[SCM] PostGIS branch master updated. 3.7.0beta1-12-g435127bbb
Thu Jul 23 08:56:38 PDT 2026
the project "PostGIS".
       via  435127bbbbb1196881abeb3a4a74fb704a636144 (commit)
      from  7538038dc5e255a033f3664dfad038311e771e17 (commit)
revisions in full, below.
commit 435127bbbbb1196881abeb3a4a74fb704a636144
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Thu Jul 23 08:56:36 2026 -0700
    ci: show Woodpecker child workflow failures (!495)
    The CI dashboard already names non-success Jenkins matrix children. Woodpecker was still reported as one opaque row, which made the current master push failure look like a whole Woodpecker failure even though pipeline 5430 has exactly one killed child workflow: regress/18 on the quarantined runner.
    This patch fetches the selected Woodpecker pipeline detail, summarizes non-success child workflows in the row message, and links directly to the child workflow when there is exactly one. Duplicate workflow names are disambiguated with the Woodpecker pid, e.g. regress/18.
    Co-authored-by: Darafei Praliaskouski <me at komzpa.net>
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/495
diff --git a/utils/ci-status.py b/utils/ci-status.py
index 6410cafc5..8ba4cf87c 100755
--- a/utils/ci-status.py
+++ b/utils/ci-status.py
@@ -382,6 +382,72 @@ def woodpecker_matches_branch(build, check, branch):
     return build.get("ref") in (None, expected_ref)
+def woodpecker_workflow_label(workflow, duplicate_names):
+    name = workflow.get("name") or f"workflow {workflow.get('pid') or workflow.get('id')}"
+    pid = workflow.get("pid")
+    if pid is not None and name in duplicate_names:
+        return f"{name}/{pid}"
+    return name
+def woodpecker_workflow_url(web_url, pipeline, workflow):
+    if not web_url or not pipeline.get("number") or workflow.get("pid") is None:
+        return None
+    return f"{web_url}/pipeline/{pipeline['number']}/{workflow['pid']}"
+def woodpecker_pipeline_detail_url(api_url, pipeline):
+    if not pipeline.get("number"):
+        return None
+    return f"{api_url.rstrip('/')}/{pipeline['number']}"
+def woodpecker_workflow_details(pipeline, web_url):
+    workflows = pipeline.get("workflows") or []
+    if not workflows:
+        return None
+    name_counts = {}
+    for workflow in workflows:
+        name_counts[name] = name_counts.get(name, 0) + 1
+    duplicate_names = {name for name, count in name_counts.items() if count > 1}
+    buckets = [
+        ("failed", []),
+        ("running", []),
+        ("unknown", []),
+    by_bucket = dict(buckets)
+    for workflow in sorted(workflows, key=lambda item: item.get("pid") or item.get("id") or 0):
+        status = normalize_woodpecker_status(workflow.get("state") or workflow.get("status"))
+        if status == SUCCESS:
+            continue
+        label = woodpecker_workflow_label(workflow, duplicate_names)
+        if status == FAILURE:
+            by_bucket["failed"].append((label, workflow))
+        elif status == IN_PROGRESS:
+            by_bucket["running"].append((label, workflow))
+        else:
+            by_bucket["unknown"].append((label, workflow))
+    parts = []
+    non_success = []
+    for heading, items in buckets:
+        if not items:
+            continue
+        labels = [label for label, workflow in items]
+        parts.append(f"{heading}: {', '.join(labels)}")
+        non_success.extend(workflow for label, workflow in items)
+    if not parts:
+        return None
+    details = {"message": "; ".join(parts)}
+    if len(non_success) == 1:
+        details["url"] = woodpecker_workflow_url(web_url, pipeline, non_success[0])
+    return details
 def woodpecker_check(check, branch, timeout):
     query = urllib.parse.urlencode({
         "branch": branch["name"],
@@ -404,6 +470,18 @@ def woodpecker_check(check, branch, timeout):
     run_url = current.get("link") or current.get("url")
     if not run_url and web_url and current.get("number"):
         run_url = f"{web_url}/pipeline/{current['number']}"
+    detail_url = woodpecker_pipeline_detail_url(api_url, current)
+    if detail_url and "workflows" not in current:
+        try:
+            current = {**current, **http_json(detail_url, timeout=timeout)}
+        except RECOVERABLE_PROVIDER_ERRORS:
