[SCM] PostGIS branch stable-3.6 updated. 3.6.4-72-gd402f622e
git at osgeo.org
git at osgeo.org
Sun Jul 19 08:59:11 PDT 2026
the project "PostGIS".
The branch, stable-3.6 has been updated
via d402f622e40deafeb5146b79599c965cecb79697 (commit)
via 6fdf1dbb0b2b97f154b6dc046dfbcbdf54fa4e44 (commit)
via 47ab82df3320d0257f9d42ff6710f6f0b212e1d1 (commit)
via 4b3b4604ff047e1246a8cf8d1b838cd0fb74321d (commit)
from 30d2db69622858abc4fdb148d21ec846138df7cf (commit)
revisions in full, below.
commit d402f622e40deafeb5146b79599c965cecb79697
Merge: 30d2db696 6fdf1dbb0
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Sun Jul 19 08:59:09 2026 -0700
Merge pull request 'Backport GEOS 3.15 compatibility fixes to stable 3.6' (!444) from Komzpa/postgis:fix/geos315-stable-3.6 into stable-3.6
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/444
commit 6fdf1dbb0b2b97f154b6dc046dfbcbdf54fa4e44
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Thu Jul 9 11:33:15 2026 +0400
Fix GEOS version parser in wrapx regression
A stray ']' made the regexp never match, so the GEOS >= 3.15
expected outputs were never selected.
(cherry picked from commit 9c931e6fcdcf78a5d605a0d445b4a51564f78ff5)
diff --git a/regress/core/wrapx.sql b/regress/core/wrapx.sql
index 321958d52..b35504961 100644
--- a/regress/core/wrapx.sql
+++ b/regress/core/wrapx.sql
@@ -15,7 +15,7 @@ $$ LANGUAGE 'plpgsql';
CREATE OR REPLACE FUNCTION geos_version()
RETURNS integer AS $$
SELECT (matches[1]::integer * 100) + matches[2]::integer
- FROM regexp_match(postgis_geos_version(), E'^([0-9]+)]\\.([0-9]+)') AS matches;
+ FROM regexp_match(postgis_geos_version(), E'^([0-9]+)\\.([0-9]+)') AS matches;
$$ LANGUAGE 'sql' IMMUTABLE;
commit 47ab82df3320d0257f9d42ff6710f6f0b212e1d1
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed Jul 8 14:10:37 2026 -0700
Fix non-topology regression tests for GEOS >= 3.15
(cherry picked from commit 63de00830dc7afb6102a095cb1a41514e9064c1f)
diff --git a/liblwgeom/cunit/cu_wrapx.c b/liblwgeom/cunit/cu_wrapx.c
index a5ca09a28..79e707238 100644
--- a/liblwgeom/cunit/cu_wrapx.c
+++ b/liblwgeom/cunit/cu_wrapx.c
@@ -83,9 +83,11 @@ static void test_lwgeom_wrapx(void)
lwgeom_free(tmp);
CU_ASSERT_FATAL(ret != NULL);
obt_wkt = lwgeom_to_ewkt(ret);
- tmp = lwgeom_from_wkt(
- "MULTILINESTRING((0 0,8 0),(-2 0,0 0))",
- LW_PARSER_CHECK_NONE);
+#if POSTGIS_GEOS_VERSION < 31500
+ tmp = lwgeom_from_wkt("MULTILINESTRING((0 0,8 0),(-2 0,0 0))",LW_PARSER_CHECK_NONE);
