[SCM] PostGIS branch master updated. 3.7.0alpha1-649-g5f4a33662
git at osgeo.org
git at osgeo.org
Sun Jul 19 13:15:17 PDT 2026
the project "PostGIS".
via 5f4a33662ea87b0bca09f116655d15ab6ce358be (commit)
via a142f8e7e4cffc62ba8e261795a46aecab9aeb7e (commit)
from 1a0b660346d2e80bdbd4b6201e8e47b4194e23a2 (commit)
revisions in full, below.
commit 5f4a33662ea87b0bca09f116655d15ab6ce358be
Merge: 1a0b66034 a142f8e7e
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Sun Jul 19 13:15:14 2026 -0700
Merge pull request 'ci: distinguish stale passed and failed checks' (!449) from Komzpa/postgis:ci/stale-pass-fail-dashboard into master
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/449
commit a142f8e7e4cffc62ba8e261795a46aecab9aeb7e
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Sun Jul 19 21:32:27 2026 +0400
diff --git a/utils/ci-status.py b/utils/ci-status.py
index 7c036ba63..e9c4b0a9b 100755
--- a/utils/ci-status.py
+++ b/utils/ci-status.py
@@ -817,7 +817,9 @@ def apply_staleness(result, config, check):
stale["revision_commits_behind"] = distance_count
stale["revision_compare_ref"] = distance_ref
stale["revision_distance"] = revision_distance_text(distance_count, distance_ref)
+ stale["stale_base_status"] = result["status"]
stale["status"] = STALE
+ stale["status_label"] = stale_status_label(result["status"])
stale["message"] = f"{result.get('message', 'CI run')} ({stale['revision_distance']})"
return stale
if result["status"] != SUCCESS:
@@ -836,7 +838,9 @@ def apply_staleness(result, config, check):
stale["revision_distance"] = distance_text
stale["message"] = f"{result.get('message', 'successful run')} (older than {threshold:g}h)"
return stale
@@ -948,6 +952,47 @@ def check_counts(branch):
return counts
+def stale_status_label(base_status):
+ return {
+ SUCCESS: "Stale passed",
+ FAILURE: "Stale failed",
+ UNKNOWN: "Stale unknown",
+ }.get(base_status, "Stale")
+def stale_count_bucket(check):
+ if check["status"] != STALE:
+ return None
+ base_status = check.get("stale_base_status")
+ if base_status in (SUCCESS, FAILURE):
+ return base_status
+ return UNKNOWN
+def stale_check_counts(branch):
+ counts = {
+ SUCCESS: 0,
+ FAILURE: 0,
+ UNKNOWN: 0,
+ for check in branch["checks"]:
+ if not check.get("required"):
+ continue
+ bucket = stale_count_bucket(check)
+ if bucket:
+ counts[bucket] += 1
+ return counts
+def stale_summary_parts(branch):
+ counts = stale_check_counts(branch)
+ return nonzero_parts(
+ (counts[SUCCESS], f"{counts[SUCCESS]} stale-passed"),
+ (counts[FAILURE], f"{counts[FAILURE]} stale-failed"),
+ (counts[UNKNOWN], f"{counts[UNKNOWN]} stale-unknown"),
def plural(count, word):
return f"{count} {word}" + ("" if count == 1 else "s")
@@ -959,7 +1004,7 @@ def nonzero_parts(*items):
def summary_text(branch):
status = branch["status"]
counts = check_counts(branch)
- unknown = counts[UNKNOWN] + counts[STALE]
+ stale_parts = stale_summary_parts(branch)
if status == SUCCESS:
return f"all {counts['required']} required CI checks OK"
if status == FAILURE:
@@ -967,24 +1012,27 @@ def summary_text(branch):
(counts[SUCCESS], f"{counts[SUCCESS]} OK"),
(counts[FAILURE], plural(counts[FAILURE], "failure")),
(counts[IN_PROGRESS], f"{counts[IN_PROGRESS]} running"),
- (unknown, f"{unknown} unknown/stale"),
+ (counts[UNKNOWN], f"{counts[UNKNOWN]} unknown"),
+ parts.extend(stale_parts)
return "; ".join(parts)
if status == IN_PROGRESS:
previous = previous_summary(branch["checks"])
parts = nonzero_parts(
prefix = "no known failures; " + ", ".join(parts)
return f"{prefix}; {previous}" if previous else prefix
if status == UNKNOWN:
return "no known failures; " + ", ".join(parts)
return "no required CI configured"
@@ -1114,7 +1162,8 @@ def print_terminal(data, use_color=True, verbose=False):
heading_text = f"{glyph} {branch['label']} / {check['check']}"
