[SCM] PostGIS branch master updated. 3.7.0alpha1-597-gb1f92a1ac
Sat Jul 18 11:57:32 PDT 2026
the project "PostGIS".
       via  b1f92a1ac5b2c57e32cea783d2934ffe7c0866f6 (commit)
       via  21e3f3cf466fdb9971192d32226850a102e69b06 (commit)
      from  9d142afa7d7b6bc11e73059f2ce71e5252be7395 (commit)
revisions in full, below.
commit b1f92a1ac5b2c57e32cea783d2934ffe7c0866f6
Merge: 9d142afa7 21e3f3cf4
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Sat Jul 18 11:57:31 2026 -0700
    Merge pull request 'dist: exclude repository-only developer docs' (!366) from Komzpa/postgis:fix/exclude-developer-docs-dist into master
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/366
commit 21e3f3cf466fdb9971192d32226850a102e69b06
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Sat Jul 18 15:18:33 2026 +0400
    chore(dist): prune developer docs from source tarball
diff --git a/CONTRIBUTING.md b/CONTRIBUTING.md
index 3347c7ca3..09e055d01 100644
--- a/CONTRIBUTING.md
+++ b/CONTRIBUTING.md
@@ -4,8 +4,8 @@ GitHub and other forge mirrors look for `CONTRIBUTING.md` in the repository
 root, so this file remains as the stable entry point.
 The maintained contribution workflow lives in
-[doc/development/contributing.md](doc/development/contributing.md). It covers Trac tickets,
+[doc/development/contributing.md](https://gitea.osgeo.org/postgis/postgis/src/branch/master/doc/development/contributing.md). It covers Trac tickets,
 OSGeo accounts, source repositories and mirrors, mailing lists, patch basics,
 and raster bug-report conventions.
-Broader developer documentation lives in [doc/development/](doc/development/).
+Broader developer documentation lives in [doc/development](https://gitea.osgeo.org/postgis/postgis/src/branch/master/doc/development/).
diff --git a/README.md b/README.md
index 7fd26ca6a..def16ec89 100644
--- a/README.md
+++ b/README.md
@@ -7,7 +7,7 @@ https://trac.osgeo.org/postgis/
 ## Build status and continuous integration:
 See the GitHub Actions workflows, OSGeo Woodie pipelines, and the CI scripts in
 the `ci/` directory. Developer setup notes are in
-[doc/development](doc/development/).
+[doc/development](https://gitea.osgeo.org/postgis/postgis/src/branch/master/doc/development/).
 ## Translations
 We are using [Weblate software](https://weblate.org) for translation.  If you want to help out, log into [OSGeo Weblate](https://weblate.osgeo.org/projects/postgis/).
@@ -32,7 +32,7 @@ http://postgis.net/development/source_code/
 If you would like to contribute to this project, please refer to our
 [contributing guidelines](CONTRIBUTING.md).
 Developer workflow, build, test, release, and documentation notes live in
 ## Project Home Page and Manuals
 Project homepage: http://postgis.net/
diff --git a/doc/README b/doc/README
index 5c27f35c5..84f183d6a 100644
--- a/doc/README
+++ b/doc/README
@@ -56,9 +56,10 @@ SVG files directly, while PDF rasterizes the same files as a backend fallback.
 Do not add screenshots or authored geometry PNGs. Static raster files under
 ``doc/html/images/static`` are limited to branding and interface icons. Use
-DocBook markup for equations and tables. See
-``doc/development/manual.md`` for layout roles, labels, textual-output policy,
-native geometry/EWKT output handling, and the visual review procedure.
+DocBook markup for equations and tables. See the repository-only developer
+manual at https://gitea.osgeo.org/postgis/postgis/src/branch/master/doc/development/manual.md
+for layout roles, labels, textual-output policy, native geometry/EWKT output
+handling, and the visual review procedure.
 To run garden tests against functions, follow these instructions on the PostGIS
 dev wiki: http://trac.osgeo.org/postgis/wiki/DevWikiGardenTest
@@ -152,7 +153,7 @@ its staged-install and database recipe but does not require unrelated optional
 features used elsewhere in the manual.
 For contributor workflow, local testing, and garden checks, see
-``doc/development/``.
+https://gitea.osgeo.org/postgis/postgis/src/branch/master/doc/development/.
 The audited Trac wiki migration record and recovered attachments live in
 ``doc/trac-wiki/``.
diff --git a/make_dist.sh b/make_dist.sh
index 61a04d0c7..24e3161fb 100755
--- a/make_dist.sh
+++ b/make_dist.sh
@@ -60,6 +60,11 @@ cd $outdir && git checkout $tag && cd -
 echo "Removing make_dist.sh"
 rm -fv "$outdir"/make_dist.sh
+echo "Removing developer docs and top-level AGENTS.md"
+rm -rfv \
+  "$outdir"/AGENTS.md \
+  "$outdir"/doc/development
 echo "Removing ci files"
 rm -rfv \
   "$outdir"/ci \
@@ -148,6 +153,33 @@ echo "Generating $package file"
 # Create tar
 tar cf - --sort=name --mode=a+rwX --owner=0 --group=0 --numeric-owner "$outdir" > ${package}.tar || exit 1
+echo "Checking tar package membership"
+if ! tar -tf "${package}.tar" | grep -Fxq "${outdir}/README.md"; then
+  echo "Missing required file in source distribution: ${outdir}/README.md"
+  exit 1
+fi
+if ! tar -tf "${package}.tar" | grep -Fxq "${outdir}/CONTRIBUTING.md"; then
+  echo "Missing required file in source distribution: ${outdir}/CONTRIBUTING.md"
+  exit 1
+fi
+if ! tar -tf "${package}.tar" | grep -Fxq "${outdir}/doc/postgis.xml"; then
+  echo "Missing required file in source distribution: ${outdir}/doc/postgis.xml"
+  exit 1
+fi
+if tar -tf "${package}.tar" | grep -Fq "${outdir}/doc/development/"; then
+  echo "Forbidden path in source distribution: ${outdir}/doc/development/"
+  exit 1
+fi
+if tar -tf "${package}.tar" | grep -Fxq "${outdir}/AGENTS.md"; then
+  echo "Forbidden file in source distribution: ${outdir}/AGENTS.md"
+  exit 1
+fi
 # Compress
 gzip -n9 < ${package}.tar > ${package} || exit 1
 rm ${package}.tar
Summary of changes:
 CONTRIBUTING.md |  4 ++--
 README.md       |  4 ++--
 doc/README      |  9 +++++----
 make_dist.sh    | 32 ++++++++++++++++++++++++++++++++
 4 files changed, 41 insertions(+), 8 deletions(-)
hooks/post-receive