+            pass
+    message = current.get("message")
+    if normalize_woodpecker_status(current.get("status")) != SUCCESS:
+        details = woodpecker_workflow_details(current, web_url)
+        if details:
+            message = details["message"]
+            run_url = details.get("url") or run_url
     result = make_result(
         check,
         branch,
@@ -412,7 +490,7 @@ def woodpecker_check(check, branch, timeout):
         debug_url=url,
         revision=current.get("commit"),
         completed_at=current.get("finished") or current.get("updated") or current.get("created"),
-        message=current.get("message"),
+        message=message,
     if previous:
         result.update(previous_fields(normalize_woodpecker_status(previous.get("status")), previous))
diff --git a/utils/test_ci_status.py b/utils/test_ci_status.py
index 5401aaeab..efdac188c 100644
--- a/utils/test_ci_status.py
+++ b/utils/test_ci_status.py
@@ -172,6 +172,79 @@ class RequiredFailureHtmlTest(unittest.TestCase):
         self.assertEqual("build 7808", result["message"])
         self.assertEqual("https://ci.example.test/job/PostGIS_Make_Dist/7808/", result["url"])
+    def test_woodpecker_failure_names_single_failed_workflow(self):
+        check_config = {
+            "name": "Woodpecker",
+            "provider": "woodpecker",
+            "required": True,
+            "api_url": "https://woodie.example.test/api/repos/30/pipelines",
+            "web_url": "https://woodie.example.test/repos/30",
+        branch = {"name": "master", "label": "master"}
+        pipeline = {
+            "number": 5430,
+            "event": "push",
+            "branch": "master",
+            "ref": "refs/heads/master",
+            "status": "killed",
+            "commit": "a" * 40,
+            "message": "opaque commit message",
+        pipeline_detail = {
+            **pipeline,
+            "workflows": [
+                {"pid": 1, "id": 24450, "name": "regress", "state": "success"},
+                {"pid": 18, "id": 24467, "name": "regress", "state": "killed"},
+                {"pid": 27, "id": 24476, "name": "tools", "state": "success"},
+        with mock.patch.object(CI_STATUS, "http_json", side_effect=([pipeline], pipeline_detail)) as http_json:
+            result = CI_STATUS.woodpecker_check(check_config, branch, timeout=5)
+        self.assertEqual(CI_STATUS.FAILURE, result["status"])
+        self.assertEqual("failed: regress/18", result["message"])
+        self.assertEqual("https://woodie.example.test/repos/30/pipeline/5430/18", result["url"])
+        self.assertEqual("a" * 40, result["revision"])
+        self.assertEqual(
+            "https://woodie.example.test/api/repos/30/pipelines/5430",
+            http_json.call_args_list[1].args[0],
+    def test_woodpecker_running_workflows_are_summarized(self):
+        check_config = {
+            "required": True,
+        branch = {"name": "stable-3.6", "label": "3.6"}
+        pipeline = {
+            "number": 5434,
+            "event": "pull_request",
+            "branch": "stable-3.6",
+            "ref": "refs/heads/stable-3.6",
+            "status": "running",
+            "commit": "b" * 40,
+            "workflows": [
+                {"pid": 1, "id": 24484, "name": "docs", "state": "success"},
+                {"pid": 2, "id": 24485, "name": "regress", "state": "running"},
+                {"pid": 3, "id": 24486, "name": "tools", "state": "success"},
+        with mock.patch.object(CI_STATUS, "http_json", return_value=[pipeline]):
+                {**check_config, "event": "pull_request"},
+                branch,
+                timeout=5,
+        self.assertEqual(CI_STATUS.IN_PROGRESS, result["status"])
+        self.assertEqual("running: regress", result["message"])
+        self.assertEqual("https://woodie.example.test/repos/30/pipeline/5434/2", result["url"])
     def test_stale_summary_distinguishes_passed_and_failed(self):
         branch = {
             "name": "stable-synthetic",
Summary of changes:
 utils/ci-status.py      | 80 ++++++++++++++++++++++++++++++++++++++++++++++++-
 utils/test_ci_status.py | 73 ++++++++++++++++++++++++++++++++++++++++++++
 2 files changed, 152 insertions(+), 1 deletion(-)
hooks/post-receive