heading = terminal_link(heading_text, url, use_color)
print(heading)
- print(terminal_field("status", check["status"], use_color))
+ status_value = check.get("status_label") or check["status"]
+ print(terminal_field("status", status_value, use_color))
if url:
print(terminal_field("url", url, use_color))
if check["status"] == IN_PROGRESS and check.get("previous_completed_status"):
@@ -1217,6 +1266,7 @@ def html_status_pill(status, label=None):
def html_branch_progress(branch):
+ stale_counts = stale_check_counts(branch)
total = counts["required"]
if not total:
return ""
@@ -1224,7 +1274,10 @@ def html_branch_progress(branch):
(SUCCESS, counts[SUCCESS], "OK"),
(FAILURE, counts[FAILURE], "failing"),
(IN_PROGRESS, counts[IN_PROGRESS], "running"),
- (UNKNOWN, counts[UNKNOWN] + counts[STALE], "unknown or stale"),
+ (UNKNOWN, counts[UNKNOWN], "unknown"),
+ ("stale-passed", stale_counts[SUCCESS], "stale-passed"),
+ ("stale-failed", stale_counts[FAILURE], "stale-failed"),
+ ("stale-unknown", stale_counts[UNKNOWN], "stale-unknown"),
labels = [f"{count} {label}" for status, count, label in segments if count]
pieces = []
@@ -1242,7 +1295,7 @@ def html_branch_progress(branch):
def html_branch_summary(branch):
parts = []
if counts[SUCCESS]:
parts.append((SUCCESS, f"{counts[SUCCESS]} OK"))
@@ -1250,8 +1303,14 @@ def html_branch_summary(branch):
parts.append((FAILURE, plural(counts[FAILURE], "failure")))
if counts[IN_PROGRESS]:
parts.append((IN_PROGRESS, f"{counts[IN_PROGRESS]} running"))
- if unknown:
- parts.append((UNKNOWN, f"{unknown} unknown/stale"))
+ if counts[UNKNOWN]:
+ parts.append((UNKNOWN, f"{counts[UNKNOWN]} unknown"))
+ if stale_counts[SUCCESS]:
+ parts.append(("stale-passed", f"{stale_counts[SUCCESS]} stale-passed"))
+ if stale_counts[FAILURE]:
+ parts.append(("stale-failed", f"{stale_counts[FAILURE]} stale-failed"))
+ if stale_counts[UNKNOWN]:
+ parts.append(("stale-unknown", f"{stale_counts[UNKNOWN]} stale-unknown"))
if not parts:
return html.escape(summary_text(branch))
return " ".join(
@@ -1313,7 +1372,10 @@ def html_check_rows(checks):
status_text = f"{status_text} previous: {previous}"
status = f"{status} <span class='previous-note'>previous: {html.escape(previous)}</span>"
message = " ".join(str(check.get("message") or "").split())
- check_status = html.escape(check["status"])
+ check_classes = [f"status-{check['status']}"]
+ if check["status"] == STALE:
+ check_classes.append(f"stale-{stale_count_bucket(check)}")
+ check_status = html.escape(" ".join(check_classes))
revision = html_revision(check)
revision_text = check.get("revision") or ""
if revision_text:
@@ -1323,7 +1385,7 @@ def html_check_rows(checks):
age = html_time(check.get("completed_at"))
age_text_value = age_text(check.get("completed_at")) if check.get("completed_at") else ""
detail_rows.append(
- f"<tr class='status-{check_status}'>"
+ f"<tr class='{check_status}'>"
f"<td class='check-name'>{check_html}{terminal_pad(check['check'], 27)}</td>"
f"<td>{terminal_sep}{status}{terminal_pad(status_text, 30)}</td>"
f"<td class='revision-cell'>{terminal_sep}{revision}{terminal_pad(revision_text, 44)}</td>"
@@ -1567,6 +1629,18 @@ h1 {{
color: var(--unknown);
background: #fff8e5;
+.chip-stale-passed {{
+ color: #5b6519;
+ background: #f5f8e8;
+.chip-stale-failed {{
+ color: #9a4f00;
+ background: #fff3e0;
+.chip-stale-unknown {{
+ color: var(--unknown);
+ background: #fff8e5;
.branch-progress {{
display: flex;
height: 5px;
@@ -1589,9 +1663,15 @@ h1 {{
.segment-in_progress {{
background: #70a7db;
-.segment-unknown, .segment-stale {{
+.segment-unknown, .segment-stale, .segment-stale-unknown {{
background: #c8a24b;
+.segment-stale-passed {{
+ background: #a4b85d;
+.segment-stale-failed {{
+ background: #d48a3a;
.status-dot {{
width: 10px;
height: 10px;
@@ -1622,6 +1702,8 @@ h1 {{
.status-failure .status-pill {{ color: var(--failure); border-color: #ffc9cf; background: #fff5f6; }}