+#else
+ tmp = lwgeom_from_wkt("LINESTRING(-2 0,0 0,8 0)",LW_PARSER_CHECK_NONE);
+#endif
tmp2 = lwgeom_normalize(tmp);
lwgeom_free(tmp);
exp_wkt = lwgeom_to_ewkt(tmp2);
diff --git a/regress/core/fixedoverlay.sql b/regress/core/fixedoverlay.sql
index 45d3b8979..2377f5667 100644
--- a/regress/core/fixedoverlay.sql
+++ b/regress/core/fixedoverlay.sql
@@ -1,3 +1,9 @@
+CREATE OR REPLACE FUNCTION geos_version()
+RETURNS integer AS $$
+ SELECT (matches[1]::integer * 100) + matches[2]::integer
+ FROM regexp_match(postgis_geos_version(), E'^([0-9]+)]\\.([0-9]+)') AS matches;
+$$ LANGUAGE 'sql' IMMUTABLE;
SELECT 'intersection', ST_AsText(ST_Intersection(
'LINESTRING(0 0, 9 0)'::geometry,
'LINESTRING(7 0, 13.2 0)'::geometry,
@@ -13,14 +19,7 @@ SELECT 'symdifference', ST_AsText(ST_SymDifference(
2));
-SELECT 'union', ST_AsText(ST_Union(
- 'LINESTRING(0.5 0, 9 0)'::geometry,
- 'LINESTRING(7 0, 13.2 0)'::geometry,
- 2));
-SELECT 'unaryunion', ST_AsText(ST_UnaryUnion(
- 'GEOMETRYCOLLECTION(LINESTRING(0.5 0, 9 0), LINESTRING(7 0, 13.2 0))'::geometry,
-2));
WITH n AS (SELECT geom
FROM ST_Subdivide(
@@ -28,3 +27,6 @@ FROM ST_Subdivide(
6, 1) AS geom)
SELECT 'subdivide', count(geom), ST_AsText(ST_Normalize(ST_Union(geom)))
FROM n;
+DROP FUNCTION geos_version();
diff --git a/regress/core/fixedoverlay_expected b/regress/core/fixedoverlay_expected
index 4f03bb27b..835d8b92c 100644
--- a/regress/core/fixedoverlay_expected
+++ b/regress/core/fixedoverlay_expected
@@ -1,6 +1,4 @@
intersection|LINESTRING(8 0,10 0)
difference|LINESTRING(0 0,8 0)
symdifference|MULTILINESTRING((0 0,8 0),(10 0,14 0))
-union|MULTILINESTRING((0 0,8 0),(8 0,10 0),(10 0,14 0))
-unaryunion|MULTILINESTRING((0 0,8 0),(8 0,10 0),(10 0,14 0))
subdivide|3|MULTIPOLYGON(((0 0,0 10,10 10,10 6,100 5,10 5,10 0,0 0)),((100 0,100 5,100 10,110 10,110 0,100 0)))
index d08dc9c9c..321958d52 100644
@@ -1,94 +1,112 @@
-CREATE FUNCTION test(geom geometry, wrap float8, amount float8, exp geometry)
+CREATE FUNCTION test_wrapx(geom geometry, wrap float8, amount float8, exp geometry)
RETURNS text AS $$
DECLARE
- obt geometry;
+ obt geometry;
BEGIN
- obt = ST_Normalize(ST_WrapX(geom, wrap, amount));
- IF ST_OrderingEquals(obt, exp) THEN
- RETURN 'OK';
- ELSE
- RETURN 'KO:' || ST_AsEWKT(obt) || ' != ' || ST_AsEWKT(exp);
- END IF;
+ obt = ST_Normalize(ST_WrapX(geom, wrap, amount));
+ IF ST_OrderingEquals(obt, exp) THEN
