[SCM] PostGIS branch master updated. 3.7.0beta1-21-ga9c631ff9
git at osgeo.org
git at osgeo.org
Fri Jul 24 12:39:37 PDT 2026
the project "PostGIS".
via a9c631ff91d5ed2f1bd94d4f978674a62d657185 (commit)
via 0ebac01d5f42edc1b16aecbb6ec80acc080c3766 (commit)
from 54bbfc720af0c81db5b972eda8eabff93a44b86a (commit)
revisions in full, below.
commit a9c631ff91d5ed2f1bd94d4f978674a62d657185
Merge: 54bbfc720 0ebac01d5
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Fri Jul 24 12:39:35 2026 -0700
Merge pull request 'Document Woodie pipeline approvals' (!505) from Komzpa/postgis:docs/woodie-api-approval-20260724 into master
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/505
commit 0ebac01d5f42edc1b16aecbb6ec80acc080c3766
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Fri Jul 24 22:57:15 2026 +0400
doc: describe Woodie pipeline approvals
diff --git a/doc/development/testing/ci.md b/doc/development/testing/ci.md
index bc27ffe0e..4fce30bf1 100644
--- a/doc/development/testing/ci.md
+++ b/doc/development/testing/ci.md
@@ -35,6 +35,45 @@ When a dashboard row describes dependency versions, operating systems, branch
coverage, or test modes, the row should be regenerated from those sources or
checked against them before publication.
+## Woodie API and Pipeline Approvals
+Use a Woodie personal access token for the Woodie API and
+[`woodpecker-cli`](https://woodpecker-ci.org/docs/cli). A Gitea access token is
+a separate credential and is not accepted by the Woodie API.
+Generate the token from the Woodie user page at
+<https://woodie.osgeo.org/user>. Do not print it, commit it, or put the literal
+value in shell history. Configure a named CLI context and verify the account
+before changing a pipeline:
+```bash
+read -rs WOODPECKER_TOKEN
+printf '\n'
+umask 077
+woodpecker-cli setup --context osgeo \
+ --server https://woodie.osgeo.org \
+ --token "$WOODPECKER_TOKEN"
+unset WOODPECKER_TOKEN
+woodpecker-cli context use osgeo
+woodpecker-cli info
+Before approving a blocked pipeline, inspect its API record at
+`/api/repos/<repo-id>/pipelines/<pipeline-number>`. Confirm the repository,
+pipeline number, commit, ref, event, and current state all match the pull request
+that needs approval. Approve only that pipeline:
+```sh
+woodpecker-cli pipeline show <repo-id-or-full-name> <pipeline-number>
+woodpecker-cli pipeline approve <repo-id-or-full-name> <pipeline-number>
+An accepted approval command is not a successful build. Read the pipeline back,
+verify that the reviewer and commit are unchanged, and wait for a terminal
+state. Check every required workflow and failed child step before reporting the
+pipeline as green or diagnosing a source failure.
## Badge Inventory Rules
For every badge entry, record enough metadata for another maintainer to verify
Summary of changes:
doc/development/testing/ci.md | 39 +++++++++++++++++++++++++++++++++++++++
1 file changed, 39 insertions(+)
hooks/post-receive
