[SCM] PostGIS branch stable-3.2 updated. 3.2.10-75-g31612cd7b
Sun Jul 19 13:47:41 PDT 2026
the project "PostGIS".
The branch, stable-3.2 has been updated
       via  31612cd7bb39311cb06eafae3348641b51b91df8 (commit)
       via  084603655a0eb10bab36a046953d19fbf713cbad (commit)
       via  9d052fbfffc819d939ab9fffbacef2ada94235fc (commit)
      from  428c1fcc21d08671b3e69fc091d11660b1112095 (commit)
revisions in full, below.
commit 31612cd7bb39311cb06eafae3348641b51b91df8
Merge: 428c1fcc2 084603655
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Sun Jul 19 13:47:39 2026 -0700
    Merge pull request 'Fix stable 3.2 ST_TileEnvelope upgrade marker syntax' (!450) from Komzpa/postgis:fix/stable-3.2-upgrade-syntax into stable-3.2
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/450
commit 084603655a0eb10bab36a046953d19fbf713cbad
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Mon Jul 20 00:43:27 2026 +0400
    utils: skip future-version downgrade probes
diff --git a/utils/check_all_upgrades.sh b/utils/check_all_upgrades.sh
index e882c9b35..92318776e 100755
--- a/utils/check_all_upgrades.sh
+++ b/utils/check_all_upgrades.sh
@@ -419,6 +419,11 @@ for EXT in ${INSTALLED_EXTENSIONS}; do #{
     kept_label "${test_label}" || continue
+    if test $cmp -gt 0; then
+      echo "SKIP: ${test_label} (${to_version} is not newer than ${from_version})"
+      continue
+    fi
     path=$( psql -XAtc "
         SELECT path
         FROM pg_catalog.pg_extension_update_paths('${EXT}')
commit 9d052fbfffc819d939ab9fffbacef2ada94235fc
Date:   Sun Jul 19 21:48:05 2026 +0400
    Fix ST_TileEnvelope upgrade marker syntax
diff --git a/NEWS b/NEWS
index 833e39991..083a5d913 100644
--- a/NEWS
+++ b/NEWS
@@ -5,6 +5,8 @@ PostGIS 3.2.11
  - #6094, [upgrade] Avoid legacy string literal warnings in downgrade checks
    with standard_conforming_strings off (Darafei Praliaskouski)
+ - [upgrade] Fix ST_TileEnvelope upgrade marker syntax
+   (Darafei Praliaskouski)
  - #5899, pg_upgrade issue for non-standard geography SRID (Paul Ramsey)
  - Flatgeobuf schema mismatch vulnerability (NeuroWinter)
  - #5989, CurvePolygon distance corner case (Paul Ramsey)
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 10ed2a260..f3fe27772 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -1807,7 +1807,7 @@ CREATE OR REPLACE FUNCTION ST_MakeEnvelope(float8, float8, float8, float8, integ
 -- Availability: 3.0.0
 -- Changed: 3.1.0 - add margin=0.0 parameter
--- Replaces ST_TileEnvelope(zoom integer, x integer, y integer, bounds geometry) deprecated in 3.1.0
+-- Replaces ST_TileEnvelope(integer, integer, integer, geometry) deprecated in 3.1.0
 CREATE OR REPLACE FUNCTION ST_TileEnvelope(zoom integer, x integer, y integer, bounds geometry DEFAULT 'SRID=3857;LINESTRING(-20037508.342789244 -20037508.342789244, 20037508.342789244 20037508.342789244)'::geometry, margin float8 DEFAULT 0.0)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'ST_TileEnvelope'
Summary of changes:
 NEWS                        | 2 ++
 postgis/postgis.sql.in      | 2 +-
 utils/check_all_upgrades.sh | 5 +++++
 3 files changed, 8 insertions(+), 1 deletion(-)
hooks/post-receive
