[SCM] PostGIS branch stable-3.3 updated. 3.3.10-87-g27f4d3304
Fri Jul 24 03:11:03 PDT 2026
the project "PostGIS".
The branch, stable-3.3 has been updated
       via  27f4d3304b832ba82ef257b4412d9142be47c132 (commit)
       via  6a0ff1711d61853d52ee82a7c7de89620a8f38d9 (commit)
      from  dd5f18e59eb69953a625ebce5c13889856df2540 (commit)
revisions in full, below.
commit 27f4d3304b832ba82ef257b4412d9142be47c132
Merge: dd5f18e59 6a0ff1711
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Fri Jul 24 03:11:02 2026 -0700
    Merge pull request 'Fix PostgreSQL 19 SFCGAL builds on stable 3.3' (!498) from Komzpa/postgis:fix/sfcgal-pqsignal-stable33-20260724 into stable-3.3
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/498
commit 6a0ff1711d61853d52ee82a7c7de89620a8f38d9
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Fri Jul 24 12:44:55 2026 +0400
    Backpatch the SFCGAL part of 0b003a82991bf05022ab1b924b5f8e1e407cd043 to avoid relying on pqsignal() returning the previous handler. New PostgreSQL headers expose pqsignal() as void, which breaks Worker_Run builds on older stable branches.
    References https://trac.osgeo.org/postgis/ticket/5841
diff --git a/NEWS b/NEWS
index dedcfa402..08f31397d 100644
--- a/NEWS
+++ b/NEWS
@@ -24,6 +24,7 @@ PostGIS 3.3.11
  - GH-895, Qualify pg_class lookup during SRID/PROJ validation
    (Darafei Praliaskouski)
  - Fix PostgreSQL 19 GeoJSON output builds (Regina Obe)
+ - Fix PostgreSQL 19 SFCGAL builds (Paul Ramsey)
  - GH-897, [topology] Harden topology helper functions and
    maintenance SQL against identifier, tolerance, bigint, and cleanup
    regressions (Darafei Praliaskouski)
diff --git a/sfcgal/lwgeom_sfcgal.c b/sfcgal/lwgeom_sfcgal.c
index 041f9d034..215e2202a 100644
--- a/sfcgal/lwgeom_sfcgal.c
+++ b/sfcgal/lwgeom_sfcgal.c
@@ -32,22 +32,12 @@
 #include "utils/elog.h"
 #include "utils/guc.h"
-#include "libpq/pqsignal.h"
 #include "../liblwgeom/liblwgeom.h"
  * This is required for builds against pgsql
 PG_MODULE_MAGIC;
-#ifdef WIN32
-static void interruptCallback() {
-  if (UNBLOCKED_SIGNAL_QUEUE())
-    pgwin32_dispatch_queued_signals();
-#endif
-static pqsigfunc coreIntHandler = 0;
-static void handleInterrupt(int sig);
  * Module load callback
@@ -56,16 +46,8 @@ void _PG_init(void);
 void
 _PG_init(void)
-  coreIntHandler = pqsignal(SIGINT, handleInterrupt);
-#ifdef WIN32
-  GEOS_interruptRegisterCallback(interruptCallback);
-  lwgeom_register_interrupt_callback(interruptCallback);
-#endif
-    /* install PostgreSQL handlers */
-    pg_install_lwgeom_handlers();
+	/* install PostgreSQL handlers */
+	pg_install_lwgeom_handlers();
@@ -75,27 +57,7 @@ void _PG_fini(void);
 void
 _PG_fini(void)
-  elog(NOTICE, "Goodbye from PostGIS SFCGAL %s", POSTGIS_VERSION);
-  pqsignal(SIGINT, coreIntHandler);
-static void
-handleInterrupt(int sig)
-  /* NOTE: printf here would be dangerous, see
-   * https://trac.osgeo.org/postgis/ticket/3644
-   * TODO: block interrupts during execution, to fix the problem
-  /* printf("Interrupt requested\n"); fflush(stdout); */
-  /* request interruption of liblwgeom as well */
-  lwgeom_request_interrupt();
-  if ( coreIntHandler ) {
-    (*coreIntHandler)(sig);
+	elog(NOTICE, "Goodbye from PostGIS SFCGAL %s", POSTGIS_VERSION);
 Datum postgis_sfcgal_version(PG_FUNCTION_ARGS);
@@ -731,4 +693,3 @@ Datum sfcgal_optimalalphashape(PG_FUNCTION_ARGS)
 	PG_RETURN_POINTER(output);
 #endif
Summary of changes:
 NEWS                   |  1 +
 sfcgal/lwgeom_sfcgal.c | 45 +++------------------------------------------
 2 files changed, 4 insertions(+), 42 deletions(-)
hooks/post-receive