+ RETURN 'OK';
+ ELSE
+ RETURN 'KO:' || ST_AsEWKT(obt) || ' != ' || ST_AsEWKT(exp);
+ END IF;
END
-$$ LANGUAGE plpgsql;
+$$ LANGUAGE 'plpgsql';
-SELECT 'P1', test(
- 'POINT(0 0)', 2, 10,
- 'POINT(10 0)');
-SELECT 'P2', test(
- 'POINT(0 0)', 2, -10,
- 'POINT(0 0)');
-SELECT 'P3', test(
- 'POINT(0 0)', -2, -10,
- 'POINT(-10 0)');
+SELECT 'P1', test_wrapx(
+ 'POINT(0 0)', 2, 10,
+ 'POINT(10 0)');
-SELECT 'L1', test(
- 'LINESTRING(0 0,10 0)', 2, 10,
- --'LINESTRING(2 0,12 0)');
- 'MULTILINESTRING((10 0,12 0),(2 0,10 0))');
+SELECT 'P2', test_wrapx(
+ 'POINT(0 0)', 2, -10,
+ 'POINT(0 0)');
-SELECT 'L2', test(
- 'LINESTRING(0 0,10 0)', 8, -10,
- 'MULTILINESTRING((0 0,8 0),(-2 0,0 0))');
+SELECT 'P3', test_wrapx(
+ 'POINT(0 0)', -2, -10,
+ 'POINT(-10 0)');
-SELECT 'L3', test(
- 'LINESTRING(0 0,10 0)', 0, 10,
- 'LINESTRING(0 0,10 0)');
+SELECT 'L1', test_wrapx(
+ 'LINESTRING(0 0,10 0)', 2, 10,
+ CASE WHEN geos_version() >= 315
+ THEN 'LINESTRING(2 0,10 0,12 0)'
+ ELSE 'MULTILINESTRING((10 0,12 0),(2 0,10 0))'
+ END);
-SELECT 'L4', test(
- 'LINESTRING(0 0,10 0)', 10, -10,
+SELECT 'L2', test_wrapx(
+ 'LINESTRING(0 0,10 0)', 8, -10,
+ THEN 'LINESTRING(-2 0,0 0,8 0)'
+ ELSE 'MULTILINESTRING((0 0,8 0),(-2 0,0 0))'
+ END);
-SELECT 'ML1', test(
- 'MULTILINESTRING((-10 0,0 0),(0 0,10 0))', 0, 20,
- 'MULTILINESTRING((10 0,20 0),(0 0,10 0))');
+SELECT 'L3', test_wrapx(
+ 'LINESTRING(0 0,10 0)', 0, 10,
+ 'LINESTRING(0 0,10 0)');
-SELECT 'ML2', test(
- 'MULTILINESTRING((-10 0,0 0),(0 0,10 0))', 0, -20,
- 'MULTILINESTRING((-10 0,0 0),(-20 0,-10 0))');
+SELECT 'L4', test_wrapx(
+ 'LINESTRING(0 0,10 0)', 10, -10,
-SELECT 'ML3', test(
- 'MULTILINESTRING((10 0,5 0),(-10 0,0 0),(0 0,5 0))', 0, -20,
- 'MULTILINESTRING((-10 0,0 0),(-15 0,-10 0),(-20 0,-15 0))');
+SELECT 'ML1', test_wrapx(
+ 'MULTILINESTRING((-10 0,0 0),(0 0,10 0))', 0, 20,
+ 'MULTILINESTRING((10 0,20 0),(0 0,10 0))');
-SELECT 'A1', test(
- 'POLYGON((0 0,10 0,10 10,0 10,0 0),
- (1 2,3 2,3 4,1 4,1 2),
- (4 2,6 2,6 4,4 4,4 2),
- (7 2,9 2,9 4,7 4,7 2))', 5, 10,
- 'POLYGON((5 0,5 2,6 2,6 4,5 4,5 10,10 10,15 10,15 4,14 4,14 2,15 2,15 0,10 0,5 0),
- (11 2,13 2,13 4,11 4,11 2),
- (7 2,9 2,9 4,7 4,7 2))');
+SELECT 'ML2', test_wrapx(
+ 'MULTILINESTRING((-10 0,0 0),(0 0,10 0))', 0, -20,
+ 'MULTILINESTRING((-10 0,0 0),(-20 0,-10 0))');
-SELECT 'A2', test(
- (7 2,9 2,9 4,7 4,7 2))', 5, -10,
- 'POLYGON((-5 0,-5 2,-4 2,-4 4,-5 4,-5 10,0 10,5 10,5 4,4 4,4 2,5 2,5 0,0 0,-5 0),
