[SCM] PostGIS branch master updated. 3.7.0alpha1-647-g1a0b66034
Sun Jul 19 10:17:35 PDT 2026
the project "PostGIS".
       via  1a0b660346d2e80bdbd4b6201e8e47b4194e23a2 (commit)
       via  cbc90f98d53a368da5e3172c4befa9e6ff5b6578 (commit)
      from  01f2e1a504fa9e66a9ea8404e58feb839acf074d (commit)
revisions in full, below.
commit 1a0b660346d2e80bdbd4b6201e8e47b4194e23a2
Merge: 01f2e1a50 cbc90f98d
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Sun Jul 19 10:17:33 2026 -0700
    Merge pull request 'doc: mark CG_3DBuffer point examples documented' (!448) from Komzpa/postgis:fix/cg3dbuffer-visuals into master
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/448
commit cbc90f98d53a368da5e3172c4befa9e6ff5b6578
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Sun Jul 19 20:00:42 2026 +0400
diff --git a/doc/reference_sfcgal.xml b/doc/reference_sfcgal.xml
index 6fda44d50..54a24f407 100644
--- a/doc/reference_sfcgal.xml
+++ b/doc/reference_sfcgal.xml
@@ -2415,13 +2415,13 @@ FROM data;</programlisting>
 <screen role="visual-primary text-primary">POLYHEDRALSURFACE Z (((0 0 1, 0.5 -0.5 0.71, 0 -0.71 0.71, 0 0 1)), ... )</screen>
        <para>A rounded point buffer using 32 segments.</para>
-       <programlisting language="sql">SELECT
+       <programlisting language="sql" role="documented-output">SELECT
   'POINT(100 90)'::geometry AS input_geometry,
   CG_3DBuffer('POINT(100 90)'::geometry, 50, 32, 0) AS buffer;</programlisting>
 <screen role="visual-primary geometry-output-precision-0">POINT(100 90) | POLYHEDRALSURFACE Z (((74 133 0,66 126 7,78 133 12,74 133 0)),((60 115 15,71 124 21,66 126 7,60 115 15)),((85 130 25,78 133 12,71 124 21,85 130 25)),((66 126 7,71 124 21,78 133 12,66 126 7)),((57 90 26,64 97 34,57 102 22,57 90 26)),((75 105 40,66 111 29,64 97 34,75 105 40)),((60 115 15,57 102 22,66 111 29,60 115 15)),((64 97 34,66 111 29,57 102 22,64 97 34)),((100 116 43,93 124 36,88 112 43,100 116 43)),((85 130 25,79 119 34,93 124 36,85 130 25)),((75 105 40,88 112 43,79 119 34,75 105 40)),((93 124 36,79 119 34,88 112 43,93 124 36)),((60 115 15,66 111 29,71 124 21,60 115 15)),((75 105 40,79 119 34,66 111 29,75 105 40)),((85 130 25,71 124 21,79 119 34,85 130 25)),((66 111 29,79 119 34,71 124 21,66 111 29)),((74 133 0,78 133 12,85 138 0,74 133 0)),((85 130 25,92 138 13,78 133 12,85 130 25)),((100 140 0,85 138 0,92 138 13,100 140 0)),((78 133 12,92 138 13,85 138 0,78 133 12)),((100 116 43,107 124 36,93 124 36,100
