[SCM] PostGIS branch master updated. 3.7.0beta1-14-gdcae3e42e
git at osgeo.org
git at osgeo.org
Thu Jul 23 12:59:48 PDT 2026
the project "PostGIS".
via dcae3e42e53bec92c265846f8656997afed5b35e (commit)
via 38d228b76268fcc1ce35faf1c4581a6e0efde7ca (commit)
from 435127bbbbb1196881abeb3a4a74fb704a636144 (commit)
revisions in full, below.
commit dcae3e42e53bec92c265846f8656997afed5b35e
Merge: 435127bbb 38d228b76
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Thu Jul 23 12:59:46 2026 -0700
Merge pull request 'ci: prefer current Jenkins queue entries' (!497) from Komzpa/postgis:ci/jenkins-current-queue-status-20260723 into master
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/497
commit 38d228b76268fcc1ce35faf1c4581a6e0efde7ca
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Thu Jul 23 21:10:44 2026 +0400
diff --git a/utils/ci-status.py b/utils/ci-status.py
index 8ba4cf87c..66fb9ac2f 100755
--- a/utils/ci-status.py
+++ b/utils/ci-status.py
@@ -764,6 +764,31 @@ def jenkins_queue_item_matches(item, job_url, check, branch):
return any(value == expected for name, value in params.items() if name == branch_parameter or name.lower() == branch_parameter.lower())
+def queued_jenkins_revision(item):
+ params = jenkins_parameters(item)
+ for name in ("after", "BRANCH", "commit", "GIT_COMMIT"):
+ value = params.get(name)
+ if value and len(value) == 40 and all(ch in "0123456789abcdefABCDEF" for ch in value):
+ return value
+ return None
+def jenkins_queue_item_rank(item, branch):
+ revision = queued_jenkins_revision(item)
+ is_current = False
+ if revision:
+ for ref in branch_compare_refs(branch):
+ distance = git_commit_distance(revision, ref)
+ if distance == 0:
+ is_current = True
+ break
+ return (
+ 0 if is_current else 1,
+ -(item.get("inQueueSince") or 0),
+ item.get("id") or 0,
def jenkins_queued_check(check, branch, job_url, timeout):
if not check.get("branch_parameter"):
return None
@@ -776,7 +801,7 @@ def jenkins_queued_check(check, branch, job_url, timeout):
return None
if not queued:
return None
- item = sorted(queued, key=lambda value: value.get("inQueueSince") or 0)[0]
+ item = sorted(queued, key=lambda value: jenkins_queue_item_rank(value, branch))[0]
message = f"queued item {item.get('id')}"
if item.get("why"):
diff --git a/utils/test_ci_status.py b/utils/test_ci_status.py
index efdac188c..c775daa84 100644
--- a/utils/test_ci_status.py
+++ b/utils/test_ci_status.py
@@ -172,6 +172,61 @@ class RequiredFailureHtmlTest(unittest.TestCase):
self.assertEqual("build 7808", result["message"])
self.assertEqual("https://ci.example.test/job/PostGIS_Make_Dist/7808/", result["url"])
+ def test_jenkins_queue_prefers_current_branch_revision(self):
+ check_config = {
+ "name": "Jenkins / Berrie",
+ "provider": "jenkins",
+ "required": True,
+ "job_url": "https://ci.example.test/job/PostGIS_Worker_Run/label=berrie/",
+ "branch_parameter": "reference",
+ branch = {
+ "name": "master",
+ "label": "master",
+ old_revision = "7" * 40
+ current_revision = "4" * 40
+ queued = [
+ "id": 108699,
+ "task": {"url": "https://ci.example.test/job/PostGIS_Worker_Run/"},
+ "why": "Build #8,030 is already in progress",
+ "inQueueSince": 1784820000000,
+ "actions": [{"parameters": [
+ {"name": "reference", "value": "refs/heads/master"},
+ {"name": "after", "value": old_revision},
+ "id": 108746,
+ "inQueueSince": 1784821000000,
+ {"name": "after", "value": current_revision},
+ def fake_distance(revision, ref):
+ return 0 if revision == current_revision else 26
+ with (
+ mock.patch.object(CI_STATUS, "jenkins_queue_items", return_value=queued),
+ mock.patch.object(CI_STATUS, "git_commit_distance", side_effect=fake_distance),
+ result = CI_STATUS.jenkins_queued_check(
+ check_config,
+ branch,
+ "https://ci.example.test/job/PostGIS_Worker_Run/label=berrie/",
+ timeout=5,
+ self.assertEqual(CI_STATUS.IN_PROGRESS, result["status"])
+ self.assertEqual(current_revision, result["revision"])
+ self.assertEqual("queued item 108746: Build #8,030 is already in progress", result["message"])
def test_woodpecker_failure_names_single_failed_workflow(self):
check_config = {
"name": "Woodpecker",
Summary of changes:
utils/ci-status.py | 27 +++++++++++++++++++++++-
utils/test_ci_status.py | 55 +++++++++++++++++++++++++++++++++++++++++++++++++
2 files changed, 81 insertions(+), 1 deletion(-)
hooks/post-receive
