[SCM] PostGIS branch master updated. 3.7.0alpha1-606-gfe789eb49
git at osgeo.org
git at osgeo.org
Sat Jul 18 14:10:26 PDT 2026
the project "PostGIS".
via fe789eb49efa9ffae30b7491cfb42563b4b9bb64 (commit)
via 19e655fd8d9661b5bfc85a048a477734c192845c (commit)
via 5991739dacc8a9fba2f12028a138da245a010441 (commit)
via f6bd3d6e68d401ffcb1266e83cefdc434d449527 (commit)
via c16851a1ef16f6f30ef48f501ae21bca975a4b63 (commit)
from eda5443251a236dcbcc4e8caef70ef837ba2f518 (commit)
revisions in full, below.
commit fe789eb49efa9ffae30b7491cfb42563b4b9bb64
Merge: eda544325 19e655fd8
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Sat Jul 18 14:10:25 2026 -0700
Merge pull request 'Support curved GML input' (!368) from Komzpa/postgis:codex/ticket-1986-gml-curves into master
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/368
commit 19e655fd8d9661b5bfc85a048a477734c192845c
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Sat Jul 18 23:23:44 2026 +0400
Complete curved GML collection handling
Accept direct MultiSurface members emitted by ST_AsGML, reuse curved ring parsing for PolygonPatch, and validate closure in the effective ring dimension.
Closes #1986
diff --git a/postgis/lwgeom_in_gml.c b/postgis/lwgeom_in_gml.c
index 80401aff0..4075e81d1 100644
--- a/postgis/lwgeom_in_gml.c
+++ b/postgis/lwgeom_in_gml.c
@@ -1382,11 +1382,13 @@ static LWGEOM* parse_gml_linearring(xmlNodePtr xnode, bool *hasz, int *root_srid
* Parse GML Polygon (2.1.2, 3.1.1)
static void
-gml_validate_ring_geom(LWGEOM *ring, int error_code)
+gml_validate_ring_geom(LWGEOM *ring, bool hasz, int error_code)
+ POINT4D first, last;
uint32_t vertices_needed = ring->type == LINETYPE ? 4 : 3;
- if (lwgeom_count_vertices(ring) < vertices_needed || !lwgeom_is_closed(ring))
+ if (lwgeom_count_vertices(ring) < vertices_needed || lwgeom_startpoint(ring, &first) == LW_FAILURE ||
+ gml_curve_endpoint(ring, &last) == LW_FAILURE || !gml_curve_points_equal(&first, &last, hasz))
gml_lwpgerror("invalid GML representation", error_code);
@@ -1404,7 +1406,7 @@ parse_gml_linearring_as_lwgeom(xmlNodePtr xnode, bool *hasz, int *root_srid)
gml_reproject_lwgeom(ring, srs.srid, *root_srid);
ring->srid = *root_srid;
- gml_validate_ring_geom(ring, 43);
+ gml_validate_ring_geom(ring, *hasz, 43);
return ring;
@@ -1462,7 +1464,7 @@ parse_gml_ring(xmlNodePtr xnode, bool *hasz, int *root_srid)
ring = gml_curve_segments_to_lwgeom(segments, nsegments, hasz, root_srid);
lwfree(segments);
return ring;
@@ -1649,12 +1651,8 @@ static LWGEOM* parse_gml_triangle(xmlNodePtr xnode, bool *hasz, int *root_srid)
static LWGEOM* parse_gml_patch(xmlNodePtr xnode, bool *hasz, int *root_srid)
- xmlChar *interpolation=NULL;
- POINTARRAY **ppa=NULL;
- LWGEOM *geom=NULL;
- xmlNodePtr xa, xb;
- int i, ring=0;
- gmlSrs srs;
+ xmlChar *interpolation = NULL;
+ LWGEOM *geom;
/* PolygonPatch */
if (!is_gml_element(xnode, "PolygonPatch"))
@@ -1669,76 +1667,9 @@ static LWGEOM* parse_gml_patch(xmlNodePtr xnode, bool *hasz, int *root_srid)
xmlFree(interpolation);
- parse_gml_srs(xnode, &srs);
- /* PolygonPatch/exterior */
- for (xa = xnode->children ; xa != NULL ; xa = xa->next)
- if (!is_gml_namespace(xa, false)) continue;
- if (!is_gml_element(xa, "exterior")) continue;
- /* PolygonPatch/exterior/LinearRing */
- for (xb = xa->children ; xb != NULL ; xb = xb->next)
- if (xb->type != XML_ELEMENT_NODE) continue;
- if (!is_gml_namespace(xb, false)) continue;
- if (!is_gml_element(xb, "LinearRing")) continue;
- ppa = (POINTARRAY**) lwalloc(sizeof(POINTARRAY*));
- ppa[0] = parse_gml_data(xb->children, hasz, root_srid);
- if (ppa[0]->npoints < 4
- || (!*hasz && !ptarray_is_closed_2d(ppa[0]))
- || (*hasz && !ptarray_is_closed_3d(ppa[0])))
- gml_lwpgerror("invalid GML representation", 48);
- if (srs.reverse_axis)
- ppa[0] = ptarray_flip_coordinates(ppa[0]);
- /* Interior but no Exterior ! */
- if ( ! ppa )
- /* PolygonPatch/interior */
- for (ring=1, xa = xnode->children ; xa != NULL ; xa = xa->next)
- if (xa->type != XML_ELEMENT_NODE) continue;
- if (!is_gml_element(xa, "interior")) continue;
- /* PolygonPatch/interior/LinearRing */
- ppa = (POINTARRAY**) lwrealloc((POINTARRAY *) ppa,
- sizeof(POINTARRAY*) * (ring + 1));
- ppa[ring] = parse_gml_data(xb->children, hasz, root_srid);
- if (ppa[ring]->npoints < 4
- || (!*hasz && !ptarray_is_closed_2d(ppa[ring]))
- || ( *hasz && !ptarray_is_closed_3d(ppa[ring])))
- gml_lwpgerror("invalid GML representation", 49);
- ppa[ring] = ptarray_flip_coordinates(ppa[ring]);
- ring++;
- /* Exterior Ring is mandatory */
- if (ppa == NULL || ppa[0] == NULL) gml_lwpgerror("invalid GML representation", 50);
- if (srs.srid != *root_srid && *root_srid != SRID_UNKNOWN)
- for (i=0 ; i < ring ; i++)
- gml_reproject_pa(ppa[i], srs.srid, *root_srid);
- geom = (LWGEOM *) lwpoly_construct(*root_srid, NULL, ring, ppa);
+ geom = parse_gml_polygon(xnode, hasz, root_srid);
+ if (lwgeom_is_empty(geom))
+ gml_lwpgerror("invalid GML representation", 50);
return geom;
@@ -2094,6 +2025,15 @@ static LWGEOM* parse_gml_msurface(xmlNodePtr xnode, bool *hasz, int *root_srid)
has_curve = true;
+ else if (is_gml_element(xa, "Polygon") || is_gml_element(xa, "CurvePolygon"))
+ LWGEOM *member = parse_gml(xa, hasz, root_srid);
+ geoms = ngeoms == 0 ? (LWGEOM **)lwalloc(sizeof(LWGEOM *))
+ : (LWGEOM **)lwrealloc(geoms, sizeof(LWGEOM *) * (ngeoms + 1));
+ geoms[ngeoms++] = member;
+ if (member->type != POLYGONTYPE)
+ has_curve = true;