  116 43)),((115 130 25,100 133 26,107 124 36,115 130 25)),((85 130 25,93 124 36,100 133 26,85 130 25)),((107 124 36,100 133 26,93 124 36,107 124 36)),((126 133 0,115 138 0,122 133 12,126 133 0)),((100 140 0,108 138 13,115 138 0,100 140 0)),((115 130 25,122 133 12,108 138 13,115 130 25)),((115 138 0,108 138 13,122 133 12,115 138 0)),((85 130 25,100 133 26,92 138 13,85 130 25)),((115 130 25,108 138 13,100 133 26,115 130 25)),((100 140 0,92 138 13,108 138 13,100 140 0)),((100 133 26,108 138 13,92 138 13,100 133 26)),((74 133 0,85 138 0,78 133 -12,74 133 0)),((100 140 0,92 138 -13,85 138 0,100 140 0)),((85 130 -25,78 133 -12,92 138 -13,85 130 -25)),((85 138 0,92 138 -13,78 133 -12,85 138 0)),((126 133 0,122 133 -12,115 138 0,126 133 0)),((115 130 -25,108 138 -13,122 133 -12,115 130 -25)),((100 140 0,115 138 0,108 138 -13,100 140 0)),((122 133 -12,108 138 -13,115 138 0,122 133 -12)),((100 116 -43,93 124 -36,107 124 -36,100 116 -43)),((85 130 -25,100 133 -26,93 124 -36,85 130 -25)),((115
 130 -25,107 124 -36,100 133 -26,115 130 -25)),((93 124 -36,100 133 -26,107 124 -36,93 124 -36)),((100 140 0,108 138 -13,92 138 -13,100 140 0)),((115 130 -25,100 133 -26,108 138 -13,115 130 -25)),((85 130 -25,92 138 -13,100 133 -26,85 130 -25)),((108 138 -13,100 133 -26,92 138 -13,108 138 -13)),((74 133 0,78 133 -12,66 126 -7,74 133 0)),((85 130 -25,71 124 -21,78 133 -12,85 130 -25)),((60 115 -15,66 126 -7,71 124 -21,60 115 -15)),((78 133 -12,71 124 -21,66 126 -7,78 133 -12)),((100 116 -43,88 112 -43,93 124 -36,100 116 -43)),((75 105 -40,79 119 -34,88 112 -43,75 105 -40)),((85 130 -25,93 124 -36,79 119 -34,85 130 -25)),((88 112 -43,79 119 -34,93 124 -36,88 112 -43)),((57 90 -26,57 102 -22,64 97 -34,57 90 -26)),((60 115 -15,66 111 -29,57 102 -22,60 115 -15)),((75 105 -40,64 97 -34,66 111 -29,75 105 -40)),((57 102 -22,66 111 -29,64 97 -34,57 102 -22)),((85 130 -25,79 119 -34,71 124 -21,85 130 -25)),((75 105 -40,66 111 -29,79 119 -34,75 105 -40)),((60 115 -15,71 124 -21,66 111 -29,60 11
 5 -15)),((79 119 -34,66 111 -29,71 124 -21,79 119 -34)),((74 133 0,66 126 -7,66 126 7,74 133 0)),((60 115 -15,57 116 0,66 126 -7,60 115 -15)),((60 115 15,66 126 7,57 116 0,60 115 15)),((66 126 -7,57 116 0,66 126 7,66 126 -7)),((57 90 -26,52 90 -15,57 102 -22,57 90 -26)),((50 90 0,52 103 -8,52 90 -15,50 90 0)),((60 115 -15,57 102 -22,52 103 -8,60 115 -15)),((52 90 -15,52 103 -8,57 102 -22,52 90 -15)),((57 90 26,57 102 22,52 90 15,57 90 26)),((60 115 15,52 103 8,57 102 22,60 115 15)),((50 90 0,52 90 15,52 103 8,50 90 0)),((57 102 22,52 103 8,52 90 15,57 102 22)),((60 115 -15,52 103 -8,57 116 0,60 115 -15)),((50 90 0,52 103 8,52 103 -8,50 90 0)),((60 115 15,57 116 0,52 103 8,60 115 15)),((52 103 -8,52 103 8,57 116 0,52 103 -8)),((126 133 0,122 133 12,134 126 7,126 133 0)),((115 130 25,129 124 21,122 133 12,115 130 25)),((140 115 15,134 126 7,129 124 21,140 115 15)),((122 133 12,129 124 21,134 126 7,122 133 12)),((100 116 43,112 112 43,107 124 36,100 116 43)),((125 105 40,121 119 34,112
