[SCM] PostGIS branch stable-3.5 updated. 3.5.7-66-g2dec9daa4
Sun Jul 19 08:59:19 PDT 2026
the project "PostGIS".
The branch, stable-3.5 has been updated
       via  2dec9daa4d5d4676f256a7d5c1fb085dca1f1758 (commit)
       via  48fcce28eb28eda328cb71eedce8c2ea7c412997 (commit)
       via  d1751e881e4f9e18cff6849fcafacfa85fe9ceb7 (commit)
       via  62c24a2c44963458aa232e50b26064f9c6d6ceb2 (commit)
      from  a40c5b03f73f50cdc22e2522a3d58d8217c03a6d (commit)
revisions in full, below.
commit 2dec9daa4d5d4676f256a7d5c1fb085dca1f1758
Merge: a40c5b03f 48fcce28e
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Sun Jul 19 08:59:18 2026 -0700
    Merge pull request 'Backport GEOS 3.15 compatibility fixes to stable 3.5' (!445) from Komzpa/postgis:fix/geos315-stable-3.5 into stable-3.5
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/445
commit 48fcce28eb28eda328cb71eedce8c2ea7c412997
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Thu Jul 9 11:33:15 2026 +0400
    Fix GEOS version parser in wrapx regression
    A stray ']' made the regexp never match, so the GEOS >= 3.15
    expected outputs were never selected.
    (cherry picked from commit 9c931e6fcdcf78a5d605a0d445b4a51564f78ff5)
diff --git a/regress/core/wrapx.sql b/regress/core/wrapx.sql
index 321958d52..b35504961 100644
--- a/regress/core/wrapx.sql
+++ b/regress/core/wrapx.sql
@@ -15,7 +15,7 @@ $$ LANGUAGE 'plpgsql';
 CREATE OR REPLACE FUNCTION geos_version()
 RETURNS integer AS $$
     SELECT (matches[1]::integer * 100) + matches[2]::integer
-    FROM regexp_match(postgis_geos_version(), E'^([0-9]+)]\\.([0-9]+)') AS matches;
+    FROM regexp_match(postgis_geos_version(), E'^([0-9]+)\\.([0-9]+)') AS matches;
 $$ LANGUAGE 'sql' IMMUTABLE;
commit d1751e881e4f9e18cff6849fcafacfa85fe9ceb7
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Jul 8 14:10:37 2026 -0700
    Fix non-topology regression tests for GEOS >= 3.15
    (cherry picked from commit 63de00830dc7afb6102a095cb1a41514e9064c1f)
diff --git a/liblwgeom/cunit/cu_wrapx.c b/liblwgeom/cunit/cu_wrapx.c
index a5ca09a28..79e707238 100644
--- a/liblwgeom/cunit/cu_wrapx.c
+++ b/liblwgeom/cunit/cu_wrapx.c
@@ -83,9 +83,11 @@ static void test_lwgeom_wrapx(void)
 	lwgeom_free(tmp);
 	CU_ASSERT_FATAL(ret != NULL);
 	obt_wkt = lwgeom_to_ewkt(ret);
-	tmp = lwgeom_from_wkt(
-					"MULTILINESTRING((0 0,8 0),(-2 0,0 0))",
-					LW_PARSER_CHECK_NONE);
+#if POSTGIS_GEOS_VERSION < 31500
+	tmp = lwgeom_from_wkt("MULTILINESTRING((0 0,8 0),(-2 0,0 0))",LW_PARSER_CHECK_NONE);
