[SCM] PostGIS branch stable-3.3 updated. 3.3.10-71-gc84938029
git at osgeo.org
git at osgeo.org
Sun Jul 19 06:01:19 PDT 2026
the project "PostGIS".
The branch, stable-3.3 has been updated
via c849380298c5a9e6354876f519b999408ab632e0 (commit)
via 4169084fc203230f3f45c4591750d4a16fc25ede (commit)
via 08563a02fe879fc68a88d1d1d11957c9d236e474 (commit)
via eb2c5f3f00617cf22588f3ad10298e0c8893fdf8 (commit)
from 8e49a35f65acf8decad125dfb9f214b559293b09 (commit)
revisions in full, below.
commit c849380298c5a9e6354876f519b999408ab632e0
Merge: 8e49a35f6 4169084fc
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Sun Jul 19 06:01:18 2026 -0700
Merge pull request 'utils: compare upgrade versions numerically' (!441) from Komzpa/postgis:ci/semver-numeric-3.3-20260719T1138Z into stable-3.3
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/441
commit 4169084fc203230f3f45c4591750d4a16fc25ede
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Sun Jul 19 16:29:37 2026 +0400
ci: use pg_ctl_options for start timeout
diff --git a/.woodpecker/regress.yml b/.woodpecker/regress.yml
index 65ebf5af3..8b4883ec5 100644
--- a/.woodpecker/regress.yml
+++ b/.woodpecker/regress.yml
@@ -9,7 +9,7 @@ variables:
- export PGPORT=$$(grep ^port /etc/postgresql/$${PGVER}/main/postgresql.conf | awk '{print $$3}')
# The test image can need crash recovery after clone-local startup. Under
# multi-workflow I/O load, Debian's default 60-second pg_ctl wait is short.
- - printf '%s\n' '-t 300' > /etc/postgresql/$${PGVER}/main/pg_ctl.conf
+ - printf '%s\n' "pg_ctl_options = '-t 300'" > /etc/postgresql/$${PGVER}/main/pg_ctl.conf
- export RUNTESTFLAGS="-v
--after-create-db-script $${CI_WORKSPACE}/regress/hooks/standard-conforming-strings-off.sql"
- export SRCDIR=$${CI_WORKSPACE}
commit 08563a02fe879fc68a88d1d1d11957c9d236e474
Date: Sun Jul 19 16:03:27 2026 +0400
ci: extend PostgreSQL start timeout
index a3bcd9eb1..65ebf5af3 100644
@@ -7,6 +7,9 @@ variables:
steps-env: &steps-env
- export PATH=/usr/lib/postgresql/$${PGVER}/bin:$${PATH}
+ # The test image can need crash recovery after clone-local startup. Under
+ # multi-workflow I/O load, Debian's default 60-second pg_ctl wait is short.
+ - printf '%s\n' '-t 300' > /etc/postgresql/$${PGVER}/main/pg_ctl.conf
commit eb2c5f3f00617cf22588f3ad10298e0c8893fdf8
Date: Sun Jul 19 03:55:09 2026 +0400
diff --git a/utils/check_all_upgrades.sh b/utils/check_all_upgrades.sh
index 207c14c95..4274849ce 100755
--- a/utils/check_all_upgrades.sh
+++ b/utils/check_all_upgrades.sh
@@ -70,6 +70,16 @@ semver_compare()
echo 1; return;
fi
V2=`echo "$V2" | cut -d. -sf2-`
+ v1_numeric=`echo "$v1" | sed 's/[^0-9].*//'`
+ v2_numeric=`echo "$v2" | sed 's/[^0-9].*//'`
+ if test -n "$v1_numeric" && test -n "$v2_numeric"; then
+ if [ "$v1_numeric" -lt "$v2_numeric" ]; then
+ echo -1; return;
+ fi
+ if [ "$v1_numeric" -gt "$v2_numeric" ]; then
+ echo 1; return;
+ fi
+ fi
# echo "v: $v1 - $v2" >&2
if expr "$v1" '<' "$v2" > /dev/null; then
echo -1; return;
@@ -291,6 +301,21 @@ check_all_upgrades_selftest()
exit 1
fi
grep -q '^FAIL: self-test downgrade gave some other error:' ${test_tmp}/other.out
+ if test "`semver_compare 3.2.7 3.2.11dev`" != "-1"; then
+ echo "FAIL: expected 3.2.7 to compare older than 3.2.11dev" >&2
+ exit 1
+ fi
+ if test "`semver_compare 3.2.11dev 3.2.7`" != "1"; then
+ echo "FAIL: expected 3.2.11dev to compare newer than 3.2.7" >&2
+ exit 1
+ fi
+ if test "`semver_compare 3.2.11dev 3.2.11dev`" != "0"; then
+ echo "FAIL: expected identical dev versions to compare equal" >&2
+ exit 1
+ fi
if test "${SELFTEST}" = 1; then
Summary of changes:
.woodpecker/regress.yml | 3 +++
utils/check_all_upgrades.sh | 25 +++++++++++++++++++++++++
2 files changed, 28 insertions(+)
hooks/post-receive