else if (is_gml_element(xa, "surfaceMember"))
if (xa->children != NULL)
diff --git a/regress/core/in_gml.sql b/regress/core/in_gml.sql
index d60a60ac3..bd0af0f06 100644
--- a/regress/core/in_gml.sql
+++ b/regress/core/in_gml.sql
@@ -173,6 +173,9 @@ SELECT 'polygon_24', ST_AsEWKT(ST_GeomFromGML('<gml:CurvePolygon xmlns:gml="http
-- ERROR mismatched Z between a Ring member and a nested compound Curve
SELECT 'polygon_25', ST_AsEWKT(ST_GeomFromGML('<gml:CurvePolygon xmlns:gml="http://www.opengis.net/gml/3.2"><gml:exterior><gml:Ring><gml:curveMember><gml:LineString><gml:posList srsDimension="3">0 0 0 1 0 0</gml:posList></gml:LineString></gml:curveMember><gml:curveMember><gml:Curve><gml:segments><gml:LineStringSegment><gml:posList srsDimension="3">1 0 99 2 0 99</gml:posList></gml:LineStringSegment><gml:ArcString><gml:posList srsDimension="3">2 0 99 3 1 99 4 0 99</gml:posList></gml:ArcString></gml:segments></gml:Curve></gml:curveMember><gml:curveMember><gml:LineString><gml:posList srsDimension="3">4 0 99 0 0 0</gml:posList></gml:LineString></gml:curveMember></gml:Ring></gml:exterior></gml:CurvePolygon>'));
+-- Mixed dimensions make the whole curved ring 2D before closure validation
+SELECT 'polygon_26', ST_AsEWKT(ST_GeomFromGML('<gml:CurvePolygon xmlns:gml="http://www.opengis.net/gml/3.2"><gml:exterior><gml:Ring><gml:curveMember><gml:Curve><gml:segments><gml:ArcString><gml:pos srsDimension="3">0 0 5</gml:pos><gml:pos>1 1</gml:pos><gml:pos>0 0</gml:pos></gml:ArcString></gml:segments></gml:Curve></gml:curveMember></gml:Ring></gml:exterior></gml:CurvePolygon>'));
-- ERROR open curved ring
SELECT 'polygon_22', ST_AsEWKT(ST_GeomFromGML('<gml:Polygon xmlns:gml="http://www.opengis.net/gml/3.2"><gml:exterior><gml:Ring><gml:curveMember><gml:Curve><gml:segments><gml:ArcString><gml:posList>0 0 1 1 2 0</gml:posList></gml:ArcString></gml:segments></gml:Curve></gml:curveMember></gml:Ring></gml:exterior></gml:Polygon>'));
SELECT 'polygon_23', ST_AsEWKT(ST_GeomFromGML('<gml:CurvePolygon xmlns:gml="http://www.opengis.net/gml/3.2" srsName="urn:ogc:def:crs:EPSG::4326"><gml:exterior><gml:Ring><gml:curveMember><gml:Curve><gml:segments><gml:ArcString><gml:posList>1 2 3 4 5 6 7 8 1 2</gml:posList></gml:ArcString></gml:segments></gml:Curve></gml:curveMember></gml:Ring></gml:exterior></gml:CurvePolygon>'));
@@ -299,6 +302,8 @@ SELECT 'surface_22', ST_AsEWKT(ST_GeomFromGML('<gml:Surface><gml:patches><gml:Po
-- ERROR: interior but no exterior
SELECT 'surface_23', ST_AsEWKT(ST_GeomFromGML('<gml:Surface><gml:patches><gml:PolygonPatch><gml:interior><gml:LinearRing><gml:coordinates>1,2 3,4 5,6 1,2</gml:coordinates></gml:LinearRing></gml:interior></gml:PolygonPatch></gml:patches></gml:Surface>'));
+SELECT 'surface_24', ST_AsEWKT(ST_GeomFromGML('<gml:Surface xmlns:gml="http://www.opengis.net/gml/3.2"><gml:patches><gml:PolygonPatch><gml:exterior><gml:Ring><gml:curveMember><gml:Curve><gml:segments><gml:ArcString><gml:posList>0 0 1 1 2 0 1 -1 0 0</gml:posList></gml:ArcString></gml:segments></gml:Curve></gml:curveMember></gml:Ring></gml:exterior></gml:PolygonPatch></gml:patches></gml:Surface>'));
-- MultiPoint
@@ -467,6 +472,8 @@ SELECT 'msurface_12', ST_AsEWKT(ST_GeomFromGML('<gml:MultiSurface><gml:surfaceMe
SELECT 'msurface_13', ST_AsEWKT(ST_GeomFromGML('<gml:MultiSurface xmlns:gml="http://www.opengis.net/gml/3.2"><gml:surfaceMember><gml:CurvePolygon><gml:exterior><gml:Ring><gml:curveMember><gml:Curve><gml:segments><gml:ArcString><gml:posList>0 0 1 1 2 0 1 -1 0 0</gml:posList></gml:ArcString></gml:segments></gml:Curve></gml:curveMember></gml:Ring></gml:exterior></gml:CurvePolygon></gml:surfaceMember></gml:MultiSurface>'));
+SELECT 'msurface_14', ST_AsEWKT(ST_GeomFromGML(ST_AsGML(3, ST_GeomFromEWKT('MULTISURFACE(CURVEPOLYGON(CIRCULARSTRING(0 0,1 1,2 0,1 -1,0 0)),((10 10,11 10,11 11,10 10)))'))));
-- PolyhedralSurface
diff --git a/regress/core/in_gml_expected b/regress/core/in_gml_expected
index 4cd4999e5..a2f83b3ad 100644
--- a/regress/core/in_gml_expected
+++ b/regress/core/in_gml_expected
@@ -57,6 +57,7 @@ polygon_20|CURVEPOLYGON(COMPOUNDCURVE((0 0,1 0),CIRCULARSTRING(1 0,2 1,3 0),(3 0
polygon_21|CURVEPOLYGON(CIRCULARSTRING(0 0,1 1,2 0,1 -1,0 0))
polygon_24|CURVEPOLYGON(COMPOUNDCURVE((0 0,1 0),(1 0,2 0),CIRCULARSTRING(2 0,3 1,4 0),(4 0,0 0)))
ERROR: invalid GML representation
+polygon_26|CURVEPOLYGON(CIRCULARSTRING(0 0,1 1,0 0))
polygon_23|SRID=4326;CURVEPOLYGON(CIRCULARSTRING(2 1,4 3,6 5,8 7,2 1))
linearring_1|POLYGON((1 2,3 4,5 6,1 2))
@@ -101,6 +102,7 @@ ERROR: invalid GML representation
surface_21|POLYGON((1 2,3 4,5 6,1 2))
+surface_24|CURVEPOLYGON(CIRCULARSTRING(0 0,1 1,2 0,1 -1,0 0))
mpoint_1|MULTIPOINT(1 2)
mpoint_2|MULTIPOINT(1 2,3 4)
mpoint_3|SRID=4326;MULTIPOINT(1 2)
@@ -156,6 +158,7 @@ msurface_10|MULTIPOLYGON(((1 2,3 4,5 6,1 2)))
msurface_11|MULTIPOLYGON(((1 2,3 4,5 6,1 2)),((7 8,9 10,11 12,7 8)))
msurface_12|MULTIPOLYGON EMPTY
msurface_13|MULTISURFACE(CURVEPOLYGON(CIRCULARSTRING(0 0,1 1,2 0,1 -1,0 0)))
+msurface_14|MULTISURFACE(CURVEPOLYGON(CIRCULARSTRING(0 0,1 1,2 0,1 -1,0 0)),((10 10,11 10,11 11,10 10)))
polyhedralsurface_1|POLYHEDRALSURFACE(((1 2 3,4 5 6,7 8 9,1 2 3)))
polyhedralsurface_2|SRID=4326;POLYHEDRALSURFACE(((1 2 3,4 5 6,7 8 9,1 2 3)))
commit 5991739dacc8a9fba2f12028a138da245a010441
Date: Sat Jul 18 23:09:52 2026 +0400
Validate nested curved GML ring continuity
Apply the full-dimensional component check while flattening nested compound curves, and cover a Z-discontinuous Ring member.