+#else
+	tmp = lwgeom_from_wkt("LINESTRING(-2 0,0 0,8 0)",LW_PARSER_CHECK_NONE);
+#endif
 	tmp2 = lwgeom_normalize(tmp);
 	lwgeom_free(tmp);
 	exp_wkt = lwgeom_to_ewkt(tmp2);
diff --git a/regress/core/fixedoverlay.sql b/regress/core/fixedoverlay.sql
index 45d3b8979..2377f5667 100644
--- a/regress/core/fixedoverlay.sql
+++ b/regress/core/fixedoverlay.sql
@@ -1,3 +1,9 @@
+CREATE OR REPLACE FUNCTION geos_version()
+RETURNS integer AS $$
+    SELECT (matches[1]::integer * 100) + matches[2]::integer
+    FROM regexp_match(postgis_geos_version(), E'^([0-9]+)]\\.([0-9]+)') AS matches;
+$$ LANGUAGE 'sql' IMMUTABLE;
 SELECT 'intersection', ST_AsText(ST_Intersection(
 	'LINESTRING(0 0, 9 0)'::geometry,
 	'LINESTRING(7 0, 13.2 0)'::geometry,
@@ -13,14 +19,7 @@ SELECT 'symdifference', ST_AsText(ST_SymDifference(
 2));
-SELECT 'union', ST_AsText(ST_Union(
-	'LINESTRING(0.5 0, 9 0)'::geometry,
-	'LINESTRING(7 0, 13.2 0)'::geometry,
- 2));
-SELECT 'unaryunion', ST_AsText(ST_UnaryUnion(
-	'GEOMETRYCOLLECTION(LINESTRING(0.5 0, 9 0), LINESTRING(7 0, 13.2 0))'::geometry,
-2));
 WITH n AS (SELECT geom
 FROM ST_Subdivide(
@@ -28,3 +27,6 @@ FROM ST_Subdivide(
 6, 1) AS geom)
 SELECT 'subdivide', count(geom), ST_AsText(ST_Normalize(ST_Union(geom)))
 FROM n;
+DROP FUNCTION geos_version();
diff --git a/regress/core/fixedoverlay_expected b/regress/core/fixedoverlay_expected
index 4f03bb27b..835d8b92c 100644
--- a/regress/core/fixedoverlay_expected
+++ b/regress/core/fixedoverlay_expected
@@ -1,6 +1,4 @@
 intersection|LINESTRING(8 0,10 0)
 difference|LINESTRING(0 0,8 0)
 symdifference|MULTILINESTRING((0 0,8 0),(10 0,14 0))
-union|MULTILINESTRING((0 0,8 0),(8 0,10 0),(10 0,14 0))
-unaryunion|MULTILINESTRING((0 0,8 0),(8 0,10 0),(10 0,14 0))
 subdivide|3|MULTIPOLYGON(((0 0,0 10,10 10,10 6,100 5,10 5,10 0,0 0)),((100 0,100 5,100 10,110 10,110 0,100 0)))
index d08dc9c9c..321958d52 100644
@@ -1,94 +1,112 @@
-CREATE FUNCTION test(geom geometry, wrap float8, amount float8, exp geometry)
+CREATE FUNCTION test_wrapx(geom geometry, wrap float8, amount float8, exp geometry)
 RETURNS text AS $$
 DECLARE
-  obt geometry;
+	obt geometry;
 BEGIN
-  obt = ST_Normalize(ST_WrapX(geom, wrap, amount));
-  IF ST_OrderingEquals(obt, exp) THEN
-    RETURN 'OK';
-  ELSE
-    RETURN 'KO:' || ST_AsEWKT(obt) || ' != ' || ST_AsEWKT(exp);
-  END IF;
+	obt = ST_Normalize(ST_WrapX(geom, wrap, amount));
+	IF ST_OrderingEquals(obt, exp) THEN
+		RETURN 'OK';
+	ELSE
+		RETURN 'KO:' || ST_AsEWKT(obt) || ' != ' || ST_AsEWKT(exp);