  112 43,125 105 40)),((115 130 25,107 124 36,121 119 34,115 130 25)),((112 112 43,121 119 34,107 124 36,112 112 43)),((143 90 26,143 102 22,136 97 34,143 90 26)),((140 115 15,134 111 29,143 102 22,140 115 15)),((125 105 40,136 97 34,134 111 29,125 105 40)),((143 102 22,134 111 29,136 97 34,143 102 22)),((115 130 25,121 119 34,129 124 21,115 130 25)),((125 105 40,134 111 29,121 119 34,125 105 40)),((140 115 15,129 124 21,134 111 29,140 115 15)),((121 119 34,134 111 29,129 124 21,121 119 34)),((100 116 43,88 112 43,100 105 48,100 116 43)),((75 105 40,87 98 48,88 112 43,75 105 40)),((100 90 50,100 105 48,87 98 48,100 90 50)),((88 112 43,87 98 48,100 105 48,88 112 43)),((57 90 26,64 83 34,64 97 34,57 90 26)),((75 75 40,74 90 43,64 83 34,75 75 40)),((75 105 40,64 97 34,74 90 43,75 105 40)),((64 83 34,74 90 43,64 97 34,64 83 34)),((100 64 43,100 75 48,88 68 43,100 64 43)),((100 90 50,87 82 48,100 75 48,100 90 50)),((75 75 40,88 68 43,87 82 48,75 75 40)),((100 75 48,87 82 48,88 68 43,100 7
 5 48)),((75 105 40,74 90 43,87 98 48,75 105 40)),((75 75 40,87 82 48,74 90 43,75 75 40)),((100 90 50,87 98 48,87 82 48,100 90 50)),((74 90 43,87 82 48,87 98 48,74 90 43)),((57 90 26,52 90 15,57 78 22,57 90 26)),((50 90 0,52 77 8,52 90 15,50 90 0)),((60 65 15,57 78 22,52 77 8,60 65 15)),((52 90 15,52 77 8,57 78 22,52 90 15)),((57 90 -26,57 78 -22,52 90 -15,57 90 -26)),((60 65 -15,52 77 -8,57 78 -22,60 65 -15)),((50 90 0,52 90 -15,52 77 -8,50 90 0)),((57 78 -22,52 77 -8,52 90 -15,57 78 -22)),((74 47 0,66 54 7,66 54 -7,74 47 0)),((60 65 15,57 64 0,66 54 7,60 65 15)),((60 65 -15,66 54 -7,57 64 0,60 65 -15)),((66 54 7,57 64 0,66 54 -7,66 54 7)),((50 90 0,52 77 -8,52 77 8,50 90 0)),((60 65 -15,57 64 0,52 77 -8,60 65 -15)),((60 65 15,52 77 8,57 64 0,60 65 15)),((52 77 -8,57 64 0,52 77 8,52 77 -8)),((57 90 -26,64 97 -34,64 83 -34,57 90 -26)),((75 105 -40,74 90 -43,64 97 -34,75 105 -40)),((75 75 -40,64 83 -34,74 90 -43,75 75 -40)),((64 97 -34,74 90 -43,64 83 -34,64 97 -34)),((100 116 -43,100
  105 -48,88 112 -43,100 116 -43)),((100 90 -50,87 98 -48,100 105 -48,100 90 -50)),((75 105 -40,88 112 -43,87 98 -48,75 105 -40)),((100 105 -48,87 98 -48,88 112 -43,100 105 -48)),((100 64 -43,88 68 -43,100 75 -48,100 64 -43)),((75 75 -40,87 82 -48,88 68 -43,75 75 -40)),((100 90 -50,100 75 -48,87 82 -48,100 90 -50)),((88 68 -43,87 82 -48,100 75 -48,88 68 -43)),((75 105 -40,87 98 -48,74 90 -43,75 105 -40)),((100 90 -50,87 82 -48,87 98 -48,100 90 -50)),((75 75 -40,74 90 -43,87 82 -48,75 75 -40)),((87 98 -48,87 82 -48,74 90 -43,87 98 -48)),((100 116 -43,107 124 -36,112 112 -43,100 116 -43)),((115 130 -25,121 119 -34,107 124 -36,115 130 -25)),((125 105 -40,112 112 -43,121 119 -34,125 105 -40)),((107 124 -36,121 119 -34,112 112 -43,107 124 -36)),((126 133 0,134 126 -7,122 133 -12,126 133 0)),((140 115 -15,129 124 -21,134 126 -7,140 115 -15)),((115 130 -25,122 133 -12,129 124 -21,115 130 -25)),((134 126 -7,129 124 -21,122 133 -12,134 126 -7)),((143 90 -26,136 97 -34,143 102 -22,143 90 -26))
