Testing postgis extension upgrade 3.6.0--3.7.0dev", output)
+ self.assertIn("Testing postgis script soft upgrade", output)
+ self.assertIn("Testing postgis script hard upgrade", output)
+ calls = self.harness.make_calls()
+ self.assertTrue(calls)
+ def test_oldest_uses_semantic_ordering_for_3_9_vs_3_10(self):
+ self.harness.create_extension_files("postgis", ["3.10.0", "3.9.0", "3.11.0"])
+ self.harness.create_contrib_files(["3.10.0"])
+ "postgis|3.10.0|3.11.0": "up",
+ "postgis|3.9.0|3.11.0": "up",
+ "postgis|unpackaged|3.11.0": "up",
+ result = self.harness.run("3.11.0", args=("--oldest",))
+ self.assertIn("Testing postgis extension upgrade 3.9.0--3.11.0", output)
+ self.assertNotIn("extension upgrade 3.10.0--3.11.0", output)
+ def test_oldest_falls_back_when_first_source_has_no_update_path(self):
+ "postgis|3.9.0|3.11.0": "",
+ self.assertIn("SKIP: postgis extension upgrade 3.9.0--3.11.0 (no upgrade path", output)
+ self.assertIn("Testing postgis extension upgrade 3.10.0--3.11.0", output)
+ def test_oldest_skipped_when_oldest_label_is_excluded_by_regex(self):
+ "3.11.0",
+ args=("--oldest", "--skip", r"3\.9\.0--3\.11\.0"),
+ self.assertIn("SKIP: postgis extension upgrade 3.9.0--3.11.0", output)
+ def test_extension_filter_runs_only_requested_extension(self):
+ self.harness.create_extension_files("postgis", ["3.8.0", "3.7.0"])
+ self.harness.create_extension_files("postgis_topology", ["3.6.0", "3.7.0"])
+ "postgis_topology|3.6.0|3.7.0": "up",
+ "postgis|3.8.0|3.7.0": "up",
+ "postgis_topology|3.7.0|3.7.0": "up",
+ "postgis|3.7.0|3.7.0": "up",
+ "postgis_topology|unpackaged|3.7.0": "up",
+ "postgis|unpackaged|3.7.0": "up",
+ result = self.harness.run("3.7.0", args=("--extension", "postgis_topology"))
+ self.assertNotIn("Testing postgis extension upgrade", output)
+ self.assertIn("Testing postgis_topology extension upgrade 3.6.0--3.7.0", output)
+ for call in calls:
+ cmd = " ".join(call["argv"])
+ self.assertIn("-C", cmd)
+ self.assertIn("topology/test", cmd)
+ def test_unpackaged_soft_and_hard_share_oldest_upgrade_source(self):
+ self.harness.create_extension_files("postgis", ["3.6.0", "3.7.0dev"])
+ self.harness.create_contrib_files(["3.5.0", "3.6.0"])
+ result = self.harness.run("3.7.0dev", args=("--oldest",))
+ soft = re.search(r"Testing postgis script soft upgrade unpackaged(\S+)--:auto", output)
+ hard = re.search(r"Testing postgis script hard upgrade unpackaged(\S+)--:auto", output)
+ self.assertIsNotNone(soft)
+ self.assertIsNotNone(hard)
+ self.assertEqual(soft.group(1), hard.group(1))
+ def test_make_child_failure_keeps_nonzero_and_stops_with_dash_s(self):
+ self.harness.create_extension_files("postgis", ["3.5.0", "3.6.0", "3.7.0"])
+ self.harness.create_contrib_files(["3.5.0"])
+ "postgis|3.5.0|3.7.0": "up",
+ "postgis|3.6.0|3.7.0": "up",
+ self.harness.set_fail_patterns({"3.5.0--3.7.0": 1})
+ result = self.harness.run("3.7.0", args=("-s",))
+ self.assertNotEqual(0, result.returncode)
+ self.assertIn("FAIL: postgis extension upgrade 3.5.0--3.7.0", output)
+ self.assertNotIn("Testing postgis extension upgrade 3.6.0--3.7.0", output)
+ self.assertLessEqual(len(calls), 1)
+if __name__ == "__main__":
+ unittest.main()
Summary of changes:
.woodpecker/regress.yml | 265 ++++++++++++++++++++----------
ci/dronie/postgis_tools.sh | 3 +-
regress/core/regress_index.sql | 9 +-
utils/check_all_upgrades.sh | 82 +++++++++-
utils/test_check_all_upgrades.py | 345 +++++++++++++++++++++++++++++++++++++++
5 files changed, 607 insertions(+), 97 deletions(-)
create mode 100644 utils/test_check_all_upgrades.py
hooks/post-receive