Restore the 3.7 documentation note and keep the release entry under the existing Enhancements section.
Closes #1986
diff --git a/NEWS b/NEWS
index a80b4d893..80f942b64 100644
--- a/NEWS
+++ b/NEWS
@@ -47,12 +47,10 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
(Bas Couwenberg)
* Enhancements *
-* New Features *
- #1986, ST_GeomFromGML support for GML ArcString and curved polygon rings
(Darafei Praliaskouski)
- GH-1161, Render manual geometry examples as build-time SVG in HTML
and PDF (Darafei Praliaskouski)
- #4749, Use point-in-polygon predicate fast paths for point-only
diff --git a/doc/reference_input.xml b/doc/reference_input.xml
index 1e427ebd3..fd5f20113 100644
--- a/doc/reference_input.xml
+++ b/doc/reference_input.xml
@@ -1570,6 +1570,7 @@ precision 6 | POLYGON((-115.1806640625 36.112060546875,-115.1806640625 36.117553
<para role="availability" conformance="1.5">Availability: 1.5, requires libxml2 1.6+</para>
<para role="enhanced" conformance="2.0.0">Enhanced: 2.0.0 support for Polyhedral surfaces and TIN was introduced.</para>
<para role="enhanced" conformance="2.0.0">Enhanced: 2.0.0 default srid optional parameter added.</para>
+ <para role="enhanced" conformance="3.7.0">Enhanced: 3.7.0 support for GML ArcString, curved Ring, and CurvePolygon geometries was introduced.</para>
<para>&Z_support;</para>
<para>&P_support;</para>
<para>&T_support;</para>
@@ -1578,10 +1579,6 @@ precision 6 | POLYGON((-115.1806640625 36.112060546875,-115.1806640625 36.117553
<para>GML support mixed SRS inside the same MultiGeometry. As PostGIS geometries don't, ST_GeomFromGML, in this case, reproject all subgeometries to the SRS root node. If no srsName attribute available for the GML root node, the function throw an error.</para>
<para>ST_GeomFromGML function is not pedantic about an explicit GML namespace. You could avoid to mention it explicitly for common usages. But you need it if you want to use XLink feature inside GML.</para>
- <note>
- <para>ST_GeomFromGML function not support SQL/MM curves geometries.</para>
- </note>
</refsection>
<refsection>
@@ -1851,6 +1848,7 @@ SELECT ST_AsEWKT(ST_GeomFromGML('
</refsection>
<refsection>
<title>See Also</title>
index b1d5dc872..80401aff0 100644
@@ -1211,10 +1211,7 @@ gml_compound_add_curve_component(LWCOMPOUND *compound, LWGEOM *segment)
LWCOMPOUND *nested = (LWCOMPOUND *)segment;
for (uint32_t i = 0; i < nested->ngeoms; i++)
- if (lwcompound_add_lwgeom(compound, nested->geoms[i]) == LW_FAILURE)
- gml_lwpgerror("invalid GML representation", 41);
+ gml_compound_add_curve_component(compound, nested->geoms[i]);
nested->ngeoms = 0;
lwgeom_free(segment);
index 4f4043abc..d60a60ac3 100644
@@ -170,6 +170,9 @@ SELECT 'polygon_20', ST_AsEWKT(ST_GeomFromGML('<gml:Polygon xmlns:gml="http://ww
SELECT 'polygon_21', ST_AsEWKT(ST_GeomFromGML('<gml:CurvePolygon xmlns:gml="http://www.opengis.net/gml/3.2"><gml:exterior><gml:Ring><gml:curveMember><gml:Curve><gml:segments><gml:ArcString><gml:posList>0 0 1 1 2 0 1 -1 0 0</gml:posList></gml:ArcString></gml:segments></gml:Curve></gml:curveMember></gml:Ring></gml:exterior></gml:CurvePolygon>'));
SELECT 'polygon_24', ST_AsEWKT(ST_GeomFromGML('<gml:CurvePolygon xmlns:gml="http://www.opengis.net/gml/3.2"><gml:exterior><gml:Ring><gml:curveMember><gml:LineString><gml:posList>0 0 1 0</gml:posList></gml:LineString></gml:curveMember><gml:curveMember><gml:Curve><gml:segments><gml:LineStringSegment><gml:posList>1 0 2 0</gml:posList></gml:LineStringSegment><gml:ArcString><gml:posList>2 0 3 1 4 0</gml:posList></gml:ArcString></gml:segments></gml:Curve></gml:curveMember><gml:curveMember><gml:LineString><gml:posList>4 0 0 0</gml:posList></gml:LineString></gml:curveMember></gml:Ring></gml:exterior></gml:CurvePolygon>'));
+-- ERROR mismatched Z between a Ring member and a nested compound Curve
+SELECT 'polygon_25', ST_AsEWKT(ST_GeomFromGML('<gml:CurvePolygon xmlns:gml="http://www.opengis.net/gml/3.2"><gml:exterior><gml:Ring><gml:curveMember><gml:LineString><gml:posList srsDimension="3">0 0 0 1 0 0</gml:posList></gml:LineString></gml:curveMember><gml:curveMember><gml:Curve><gml:segments><gml:LineStringSegment><gml:posList srsDimension="3">1 0 99 2 0 99</gml:posList></gml:LineStringSegment><gml:ArcString><gml:posList srsDimension="3">2 0 99 3 1 99 4 0 99</gml:posList></gml:ArcString></gml:segments></gml:Curve></gml:curveMember><gml:curveMember><gml:LineString><gml:posList srsDimension="3">4 0 99 0 0 0</gml:posList></gml:LineString></gml:curveMember></gml:Ring></gml:exterior></gml:CurvePolygon>'));
index 54b91812c..4cd4999e5 100644
+ERROR: invalid GML representation
linearring_2|SRID=4326;POLYGON((1 2,3 4,5 6,1 2))
commit f6bd3d6e68d401ffcb1266e83cefdc434d449527
Date: Mon Jul 6 17:46:18 2026 +0400
NEWS: move entry to 3.7.0beta1
Closes #1986
index f3c33facc..a80b4d893 100644
--- a/NEWS
+++ b/NEWS
@@ -47,6 +47,11 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
(Bas Couwenberg)
* Enhancements *
+* New Features *
+ - #1986, ST_GeomFromGML support for GML ArcString and curved polygon rings
+ (Darafei Praliaskouski)
@@ -116,8 +121,6 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
- #4398, Add ST_CatmullSmoothing smoothes but retains original vertices (Paul Ramsey)
- #4560, ST_3DInterpolatePoint for M interpolation from XYZ inputs (Paul Ramsey)
- #1291, ST_MakePolygon support for curved rings (Darafei Praliaskouski)
- - #1986, ST_GeomFromGML support for GML ArcString and curved polygon rings
- (Darafei Praliaskouski)
- GT-270, Add NURBSCurve (Loïc Bartoletti)
- #2863, Add ST_XSize, ST_YSize, ST_ZSize, and ST_MSize dimension helpers
commit c16851a1ef16f6f30ef48f501ae21bca975a4b63
Date: Sun Jun 21 03:47:09 2026 +0400
Add ST_GeomFromGML support for GML ArcString segments, curved Ring boundaries, CurvePolygon input, and curved members in MultiCurve/MultiSurface collections.