 ,((125 105 -40,134 111 -29,136 97 -34,125 105 -40)),((140 115 -15,143 102 -22,134 111 -29,140 115 -15)),((136 97 -34,134 111 -29,143 102 -22,136 97 -34)),((115 130 -25,129 124 -21,121 119 -34,115 130 -25)),((140 115 -15,134 111 -29,129 124 -21,140 115 -15)),((125 105 -40,121 119 -34,134 111 -29,125 105 -40)),((129 124 -21,134 111 -29,121 119 -34,129 124 -21)),((126 47 0,134 54 7,122 47 12,126 47 0)),((140 65 15,129 56 21,134 54 7,140 65 15)),((115 50 25,122 47 12,129 56 21,115 50 25)),((134 54 7,129 56 21,122 47 12,134 54 7)),((143 90 26,136 83 34,143 78 22,143 90 26)),((125 75 40,134 69 29,136 83 34,125 75 40)),((140 65 15,143 78 22,134 69 29,140 65 15)),((136 83 34,134 69 29,143 78 22,136 83 34)),((100 64 43,107 56 36,112 68 43,100 64 43)),((115 50 25,121 61 34,107 56 36,115 50 25)),((125 75 40,112 68 43,121 61 34,125 75 40)),((107 56 36,121 61 34,112 68 43,107 56 36)),((140 65 15,134 69 29,129 56 21,140 65 15)),((125 75 40,121 61 34,134 69 29,125 75 40)),((115 50 25,129 56 21,121
  61 34,115 50 25)),((134 69 29,121 61 34,129 56 21,134 69 29)),((126 47 0,122 47 12,115 42 0,126 47 0)),((115 50 25,108 42 13,122 47 12,115 50 25)),((100 40 0,115 42 0,108 42 13,100 40 0)),((122 47 12,108 42 13,115 42 0,122 47 12)),((100 64 43,93 56 36,107 56 36,100 64 43)),((85 50 25,100 47 26,93 56 36,85 50 25)),((115 50 25,107 56 36,100 47 26,115 50 25)),((93 56 36,100 47 26,107 56 36,93 56 36)),((74 47 0,85 42 0,78 47 12,74 47 0)),((100 40 0,92 42 13,85 42 0,100 40 0)),((85 50 25,78 47 12,92 42 13,85 50 25)),((85 42 0,92 42 13,78 47 12,85 42 0)),((115 50 25,100 47 26,108 42 13,115 50 25)),((85 50 25,92 42 13,100 47 26,85 50 25)),((100 40 0,108 42 13,92 42 13,100 40 0)),((100 47 26,92 42 13,108 42 13,100 47 26)),((126 47 0,115 42 0,122 47 -12,126 47 0)),((100 40 0,108 42 -13,115 42 0,100 40 0)),((115 50 -25,122 47 -12,108 42 -13,115 50 -25)),((115 42 0,108 42 -13,122 47 -12,115 42 0)),((74 47 0,78 47 -12,85 42 0,74 47 0)),((85 50 -25,92 42 -13,78 47 -12,85 50 -25)),((100 40 0,85
 42 0,92 42 -13,100 40 0)),((78 47 -12,92 42 -13,85 42 0,78 47 -12)),((100 64 -43,107 56 -36,93 56 -36,100 64 -43)),((115 50 -25,100 47 -26,107 56 -36,115 50 -25)),((85 50 -25,93 56 -36,100 47 -26,85 50 -25)),((107 56 -36,100 47 -26,93 56 -36,107 56 -36)),((100 40 0,92 42 -13,108 42 -13,100 40 0)),((85 50 -25,100 47 -26,92 42 -13,85 50 -25)),((115 50 -25,108 42 -13,100 47 -26,115 50 -25)),((92 42 -13,100 47 -26,108 42 -13,92 42 -13)),((126 47 0,122 47 -12,134 54 -7,126 47 0)),((115 50 -25,129 56 -21,122 47 -12,115 50 -25)),((140 65 -15,134 54 -7,129 56 -21,140 65 -15)),((122 47 -12,129 56 -21,134 54 -7,122 47 -12)),((100 64 -43,112 68 -43,107 56 -36,100 64 -43)),((125 75 -40,121 61 -34,112 68 -43,125 75 -40)),((115 50 -25,107 56 -36,121 61 -34,115 50 -25)),((112 68 -43,121 61 -34,107 56 -36,112 68 -43)),((143 90 -26,143 78 -22,136 83 -34,143 90 -26)),((140 65 -15,134 69 -29,143 78 -22,140 65 -15)),((125 75 -40,136 83 -34,134 69 -29,125 75 -40)),((143 78 -22,134 69 -29,136 83 -34,143
