[SCM] PostGIS branch master updated. 3.7.0alpha1-651-g590881519
git at osgeo.org
git at osgeo.org
Sun Jul 19 17:35:54 PDT 2026
the project "PostGIS".
via 590881519946958409ed9cdc9f9f459ab34027d5 (commit)
via 004d06e76d64b0bba71781cb10a2d4916936c45a (commit)
from 5f4a33662ea87b0bca09f116655d15ab6ce358be (commit)
revisions in full, below.
commit 590881519946958409ed9cdc9f9f459ab34027d5
Merge: 5f4a33662 004d06e76
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Sun Jul 19 17:35:51 2026 -0700
Merge pull request 'Fix Make Dist PDF fallback for embedded visual images' (!453) from Komzpa/postgis:fix/master-makedist-data-uri-images into master
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/453
commit 004d06e76d64b0bba71781cb10a2d4916936c45a
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Mon Jul 20 04:25:32 2026 +0400
doc: rasterize embedded visual example images for PDF
diff --git a/doc/html/images/Makefile.in b/doc/html/images/Makefile.in
index ff15ff30b..b417b93ec 100644
--- a/doc/html/images/Makefile.in
+++ b/doc/html/images/Makefile.in
@@ -26,6 +26,7 @@ INSTALL=@INSTALL@
INSTALL_DATA=@INSTALL_DATA@
SHELL = @SHELL@
+PERL = @PERL@
VPATH = $(srcdir)
@@ -72,14 +73,22 @@ visual-examples-pdf: visual-examples-check
target="$(PDF_IMAGES_BUILD_DIR)/$(VISUAL_EXAMPLES_DIR)/$$name.png"; \
temporary="$$target.tmp.png"; \
diagnostics="$$target.tmp.log"; \
+ embedded_tmpdir=; \
rm -f "$$temporary" "$$diagnostics"; \
if test "$$rasterizer" = rsvg; then \
rsvg-convert -w 1200 -b white -o "$$temporary" "$$source" 2>"$$diagnostics" || \
{ cat "$$diagnostics" >&2; exit 1; }; \
else \
- $$converter -density 240 "$$source" -background white -flatten \
+ converter_source="$$source"; \
+ if grep -Eq "(xlink:)?href=['\"]data:image/[^;]+;base64," "$$source"; then \
+ embedded_tmpdir=$$(mktemp -d "$${TMPDIR:-/tmp}/postgis-visual-svg.XXXXXX"); \
+ converter_source="$$embedded_tmpdir/$$name.svg"; \
+ $(PERL) $(srcdir)/prepare-svg-for-converter.pl "$$source" "$$converter_source" "$$embedded_tmpdir" || exit 1; \
+ fi; \
+ $$converter -density 240 "$$converter_source" -background white -flatten \
-resize 1200x1200\> "$$temporary" 2>"$$diagnostics" || \
- { cat "$$diagnostics" >&2; exit 1; }; \
+ { cat "$$diagnostics" >&2; test -z "$$embedded_tmpdir" || rm -rf "$$embedded_tmpdir"; exit 1; }; \
+ test -z "$$embedded_tmpdir" || rm -rf "$$embedded_tmpdir"; \
fi; \
test ! -s "$$diagnostics" || { cat "$$diagnostics" >&2; exit 1; }; \
test -s "$$temporary" || { echo "Failed to rasterize $$source" >&2; exit 1; }; \
diff --git a/doc/html/images/prepare-svg-for-converter.pl b/doc/html/images/prepare-svg-for-converter.pl
new file mode 100644
index 000000000..d252ec2dc
--- /dev/null
+++ b/doc/html/images/prepare-svg-for-converter.pl
@@ -0,0 +1,31 @@
+#!/usr/bin/env perl
+use strict;
+use warnings;
+use File::Path qw(make_path);
+use MIME::Base64 qw(decode_base64);
+my ($source, $target, $asset_dir) = @ARGV;
+die "usage: $0 SOURCE TARGET ASSET_DIR\n" unless defined $asset_dir;
+open my $in, '<:raw', $source or die "Cannot read $source: $!\n";
+my $svg = do { local $/; <$in> };
+close $in;
+make_path($asset_dir);
+my $index = 0;
+$svg =~ s{((?:xlink:)?href)=(['"])data:image/(png|gif|jpe?g);base64,([^'"]+)\2}{
+ my ($attribute, $quote, $extension, $encoded) = ($1, $2, $3, $4);
+ $extension = 'jpg' if $extension eq 'jpeg';
+ my $filename = sprintf('embedded-image-%03d.%s', ++$index, $extension);
+ my $path = "$asset_dir/$filename";
+ open my $out, '>:raw', $path or die "Cannot write $path: $!\n";
+ print {$out} decode_base64($encoded);
+ close $out;
+ qq{$attribute=$quote$path$quote};
+}gex;
+open my $out, '>:raw', $target or die "Cannot write $target: $!\n";
+print {$out} $svg;
+close $out;
Summary of changes:
doc/html/images/Makefile.in | 13 ++++++++++--
doc/html/images/prepare-svg-for-converter.pl | 31 ++++++++++++++++++++++++++++
2 files changed, 42 insertions(+), 2 deletions(-)
create mode 100644 doc/html/images/prepare-svg-for-converter.pl
hooks/post-receive