Closes #1986
index 1e6959eaf..f3c33facc 100644
--- a/NEWS
+++ b/NEWS
@@ -116,6 +116,8 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
index f0a29c6f2..1e427ebd3 100644
@@ -1847,7 +1847,7 @@ SELECT ST_AsEWKT(ST_GeomFromGML('
<refsection>
<title>Description</title>
<para>This function is an alias for <xref linkend="ST_GeomFromGML"/> and provides the same signatures.</para>
- <para>&sqlmm_compliant; SQL-MM 3: 5.1.50 (except for curves support).</para>
+ <para>&sqlmm_compliant; SQL-MM 3: 5.1.50.</para>
index 5f3a5acb6..b1d5dc872 100644
@@ -370,6 +370,43 @@ gml_reproject_pa(POINTARRAY *pa, int32_t epsg_in, int32_t epsg_out)
return pa;
+static LWGEOM *
+gml_reproject_lwgeom(LWGEOM *geom, int32_t epsg_in, int32_t epsg_out)
+ LWPROJ *lwp;
+ char text_in[16];
+ char text_out[16];
+ if (epsg_in == SRID_UNKNOWN)
+ return geom;
+ if (epsg_out == SRID_UNKNOWN)
+ gml_lwpgerror("invalid GML representation", 3);
+ return NULL;
+ snprintf(text_in, 16, "EPSG:%d", epsg_in);
+ snprintf(text_out, 16, "EPSG:%d", epsg_out);
+ lwp = lwproj_from_str(text_in, text_out);
+ if (!lwp)
+ gml_lwpgerror("Could not create LWPROJ*", 57);
+ return NULL;
+ if (lwgeom_transform(geom, lwp) == LW_FAILURE)
+ elog(ERROR, "gml_reproject_lwgeom: reprojection failed");
+ return NULL;
+ proj_destroy(lwp->pj);
+ pfree(lwp);
+ return geom;
* Return 1 if the SRS definition from the authority has a GIS friendly order,
* that is easting,northing. This is typically true for most projected CRS
@@ -1090,6 +1127,165 @@ static LWGEOM* parse_gml_line(xmlNodePtr xnode, bool *hasz, int *root_srid)
* Parse GML Curve (3.1.1)
+static LWGEOM *
+parse_gml_curve_segment(xmlNodePtr xnode, bool *hasz, int *root_srid)
+ POINTARRAY *pa;
+ if (is_gml_element(xnode, "LineStringSegment"))
+ interpolation = gmlGetProp(xnode, "interpolation");
+ if (interpolation != NULL)
+ if (strcmp((char *)interpolation, "linear"))
+ gml_lwpgerror("invalid GML representation", 38);
+ xmlFree(interpolation);
+ pa = parse_gml_data(xnode->children, hasz, root_srid);
+ if (pa->npoints < 2)
+ gml_lwpgerror("invalid GML representation", 39);
+ return lwline_as_lwgeom(lwline_construct(SRID_UNKNOWN, NULL, pa));
+ if (is_gml_element(xnode, "ArcString"))
+ if (strcmp((char *)interpolation, "circularArc3Points"))
+ if (pa->npoints < 3 || pa->npoints % 2 == 0)
+ return lwcircstring_as_lwgeom(lwcircstring_construct(SRID_UNKNOWN, NULL, pa));
+ return NULL;
+static int
+gml_curve_endpoint(const LWGEOM *geom, POINT4D *pt)
+ if (!geom || lwgeom_is_empty(geom))
+ return LW_FAILURE;
+ if (geom->type == COMPOUNDTYPE)
+ const LWCOMPOUND *compound = (const LWCOMPOUND *)geom;
+ return gml_curve_endpoint(compound->geoms[compound->ngeoms - 1], pt);
+ if (geom->type == LINETYPE || geom->type == CIRCSTRINGTYPE)
+ const LWLINE *line = (const LWLINE *)geom;
+ if (!line->points || line->points->npoints < 1)
+ return getPoint4d_p(line->points, line->points->npoints - 1, pt) ? LW_SUCCESS : LW_FAILURE;
+static int
+gml_curve_points_equal(const POINT4D *a, const POINT4D *b, bool hasz)
+ if (a->x != b->x || a->y != b->y)
+ return LW_FALSE;
+ if (hasz && a->z != b->z)
+ return LW_FALSE;
+ return LW_TRUE;
+static void
+gml_compound_add_curve_component(LWCOMPOUND *compound, LWGEOM *segment)
+ if (segment->type == COMPOUNDTYPE)
+ LWCOMPOUND *nested = (LWCOMPOUND *)segment;
+ for (uint32_t i = 0; i < nested->ngeoms; i++)
+ if (lwcompound_add_lwgeom(compound, nested->geoms[i]) == LW_FAILURE)
+ gml_lwpgerror("invalid GML representation", 41);
+ nested->ngeoms = 0;
+ lwgeom_free(segment);
+ return;
+ if (compound->ngeoms > 0)
+ bool hasz = lwgeom_has_z(lwcompound_as_lwgeom(compound));
+ if (lwgeom_startpoint(segment, &first) == LW_FAILURE ||
+ gml_curve_endpoint(compound->geoms[compound->ngeoms - 1], &last) == LW_FAILURE ||
+ !gml_curve_points_equal(&first, &last, hasz))
+ if (lwcompound_add_lwgeom(compound, segment) == LW_FAILURE)
+static LWGEOM *
+gml_curve_segments_to_lwgeom(LWGEOM **segments, size_t nsegments, bool *hasz, int *root_srid)
+ bool has_curve = false;
+ if (nsegments == 0)
+ gml_lwpgerror("invalid GML representation", 40);
+ for (size_t i = 0; i < nsegments; i++)
+ if (segments[i]->type != LINETYPE)
+ has_curve = true;
+ break;
+ if (nsegments == 1)
+ return segments[0];
+ if (!has_curve)
+ LWLINE *line = (LWLINE *)segments[0];
+ POINTARRAY *pa = ptarray_clone_deep(line->points);
+ size_t point_size = *hasz ? sizeof(POINT3D) : sizeof(POINT2D);
+ for (size_t i = 1; i < nsegments; i++)
+ LWLINE *next = (LWLINE *)segments[i];
+ if (memcmp(
+ getPoint_internal(pa, pa->npoints - 1), getPoint_internal(next->points, 0), point_size))
+ if (ptarray_append_ptarray(pa, next->points, 0.0) == LW_FAILURE)
+ lwgeom_free(segments[i]);
+ lwgeom_free(segments[0]);
+ return lwline_as_lwgeom(lwline_construct(*root_srid, NULL, pa));
+ else
+ LWCOMPOUND *compound = lwcompound_construct_empty(*root_srid, *hasz, 0);
+ gml_compound_add_curve_component(compound, segments[i]);
+ return lwcompound_as_lwgeom(compound);
static LWGEOM* parse_gml_curve(xmlNodePtr xnode, bool *hasz, int *root_srid)
xmlNodePtr xa;