+	END IF;
 END
-$$ LANGUAGE plpgsql;
+$$ LANGUAGE 'plpgsql';
-SELECT 'P1', test(
-  'POINT(0 0)', 2, 10,
-  'POINT(10 0)');
-SELECT 'P2', test(
-  'POINT(0 0)', 2, -10,
-  'POINT(0 0)');
-SELECT 'P3', test(
-  'POINT(0 0)', -2, -10,
-  'POINT(-10 0)');
+SELECT 'P1', test_wrapx(
+	'POINT(0 0)', 2, 10,
+	'POINT(10 0)');
-SELECT 'L1', test(
-  'LINESTRING(0 0,10 0)', 2, 10,
-  --'LINESTRING(2 0,12 0)');
-  'MULTILINESTRING((10 0,12 0),(2 0,10 0))');
+SELECT 'P2', test_wrapx(
+	'POINT(0 0)', 2, -10,
+	'POINT(0 0)');
-SELECT 'L2', test(
-  'LINESTRING(0 0,10 0)', 8, -10,
-  'MULTILINESTRING((0 0,8 0),(-2 0,0 0))');
+SELECT 'P3', test_wrapx(
+	'POINT(0 0)', -2, -10,
+	'POINT(-10 0)');
-SELECT 'L3', test(
-  'LINESTRING(0 0,10 0)', 0, 10,
-  'LINESTRING(0 0,10 0)');
+SELECT 'L1', test_wrapx(
+	'LINESTRING(0 0,10 0)', 2, 10,
+	CASE WHEN geos_version() >= 315
+	  THEN 'LINESTRING(2 0,10 0,12 0)'
+	  ELSE 'MULTILINESTRING((10 0,12 0),(2 0,10 0))'
+	END);
-SELECT 'L4', test(
-  'LINESTRING(0 0,10 0)', 10, -10,
+SELECT 'L2', test_wrapx(
+	'LINESTRING(0 0,10 0)', 8, -10,
+	  THEN 'LINESTRING(-2 0,0 0,8 0)'
+	  ELSE 'MULTILINESTRING((0 0,8 0),(-2 0,0 0))'
+	END);
-SELECT 'ML1', test(
-  'MULTILINESTRING((-10 0,0 0),(0 0,10 0))', 0, 20,
-  'MULTILINESTRING((10 0,20 0),(0 0,10 0))');
+SELECT 'L3', test_wrapx(
+	'LINESTRING(0 0,10 0)', 0, 10,
+	'LINESTRING(0 0,10 0)');
-SELECT 'ML2', test(
-  'MULTILINESTRING((-10 0,0 0),(0 0,10 0))', 0, -20,
-  'MULTILINESTRING((-10 0,0 0),(-20 0,-10 0))');
+SELECT 'L4', test_wrapx(
+	'LINESTRING(0 0,10 0)', 10, -10,
-SELECT 'ML3', test(
-  'MULTILINESTRING((10 0,5 0),(-10 0,0 0),(0 0,5 0))', 0, -20,
-  'MULTILINESTRING((-10 0,0 0),(-15 0,-10 0),(-20 0,-15 0))');
+SELECT 'ML1', test_wrapx(
+	'MULTILINESTRING((-10 0,0 0),(0 0,10 0))', 0, 20,
+	'MULTILINESTRING((10 0,20 0),(0 0,10 0))');
-SELECT 'A1', test(
-  'POLYGON((0 0,10 0,10 10,0 10,0 0),
-           (1 2,3 2,3 4,1 4,1 2),
-           (4 2,6 2,6 4,4 4,4 2),
-           (7 2,9 2,9 4,7 4,7 2))', 5, 10,
-  'POLYGON((5 0,5 2,6 2,6 4,5 4,5 10,10 10,15 10,15 4,14 4,14 2,15 2,15 0,10 0,5 0),
-           (11 2,13 2,13 4,11 4,11 2),
-           (7 2,9 2,9 4,7 4,7 2))');
+SELECT 'ML2', test_wrapx(
+	'MULTILINESTRING((-10 0,0 0),(0 0,10 0))', 0, -20,
+	'MULTILINESTRING((-10 0,0 0),(-20 0,-10 0))');
-SELECT 'A2', test(
-           (7 2,9 2,9 4,7 4,7 2))', 5, -10,
-  'POLYGON((-5 0,-5 2,-4 2,-4 4,-5 4,-5 10,0 10,5 10,5 4,4 4,4 2,5 2,5 0,0 0,-5 0),
-           (-3 2,-1 2,-1 4,-3 4,-3 2))');
