[SCM] PostGIS branch stable-3.2 updated. 3.2.10-81-g15c7d6378
Fri Jul 24 03:10:55 PDT 2026
the project "PostGIS".
The branch, stable-3.2 has been updated
       via  15c7d6378e5de6629a392495ac226513bdfd8752 (commit)
       via  de31a859edbd348d3ffa7627ea7011c2352738d8 (commit)
      from  184fc31b65e84cffba35bf54bcb9e0cc265ff0cd (commit)
revisions in full, below.
commit 15c7d6378e5de6629a392495ac226513bdfd8752
Merge: 184fc31b6 de31a859e
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Fri Jul 24 03:10:53 2026 -0700
    Merge pull request 'Fix PostgreSQL 19 SFCGAL builds on stable 3.2' (!499) from Komzpa/postgis:fix/sfcgal-pqsignal-stable32-20260724 into stable-3.2
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/499
commit de31a859edbd348d3ffa7627ea7011c2352738d8
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Fri Jul 24 12:44:55 2026 +0400
    Backpatch the SFCGAL part of 0b003a82991bf05022ab1b924b5f8e1e407cd043 to avoid relying on pqsignal() returning the previous handler. New PostgreSQL headers expose pqsignal() as void, which breaks Worker_Run builds on older stable branches.
    References https://trac.osgeo.org/postgis/ticket/5841
diff --git a/NEWS b/NEWS
index 083a5d913..6c6396e6d 100644
--- a/NEWS
+++ b/NEWS
@@ -25,6 +25,7 @@ PostGIS 3.2.11
    GDAL compatibility (Darafei Praliaskouski)
  - GH-895, Qualify pg_class lookup during SRID/PROJ validation
+ - Fix PostgreSQL 19 SFCGAL builds (Paul Ramsey)
  - GH-897, [topology] Harden topology helper functions and
    maintenance SQL against identifier, tolerance, bigint, and cleanup
    regressions (Darafei Praliaskouski)
diff --git a/sfcgal/lwgeom_sfcgal.c b/sfcgal/lwgeom_sfcgal.c
index 3e3729bc5..995b89ccd 100644
--- a/sfcgal/lwgeom_sfcgal.c
+++ b/sfcgal/lwgeom_sfcgal.c
@@ -31,22 +31,12 @@
 #include "utils/elog.h"
 #include "utils/guc.h"
-#include "libpq/pqsignal.h"
 #include "../liblwgeom/liblwgeom.h"
  * This is required for builds against pgsql
 PG_MODULE_MAGIC;
-#ifdef WIN32
-static void interruptCallback() {
-  if (UNBLOCKED_SIGNAL_QUEUE())
-    pgwin32_dispatch_queued_signals();
-#endif
-static pqsigfunc coreIntHandler = 0;
-static void handleInterrupt(int sig);
  * Module load callback
@@ -55,16 +45,8 @@ void _PG_init(void);
 void
 _PG_init(void)
-  coreIntHandler = pqsignal(SIGINT, handleInterrupt);
-#ifdef WIN32
-  GEOS_interruptRegisterCallback(interruptCallback);
-  lwgeom_register_interrupt_callback(interruptCallback);
-#endif
-    /* install PostgreSQL handlers */
-    pg_install_lwgeom_handlers();
+	/* install PostgreSQL handlers */
+	pg_install_lwgeom_handlers();
@@ -74,27 +56,7 @@ void _PG_fini(void);
 void
 _PG_fini(void)
-  elog(NOTICE, "Goodbye from PostGIS SFCGAL %s", POSTGIS_VERSION);
-  pqsignal(SIGINT, coreIntHandler);
-static void
-handleInterrupt(int sig)
-  /* NOTE: printf here would be dangerous, see
-   * https://trac.osgeo.org/postgis/ticket/3644
-   * TODO: block interrupts during execution, to fix the problem
-  /* printf("Interrupt requested\n"); fflush(stdout); */
-  /* request interruption of liblwgeom as well */
-  lwgeom_request_interrupt();
-  if ( coreIntHandler ) {
-    (*coreIntHandler)(sig);
+	elog(NOTICE, "Goodbye from PostGIS SFCGAL %s", POSTGIS_VERSION);
 Datum postgis_sfcgal_version(PG_FUNCTION_ARGS);
Summary of changes:
 NEWS                   |  1 +
 sfcgal/lwgeom_sfcgal.c | 44 +++-----------------------------------------
 2 files changed, 4 insertions(+), 41 deletions(-)
hooks/post-receive
