[SCM] PostGIS branch master updated. 3.7.0alpha1-601-geda544325
git at osgeo.org
git at osgeo.org
Sat Jul 18 12:41:45 PDT 2026
the project "PostGIS".
via eda5443251a236dcbcc4e8caef70ef837ba2f518 (commit)
via 50ddba709a42fec8cab383196b1a767e293b20e7 (commit)
via fa316a13e21e84d0dc4d4f15f45e9a47af9832c2 (commit)
via 7ec541afed4cdb08820f01ddc4d9cfc68c4c3855 (commit)
from b1f92a1ac5b2c57e32cea783d2934ffe7c0866f6 (commit)
revisions in full, below.
commit eda5443251a236dcbcc4e8caef70ef837ba2f518
Merge: b1f92a1ac 50ddba709
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Sat Jul 18 12:41:44 2026 -0700
Merge pull request 'ci: make CI jobs self-contained' (!367) from Komzpa/postgis:fix/jenkins-env-preflight into master
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/367
commit 50ddba709a42fec8cab383196b1a767e293b20e7
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Sat Jul 18 22:46:34 2026 +0400
ci: speed up disposable PostgreSQL clusters
Disable durability work and PostgreSQL 18 data checksums in the throwaway documentation clusters.
diff --git a/.woodpecker/docs.yml b/.woodpecker/docs.yml
index 9943e69a4..b71ffae6b 100644
--- a/.woodpecker/docs.yml
+++ b/.woodpecker/docs.yml
@@ -55,8 +55,12 @@ steps:
- chown postgres:postgres "$${PGROOT}"
- export PGDATA="$${PGROOT}/data" PGHOST="$${PGROOT}/socket" PGUSER=postgres
- runuser -u postgres -- mkdir "$${PGDATA}" "$${PGHOST}"
- - runuser -u postgres -- initdb -D "$${PGDATA}" -A trust --no-sync
- - runuser -u postgres -- pg_ctl -D "$${PGDATA}" -l "$${PGROOT}/postgresql.log" -o "-F -h '' -k $${PGHOST}" -w start
+ - runuser -u postgres -- initdb -D "$${PGDATA}" -A trust --no-sync --no-data-checksums
+ runuser -u postgres -- pg_ctl -D "$${PGDATA}"
+ -l "$${PGROOT}/postgresql.log"
+ -o "-F -h '' -k $${PGHOST} -c synchronous_commit=off -c full_page_writes=off"
+ -w start
- trap 'runuser -u postgres -- pg_ctl -D "$${PGDATA}" -m fast -w stop || true' EXIT
- make -C build-docs/regress visual-examples
diff --git a/ci/debbie/postgis_release_docs.sh b/ci/debbie/postgis_release_docs.sh
index 716934224..bd75bb2ed 100644
--- a/ci/debbie/postgis_release_docs.sh
+++ b/ci/debbie/postgis_release_docs.sh
@@ -42,15 +42,21 @@ start_release_docs_pg()
release_docs_pghost="${release_docs_tmpdir}/socket"
mkdir "${release_docs_pghost}"
- "${PGPATH}/bin/initdb" -D "${release_docs_pgdata}" -A trust --no-sync
+ release_docs_initdb_options=(-D "${release_docs_pgdata}" -A trust --no-sync)
+ if "${PGPATH}/bin/initdb" --help | grep -q -- '--no-data-checksums'; then
+ release_docs_initdb_options+=(--no-data-checksums)
+ fi
+ "${PGPATH}/bin/initdb" "${release_docs_initdb_options[@]}"
export PGHOST="${release_docs_pghost}"
export PGPORT="${PGPORT:-8447}"
PGUSER=$(id -un)
export PGUSER
+ release_docs_pgopts="-F -h '' -k ${PGHOST} -p ${PGPORT}"
+ release_docs_pgopts="${release_docs_pgopts} -c synchronous_commit=off -c full_page_writes=off"
"${PGPATH}/bin/pg_ctl" \
-D "${release_docs_pgdata}" \
-l "${release_docs_tmpdir}/postgresql.log" \
- -o "-F -h '' -k ${PGHOST} -p ${PGPORT}" \
+ -o "${release_docs_pgopts}" \
-w start
commit fa316a13e21e84d0dc4d4f15f45e9a47af9832c2
Date: Sat Jul 18 22:43:50 2026 +0400
ci: isolate the docs PostgreSQL cluster
Initialize a fresh private cluster for visual-example rendering instead of starting the image's stale system data directory.
index ab95f5e5e..9943e69a4 100644
@@ -51,7 +51,13 @@ steps:
depends_on: prepare
commands:
- export PATH=/usr/lib/postgresql/18/bin:$${PATH}
- - service postgresql start 18
+ - export PGROOT=$$(mktemp -d)
+ - chown postgres:postgres "$${PGROOT}"
+ - export PGDATA="$${PGROOT}/data" PGHOST="$${PGROOT}/socket" PGUSER=postgres
+ - runuser -u postgres -- mkdir "$${PGDATA}" "$${PGHOST}"
+ - runuser -u postgres -- pg_ctl -D "$${PGDATA}" -l "$${PGROOT}/postgresql.log" -o "-F -h '' -k $${PGHOST}" -w start
+ - trap 'runuser -u postgres -- pg_ctl -D "$${PGDATA}" -m fast -w stop || true' EXIT
check-xml:
commit 7ec541afed4cdb08820f01ddc4d9cfc68c4c3855
Date: Sat Jul 18 22:34:07 2026 +0400
ci: prepare Jenkins runtime prerequisites
Create configured temporary directories on Winnie, give the release-doc job a private PostgreSQL cluster for visual examples, and skip Berrie64's optional PROJ-grid preflight while retaining runnable garden examples.
diff --git a/ci/berrie64/postgis_regress.sh b/ci/berrie64/postgis_regress.sh
index 35221bb3d..01227c641 100644
--- a/ci/berrie64/postgis_regress.sh
+++ b/ci/berrie64/postgis_regress.sh
@@ -25,7 +25,10 @@ make install
make check RUNTESTFLAGS="-v --extension"
err_status=$?