@@ -1097,10 +1293,7 @@ static LWGEOM* parse_gml_curve(xmlNodePtr xnode, bool *hasz, int *root_srid)
bool found=false;
gmlSrs srs;
LWGEOM *geom=NULL;
- POINTARRAY *pa=NULL;
- uint32 npoints=0;
+ LWGEOM **segments = NULL;
if (is_xlink(xnode)) xnode = get_xlink_node(xnode);
if (xnode == NULL)
@@ -1119,83 +1312,36 @@ static LWGEOM* parse_gml_curve(xmlNodePtr xnode, bool *hasz, int *root_srid)
if (!found) gml_lwpgerror("invalid GML representation", 37);
+ segments = (LWGEOM **)lwalloc(sizeof(LWGEOM *));
- /* Processing each gml:LineStringSegment */
+ /* Processing each gml:LineStringSegment or gml:ArcString */
for (xa = xa->children, lss=0; xa != NULL ; xa = xa->next)
+ LWGEOM *segment;
- if (!is_gml_element(xa, "LineStringSegment")) continue;
+ segment = parse_gml_curve_segment(xa, hasz, root_srid);
+ if (segment == NULL)
+ continue;
- /* GML SF is restricted to linear interpolation */
- interpolation = gmlGetProp(xa, "interpolation");
- if (interpolation != NULL)
- if (strcmp((char *) interpolation, "linear"))
- gml_lwpgerror("invalid GML representation", 38);
- xmlFree(interpolation);
- if (lss > 0) ppa = (POINTARRAY**) lwrealloc((POINTARRAY *) ppa,
- sizeof(POINTARRAY*) * (lss + 1));
- ppa[lss] = parse_gml_data(xa->children, hasz, root_srid);
- npoints += ppa[lss]->npoints;
- if (ppa[lss]->npoints < 2)
- gml_lwpgerror("invalid GML representation", 39);
+ if (lss > 0)
+ segments = lwrealloc(segments, sizeof(LWGEOM *) * (lss + 1));
+ segments[lss] = segment;
lss++;
if (lss == 0) gml_lwpgerror("invalid GML representation", 40);
- /* Most common case, a single segment */
- if (lss == 1) pa = ppa[0];
- if (lss > 1)
- * "The curve segments are connected to one another, with the end point
- * of each segment except the last being the start point of the next
- * segment" from ISO 19107:2003 -> 6.3.16.1 (p43)
- * So we must aggregate all the segments into a single one and avoid
- * to copy the redundant points
- size_t cp_point_size = sizeof(POINT3D); /* All internals are done with 3D */
- size_t final_point_size = *hasz ? sizeof(POINT3D) : sizeof(POINT2D);
- pa = ptarray_construct(1, 0, npoints - lss + 1);
- /* Copy the first linestring fully */
- memcpy(getPoint_internal(pa, 0), getPoint_internal(ppa[0], 0), cp_point_size * (ppa[0]->npoints));
- npoints = ppa[0]->npoints;
- lwfree(ppa[0]);
- /* For the rest of linestrings, ensure the first point matches the
- * last point of the previous one, and copy all points except the
- * first one (since it'd be repeated)
- for (size_t i = 1; i < lss; i++)
- if (memcmp(getPoint_internal(pa, npoints - 1), getPoint_internal(ppa[i], 0), final_point_size))
- memcpy(getPoint_internal(pa, npoints),
- getPoint_internal(ppa[i], 1),
- cp_point_size * (ppa[i]->npoints - 1));
- npoints += ppa[i]->npoints - 1;
- lwfree(ppa[i]);
- lwfree(ppa);
+ geom = gml_curve_segments_to_lwgeom(segments, lss, hasz, root_srid);
+ lwfree(segments);
- if (srs.reverse_axis) pa = ptarray_flip_coordinates(pa);
+ if (srs.reverse_axis)
+ lwgeom_swap_ordinates(geom, LWORD_X, LWORD_Y);
- gml_reproject_pa(pa, srs.srid, *root_srid);
- geom = (LWGEOM *) lwline_construct(*root_srid, NULL, pa);
+ gml_reproject_lwgeom(geom, srs.srid, *root_srid);
+ geom->srid = *root_srid;
return geom;
@@ -1238,13 +1384,100 @@ static LWGEOM* parse_gml_linearring(xmlNodePtr xnode, bool *hasz, int *root_srid
+static void
+gml_validate_ring_geom(LWGEOM *ring, int error_code)
+ uint32_t vertices_needed = ring->type == LINETYPE ? 4 : 3;
+ if (lwgeom_count_vertices(ring) < vertices_needed || !lwgeom_is_closed(ring))
+ gml_lwpgerror("invalid GML representation", error_code);
+static LWGEOM *
+parse_gml_linearring_as_lwgeom(xmlNodePtr xnode, bool *hasz, int *root_srid)
+ gmlSrs srs;
+ POINTARRAY *pa = parse_gml_data(xnode->children, hasz, root_srid);
+ LWGEOM *ring = lwline_as_lwgeom(lwline_construct(SRID_UNKNOWN, NULL, pa));
+ parse_gml_srs(xnode, &srs);
+ lwgeom_swap_ordinates(ring, LWORD_X, LWORD_Y);
+ if (srs.srid != *root_srid && *root_srid != SRID_UNKNOWN)
+ gml_reproject_lwgeom(ring, srs.srid, *root_srid);
+ ring->srid = *root_srid;
+ gml_validate_ring_geom(ring, 43);
+ return ring;
+static LWGEOM *
+parse_gml_ring(xmlNodePtr xnode, bool *hasz, int *root_srid)
+ xmlNodePtr xa, xb;
+ size_t nsegments = 0;
+ LWGEOM *ring;
+ if (is_xlink(xnode))
+ xnode = get_xlink_node(xnode);
+ if (xnode == NULL)
+ gml_lwpgerror("invalid GML representation", 30);
+ for (xa = xnode->children; xa != NULL; xa = xa->next)
+ if (xa->type != XML_ELEMENT_NODE)
+ continue;
+ if (!is_gml_namespace(xa, false))
+ continue;
+ if (is_gml_element(xa, "curveMembers"))
+ for (xb = xa->children; xb != NULL; xb = xb->next)
+ if (xb->type != XML_ELEMENT_NODE)
+ continue;
+ if (!is_gml_namespace(xb, false))
+ continue;
+ if (nsegments > 0)
+ segments = lwrealloc(segments, sizeof(LWGEOM *) * (nsegments + 1));
+ segments[nsegments++] = parse_gml(xb, hasz, root_srid);
+ else if (is_gml_element(xa, "curveMember"))
+ if (xa->children != NULL)
+ segments[nsegments++] = parse_gml(xa->children, hasz, root_srid);
+ gml_lwpgerror("invalid GML representation", 43);
