[SCM] PostGIS branch stable-3.4 updated. 3.4.6-74-gdd9cdb99e
git at osgeo.org
git at osgeo.org
Sun Jul 19 06:01:04 PDT 2026
the project "PostGIS".
The branch, stable-3.4 has been updated
via dd9cdb99e92b435441c0eea419a2d980a366168b (commit)
via d6c2080a00db8b27348afbaeb2a48bc920e6540b (commit)
via c68b42044475a5edf6b3e9d4710339d098facb90 (commit)
via e47beeb971e343098d5f9276574da0fbb747afd7 (commit)
from d1196f6043de1e608864739e915cc876a44b1ee5 (commit)
revisions in full, below.
commit dd9cdb99e92b435441c0eea419a2d980a366168b
Merge: d1196f604 d6c2080a0
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Sun Jul 19 06:01:03 2026 -0700
Merge pull request 'utils: compare upgrade versions numerically' (!440) from Komzpa/postgis:ci/semver-numeric-3.4-20260719T1138Z into stable-3.4
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/440
commit d6c2080a00db8b27348afbaeb2a48bc920e6540b
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Sun Jul 19 16:29:37 2026 +0400
ci: use pg_ctl_options for start timeout
diff --git a/.woodpecker/regress.yml b/.woodpecker/regress.yml
index 0b90f98fa..b224b6f32 100644
--- a/.woodpecker/regress.yml
+++ b/.woodpecker/regress.yml
@@ -7,7 +7,7 @@ variables:
- export PGPORT=$$(grep ^port /etc/postgresql/$${PGVER}/main/postgresql.conf | awk '{print $$3}')
# The test image can need crash recovery after clone-local startup. Under
# multi-workflow I/O load, Debian's default 60-second pg_ctl wait is short.
- - printf '%s\n' '-t 300' > /etc/postgresql/$${PGVER}/main/pg_ctl.conf
+ - printf '%s\n' "pg_ctl_options = '-t 300'" > /etc/postgresql/$${PGVER}/main/pg_ctl.conf
- export SRCDIR=$${CI_WORKSPACE}
- export RUNTESTFLAGS="-v
--after-create-db-script $${SRCDIR}/regress/hooks/standard-conforming-strings-off.sql"
commit c68b42044475a5edf6b3e9d4710339d098facb90
Date: Sun Jul 19 16:03:27 2026 +0400
ci: extend PostgreSQL start timeout
index e6bf5ad09..0b90f98fa 100644
@@ -5,6 +5,9 @@ variables:
steps-env: &steps-env
- export PATH=/usr/lib/postgresql/$${PGVER}/bin:$${PATH}
+ # The test image can need crash recovery after clone-local startup. Under
+ # multi-workflow I/O load, Debian's default 60-second pg_ctl wait is short.
+ - printf '%s\n' '-t 300' > /etc/postgresql/$${PGVER}/main/pg_ctl.conf
commit e47beeb971e343098d5f9276574da0fbb747afd7
Date: Sun Jul 19 03:55:09 2026 +0400
diff --git a/utils/check_all_upgrades.sh b/utils/check_all_upgrades.sh
index d16533f40..1ad78384f 100755
--- a/utils/check_all_upgrades.sh
+++ b/utils/check_all_upgrades.sh
@@ -65,6 +65,16 @@ semver_compare()
echo 1; return;
fi
V2=`echo "$V2" | cut -d. -sf2-`
+ v1_numeric=`echo "$v1" | sed 's/[^0-9].*//'`
+ v2_numeric=`echo "$v2" | sed 's/[^0-9].*//'`
+ if test -n "$v1_numeric" && test -n "$v2_numeric"; then
+ if [ "$v1_numeric" -lt "$v2_numeric" ]; then
+ echo -1; return;
+ fi
+ if [ "$v1_numeric" -gt "$v2_numeric" ]; then
+ echo 1; return;
+ fi
+ fi
# echo "v: $v1 - $v2" >&2
if expr "$v1" '<' "$v2" > /dev/null; then
echo -1; return;
@@ -286,6 +296,21 @@ check_all_upgrades_selftest()
exit 1
fi
grep -q '^FAIL: self-test downgrade gave some other error:' ${test_tmp}/other.out
+ if test "`semver_compare 3.2.7 3.2.11dev`" != "-1"; then
+ echo "FAIL: expected 3.2.7 to compare older than 3.2.11dev" >&2
+ exit 1
+ fi
+ if test "`semver_compare 3.2.11dev 3.2.7`" != "1"; then
+ echo "FAIL: expected 3.2.11dev to compare newer than 3.2.7" >&2
+ exit 1
+ fi
+ if test "`semver_compare 3.2.11dev 3.2.11dev`" != "0"; then
+ echo "FAIL: expected identical dev versions to compare equal" >&2
+ exit 1
+ fi
if test "${SELFTEST}" = 1; then
Summary of changes:
.woodpecker/regress.yml | 3 +++
utils/check_all_upgrades.sh | 25 +++++++++++++++++++++++++
2 files changed, 28 insertions(+)
hooks/post-receive