 78 -22)),((115 50 -25,121 61 -34,129 56 -21,115 50 -25)),((125 75 -40,134 69 -29,121 61 -34,125 75 -40)),((140 65 -15,129 56 -21,134 69 -29,140 65 -15)),((121 61 -34,134 69 -29,129 56 -21,121 61 -34)),((126 47 0,134 54 -7,134 54 7,126 47 0)),((140 65 -15,143 64 0,134 54 -7,140 65 -15)),((140 65 15,134 54 7,143 64 0,140 65 15)),((134 54 -7,143 64 0,134 54 7,134 54 -7)),((143 90 -26,148 90 -15,143 78 -22,143 90 -26)),((150 90 0,148 77 -8,148 90 -15,150 90 0)),((140 65 -15,143 78 -22,148 77 -8,140 65 -15)),((148 90 -15,148 77 -8,143 78 -22,148 90 -15)),((143 90 26,143 78 22,148 90 15,143 90 26)),((140 65 15,148 77 8,143 78 22,140 65 15)),((150 90 0,148 90 15,148 77 8,150 90 0)),((143 78 22,148 77 8,148 90 15,143 78 22)),((140 65 -15,148 77 -8,143 64 0,140 65 -15)),((150 90 0,148 77 8,148 77 -8,150 90 0)),((140 65 15,143 64 0,148 77 8,140 65 15)),((148 77 -8,148 77 8,143 64 0,148 77 -8)),((100 64 43,112 68 43,100 75 48,100 64 43)),((125 75 40,113 82 48,112 68 43,125 75 40)),((100 90 50,
 100 75 48,113 82 48,100 90 50)),((112 68 43,113 82 48,100 75 48,112 68 43)),((143 90 26,136 97 34,136 83 34,143 90 26)),((125 105 40,126 90 43,136 97 34,125 105 40)),((125 75 40,136 83 34,126 90 43,125 75 40)),((136 97 34,126 90 43,136 83 34,136 97 34)),((100 116 43,100 105 48,112 112 43,100 116 43)),((100 90 50,113 98 48,100 105 48,100 90 50)),((125 105 40,112 112 43,113 98 48,125 105 40)),((100 105 48,113 98 48,112 112 43,100 105 48)),((125 75 40,126 90 43,113 82 48,125 75 40)),((125 105 40,113 98 48,126 90 43,125 105 40)),((100 90 50,113 82 48,113 98 48,100 90 50)),((126 90 43,113 98 48,113 82 48,126 90 43)),((74 47 0,78 47 12,66 54 7,74 47 0)),((85 50 25,71 56 21,78 47 12,85 50 25)),((60 65 15,66 54 7,71 56 21,60 65 15)),((78 47 12,71 56 21,66 54 7,78 47 12)),((100 64 43,88 68 43,93 56 36,100 64 43)),((75 75 40,79 61 34,88 68 43,75 75 40)),((85 50 25,93 56 36,79 61 34,85 50 25)),((88 68 43,79 61 34,93 56 36,88 68 43)),((57 90 26,57 78 22,64 83 34,57 90 26)),((60 65 15,66 69 29,5
 7 78 22,60 65 15)),((75 75 40,64 83 34,66 69 29,75 75 40)),((57 78 22,66 69 29,64 83 34,57 78 22)),((85 50 25,79 61 34,71 56 21,85 50 25)),((75 75 40,66 69 29,79 61 34,75 75 40)),((60 65 15,71 56 21,66 69 29,60 65 15)),((79 61 34,66 69 29,71 56 21,79 61 34)),((100 64 -43,93 56 -36,88 68 -43,100 64 -43)),((85 50 -25,79 61 -34,93 56 -36,85 50 -25)),((75 75 -40,88 68 -43,79 61 -34,75 75 -40)),((93 56 -36,79 61 -34,88 68 -43,93 56 -36)),((74 47 0,66 54 -7,78 47 -12,74 47 0)),((60 65 -15,71 56 -21,66 54 -7,60 65 -15)),((85 50 -25,78 47 -12,71 56 -21,85 50 -25)),((66 54 -7,71 56 -21,78 47 -12,66 54 -7)),((57 90 -26,64 83 -34,57 78 -22,57 90 -26)),((75 75 -40,66 69 -29,64 83 -34,75 75 -40)),((60 65 -15,57 78 -22,66 69 -29,60 65 -15)),((64 83 -34,66 69 -29,57 78 -22,64 83 -34)),((85 50 -25,71 56 -21,79 61 -34,85 50 -25)),((60 65 -15,66 69 -29,71 56 -21,60 65 -15)),((75 75 -40,79 61 -34,66 69 -29,75 75 -40)),((71 56 -21,66 69 -29,79 61 -34,71 56 -21)),((143 90 -26,136 83 -34,136 97 -34,143 9
