[SCM] postgis.net branch website updated. clarity-final-204-gff13b5c
git at osgeo.org
git at osgeo.org
Fri Jul 24 09:59:07 PDT 2026
the project "postgis.net".
The branch, website has been updated
via ff13b5c9a17b469dc58b8f0db4ea3b4dcd1db382 (commit)
via df2394a16b4e6c6aa56939a0445d245bbbe0b8fb (commit)
from f732f363caeef015aaaca1e07e9dc734ef549fe2 (commit)
revisions in full, below.
commit ff13b5c9a17b469dc58b8f0db4ea3b4dcd1db382
Merge: f732f36 df2394a
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Fri Jul 24 09:59:06 2026 -0700
Merge pull request 'build: publish website output atomically' (!12) from Komzpa/postgis.net:ci/atomic-public-publish-20260724 into website
Reviewed-on: https://gitea.osgeo.org/postgis/postgis.net/pulls/12
commit df2394a16b4e6c6aa56939a0445d245bbbe0b8fb
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Fri Jul 24 19:38:01 2026 +0400
diff --git a/.gitignore b/.gitignore
index 0e4a390..5cc7e96 100644
--- a/.gitignore
+++ b/.gitignore
@@ -1,4 +1,6 @@
public
+.public-releases/
+.public.next
/content/development/docs/
.hugo_build.lock
resources
diff --git a/Makefile b/Makefile
index 9241317..b111b72 100644
--- a/Makefile
+++ b/Makefile
@@ -1,7 +1,11 @@
.DEFAULT_GOAL := help
+# Keep workflows in short make targets: do not replace them with one-off shell
+# scripts, and split a target before its recipe grows into a screenful of shell.
POSTGIS ?= ../postgis
DOCS := content/development/docs
+PUBLIC ?= $(CURDIR)/public
.PHONY: help check check-releases publish site docs ci
@@ -14,11 +18,15 @@ check: check-releases ## Run all tests
check-releases: ## Check release checksums
utils/check_releases_md5.sh
-publish: site ci ## Build the site and CI status in parallel
- chown -R www-data:www-data public
+publish: ## Build the site and CI status, then atomically switch public
+ release="$(CURDIR)/.public-releases/public.$$(date -u +%Y%m%dT%H%M%SZ).$$$$"; \
+ $(MAKE) site ci PUBLIC="$$release" && \
+ chown -R www-data:www-data "$$release" && \
+ ln -sfn "$$release" "$(PUBLIC).next" && \
+ mv -Tf "$(PUBLIC).next" "$(PUBLIC)"
site: docs ## Build the Hugo site with developer docs
- hugo -D
+ hugo -D --destination "$(PUBLIC)"
docs: ## Copy developer docs from the PostGIS checkout
rm -rf "$(DOCS)"
@@ -30,4 +38,4 @@ ci: ## Generate the CI status page
cd "$(POSTGIS)" && python3 utils/ci-status.py \
--config utils/ci-status.json \
--format html \
- --output-dir "$(CURDIR)/public/ci"
+ --output-dir "$(PUBLIC)/ci"
diff --git a/README.md b/README.md
index d2af5f6..b47d62c 100644
--- a/README.md
+++ b/README.md
@@ -46,9 +46,11 @@ Run `make check` after changes, before push
## Production publishing
The build reads developer documentation and the CI-status generator from a
-sibling checkout of `postgis/postgis`. Generated files stay in `public/` and
-are not committed to this repository. `make -j publish` runs the Hugo and CI
-branches in parallel, then restores the ownership expected by nginx.
+sibling checkout of `postgis/postgis`. Generated files stay under
+`.public-releases/`, and the live `public` path is a symbolic link to the
+latest complete release. `make -j publish` builds Hugo and CI status into a new
+release directory, then switches the `public` symlink after both outputs are
+ready.
Create the source checkout once on Debbie:
@@ -65,7 +67,7 @@ Replace the current root cron entry:
with:
```cron
-*/5 * * * * cd /var/www/postgis_website && git clean -fdx && git pull --ff-only && git -C ../postgis pull --ff-only && make -j publish
+*/5 * * * * cd /var/www/postgis_website && git pull --ff-only && git -C ../postgis pull --ff-only && make -j publish
This also refreshes `/development/docs/` and `/ci/` when only the PostGIS
Summary of changes:
.gitignore | 2 ++
Makefile | 16 ++++++++++++----
README.md | 10 ++++++----
3 files changed, 20 insertions(+), 8 deletions(-)
hooks/post-receive
postgis.net