+SELECT 'ML3', test_wrapx(
+	'MULTILINESTRING((10 0,5 0),(-10 0,0 0),(0 0,5 0))', 0, -20,
+	'MULTILINESTRING((-10 0,0 0),(-15 0,-10 0),(-20 0,-15 0))');
-SELECT 'C1', test(
-    POLYGON((0 0,10 0,10 10,0 10,0 0),
-            (7 2,9 2,9 4,7 4,7 2)),
-    POINT(2 20),
-    POINT(7 -20),
-    LINESTRING(0 40,10 40)
-  5, -10,
-    POLYGON((-5 0,-5 2,-4 2,-4 4,-5 4,-5 10,0 10,5 10,5 4,4 4,4 2,5 2,5 0,0 0,-5 0),
-            (-3 2,-1 2,-1 4,-3 4,-3 2)),
-    MULTILINESTRING((0 40,5 40),(-5 40,0 40)),
-    POINT(2 20),
-    POINT(-3 -20)
+SELECT 'A1', test_wrapx(
+	'POLYGON((0 0,10 0,10 10,0 10,0 0),
+					 (1 2,3 2,3 4,1 4,1 2),
+					 (4 2,6 2,6 4,4 4,4 2),
+					 (7 2,9 2,9 4,7 4,7 2))', 5, 10,
+	'POLYGON((5 0,5 2,6 2,6 4,5 4,5 10,10 10,15 10,15 4,14 4,14 2,15 2,15 0,10 0,5 0),
+					 (11 2,13 2,13 4,11 4,11 2),
+					 (7 2,9 2,9 4,7 4,7 2))');
-DROP FUNCTION test(geometry, float8, float8, geometry);
+SELECT 'A2', test_wrapx(
+					 (7 2,9 2,9 4,7 4,7 2))', 5, -10,
+	'POLYGON((-5 0,-5 2,-4 2,-4 4,-5 4,-5 10,0 10,5 10,5 4,4 4,4 2,5 2,5 0,0 0,-5 0),
+					 (-3 2,-1 2,-1 4,-3 4,-3 2))');
+SELECT 'C1', test_wrapx(
+	'GEOMETRYCOLLECTION(
+		POLYGON((0 0,10 0,10 10,0 10,0 0),
+						(7 2,9 2,9 4,7 4,7 2)),
+		POINT(2 20),
+		POINT(7 -20),
+		LINESTRING(0 40,10 40)
+	5, -10,
+	  THEN 'GEOMETRYCOLLECTION(POLYGON((-5 0,-5 2,-4 2,-4 4,-5 4,-5 10,0 10,5 10,5 4,4 4,4 2,5 2,5 0,0 0,-5 0),(1 2,3 2,3 4,1 4,1 2),(-3 2,-1 2,-1 4,-3 4,-3 2)),LINESTRING(-5 40,0 40,5 40),POINT(2 20),POINT(-3 -20))'
+	  ELSE 'GEOMETRYCOLLECTION(
+		POLYGON((-5 0,-5 2,-4 2,-4 4,-5 4,-5 10,0 10,5 10,5 4,4 4,4 2,5 2,5 0,0 0,-5 0),
+						(-3 2,-1 2,-1 4,-3 4,-3 2)),
+		MULTILINESTRING((0 40,5 40),(-5 40,0 40)),
+		POINT(2 20),
+		POINT(-3 -20)
+	END);
+DROP FUNCTION test_wrapx(geometry, float8, float8, geometry);
commit 62c24a2c44963458aa232e50b26064f9c6d6ceb2
Date:   Tue Jun 30 12:05:14 2026 -0700
    Use GEOSSplit where available for ST_Split
    (cherry picked from commit 370c6a160a21d46b0768fb70ea0d75292cc475d0)
diff --git a/liblwgeom/lwgeom_geos_split.c b/liblwgeom/lwgeom_geos_split.c
index 15ca6ff5c..883a17751 100644
--- a/liblwgeom/lwgeom_geos_split.c
+++ b/liblwgeom/lwgeom_geos_split.c
@@ -112,12 +112,23 @@ lwline_split_by_line(const LWLINE* lwline_in, const LWGEOM* blade_in)
-	gdiff = GEOSDifference(g1,g2);
+#if POSTGIS_GEOS_VERSION >= 31500
+	/* GEOS 3.15 added an explicit splitter. Older GEOS relies on the
+	 * side-effect of GEOSDifference returning the input split at the
