[SCM] PostGIS branch stable-3.6 updated. 3.6.4-85-gebf8f43a5
git at osgeo.org
git at osgeo.org
Wed Jul 22 23:23:03 PDT 2026
the project "PostGIS".
The branch, stable-3.6 has been updated
via ebf8f43a55c86b1f6b1fab1ccac1ca04c262404a (commit)
from 4d17da017d2269263f8c77cc5218b4a58c022fd3 (commit)
revisions in full, below.
commit ebf8f43a55c86b1f6b1fab1ccac1ca04c262404a
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Wed Jul 22 23:23:02 2026 -0700
ci: stop Berrie PostgreSQL after regressions (!486)
Companion/backport of the Berrie/Berrie64 Jenkins cleanup from master PR #485 for `stable-3.6`.
stable-3.6 currently has a stale-fail Berrie worker row on build 8009, and this branch has the same cleanup bug as master.
The Berrie scripts were testing `$PGDATA/postmaster.pid` as a directory, and Berrie64 also had the bracket typo in that test. The regress scripts use `set -e`, so failures could skip the final shutdown and leave stale PostgreSQL state for the next worker run.
This patch changes the running-cluster check to a non-empty `postmaster.pid`, keeps the branch-specific stable script lines, and adds an `EXIT` trap so failed regressions still stop PostgreSQL.
Checks:
- `bash -n ci/berrie/pg_init_start.sh ci/berrie/postgis_regress.sh ci/berrie64/pg_init_start.sh ci/berrie64/postgis_regress.sh`
- `git diff --check`
- `shellcheck` with the pre-existing Jenkins-script style/noise warnings excluded
Co-authored-by: Darafei Praliaskouski <me at komzpa.net>
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/486
diff --git a/ci/berrie/pg_init_start.sh b/ci/berrie/pg_init_start.sh
index 759930391..f17399176 100644
--- a/ci/berrie/pg_init_start.sh
+++ b/ci/berrie/pg_init_start.sh
@@ -16,16 +16,16 @@ DAEMON="$PGPATH/bin/pg_ctl -D $PGDATA -o '-F' -l logfile start"
PGCTL="$PGPATH/bin/pg_ctl"
# remove cluster if exists
-if [ -d $PGDATA ] ; then
- if [ -d $PGDATA/postmaster.pid ] ; then
- $PGCTL stop -D $PGDATA -s -m fast
+if [ -d "$PGDATA" ] ; then
+ if test -s "$PGDATA/postmaster.pid" ; then
+ "$PGCTL" stop -D "$PGDATA" -s -m fast
fi;
- rm -rf $PGDATA
+ rm -rf "$PGDATA"
fi;
#initialize cluster
-$PGPATH/bin/initdb
+"$PGPATH/bin/initdb"
echo -n "Starting PostgreSQL: "
$DAEMON &
diff --git a/ci/berrie/postgis_regress.sh b/ci/berrie/postgis_regress.sh
index dda1678f5..50c837300 100644
--- a/ci/berrie/postgis_regress.sh
+++ b/ci/berrie/postgis_regress.sh
@@ -13,6 +13,14 @@ export CONFIG_FILE="$CUR_DIR/configs.sh"
echo $PATH
echo $WORKSPACE
+pg_stop()
+ if [ -n "${PGDATA:-}" ] && test -s "${PGDATA}/postmaster.pid"; then
+ "${PGPATH}/bin/pg_ctl" stop -D "${PGDATA}" -s -m fast || true
+ fi
+trap pg_stop EXIT
sh autogen.sh
./configure --with-pgconfig=${PGPATH}/bin/pg_config \
--with-geosconfig=${GEOS_PATH}/bin/geos-config \
@@ -31,7 +39,4 @@ err_status=$?
#make garden
#err_status=$?
-if [ -d $PGDATA/postmaster.pid ] ; then
-fi
exit $err_status
diff --git a/ci/berrie64/pg_init_start.sh b/ci/berrie64/pg_init_start.sh
index 2a295d119..7e0c4cd5f 100644
--- a/ci/berrie64/pg_init_start.sh
+++ b/ci/berrie64/pg_init_start.sh
@@ -17,16 +17,16 @@ DAEMON="$PGPATH/bin/pg_ctl -D $PGDATA -o '-F' -l logfile start"
- if [ -d $PGDATA/postmaster.pid] ; then
fi;
- rm -rf $PGDATA
+ rm -rf "$PGDATA"
fi;
#initialize cluster
-$PGPATH/bin/initdb
$DAEMON &
diff --git a/ci/berrie64/postgis_regress.sh b/ci/berrie64/postgis_regress.sh
index 35221bb3d..7bbd3dd69 100644
--- a/ci/berrie64/postgis_regress.sh
+++ b/ci/berrie64/postgis_regress.sh
. $CONFIG_FILE
echo $PATH
+pg_stop()
+ fi
+trap pg_stop EXIT
sh autogen.sh
./configure --with-pgconfig=${PGPATH}/bin/pg_config --with-geosconfig=${GEOS_PATH}/bin/geos-config --with-library-minor-version \
--without-interrupt-tests --prefix=${PGPATH}
@@ -33,7 +41,4 @@ utils/check_all_upgrades.sh \
err_status=$?
-fi
exit $err_status
Summary of changes:
ci/berrie/pg_init_start.sh | 10 +++++-----
ci/berrie/postgis_regress.sh | 11 ++++++++---
ci/berrie64/pg_init_start.sh | 10 +++++-----
ci/berrie64/postgis_regress.sh | 11 ++++++++---
4 files changed, 26 insertions(+), 16 deletions(-)
hooks/post-receive