- (-3 2,-1 2,-1 4,-3 4,-3 2))');
+SELECT 'ML3', test_wrapx(
+ 'MULTILINESTRING((10 0,5 0),(-10 0,0 0),(0 0,5 0))', 0, -20,
+ 'MULTILINESTRING((-10 0,0 0),(-15 0,-10 0),(-20 0,-15 0))');
-SELECT 'C1', test(
- POLYGON((0 0,10 0,10 10,0 10,0 0),
- (7 2,9 2,9 4,7 4,7 2)),
- POINT(2 20),
- POINT(7 -20),
- LINESTRING(0 40,10 40)
- 5, -10,
- POLYGON((-5 0,-5 2,-4 2,-4 4,-5 4,-5 10,0 10,5 10,5 4,4 4,4 2,5 2,5 0,0 0,-5 0),
- (-3 2,-1 2,-1 4,-3 4,-3 2)),
- MULTILINESTRING((0 40,5 40),(-5 40,0 40)),
- POINT(2 20),
- POINT(-3 -20)
+SELECT 'A1', test_wrapx(
+ 'POLYGON((0 0,10 0,10 10,0 10,0 0),
+ (1 2,3 2,3 4,1 4,1 2),
+ (4 2,6 2,6 4,4 4,4 2),
+ (7 2,9 2,9 4,7 4,7 2))', 5, 10,
+ 'POLYGON((5 0,5 2,6 2,6 4,5 4,5 10,10 10,15 10,15 4,14 4,14 2,15 2,15 0,10 0,5 0),
+ (11 2,13 2,13 4,11 4,11 2),
+ (7 2,9 2,9 4,7 4,7 2))');
-DROP FUNCTION test(geometry, float8, float8, geometry);
+SELECT 'A2', test_wrapx(
+ (7 2,9 2,9 4,7 4,7 2))', 5, -10,
+ 'POLYGON((-5 0,-5 2,-4 2,-4 4,-5 4,-5 10,0 10,5 10,5 4,4 4,4 2,5 2,5 0,0 0,-5 0),
+ (-3 2,-1 2,-1 4,-3 4,-3 2))');
+SELECT 'C1', test_wrapx(
+ 'GEOMETRYCOLLECTION(
+ POLYGON((0 0,10 0,10 10,0 10,0 0),
+ (7 2,9 2,9 4,7 4,7 2)),
+ POINT(2 20),
+ POINT(7 -20),
+ LINESTRING(0 40,10 40)
+ 5, -10,
+ THEN 'GEOMETRYCOLLECTION(POLYGON((-5 0,-5 2,-4 2,-4 4,-5 4,-5 10,0 10,5 10,5 4,4 4,4 2,5 2,5 0,0 0,-5 0),(1 2,3 2,3 4,1 4,1 2),(-3 2,-1 2,-1 4,-3 4,-3 2)),LINESTRING(-5 40,0 40,5 40),POINT(2 20),POINT(-3 -20))'
+ ELSE 'GEOMETRYCOLLECTION(
+ POLYGON((-5 0,-5 2,-4 2,-4 4,-5 4,-5 10,0 10,5 10,5 4,4 4,4 2,5 2,5 0,0 0,-5 0),
+ (-3 2,-1 2,-1 4,-3 4,-3 2)),
+ MULTILINESTRING((0 40,5 40),(-5 40,0 40)),
+ POINT(2 20),
+ POINT(-3 -20)
+ END);
+DROP FUNCTION test_wrapx(geometry, float8, float8, geometry);
commit 4b3b4604ff047e1246a8cf8d1b838cd0fb74321d
Date: Tue Jun 30 12:05:14 2026 -0700
Use GEOSSplit where available for ST_Split
(cherry picked from commit 370c6a160a21d46b0768fb70ea0d75292cc475d0)
diff --git a/liblwgeom/lwgeom_geos_split.c b/liblwgeom/lwgeom_geos_split.c
index 15ca6ff5c..883a17751 100644
--- a/liblwgeom/lwgeom_geos_split.c
+++ b/liblwgeom/lwgeom_geos_split.c
@@ -112,12 +112,23 @@ lwline_split_by_line(const LWLINE* lwline_in, const LWGEOM* blade_in)
- gdiff = GEOSDifference(g1,g2);
+#if POSTGIS_GEOS_VERSION >= 31500
+ /* GEOS 3.15 added an explicit splitter. Older GEOS relies on the
+ * side-effect of GEOSDifference returning the input split at the