 0 -26)),((125 75 -40,126 90 -43,136 83 -34,125 75 -40)),((125 105 -40,136 97 -34,126 90 -43,125 105 -40)),((136 83 -34,126 90 -43,136 97 -34,136 83 -34)),((100 64 -43,100 75 -48,112 68 -43,100 64 -43)),((100 90 -50,113 82 -48,100 75 -48,100 90 -50)),((125 75 -40,112 68 -43,113 82 -48,125 75 -40)),((100 75 -48,113 82 -48,112 68 -43,100 75 -48)),((100 116 -43,112 112 -43,100 105 -48,100 116 -43)),((125 105 -40,113 98 -48,112 112 -43,125 105 -40)),((100 90 -50,100 105 -48,113 98 -48,100 90 -50)),((112 112 -43,113 98 -48,100 105 -48,112 112 -43)),((125 75 -40,113 82 -48,126 90 -43,125 75 -40)),((100 90 -50,113 98 -48,113 82 -48,100 90 -50)),((125 105 -40,126 90 -43,113 98 -48,125 105 -40)),((113 82 -48,113 98 -48,126 90 -43,113 82 -48)),((143 90 26,148 90 15,143 102 22,143 90 26)),((150 90 0,148 103 8,148 90 15,150 90 0)),((140 115 15,143 102 22,148 103 8,140 115 15)),((148 90 15,148 103 8,143 102 22,148 90 15)),((143 90 -26,143 102 -22,148 90 -15,143 90 -26)),((140 115 -15,148 103 -8,1
 43 102 -22,140 115 -15)),((150 90 0,148 90 -15,148 103 -8,150 90 0)),((143 102 -22,148 103 -8,148 90 -15,143 102 -22)),((126 133 0,134 126 7,134 126 -7,126 133 0)),((140 115 15,143 116 0,134 126 7,140 115 15)),((140 115 -15,134 126 -7,143 116 0,140 115 -15)),((134 126 7,143 116 0,134 126 -7,134 126 7)),((150 90 0,148 103 -8,148 103 8,150 90 0)),((140 115 -15,143 116 0,148 103 -8,140 115 -15)),((140 115 15,148 103 8,143 116 0,140 115 15)),((148 103 -8,143 116 0,148 103 8,148 103 -8)))</screen>
        <para>A coarser rounded point buffer using 5 segments.</para>
   CG_3DBuffer('POINT(100 90)'::geometry, 50, 5, 0) AS buffer;</programlisting>
 <screen role="visual-primary geometry-output-precision-0">POINT(100 90) | POLYHEDRALSURFACE Z (((74 133 0,60 115 15,85 130 25,74 133 0)),((57 90 26,75 105 40,60 115 15,57 90 26)),((100 116 43,85 130 25,75 105 40,100 116 43)),((60 115 15,75 105 40,85 130 25,60 115 15)),((74 133 0,85 130 25,100 140 0,74 133 0)),((100 116 43,115 130 25,85 130 25,100 116 43)),((126 133 0,100 140 0,115 130 25,126 133 0)),((85 130 25,115 130 25,100 140 0,85 130 25)),((74 133 0,100 140 0,85 130 -25,74 133 0)),((126 133 0,115 130 -25,100 140 0,126 133 0)),((100 116 -43,85 130 -25,115 130 -25,100 116 -43)),((100 140 0,115 130 -25,85 130 -25,100 140 0)),((74 133 0,85 130 -25,60 115 -15,74 133 0)),((100 116 -43,75 105 -40,85 130 -25,100 116 -43)),((57 90 -26,60 115 -15,75 105 -40,57 90 -26)),((85 130 -25,75 105 -40,60 115 -15,85 130 -25)),((74 133 0,60 115 -15,60 115 15,74 133 0)),((57 90 -26,50 90 0,60 115 -15,57 90 -26)),((57 90 26,60 115 15,50 90 0,57 90 26)),((60 115 -15,50 90 0,60 115 15,60 115 -15)),((12
