[SCM] PostGIS branch master updated. 3.7.0beta1-16-g1ba934e1f
git at osgeo.org
git at osgeo.org
Fri Jul 24 03:35:36 PDT 2026
the project "PostGIS".
via 1ba934e1f8a48188d39f88757379885e4ee3ebc5 (commit)
via 1b5c8e6a8e4f7d73f7f149d18b03356bc00792fe (commit)
from dcae3e42e53bec92c265846f8656997afed5b35e (commit)
revisions in full, below.
commit 1ba934e1f8a48188d39f88757379885e4ee3ebc5
Merge: dcae3e42e 1b5c8e6a8
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Fri Jul 24 03:35:34 2026 -0700
Merge pull request 'ci: use newest Woodpecker pipeline in status' (!500) from Komzpa/postgis:ci/woodie-current-order-20260724 into master
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/500
commit 1b5c8e6a8e4f7d73f7f149d18b03356bc00792fe
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Fri Jul 24 14:29:54 2026 +0400
diff --git a/utils/ci-status.py b/utils/ci-status.py
index 66fb9ac2f..c06c99da8 100755
--- a/utils/ci-status.py
+++ b/utils/ci-status.py
@@ -382,6 +382,15 @@ def woodpecker_matches_branch(build, check, branch):
return build.get("ref") in (None, expected_ref)
+def woodpecker_build_sort_key(build):
+ return (
+ build.get("created") or build.get("created_at") or 0,
+ build.get("started") or build.get("started_at") or 0,
+ build.get("finished") or build.get("finished_at") or 0,
+ build.get("number") or 0,
def woodpecker_workflow_label(workflow, duplicate_names):
name = workflow.get("name") or f"workflow {workflow.get('pid') or workflow.get('id')}"
pid = workflow.get("pid")
@@ -396,6 +405,13 @@ def woodpecker_workflow_url(web_url, pipeline, workflow):
return f"{web_url}/pipeline/{pipeline['number']}/{workflow['pid']}"
+def woodpecker_pipeline_url(web_url, pipeline):
+ run_url = pipeline.get("link") or pipeline.get("url")
+ if not run_url and web_url and pipeline.get("number"):
+ run_url = f"{web_url}/pipeline/{pipeline['number']}"
+ return run_url
def woodpecker_pipeline_detail_url(api_url, pipeline):
if not pipeline.get("number"):
return None
@@ -464,12 +480,14 @@ def woodpecker_check(check, branch, timeout):
if not builds:
return make_result(check, branch, UNKNOWN, message="no Woodpecker builds found", debug_url=url)
+ builds = sorted(builds, key=woodpecker_build_sort_key, reverse=True)
current = builds[0]
- previous = next((build for build in builds[1:] if normalize_woodpecker_status(build.get("status")) not in (IN_PROGRESS, UNKNOWN)), None)
+ previous = next(
+ (build for build in builds[1:] if normalize_woodpecker_status(build.get("status")) not in (IN_PROGRESS, UNKNOWN)),
+ None,
web_url = check.get("web_url")
- run_url = current.get("link") or current.get("url")
- if not run_url and web_url and current.get("number"):
- run_url = f"{web_url}/pipeline/{current['number']}"
+ run_url = woodpecker_pipeline_url(web_url, current)
detail_url = woodpecker_pipeline_detail_url(api_url, current)
if detail_url and "workflows" not in current:
try:
@@ -493,6 +511,9 @@ def woodpecker_check(check, branch, timeout):
message=message,
if previous:
+ previous_url = woodpecker_pipeline_url(web_url, previous)
+ if previous_url and not (previous.get("link") or previous.get("url")):
+ previous = {**previous, "url": previous_url}
result.update(previous_fields(normalize_woodpecker_status(previous.get("status")), previous))
return result
diff --git a/utils/test_ci_status.py b/utils/test_ci_status.py
index c775daa84..e27147347 100644
--- a/utils/test_ci_status.py
+++ b/utils/test_ci_status.py
@@ -300,6 +300,49 @@ class RequiredFailureHtmlTest(unittest.TestCase):
self.assertEqual("running: regress", result["message"])
self.assertEqual("https://woodie.example.test/repos/30/pipeline/5434/2", result["url"])
+ def test_woodpecker_uses_newest_pipeline_when_api_order_is_unstable(self):
+ check_config = {
+ "name": "Woodpecker",
+ "provider": "woodpecker",
+ "required": True,
+ "api_url": "https://woodie.example.test/api/repos/30/pipelines",
+ "web_url": "https://woodie.example.test/repos/30",
+ branch = {"name": "stable-3.4", "label": "3.4"}
+ older_failed = {
+ "number": 5415,
+ "event": "push",
+ "branch": "stable-3.4",
+ "ref": "refs/heads/stable-3.4",
+ "status": "failure",
+ "commit": "5" * 40,
+ "created": 1784787793,
+ "started": 1784787796,
+ "finished": 1784794269,
+ "message": "older failed pipeline",
+ newer_success = {
+ "number": 5425,
+ "event": "push",
+ "status": "success",
+ "created": 1784806066,
+ "started": 1784806067,
+ "finished": 1784812852,
+ "message": "newer successful pipeline",
+ with mock.patch.object(CI_STATUS, "http_json", side_effect=([older_failed, newer_success], newer_success)):
+ result = CI_STATUS.woodpecker_check(check_config, branch, timeout=5)
+ self.assertEqual(CI_STATUS.SUCCESS, result["status"])
+ self.assertEqual("https://woodie.example.test/repos/30/pipeline/5425", result["url"])
+ self.assertEqual("newer successful pipeline", result["message"])
+ self.assertEqual(CI_STATUS.FAILURE, result["previous_completed_status"])
+ self.assertEqual("https://woodie.example.test/repos/30/pipeline/5415", result["previous_completed_url"])
def test_stale_summary_distinguishes_passed_and_failed(self):
branch = {
"name": "stable-synthetic",
Summary of changes:
utils/ci-status.py | 29 +++++++++++++++++++++++++----
utils/test_ci_status.py | 43 +++++++++++++++++++++++++++++++++++++++++++
2 files changed, 68 insertions(+), 4 deletions(-)
hooks/post-receive