.status-in_progress .status-pill {{ color: var(--running); border-color: #bfdbfe; background: #f0f7ff; }}
.status-unknown .status-pill, .status-stale .status-pill {{ color: var(--unknown); border-color: #f1d08a; background: #fff8e5; }}
+.status-stale.stale-success .status-pill {{ color: #5b6519; border-color: #d8df9f; background: #f5f8e8; }}
+.status-stale.stale-failure .status-pill {{ color: #9a4f00; border-color: #efc07a; background: #fff3e0; }}
tr.status-success .status-pill {{ color: var(--success); border-color: #b7dfc1; background: #f0fff4; }}
tr.status-failure .status-pill {{ color: var(--failure); border-color: #ffc9cf; background: #fff5f6; }}
tr.status-in_progress .status-pill {{ color: var(--running); border-color: #bfdbfe; background: #f0f7ff; }}
diff --git a/utils/test_ci_status.py b/utils/test_ci_status.py
index 8241ac5ba..5e9891758 100644
--- a/utils/test_ci_status.py
+++ b/utils/test_ci_status.py
@@ -1,6 +1,7 @@
import importlib.util
import pathlib
import unittest
+from unittest import mock
MODULE_PATH = pathlib.Path(__file__).with_name("ci-status.py")
@@ -24,6 +25,77 @@ def check(name, status, *, required=True, url=None):
class RequiredFailureHtmlTest(unittest.TestCase):
+ def test_apply_staleness_labels_passed_and_failed_results(self):
+ config = {
+ "stale_after_hours": 168,
+ "branches": [{"name": "stable-synthetic", "label": "Synthetic"}],
+ stale_check = {"name": "Synthetic CI"}
+ base = {
+ "branch": "stable-synthetic",
+ "branch_label": "Synthetic",
+ "check": "Synthetic CI",
+ "provider": "synthetic",
+ "required": True,
+ "revision": "0" * 40,
+ with mock.patch.object(CI_STATUS, "result_revision_distance", return_value=(3, "stable-synthetic")):
+ failed = CI_STATUS.apply_staleness({
+ **base,
+ "status": CI_STATUS.FAILURE,
+ "message": "build 1",
+ }, config, stale_check)
+ passed = CI_STATUS.apply_staleness({
+ **base,
+ "status": CI_STATUS.SUCCESS,
+ "completed_at": "2026-07-01T00:00:00Z",
+ "message": "build 2",
+ self.assertEqual(CI_STATUS.STALE, failed["status"])
+ self.assertEqual(CI_STATUS.FAILURE, failed["stale_base_status"])
+ self.assertEqual("Stale failed", failed["status_label"])
+ self.assertIn("3 commits behind stable-synthetic", failed["message"])
+ self.assertEqual(CI_STATUS.STALE, passed["status"])
+ self.assertEqual(CI_STATUS.SUCCESS, passed["stale_base_status"])
+ self.assertEqual("Stale passed", passed["status_label"])
+ def test_stale_summary_distinguishes_passed_and_failed(self):
+ branch = {
+ "name": "stable-synthetic",
+ "label": "Synthetic",
+ "status": CI_STATUS.UNKNOWN,
+ "failures": 0,
+ "checks": [
+ check("Required / Passed", CI_STATUS.STALE),
+ check("Required / Failed", CI_STATUS.STALE),
+ check("Required / Unknown", CI_STATUS.UNKNOWN),
+ branch["checks"][0]["stale_base_status"] = CI_STATUS.SUCCESS
+ branch["checks"][0]["status_label"] = "Stale passed"
+ branch["checks"][1]["stale_base_status"] = CI_STATUS.FAILURE
+ branch["checks"][1]["status_label"] = "Stale failed"
+ self.assertEqual(
+ "no known failures; 1 unknown, 1 stale-passed, 1 stale-failed",
+ CI_STATUS.summary_text(branch),
+ rendered = CI_STATUS.render_html({
+ "generated_at": "2026-07-19T00:00:00+00:00",
+ "branches": [branch],
+ self.assertIn("1 stale-passed", rendered)
+ self.assertIn("1 stale-failed", rendered)
+ self.assertIn("Stale passed", rendered)
+ self.assertIn("Stale failed", rendered)
+ self.assertIn("status-stale stale-success", rendered)
+ self.assertIn("status-stale stale-failure", rendered)
def test_failure_summary_names_only_required_failed_checks(self):
branches = [
Summary of changes:
utils/ci-status.py | 106 ++++++++++++++++++++++++++++++++++++++++++------
utils/test_ci_status.py | 72 ++++++++++++++++++++++++++++++++
2 files changed, 166 insertions(+), 12 deletions(-)
hooks/post-receive