 6 133 0,115 130 25,140 115 15,126 133 0)),((100 116 43,125 105 40,115 130 25,100 116 43)),((143 90 26,140 115 15,125 105 40,143 90 26)),((115 130 25,125 105 40,140 115 15,115 130 25)),((100 116 43,75 105 40,100 90 50,100 116 43)),((57 90 26,75 75 40,75 105 40,57 90 26)),((100 64 43,100 90 50,75 75 40,100 64 43)),((75 105 40,75 75 40,100 90 50,75 105 40)),((57 90 26,50 90 0,60 65 15,57 90 26)),((57 90 -26,60 65 -15,50 90 0,57 90 -26)),((74 47 0,60 65 15,60 65 -15,74 47 0)),((50 90 0,60 65 -15,60 65 15,50 90 0)),((57 90 -26,75 105 -40,75 75 -40,57 90 -26)),((100 116 -43,100 90 -50,75 105 -40,100 116 -43)),((100 64 -43,75 75 -40,100 90 -50,100 64 -43)),((75 105 -40,100 90 -50,75 75 -40,75 105 -40)),((100 116 -43,115 130 -25,125 105 -40,100 116 -43)),((126 133 0,140 115 -15,115 130 -25,126 133 0)),((143 90 -26,125 105 -40,140 115 -15,143 90 -26)),((115 130 -25,140 115 -15,125 105 -40,115 130 -25)),((126 47 0,140 65 15,115 50 25,126 47 0)),((143 90 26,125 75 40,140 65 15,143 90 26)),((10
 0 64 43,115 50 25,125 75 40,100 64 43)),((140 65 15,125 75 40,115 50 25,140 65 15)),((126 47 0,115 50 25,100 40 0,126 47 0)),((100 64 43,85 50 25,115 50 25,100 64 43)),((74 47 0,100 40 0,85 50 25,74 47 0)),((115 50 25,85 50 25,100 40 0,115 50 25)),((126 47 0,100 40 0,115 50 -25,126 47 0)),((74 47 0,85 50 -25,100 40 0,74 47 0)),((100 64 -43,115 50 -25,85 50 -25,100 64 -43)),((100 40 0,85 50 -25,115 50 -25,100 40 0)),((126 47 0,115 50 -25,140 65 -15,126 47 0)),((100 64 -43,125 75 -40,115 50 -25,100 64 -43)),((143 90 -26,140 65 -15,125 75 -40,143 90 -26)),((115 50 -25,125 75 -40,140 65 -15,115 50 -25)),((126 47 0,140 65 -15,140 65 15,126 47 0)),((143 90 -26,150 90 0,140 65 -15,143 90 -26)),((143 90 26,140 65 15,150 90 0,143 90 26)),((140 65 -15,150 90 0,140 65 15,140 65 -15)),((100 64 43,125 75 40,100 90 50,100 64 43)),((143 90 26,125 105 40,125 75 40,143 90 26)),((100 116 43,100 90 50,125 105 40,100 116 43)),((125 75 40,125 105 40,100 90 50,125 75 40)),((74 47 0,85 50 25,60 65 15,74 4
 7 0)),((100 64 43,75 75 40,85 50 25,100 64 43)),((57 90 26,60 65 15,75 75 40,57 90 26)),((85 50 25,75 75 40,60 65 15,85 50 25)),((100 64 -43,85 50 -25,75 75 -40,100 64 -43)),((74 47 0,60 65 -15,85 50 -25,74 47 0)),((57 90 -26,75 75 -40,60 65 -15,57 90 -26)),((85 50 -25,60 65 -15,75 75 -40,85 50 -25)),((143 90 -26,125 75 -40,125 105 -40,143 90 -26)),((100 64 -43,100 90 -50,125 75 -40,100 64 -43)),((100 116 -43,125 105 -40,100 90 -50,100 116 -43)),((125 75 -40,100 90 -50,125 105 -40,125 75 -40)),((143 90 26,150 90 0,140 115 15,143 90 26)),((143 90 -26,140 115 -15,150 90 0,143 90 -26)),((126 133 0,140 115 15,140 115 -15,126 133 0)),((150 90 0,140 115 -15,140 115 15,150 90 0)))</screen>
Summary of changes:
 doc/reference_sfcgal.xml | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