+	 * crossing points of the (non-overlapping) blade. */
+	gdiff = GEOSSplit(g1, g2);
+#else
+	gdiff = GEOSDifference(g1, g2);
+#endif
 	GEOSGeom_destroy(g1);
 	GEOSGeom_destroy(g2);
 	if (gdiff == NULL)
+		lwerror("GEOSSplit: %s", lwgeom_geos_errmsg);
+#else
 		lwerror("GEOSDifference: %s", lwgeom_geos_errmsg);
+#endif
 		return NULL;
@@ -353,6 +364,69 @@ lwline_split(const LWLINE* lwline_in, const LWGEOM* blade_in)
 static LWGEOM*
 lwpoly_split_by_line(const LWPOLY* lwpoly_in, const LWGEOM* blade_in)
+	/* GEOS 3.15 splits polygons directly, filtering out the pieces that
+	 * fall inside holes for us. On older GEOS we reproduce that logic by
+	 * polygonizing the boundary unioned with the blade and discarding the
+	 * pieces whose point-on-surface is not contained by the input (#else). */
+	LWGEOM* split;
+	LWCOLLECTION* out;
+	GEOSGeometry* g1;
+	GEOSGeometry* g2;
+	GEOSGeometry* gsplit;
+	int hasZ = FLAGS_GET_Z(lwpoly_in->flags);
+	initGEOS(lwgeom_geos_error, lwgeom_geos_error);
+	g1 = LWGEOM2GEOS((LWGEOM*)lwpoly_in, 0);
+	if ( NULL == g1 )
+		lwerror("LWGEOM2GEOS: %s", lwgeom_geos_errmsg);
+		return NULL;
+	g2 = LWGEOM2GEOS(blade_in, 0);
+	if ( NULL == g2 )
+		GEOSGeom_destroy(g1);
+		return NULL;
+	gsplit = GEOSSplit(g1, g2);
+	GEOSGeom_destroy(g2);
+	if ( NULL == gsplit )
+		return NULL;
+	split = GEOS2LWGEOM(gsplit, hasZ);
+	GEOSGeom_destroy(gsplit);
+	if ( NULL == split )
+		lwerror("GEOS2LWGEOM: %s", lwgeom_geos_errmsg);
+		return NULL;
+	/* GEOSSplit always returns a collection, but wrap defensively */
+	out = lwgeom_as_lwcollection(split);
+	if ( ! out )
+		LWGEOM** components = lwalloc(sizeof(LWGEOM*));
+		components[0] = split;
+		out = lwcollection_construct(COLLECTIONTYPE, lwpoly_in->srid,
+		                             NULL, 1, components);
+	else
+		lwgeom_set_srid((LWGEOM*)out, lwpoly_in->srid);
+		out->type = COLLECTIONTYPE;
+	return (LWGEOM*)out;
+#else
 	LWCOLLECTION* out;
 	GEOSGeometry* g1;
 	GEOSGeometry* g2;
@@ -491,6 +565,7 @@ lwpoly_split_by_line(const LWPOLY* lwpoly_in, const LWGEOM* blade_in)
 	GEOSGeom_destroy(polygons);
+#endif /* POSTGIS_GEOS_VERSION >= 31500 */
 static LWGEOM*
Summary of changes:
 liblwgeom/cunit/cu_wrapx.c         |   8 +-
 liblwgeom/lwgeom_geos_split.c      |  77 ++++++++++++++-
 regress/core/fixedoverlay.sql      |  16 +--
 regress/core/fixedoverlay_expected |   2 -
 regress/core/wrapx.sql             | 198 ++++++++++++++++++++-----------------
 5 files changed, 198 insertions(+), 103 deletions(-)
hooks/post-receive
