[SCM] PostGIS branch stable-3.4 updated. 3.4.6-87-g1bf66b058
Wed Jul 22 23:23:10 PDT 2026
the project "PostGIS".
The branch, stable-3.4 has been updated
       via  1bf66b05846cf99ed1430868004ff8646bf5728e (commit)
      from  260cd1349110c6ecd3a119c7a0100df4a7795cde (commit)
revisions in full, below.
commit 1bf66b05846cf99ed1430868004ff8646bf5728e
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Wed Jul 22 23:23:08 2026 -0700
    ci: stop Berrie PostgreSQL after regressions (!488)
    Companion/backport of the Berrie/Berrie64 Jenkins cleanup from master PR #485 for `stable-3.4`.
    stable-3.4 currently has stale/stale-fail Berrie/Berrie64 worker rows on build 8011, and this branch has the same cleanup bug as master.
    The Berrie scripts were testing `$PGDATA/postmaster.pid` as a directory, and Berrie64 also had the bracket typo in that test. The regress scripts use `set -e`, so failures could skip the final shutdown and leave stale PostgreSQL state for the next worker run.
    This patch changes the running-cluster check to a non-empty `postmaster.pid`, keeps the branch-specific stable script lines, and adds an `EXIT` trap so failed regressions still stop PostgreSQL.
    Checks:
    - `bash -n ci/berrie/pg_init_start.sh ci/berrie/postgis_regress.sh ci/berrie64/pg_init_start.sh ci/berrie64/postgis_regress.sh`
    - `git diff --check`
    - `shellcheck` with the pre-existing Jenkins-script style/noise warnings excluded
    Co-authored-by: Darafei Praliaskouski <me at komzpa.net>
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/488
diff --git a/ci/berrie/pg_init_start.sh b/ci/berrie/pg_init_start.sh
index de42cb9fa..69967e725 100644
--- a/ci/berrie/pg_init_start.sh
+++ b/ci/berrie/pg_init_start.sh
@@ -16,16 +16,16 @@ DAEMON="$PGPATH/bin/pg_ctl -D $PGDATA -o '-F' -l logfile start"
 PGCTL="$PGPATH/bin/pg_ctl"
 # remove cluster if exists
-if [ -d $PGDATA ] ; then
-    if [ -d $PGDATA/postmaster.pid ] ; then
-    	$PGCTL stop -D $PGDATA -s -m fast
+if [ -d "$PGDATA" ] ; then
+    if test -s "$PGDATA/postmaster.pid" ; then
+        "$PGCTL" stop -D "$PGDATA" -s -m fast
     fi;
-    rm -rf $PGDATA
+    rm -rf "$PGDATA"
 fi;
 #initialize cluster
-$PGPATH/bin/initdb
+"$PGPATH/bin/initdb"
 echo -n "Starting PostgreSQL: "
 $DAEMON &
diff --git a/ci/berrie/postgis_regress.sh b/ci/berrie/postgis_regress.sh
index 68a618b2f..da44178e9 100644
--- a/ci/berrie/postgis_regress.sh
+++ b/ci/berrie/postgis_regress.sh
@@ -13,6 +13,14 @@ export CONFIG_FILE="$CUR_DIR/configs.sh"
 echo $PATH
 echo $WORKSPACE
+pg_stop()
+	if [ -n "${PGDATA:-}" ] && test -s "${PGDATA}/postmaster.pid"; then
+		"${PGPATH}/bin/pg_ctl" stop -D "${PGDATA}" -s -m fast || true
+	fi
+trap pg_stop EXIT
 sh autogen.sh
 ./configure --with-pgconfig=${PGPATH}/bin/pg_config \
   --with-geosconfig=${GEOS_PATH}/bin/geos-config \
@@ -29,7 +37,4 @@ err_status=$?
 make garden
 err_status=$?
-if [ -d $PGDATA/postmaster.pid ] ; then
-fi
 exit $err_status
diff --git a/ci/berrie64/pg_init_start.sh b/ci/berrie64/pg_init_start.sh
index 8b855dff3..39e2049d5 100644
--- a/ci/berrie64/pg_init_start.sh
+++ b/ci/berrie64/pg_init_start.sh
@@ -17,16 +17,16 @@ DAEMON="$PGPATH/bin/pg_ctl -D $PGDATA -o '-F' -l logfile start"
-    if [ -d $PGDATA/postmaster.pid] ; then
     fi;
-    rm -rf $PGDATA
+    rm -rf "$PGDATA"
 fi;
 #initialize cluster
-$PGPATH/bin/initdb
 $DAEMON &
diff --git a/ci/berrie64/postgis_regress.sh b/ci/berrie64/postgis_regress.sh
index 5eb3952a9..003d4119e 100644
--- a/ci/berrie64/postgis_regress.sh
+++ b/ci/berrie64/postgis_regress.sh
 . $CONFIG_FILE
 echo $PATH
+pg_stop()
+	fi
+trap pg_stop EXIT
 cd ${WORKSPACE}/PostGIS_Worker_Run/label/${label}/$BRANCH
 sh autogen.sh
@@ -34,7 +42,4 @@ utils/check_all_upgrades.sh \
 err_status=$?
-fi
 exit $err_status
Summary of changes:
 ci/berrie/pg_init_start.sh     | 10 +++++-----
 ci/berrie/postgis_regress.sh   | 11 ++++++++---
 ci/berrie64/pg_init_start.sh   | 10 +++++-----
 ci/berrie64/postgis_regress.sh | 11 ++++++++---
 4 files changed, 26 insertions(+), 16 deletions(-)
hooks/post-receive