+ ring = gml_curve_segments_to_lwgeom(segments, nsegments, hasz, root_srid);
+ lwfree(segments);
+ return ring;
static LWGEOM* parse_gml_polygon(xmlNodePtr xnode, bool *hasz, int *root_srid)
gmlSrs srs;
- int i, ring;
+ int ring;
LWGEOM *geom;
xmlNodePtr xa, xb;
- POINTARRAY **ppa = NULL;
+ LWGEOM **rings = NULL;
+ bool has_curve_ring = false;
if (xnode == NULL)
@@ -1269,22 +1502,19 @@ static LWGEOM* parse_gml_polygon(xmlNodePtr xnode, bool *hasz, int *root_srid)
+ if (!(is_gml_element(xb, "LinearRing") || is_gml_element(xb, "Ring")))
+ continue;
- gml_lwpgerror("invalid GML representation", 43);
- if (srs.reverse_axis) ppa[0] = ptarray_flip_coordinates(ppa[0]);
+ rings = (LWGEOM **)lwalloc(sizeof(LWGEOM *));
+ rings[0] = is_gml_element(xb, "Ring") ? parse_gml_ring(xb, hasz, root_srid)
+ : parse_gml_linearring_as_lwgeom(xb, hasz, root_srid);
+ if (rings[0]->type != LINETYPE)
+ has_curve_ring = true;
/* Found an <exterior> or <outerBoundaryIs> but no rings?!? We're outa here! */
- if ( ! ppa )
+ if (!rings)
@@ -1301,31 +1531,48 @@ static LWGEOM* parse_gml_polygon(xmlNodePtr xnode, bool *hasz, int *root_srid)
+ continue;
- || (*hasz && !ptarray_is_closed_3d(ppa[ring])))
- if (srs.reverse_axis) ppa[ring] = ptarray_flip_coordinates(ppa[ring]);
+ rings = lwrealloc(rings, sizeof(LWGEOM *) * (ring + 1));
+ rings[ring] = is_gml_element(xb, "Ring") ? parse_gml_ring(xb, hasz, root_srid)
+ if (rings[ring]->type != LINETYPE)
ring++;
- if (ppa == NULL || ppa[0] == NULL) gml_lwpgerror("invalid GML representation", 44);
+ if (rings == NULL || rings[0] == NULL)
+ gml_lwpgerror("invalid GML representation", 44);
+ if (has_curve_ring)
+ LWCURVEPOLY *curvepoly =
+ lwcurvepoly_construct_empty(*root_srid, FLAGS_GET_Z(rings[0]->flags), FLAGS_GET_M(rings[0]->flags));
+ for (int i = 0; i < ring; i++)
+ if (lwcurvepoly_add_ring(curvepoly, rings[i]) == LW_FAILURE)
+ lwfree(rings);
+ geom = lwcurvepoly_as_lwgeom(curvepoly);
+ else
+ POINTARRAY **ppa = (POINTARRAY **)lwalloc(sizeof(POINTARRAY *) * ring);
+ LWLINE *line = (LWLINE *)rings[i];
+ ppa[i] = ptarray_clone_deep(line->points);
+ lwgeom_free(rings[i]);
+ lwfree(rings);
+ geom = (LWGEOM *)lwpoly_construct(*root_srid, NULL, ring, ppa);
return geom;
@@ -1699,7 +1946,9 @@ static LWGEOM* parse_gml_mcurve(xmlNodePtr xnode, bool *hasz, int *root_srid)
gmlSrs srs;
xmlNodePtr xa, xb;
- LWGEOM *geom = NULL;
+ LWGEOM **geoms = NULL;
+ uint32_t ngeoms = 0;
if (xnode == NULL)
@@ -1709,10 +1958,8 @@ static LWGEOM* parse_gml_mcurve(xmlNodePtr xnode, bool *hasz, int *root_srid)
if (*root_srid == SRID_UNKNOWN && srs.srid != SRID_UNKNOWN)
*root_srid = srs.srid;
- geom = (LWGEOM *)lwcollection_construct_empty(MULTILINETYPE, *root_srid, 1, 0);
if (xnode->children == NULL)
- return geom;
+ return (LWGEOM *)lwcollection_construct_empty(MULTILINETYPE, *root_srid, 1, 0);
@@ -1724,20 +1971,47 @@ static LWGEOM* parse_gml_mcurve(xmlNodePtr xnode, bool *hasz, int *root_srid)
- if (xb != NULL)
- geom = (LWGEOM*)lwmline_add_lwline((LWMLINE*)geom,
- (LWLINE*)parse_gml(xb, hasz, root_srid));
+ LWGEOM *member;
+ continue;
+ continue;
+ member = parse_gml(xb, hasz, root_srid);
+ if (member->type != LINETYPE)
+ has_curve = true;
- (LWLINE*)parse_gml(xa->children, hasz, root_srid));
+ LWGEOM *member = parse_gml(xa->children, hasz, root_srid);
+ has_curve = true;
- return geom;
+ if (ngeoms == 0)
+ else
+ LWCOLLECTION *col = lwcollection_construct_empty(has_curve ? MULTICURVETYPE : MULTILINETYPE,
+ *root_srid,
+ FLAGS_GET_Z(geoms[0]->flags),
+ FLAGS_GET_M(geoms[0]->flags));
+ for (uint32_t i = 0; i < ngeoms; i++)
+ lwcollection_add_lwgeom(col, geoms[i]);
+ lwfree(geoms);
+ return (LWGEOM *)col;
@@ -1785,7 +2059,9 @@ static LWGEOM* parse_gml_msurface(xmlNodePtr xnode, bool *hasz, int *root_srid)
gmlSrs srs;
xmlNodePtr xa, xb;
if (xnode == NULL)
@@ -1795,10 +2071,8 @@ static LWGEOM* parse_gml_msurface(xmlNodePtr xnode, bool *hasz, int *root_srid)
- geom = (LWGEOM *)lwcollection_construct_empty(MULTIPOLYGONTYPE, *root_srid, 1, 0);
- return geom;
+ return (LWGEOM *)lwcollection_construct_empty(MULTIPOLYGONTYPE, *root_srid, 1, 0);
@@ -1809,20 +2083,47 @@ static LWGEOM* parse_gml_msurface(xmlNodePtr xnode, bool *hasz, int *root_srid)
- if (xb != NULL)
- geom = (LWGEOM*)lwmpoly_add_lwpoly((LWMPOLY*)geom,
- (LWPOLY*)parse_gml(xb, hasz, root_srid));
+ LWGEOM *member;
+ continue;
+ continue;
+ has_curve = true;
- (LWPOLY*)parse_gml(xa->children, hasz, root_srid));
+ has_curve = true;
- return geom;
+ if (ngeoms == 0)
+ else
+ LWCOLLECTION *col = lwcollection_construct_empty(has_curve ? MULTISURFACETYPE : MULTIPOLYGONTYPE,
+ *root_srid,
+ lwfree(geoms);
@@ -2018,7 +2319,7 @@ static LWGEOM* parse_gml(xmlNodePtr xnode, bool *hasz, int *root_srid)
if (is_gml_element(xa, "LinearRing"))
return parse_gml_linearring(xa, hasz, root_srid);
- if (is_gml_element(xa, "Polygon"))
+ if (is_gml_element(xa, "Polygon") || is_gml_element(xa, "CurvePolygon"))
return parse_gml_polygon(xa, hasz, root_srid);
if (is_gml_element(xa, "Triangle"))
index d676ef688..4f4043abc 100644