+ * crossing points of the (non-overlapping) blade. */
+ gdiff = GEOSSplit(g1, g2);
+#else
+ gdiff = GEOSDifference(g1, g2);
+#endif
GEOSGeom_destroy(g1);
GEOSGeom_destroy(g2);
if (gdiff == NULL)
+ lwerror("GEOSSplit: %s", lwgeom_geos_errmsg);
+#else
lwerror("GEOSDifference: %s", lwgeom_geos_errmsg);
+#endif
return NULL;
@@ -353,6 +364,69 @@ lwline_split(const LWLINE* lwline_in, const LWGEOM* blade_in)
static LWGEOM*
lwpoly_split_by_line(const LWPOLY* lwpoly_in, const LWGEOM* blade_in)
+ /* GEOS 3.15 splits polygons directly, filtering out the pieces that
+ * fall inside holes for us. On older GEOS we reproduce that logic by
+ * polygonizing the boundary unioned with the blade and discarding the
+ * pieces whose point-on-surface is not contained by the input (#else). */
+ LWGEOM* split;
+ LWCOLLECTION* out;
+ GEOSGeometry* g1;
+ GEOSGeometry* g2;
+ GEOSGeometry* gsplit;
+ int hasZ = FLAGS_GET_Z(lwpoly_in->flags);
+ initGEOS(lwgeom_geos_error, lwgeom_geos_error);
+ g1 = LWGEOM2GEOS((LWGEOM*)lwpoly_in, 0);
+ if ( NULL == g1 )
+ lwerror("LWGEOM2GEOS: %s", lwgeom_geos_errmsg);
+ return NULL;
+ g2 = LWGEOM2GEOS(blade_in, 0);
+ if ( NULL == g2 )
+ GEOSGeom_destroy(g1);
+ return NULL;
+ gsplit = GEOSSplit(g1, g2);
+ GEOSGeom_destroy(g2);
+ if ( NULL == gsplit )
+ return NULL;
+ split = GEOS2LWGEOM(gsplit, hasZ);
+ GEOSGeom_destroy(gsplit);
+ if ( NULL == split )
+ lwerror("GEOS2LWGEOM: %s", lwgeom_geos_errmsg);
+ return NULL;
+ /* GEOSSplit always returns a collection, but wrap defensively */
+ out = lwgeom_as_lwcollection(split);
+ if ( ! out )
+ LWGEOM** components = lwalloc(sizeof(LWGEOM*));
+ components[0] = split;
+ out = lwcollection_construct(COLLECTIONTYPE, lwpoly_in->srid,
+ NULL, 1, components);
+ else
+ lwgeom_set_srid((LWGEOM*)out, lwpoly_in->srid);
+ out->type = COLLECTIONTYPE;
+ return (LWGEOM*)out;
+#else
LWCOLLECTION* out;
GEOSGeometry* g1;
GEOSGeometry* g2;
@@ -491,6 +565,7 @@ lwpoly_split_by_line(const LWPOLY* lwpoly_in, const LWGEOM* blade_in)
GEOSGeom_destroy(polygons);
+#endif /* POSTGIS_GEOS_VERSION >= 31500 */
static LWGEOM*
Summary of changes:
liblwgeom/cunit/cu_wrapx.c | 8 +-
liblwgeom/lwgeom_geos_split.c | 77 ++++++++++++++-
regress/core/fixedoverlay.sql | 16 +--
regress/core/fixedoverlay_expected | 2 -
regress/core/wrapx.sql | 198 ++++++++++++++++++++-----------------
5 files changed, 198 insertions(+), 103 deletions(-)
hooks/post-receive
