[SCM] PostGIS branch stable-3.2 updated. 3.2.10-72-g428c1fcc2
Sun Jul 19 09:00:07 PDT 2026
the project "PostGIS".
The branch, stable-3.2 has been updated
       via  428c1fcc21d08671b3e69fc091d11660b1112095 (commit)
       via  a84d808df7c7a0bb937817801a57756b28a1b4b4 (commit)
       via  638428c2d3d9042c2d499915944898e935049a4c (commit)
      from  d3422755140c9a93196410f0e4087cb2dd0c043d (commit)
revisions in full, below.
commit 428c1fcc21d08671b3e69fc091d11660b1112095
Merge: d34227551 a84d808df
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Sun Jul 19 09:00:05 2026 -0700
    Merge pull request 'Repair stable 3.2 upgrade path checks' (!447) from Komzpa/postgis:fix/upgrade-path-hygiene-stable-3.2 into stable-3.2
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/447
commit a84d808df7c7a0bb937817801a57756b28a1b4b4
Author: Sandro Santilli <strk at kbt.io>
Date:   Sun Jul 19 19:11:15 2026 +0400
    Fix upgrades in presence of views using ST_TileEnvelope
    Backport the upgrade marker so create_upgrade.pl handles the replaced ST_TileEnvelope signature instead of forcing the pre-upgrade drop to succeed while dependent objects may still exist.
    References #5499 in 3.2 branch
    (cherry picked from commit 308494525858277bbeb546fe36d6aa4c1c157cf7)
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index d28756e8d..10ed2a260 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -1807,6 +1807,7 @@ CREATE OR REPLACE FUNCTION ST_MakeEnvelope(float8, float8, float8, float8, integ
 -- Availability: 3.0.0
 -- Changed: 3.1.0 - add margin=0.0 parameter
+-- Replaces ST_TileEnvelope(zoom integer, x integer, y integer, bounds geometry) deprecated in 3.1.0
 CREATE OR REPLACE FUNCTION ST_TileEnvelope(zoom integer, x integer, y integer, bounds geometry DEFAULT 'SRID=3857;LINESTRING(-20037508.342789244 -20037508.342789244, 20037508.342789244 20037508.342789244)'::geometry, margin float8 DEFAULT 0.0)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'ST_TileEnvelope'
diff --git a/postgis/postgis_before_upgrade.sql b/postgis/postgis_before_upgrade.sql
index 11a599d8d..d5d887e77 100644
--- a/postgis/postgis_before_upgrade.sql
+++ b/postgis/postgis_before_upgrade.sql
@@ -183,14 +183,6 @@ SELECT _postgis_drop_function_if_needed
 	'GeometryA geometry, GeometryB geometry'
--- FUNCTION st_tileenvelope added a new default argument in 3.1
-SELECT _postgis_drop_function_if_needed
-    'st_tileenvelope',
-    'zoom integer, x integer, y integer, bounds geometry'
 -- FUNCTION st_buffer changed to add defaults in 3.0
 -- This signature was superseeded
 DROP FUNCTION IF EXISTS st_buffer(geometry, double precision); -- Does not conflict
@@ -242,4 +234,3 @@ $$;
 -- DROP auxiliar function (created above)
 DROP FUNCTION _postgis_drop_function_if_needed(text, text);
commit 638428c2d3d9042c2d499915944898e935049a4c
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Sun Jul 19 19:11:08 2026 +0400
    upgrade: clean stale target-version paths before install
    Remove previously installed upgrade scripts for the target extension version before recreating the branch-declared symlink set. This keeps shared extension directories from exposing stale downgrade paths that the current branch no longer installs.
diff --git a/extensions/upgrade-paths-rules.mk b/extensions/upgrade-paths-rules.mk
index 27dff04bb..730c81cb5 100644
--- a/extensions/upgrade-paths-rules.mk
+++ b/extensions/upgrade-paths-rules.mk
@@ -6,6 +6,7 @@ install: install-upgrade-paths
 # revisions of the same version
 install-upgrade-paths:
 	tpl='$(EXTENSION)--ANY--$(EXTVERSION).sql'; \
+	rm -f "$(EXTDIR)/$(EXTENSION)--"*--"$(EXTVERSION).sql"; \
 	$(INSTALL_DATA) sql/$${tpl} "$(EXTDIR)/$${tpl}"; \
 	ln -fs "$${tpl}" $(EXTDIR)/$(EXTENSION)--$(EXTVERSION)--$(EXTVERSION)next.sql; \
 	ln -fs "$${tpl}" $(EXTDIR)/$(EXTENSION)--$(EXTVERSION)next--$(EXTVERSION).sql; \
Summary of changes:
 extensions/upgrade-paths-rules.mk  | 1 +
 postgis/postgis.sql.in             | 1 +
 postgis/postgis_before_upgrade.sql | 9 ---------
 3 files changed, 2 insertions(+), 9 deletions(-)
hooks/post-receive