@@ -97,6 +97,21 @@ SELECT 'curve_14', ST_AsEWKT(ST_GeomFromGML('<gml:Curve><gml:segments><gml:LineS
SELECT 'curve_15', ST_AsEWKT(ST_GeomFromGML('<gml:Curve><gml:segments><gml:LineStringSegment><gml:posList srsDimension="3">1 2 3 4 5 6</gml:posList></gml:LineStringSegment><gml:LineStringSegment><gml:posList srsDimension="2">4 5 7 8</gml:posList></gml:LineStringSegment></gml:segments></gml:Curve>'));
SELECT 'curve_16', ST_AsEWKT(ST_GeomFromGML('<gml:Curve><gml:segments><gml:LineStringSegment><gml:posList srsDimension="2">1 2 3 4</gml:posList></gml:LineStringSegment><gml:LineStringSegment><gml:posList srsDimension="3">3 4 5 6 7 8</gml:posList></gml:LineStringSegment></gml:segments></gml:Curve>'));
+-- ArcString
+SELECT 'curve_17', ST_AsEWKT(ST_GeomFromGML('<gml:Curve><gml:segments><gml:ArcString><gml:posList>0 0 1 1 2 0</gml:posList></gml:ArcString></gml:segments></gml:Curve>'));
+SELECT 'curve_18', ST_AsEWKT(ST_GeomFromGML('<gml:Curve><gml:segments><gml:LineStringSegment><gml:posList>0 0 1 0</gml:posList></gml:LineStringSegment><gml:ArcString><gml:posList>1 0 2 1 3 0</gml:posList></gml:ArcString></gml:segments></gml:Curve>'));
+-- ERROR malformed ArcString
+SELECT 'curve_19', ST_AsEWKT(ST_GeomFromGML('<gml:Curve><gml:segments><gml:ArcString><gml:posList>0 0 1 1</gml:posList></gml:ArcString></gml:segments></gml:Curve>'));
+-- ERROR disjoint compound curve components
+SELECT 'curve_20', ST_AsEWKT(ST_GeomFromGML('<gml:Curve><gml:segments><gml:LineStringSegment><gml:posList>0 0 1 0</gml:posList></gml:LineStringSegment><gml:ArcString><gml:posList>2 0 3 1 4 0</gml:posList></gml:ArcString></gml:segments></gml:Curve>'));
+SELECT 'curve_21', ST_AsEWKT(ST_GeomFromGML('<gml:Curve srsName="urn:ogc:def:crs:EPSG::4326"><gml:segments><gml:ArcString><gml:posList>1 2 3 4 5 6</gml:posList></gml:ArcString></gml:segments></gml:Curve>'));
+-- ERROR mismatched Z compound curve components
+SELECT 'curve_22', ST_AsEWKT(ST_GeomFromGML('<gml:Curve><gml:segments><gml:LineStringSegment><gml:posList srsDimension="3">0 0 0 1 0 0</gml:posList></gml:LineStringSegment><gml:ArcString><gml:posList srsDimension="3">1 0 99 2 1 99 3 0 99</gml:posList></gml:ArcString></gml:segments></gml:Curve>'));
-- Polygon
@@ -150,6 +165,15 @@ SELECT 'polygon_17', ST_AsEWKT(ST_GeomFromGML('<gml:Polygon><gml:exterior><gml:L
SELECT 'polygon_18', ST_AsEWKT(ST_GeomFromGML('<gml:Polygon><gml:exterior><gml:LinearRing><gml:posList srsDimension="3">1 2 3 4 5 6 7 8 9 1 2 3</gml:posList></gml:LinearRing></gml:exterior><gml:interior><gml:LinearRing><gml:posList srsDimension="2">10 11 12 13 14 15 10 11</gml:posList></gml:LinearRing></gml:interior></gml:Polygon>'));
SELECT 'polygon_19', ST_AsEWKT(ST_GeomFromGML('<gml:Polygon><gml:exterior><gml:LinearRing><gml:posList srsDimension="2">1 2 3 4 5 6 1 2</gml:posList></gml:LinearRing></gml:exterior><gml:interior><gml:LinearRing><gml:posList srsDimension="3">7 8 9 10 11 12 13 14 15 7 8 9</gml:posList></gml:LinearRing></gml:interior></gml:Polygon>'));
+-- GML 3.2 Ring with curve members
+SELECT 'polygon_20', ST_AsEWKT(ST_GeomFromGML('<gml:Polygon xmlns:gml="http://www.opengis.net/gml/3.2"><gml:exterior><gml:Ring><gml:curveMember><gml:LineString><gml:posList>0 0 1 0</gml:posList></gml:LineString></gml:curveMember><gml:curveMember><gml:Curve><gml:segments><gml:ArcString><gml:posList>1 0 2 1 3 0</gml:posList></gml:ArcString></gml:segments></gml:Curve></gml:curveMember><gml:curveMember><gml:LineString><gml:posList>3 0 0 0</gml:posList></gml:LineString></gml:curveMember></gml:Ring></gml:exterior><gml:interior><gml:LinearRing><gml:posList>0.5 0.1 0.75 0.2 0.5 0.3 0.5 0.1</gml:posList></gml:LinearRing></gml:interior></gml:Polygon>'));
+SELECT 'polygon_21', ST_AsEWKT(ST_GeomFromGML('<gml:CurvePolygon xmlns:gml="http://www.opengis.net/gml/3.2"><gml:exterior><gml:Ring><gml:curveMember><gml:Curve><gml:segments><gml:ArcString><gml:posList>0 0 1 1 2 0 1 -1 0 0</gml:posList></gml:ArcString></gml:segments></gml:Curve></gml:curveMember></gml:Ring></gml:exterior></gml:CurvePolygon>'));
+SELECT 'polygon_24', ST_AsEWKT(ST_GeomFromGML('<gml:CurvePolygon xmlns:gml="http://www.opengis.net/gml/3.2"><gml:exterior><gml:Ring><gml:curveMember><gml:LineString><gml:posList>0 0 1 0</gml:posList></gml:LineString></gml:curveMember><gml:curveMember><gml:Curve><gml:segments><gml:LineStringSegment><gml:posList>1 0 2 0</gml:posList></gml:LineStringSegment><gml:ArcString><gml:posList>2 0 3 1 4 0</gml:posList></gml:ArcString></gml:segments></gml:Curve></gml:curveMember><gml:curveMember><gml:LineString><gml:posList>4 0 0 0</gml:posList></gml:LineString></gml:curveMember></gml:Ring></gml:exterior></gml:CurvePolygon>'));
+-- ERROR open curved ring
+SELECT 'polygon_22', ST_AsEWKT(ST_GeomFromGML('<gml:Polygon xmlns:gml="http://www.opengis.net/gml/3.2"><gml:exterior><gml:Ring><gml:curveMember><gml:Curve><gml:segments><gml:ArcString><gml:posList>0 0 1 1 2 0</gml:posList></gml:ArcString></gml:segments></gml:Curve></gml:curveMember></gml:Ring></gml:exterior></gml:Polygon>'));
