[SCM] PostGIS branch master updated. 3.7.0beta1-10-g705f2d999
Wed Jul 22 23:22:50 PDT 2026
the project "PostGIS".
       via  705f2d999f4379b6f37ea03d7d590f6e00d1d191 (commit)
      from  3acbc94c2ea3f6e13744fd7628fe23a217375e0a (commit)
revisions in full, below.
commit 705f2d999f4379b6f37ea03d7d590f6e00d1d191
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Wed Jul 22 23:22:48 2026 -0700
    ci: stop Berrie PostgreSQL after regressions (!485)
    The Berrie/Berrie64 Jenkins scripts were trying to decide whether PostgreSQL was running by testing `$PGDATA/postmaster.pid` as a directory. Berrie64 also had the bracket typo in that test. That means a failed run can leave a PostgreSQL cluster behind, and the next run can be poisoned by stale server state.
    This changes those checks to look for a non-empty `postmaster.pid`, quotes the stop/remove/initdb paths while touching those lines, and installs an `EXIT` trap in the regress scripts so `set -e` failures still stop PostgreSQL.
    Observed failure this is aimed at: PostGIS_Worker_Run `label=berrie` build 8024 on master failed during the extension raster loader phase with `could not access file "$libdir/postgis_raster-3.7"`, followed by a `psql: not found` cascade, while the source scripts showed the stale-cluster cleanup bug above.
    Checks:
    - `bash -n ci/berrie/pg_init_start.sh ci/berrie/postgis_regress.sh ci/berrie64/pg_init_start.sh ci/berrie64/postgis_regress.sh`
    - `git diff --check`
    - `shellcheck` with the pre-existing style/noise warnings excluded
    Co-authored-by: Darafei Praliaskouski <me at komzpa.net>
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/485
diff --git a/ci/berrie/pg_init_start.sh b/ci/berrie/pg_init_start.sh
index 759930391..f17399176 100644
--- a/ci/berrie/pg_init_start.sh
+++ b/ci/berrie/pg_init_start.sh
@@ -16,16 +16,16 @@ DAEMON="$PGPATH/bin/pg_ctl -D $PGDATA -o '-F' -l logfile start"
 PGCTL="$PGPATH/bin/pg_ctl"
 # remove cluster if exists
-if [ -d $PGDATA ] ; then
-    if [ -d $PGDATA/postmaster.pid ] ; then
-    	$PGCTL stop -D $PGDATA -s -m fast
+if [ -d "$PGDATA" ] ; then
+    if test -s "$PGDATA/postmaster.pid" ; then
+        "$PGCTL" stop -D "$PGDATA" -s -m fast
     fi;
-    rm -rf $PGDATA
+    rm -rf "$PGDATA"
 fi;
 #initialize cluster
-$PGPATH/bin/initdb
+"$PGPATH/bin/initdb"
 echo -n "Starting PostgreSQL: "
 $DAEMON &
diff --git a/ci/berrie/postgis_regress.sh b/ci/berrie/postgis_regress.sh
index 426cc52d8..8bdffe300 100644
--- a/ci/berrie/postgis_regress.sh
+++ b/ci/berrie/postgis_regress.sh
@@ -13,6 +13,14 @@ export CONFIG_FILE="$CUR_DIR/configs.sh"
 echo $PATH
 echo $WORKSPACE
+pg_stop()
+	if [ -n "${PGDATA:-}" ] && test -s "${PGDATA}/postmaster.pid"; then
+		"${PGPATH}/bin/pg_ctl" stop -D "${PGDATA}" -s -m fast || true
+	fi
+trap pg_stop EXIT
 sh autogen.sh
 ./configure --with-pgconfig=${PGPATH}/bin/pg_config \
   --with-geosconfig=${GEOS_PATH}/bin/geos-config \
@@ -32,7 +40,4 @@ err_status=$?
 #make garden
 #err_status=$?
-if [ -d $PGDATA/postmaster.pid ] ; then
-fi
 exit $err_status
diff --git a/ci/berrie64/pg_init_start.sh b/ci/berrie64/pg_init_start.sh
index 2a295d119..7e0c4cd5f 100644
--- a/ci/berrie64/pg_init_start.sh
+++ b/ci/berrie64/pg_init_start.sh
@@ -17,16 +17,16 @@ DAEMON="$PGPATH/bin/pg_ctl -D $PGDATA -o '-F' -l logfile start"
-    if [ -d $PGDATA/postmaster.pid] ; then
     fi;
-    rm -rf $PGDATA
+    rm -rf "$PGDATA"
 fi;
 #initialize cluster
-$PGPATH/bin/initdb
 $DAEMON &
diff --git a/ci/berrie64/postgis_regress.sh b/ci/berrie64/postgis_regress.sh
index 01227c641..d9929fe18 100644
--- a/ci/berrie64/postgis_regress.sh
+++ b/ci/berrie64/postgis_regress.sh
 . $CONFIG_FILE
 echo $PATH
+pg_stop()
+	fi
+trap pg_stop EXIT
 sh autogen.sh
 ./configure --with-pgconfig=${PGPATH}/bin/pg_config --with-geosconfig=${GEOS_PATH}/bin/geos-config --with-library-minor-version \
     --without-interrupt-tests --prefix=${PGPATH}
@@ -36,7 +44,4 @@ utils/check_all_upgrades.sh \
 err_status=$?
-fi
 exit $err_status
Summary of changes:
 ci/berrie/pg_init_start.sh     | 10 +++++-----
 ci/berrie/postgis_regress.sh   | 11 ++++++++---
 ci/berrie64/pg_init_start.sh   | 10 +++++-----
 ci/berrie64/postgis_regress.sh | 11 ++++++++---
 4 files changed, 26 insertions(+), 16 deletions(-)
hooks/post-receive
