[SCM] PostGIS branch stable-3.5 updated. 3.5.7-62-ga40c5b03f
Sun Jul 19 06:00:41 PDT 2026
the project "PostGIS".
The branch, stable-3.5 has been updated
       via  a40c5b03f73f50cdc22e2522a3d58d8217c03a6d (commit)
       via  a26387956b186f71868bffc08ac1de406d628db1 (commit)
       via  60c8f2bd24fe522cd57935ada9cc9a1dd449716f (commit)
       via  b1c4872cd8c2275855f48c1664eef21c9866d311 (commit)
      from  ddb120471d35f068710a411a6c651f03c5983ea9 (commit)
revisions in full, below.
commit a40c5b03f73f50cdc22e2522a3d58d8217c03a6d
Merge: ddb120471 a26387956
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Sun Jul 19 06:00:40 2026 -0700
    Merge pull request 'utils: compare upgrade versions numerically' (!439) from Komzpa/postgis:ci/semver-numeric-3.5-20260719T1138Z into stable-3.5
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/439
commit a26387956b186f71868bffc08ac1de406d628db1
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Sun Jul 19 16:29:37 2026 +0400
    ci: use pg_ctl_options for start timeout
diff --git a/.woodpecker/regress.yml b/.woodpecker/regress.yml
index 2dd7bb05e..e5cb74c29 100644
--- a/.woodpecker/regress.yml
+++ b/.woodpecker/regress.yml
@@ -9,7 +9,7 @@ variables:
     - export PGPORT=$$(grep ^port /etc/postgresql/$${PGVER}/main/postgresql.conf | awk '{print $$3}')
     # The test image can need crash recovery after clone-local startup. Under
     # multi-workflow I/O load, Debian's default 60-second pg_ctl wait is short.
-    - printf '%s\n' '-t 300' > /etc/postgresql/$${PGVER}/main/pg_ctl.conf
+    - printf '%s\n' "pg_ctl_options = '-t 300'" > /etc/postgresql/$${PGVER}/main/pg_ctl.conf
     - export POSTGIS_REGRESS_DB_OWNER=postgis_reg_unprivileged_user
     - export RUNTESTFLAGS="-v
       --after-create-db-script $${CI_WORKSPACE}/regress/hooks/configure-pgextwlist.sql
commit 60c8f2bd24fe522cd57935ada9cc9a1dd449716f
Date:   Sun Jul 19 16:03:27 2026 +0400
    ci: extend PostgreSQL start timeout
index cbf30231d..2dd7bb05e 100644
@@ -7,6 +7,9 @@ variables:
   steps-env: &steps-env
     - export PATH=/usr/lib/postgresql/$${PGVER}/bin:$${PATH}
+    # The test image can need crash recovery after clone-local startup. Under
+    # multi-workflow I/O load, Debian's default 60-second pg_ctl wait is short.
+    - printf '%s\n' '-t 300' > /etc/postgresql/$${PGVER}/main/pg_ctl.conf
commit b1c4872cd8c2275855f48c1664eef21c9866d311
Date:   Sun Jul 19 15:40:32 2026 +0400
diff --git a/utils/check_all_upgrades.sh b/utils/check_all_upgrades.sh
index 3ebb94b35..012413e75 100755
--- a/utils/check_all_upgrades.sh
+++ b/utils/check_all_upgrades.sh
@@ -7,6 +7,7 @@ TMPDIR=$(mktemp -d "${TMPDIR:-/tmp}/check_all_upgrades.XXXXXX") || exit 1
 PGVER=`pg_config --version | awk '{print $2}'`
 PGVER_MAJOR=$(echo "${PGVER}" | sed 's/\.[^\.]*//' | sed 's/\(alpha\|beta\|rc\).*//' )
 SKIP_LABEL_REGEXP=
+SELFTEST=0
 echo "INFO: PostgreSQL version: ${PGVER} [${PGVER_MAJOR}]"
 MAKE=$(which gmake make | head -1)
 BUILDDIR=$PWD # TODO: allow override ?
@@ -23,11 +24,14 @@ usage() {
   echo "Options:"
   echo "\t-s  Stop on first failure"
   echo "\t--skip <regexp>  Do not run tests with label matching given extended regexp"
+  echo "\t--self-test  Run check_all_upgrades.sh unit tests"
 while test -n "$1"; do
   if test "$1" = "-s"; then
     EXIT_ON_FIRST_FAILURE=1
+  elif test "$1" = "--self-test"; then
+    SELFTEST=1
   elif test "$1" = "--skip"; then
     shift
     SKIP_LABEL_REGEXP=$1
@@ -40,7 +44,7 @@ while test -n "$1"; do
   shift
 done
-if test -z "$to_version_param"; then
+if test "${SELFTEST}" != 1 && test -z "$to_version_param"; then
   usage >&2
   exit 1
 fi
@@ -69,6 +73,16 @@ semver_compare()
       echo 1; return;
     fi
     V2=`echo "$V2" | cut -d. -sf2-`
+    v1_numeric=`echo "$v1" | sed 's/[^0-9].*//'`
+    v2_numeric=`echo "$v2" | sed 's/[^0-9].*//'`
+    if test -n "$v1_numeric" && test -n "$v2_numeric"; then
+      if [ "$v1_numeric" -lt "$v2_numeric" ]; then
+        echo -1; return;
+      fi
+      if [ "$v1_numeric" -gt "$v2_numeric" ]; then
+        echo 1; return;
+      fi
+    fi
     # echo "v: $v1 - $v2" >&2
     if expr "$v1" '<' "$v2" > /dev/null; then
       echo -1; return;
@@ -212,6 +226,29 @@ report_missing_versions()
   cleanup
+check_all_upgrades_selftest()
+  if test "`semver_compare 3.2.7 3.2.11dev`" != "-1"; then
+    echo "FAIL: expected 3.2.7 to compare older than 3.2.11dev" >&2
+    exit 1
+  fi
+  if test "`semver_compare 3.2.11dev 3.2.7`" != "1"; then
+    echo "FAIL: expected 3.2.11dev to compare newer than 3.2.7" >&2
+    exit 1
+  fi
+  if test "`semver_compare 3.2.11dev 3.2.11dev`" != "0"; then
+    echo "FAIL: expected identical dev versions to compare equal" >&2
+    exit 1
+  fi
+if test "${SELFTEST}" = 1; then
+  check_all_upgrades_selftest
+  exit
+fi
 to_version=$to_version_param
 if expr $to_version : ':auto' >/dev/null; then
Summary of changes:
 .woodpecker/regress.yml     |  3 +++
 utils/check_all_upgrades.sh | 39 ++++++++++++++++++++++++++++++++++++++-
 2 files changed, 41 insertions(+), 1 deletion(-)
hooks/post-receive