+SELECT 'polygon_23', ST_AsEWKT(ST_GeomFromGML('<gml:CurvePolygon xmlns:gml="http://www.opengis.net/gml/3.2" srsName="urn:ogc:def:crs:EPSG::4326"><gml:exterior><gml:Ring><gml:curveMember><gml:Curve><gml:segments><gml:ArcString><gml:posList>1 2 3 4 5 6 7 8 1 2</gml:posList></gml:ArcString></gml:segments></gml:Curve></gml:curveMember></gml:Ring></gml:exterior></gml:CurvePolygon>'));
-- LinearRing
@@ -368,6 +392,11 @@ SELECT 'mcurve_11', ST_AsEWKT(ST_GeomFromGML('<gml:MultiCurve><gml:curveMembers>
SELECT 'mcurve_12', ST_AsEWKT(ST_GeomFromGML('<gml:MultiCurve><gml:curveMembers></gml:curveMembers></gml:MultiCurve>'));
+SELECT 'mcurve_13', ST_AsEWKT(ST_GeomFromGML('<gml:MultiCurve><gml:curveMember><gml:Curve><gml:segments><gml:ArcString><gml:posList>0 0 1 1 2 0</gml:posList></gml:ArcString></gml:segments></gml:Curve></gml:curveMember></gml:MultiCurve>'));
+WITH g AS (SELECT ST_GeomFromGML('<gml:MultiCurve srsName="EPSG:27582"><gml:curveMember><gml:Curve srsName="EPSG:27562"><gml:segments><gml:ArcString><gml:coordinates>400000,5000000 400010,5000010 400020,5000000</gml:coordinates></gml:ArcString></gml:segments></gml:Curve></gml:curveMember></gml:MultiCurve>') as g)
+SELECT 'mcurve_14', ST_SRID(g.g), ST_AsText(g.g, 8) FROM g;
-- MultiPolygon
@@ -433,6 +462,8 @@ SELECT 'msurface_11', ST_AsEWKT(ST_GeomFromGML('<gml:MultiSurface><gml:surfaceMe
-- Empty surfaceMembers
SELECT 'msurface_12', ST_AsEWKT(ST_GeomFromGML('<gml:MultiSurface><gml:surfaceMembers></gml:surfaceMembers></gml:MultiSurface>'));
+SELECT 'msurface_13', ST_AsEWKT(ST_GeomFromGML('<gml:MultiSurface xmlns:gml="http://www.opengis.net/gml/3.2"><gml:surfaceMember><gml:CurvePolygon><gml:exterior><gml:Ring><gml:curveMember><gml:Curve><gml:segments><gml:ArcString><gml:posList>0 0 1 1 2 0 1 -1 0 0</gml:posList></gml:ArcString></gml:segments></gml:Curve></gml:curveMember></gml:Ring></gml:exterior></gml:CurvePolygon></gml:surfaceMember></gml:MultiSurface>'));
index 5b5257ec2..54b91812c 100644
@@ -28,6 +28,12 @@ ERROR: invalid GML representation
curve_15|LINESTRING(1 2,4 5,7 8)
curve_16|LINESTRING(1 2,3 4,6 7)
+curve_17|CIRCULARSTRING(0 0,1 1,2 0)
+curve_18|COMPOUNDCURVE((0 0,1 0),CIRCULARSTRING(1 0,2 1,3 0))
+curve_21|SRID=4326;CIRCULARSTRING(2 1,4 3,6 5)
polygon_1|POLYGON((1 2,3 4,5 6,1 2))
polygon_2|SRID=4326;POLYGON((1 2,3 4,5 6,1 2))
@@ -47,6 +53,11 @@ polygon_16|POLYGON((1 2,3 4,5 6,1 2),(7 8,9 10,11 12,7 8),(13 14,15 16,17 18,13
polygon_17|POLYGON((1 2,3 4,5 6,1 2),(7 8,9 10,11 12,7 8))
polygon_18|POLYGON((1 2,4 5,7 8,1 2),(10 11,12 13,14 15,10 11))
polygon_19|POLYGON((1 2,3 4,5 6,1 2),(7 8,10 11,13 14,7 8))
+polygon_20|CURVEPOLYGON(COMPOUNDCURVE((0 0,1 0),CIRCULARSTRING(1 0,2 1,3 0),(3 0,0 0)),(0.5 0.1,0.75 0.2,0.5 0.3,0.5 0.1))
+polygon_21|CURVEPOLYGON(CIRCULARSTRING(0 0,1 1,2 0,1 -1,0 0))
+polygon_24|CURVEPOLYGON(COMPOUNDCURVE((0 0,1 0),(1 0,2 0),CIRCULARSTRING(2 0,3 1,4 0),(4 0,0 0)))
+polygon_23|SRID=4326;CURVEPOLYGON(CIRCULARSTRING(2 1,4 3,6 5,8 7,2 1))
@@ -120,6 +131,8 @@ mcurve_9|27582|MULTILINESTRING((1 2,3 4),(400000 7000000,400010 7000010))
mcurve_10|MULTILINESTRING((1 2,3 4))
mcurve_11|MULTILINESTRING((1 2,3 4),(5 6,7 8))
mcurve_12|MULTILINESTRING EMPTY
+mcurve_13|MULTICURVE(CIRCULARSTRING(0 0,1 1,2 0))
+mcurve_14|27582|MULTICURVE(CIRCULARSTRING(400000 7000000,400010 7000010,400020 7000000))
mpoly_1|MULTIPOLYGON(((1 2,3 4,5 6,1 2)))
mpoly_2|MULTIPOLYGON(((1 2,3 4,5 6,1 2)),((7 8,9 10,11 12,7 8)))
mpoly_3|SRID=4326;MULTIPOLYGON(((1 2,3 4,5 6,1 2)))
@@ -141,6 +154,7 @@ msurface_9|MULTIPOLYGON(((1 2,3 4,5 6,1 2)),((400000 7000000,400010 7000010,4000
+msurface_13|MULTISURFACE(CURVEPOLYGON(CIRCULARSTRING(0 0,1 1,2 0,1 -1,0 0)))
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index 1daac1d93..c580547f4 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -220,7 +220,7 @@ NOTICE: SRID value -1 converted to the officially unknown SRID value 0
#1776|POLYGON((0 0,10 0,10 10,0 0))|POLYGON((0 0,10 0,10 10,0 0))
#1780|t
ERROR: ST_Segmentize: invalid max_distance 0 (must be >= 0)
-ERROR: invalid GML representation
+CURVEPOLYGON(COMPOUNDCURVE((1070163.61 711540.35,1070166.54 711523.82,1070164.14 711521.3,1070162.44 711519.52,1070164.62 711518.57,1070824.94 712154.47),CIRCULARSTRING(1070824.94 712154.47,1070826.04 712154.98,1070827.22 712154.41),(1070827.22 712154.41,1070837.07 712160.31,1070835.36 712160.92,1071007.95 712207.89),CIRCULARSTRING(1071007.95 712207.89,1071005.59 712207.48,1071001.28 712208.38),(1071001.28 712208.38,1070949.67 712228.74,1070936.15 712233.98,1070788.72 712124.93),CIRCULARSTRING(1070788.72 712124.93,1070785.87 712124.28,1070783.38 712124.63),(1070783.38 712124.63,1070764.12 712141.04,1070757.01 712146.6,1070163.61 711540.35)),(1070354.46 713061.62,1070335.12 713053.59,1070315.92 713049.58,1070298.33 713049.65,1070354.46 713061.62))
#1957|1
#1978|3.1416
#1996|{"type":"Point","coordinates":[]}
Summary of changes:
NEWS | 3 +
doc/reference_input.xml | 8 +-
postgis/lwgeom_in_gml.c | 628 +++++++++++++++++++++++++++++-------------
regress/core/in_gml.sql | 41 +++
regress/core/in_gml_expected | 18 ++
regress/core/tickets_expected | 2 +-
6 files changed, 499 insertions(+), 201 deletions(-)
hooks/post-receive