-make garden
+# Optional PROJ grids are not installed on this worker. Grid-dependent manual
+# examples are marked requires-external-state, so run the remaining examples
+# without the global optional-grid preflight.
+make garden EXAMPLETEST_CHECK_ENVIRONMENT=no
err_status=$?
utils/check_all_upgrades.sh \
index f6ced7dad..716934224 100644
@@ -15,6 +15,47 @@ export PGPATH=${PROJECTS}/pg/rel/pg${PG_VER}w${OS_BUILD}
export PATH="${PGPATH}/bin:$PATH"
export LD_LIBRARY_PATH="${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}/lib:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}/lib:${PGPATH}/lib"
+release_docs_tmpdir=
+release_docs_pgdata=
+cleanup_release_docs_pg()
+ status=$?
+ if test "${status}" -ne 0 && test -n "${release_docs_tmpdir}" && test -f "${release_docs_tmpdir}/postgresql.log"; then
+ tail -n 100 "${release_docs_tmpdir}/postgresql.log"
+ fi
+ if test -n "${release_docs_pgdata}" && test -f "${release_docs_pgdata}/postmaster.pid"; then
+ "${PGPATH}/bin/pg_ctl" -D "${release_docs_pgdata}" -m fast -w stop || true
+ fi
+ if test -n "${release_docs_tmpdir}"; then
+ rm -rf -- "${release_docs_tmpdir}"
+ fi
+ return "${status}"
+start_release_docs_pg()
+ tmp_root=${TMPDIR:-/tmp}
+ mkdir -p "${tmp_root}"
+ release_docs_tmpdir=$(mktemp -d "${tmp_root}/postgis-release-docs.XXXXXX")
+ release_docs_pgdata="${release_docs_tmpdir}/data"
+ release_docs_pghost="${release_docs_tmpdir}/socket"
+ mkdir "${release_docs_pghost}"
+ "${PGPATH}/bin/initdb" -D "${release_docs_pgdata}" -A trust --no-sync
+ export PGHOST="${release_docs_pghost}"
+ export PGPORT="${PGPORT:-8447}"
+ PGUSER=$(id -un)
+ export PGUSER
+ "${PGPATH}/bin/pg_ctl" \
+ -D "${release_docs_pgdata}" \
+ -l "${release_docs_tmpdir}/postgresql.log" \
+ -o "-F -h '' -k ${PGHOST} -p ${PGPORT}" \
+ -w start
+trap cleanup_release_docs_pg EXIT
./autogen.sh
@@ -48,6 +89,11 @@ LDFLAGS="-L${PGPATH}/lib" ./configure \
--docdir ${STUFF_DIR}
make clean
+# The rendered manual now builds visual examples through a temporary PostGIS
+# database. The distribution job does not otherwise require a running server,
+# so keep this database private to the documentation build.
# generating postgis_revision.h in case hasn't been generated
if test -f utils/repo_revision.pl; then
echo "Generating postgis_revision.h"
diff --git a/ci/winnie/regress_postgis.sh b/ci/winnie/regress_postgis.sh
index deba4fdb1..ea5777631 100644
--- a/ci/winnie/regress_postgis.sh
+++ b/ci/winnie/regress_postgis.sh
@@ -38,14 +38,12 @@ export RELVERDIR=postgis-pg${REL_PGVER}-binaries-${POSTGIS_MICRO_VER}w${OS_BUILD
echo PATH AFTER: $PATH
echo WORKSPACE IS $WORKSPACE
-#mkdir ${PROJECTS}/postgis/tmp
-#export PGIS_REG_TMPDIR=${PROJECTS}/postgis/tmp/${POSTGIS_MICRO_VER}_pg${PG_VER}_geos${GEOS_VER}_gdal${GDAL_VER}w${OS_BUILD}
-#rm -rf ${PGIS_REG_TMPDIR}
-#mkdir ${PGIS_REG_TMPDIR}
-#export TMPDIR=${PGIS_REG_TMPDIR}
-#TMPDIR=${PROJECTS}/postgis/tmp/${POSTGIS_VER}_${PG_VER}_${GEOS_VERSION}_${PROJ_VER}
+if [ -z "${PGIS_REG_TMPDIR:-}" ]; then
+ PGIS_REG_TMPDIR=${PROJECTS}/postgis/tmp/${POSTGIS_MICRO_VER}_pg${PG_VER}_geos${GEOS_VER}_gdal${GDAL_VER}w${OS_BUILD}
+fi
+mkdir -p "${PGIS_REG_TMPDIR}"
+export PGIS_REG_TMPDIR
+export TMPDIR="${PGIS_REG_TMPDIR}"
echo PORT IS $PGPORT
echo PGIS_REG_TMPDIR IS $PGIS_REG_TMPDIR
export XSLTPROCFLAGS=
Summary of changes:
.woodpecker/docs.yml | 12 ++++++++-
ci/berrie64/postgis_regress.sh | 5 +++-
ci/debbie/postgis_release_docs.sh | 52 +++++++++++++++++++++++++++++++++++++++
ci/winnie/regress_postgis.sh | 14 +++++------
4 files changed, 73 insertions(+), 10 deletions(-)
hooks/post-receive
