[SCM] PostGIS branch master updated. 3.7.0beta1-23-ge44cfd9ac
git at osgeo.org
git at osgeo.org
Sat Jul 25 06:03:15 PDT 2026
the project "PostGIS".
via e44cfd9ac84eb4df25b6ca0faf155cbae4a11682 (commit)
via 9636cd98eb49bfab245ffc5e077de6af7ec99fd2 (commit)
from a9c631ff91d5ed2f1bd94d4f978674a62d657185 (commit)
revisions in full, below.
commit e44cfd9ac84eb4df25b6ca0faf155cbae4a11682
Merge: a9c631ff9 9636cd98e
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Sat Jul 25 06:03:13 2026 -0700
Merge pull request 'Cache successful CI checks at unchanged branch heads' (!507) from Komzpa/postgis:ci/current-success-cache-20260725 into master
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/507
commit 9636cd98eb49bfab245ffc5e077de6af7ec99fd2
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Sat Jul 25 16:46:35 2026 +0400
ci: cache successful checks at current branch head
diff --git a/utils/ci-status.json b/utils/ci-status.json
index 9f22524b2..7d7f45853 100644
--- a/utils/ci-status.json
+++ b/utils/ci-status.json
@@ -1,5 +1,6 @@
"stale_after_hours": 168,
+ "cache_head_remote": "https://gitea.osgeo.org/postgis/postgis.git",
"branches": [
{ "name": "master", "label": "master", "eol": false, "version": "3.7" },
{ "name": "stable-3.6", "label": "3.6", "eol": false, "version": "3.6" },
diff --git a/utils/ci-status.py b/utils/ci-status.py
index 7b12f6ddb..7d8f3f3cd 100755
--- a/utils/ci-status.py
+++ b/utils/ci-status.py
@@ -1119,6 +1119,113 @@ def result_from_exception(check, branch, exc):
return make_result(check, branch, UNKNOWN, message=str(exc), debug_url=debug_url)
+def index_status_cache(data):
+ if data is None:
+ return None
+ if not isinstance(data, dict) or not isinstance(data.get("branches"), list):
+ raise ConfigError("status cache must contain a branches array")
+ checks = {}
+ for branch in data["branches"]:
+ if not isinstance(branch, dict):
+ continue
+ branch_name = branch.get("name")
+ for result in branch.get("checks") or []:
+ if not isinstance(result, dict):
+ continue
+ check_name = result.get("check")
+ if branch_name and check_name:
+ checks[(branch_name, check_name)] = result
+ return {
+ "generated_at": data.get("generated_at"),
+ "checks": checks,
+def load_status_cache(path):
+ if not path:
+ return None
+ try:
+ with open(path, "r", encoding="utf-8") as handle:
+ return index_status_cache(json.load(handle))
+ except FileNotFoundError:
+ return None
+ except OSError as exc:
+ raise ConfigError(f"cannot read status cache {path}: {exc}") from exc
+ except json.JSONDecodeError as exc:
+ raise ConfigError(f"invalid JSON in status cache {path}: {exc}") from exc
+def resolve_cache_heads(config, work, cache, timeout):
+ if not cache:
+ return {}
+ remote = config.get("cache_head_remote")
+ if not remote:
+ return {}
+ branch_names = sorted({
+ branch["name"]
+ for branch, _check in work
+ if any(
+ cached.get("status") == SUCCESS
+ for (cached_branch, _cached_check), cached in cache["checks"].items()
+ if cached_branch == branch["name"]
+ if not branch_names:
+ return {}
+ refs = [f"refs/heads/{name}" for name in branch_names]
+ try:
+ completed = subprocess.run(
+ ["git", "ls-remote", "--exit-code", "--heads", remote, *refs],
+ check=True,
+ capture_output=True,
+ text=True,
+ timeout=timeout,
+ except (OSError, subprocess.CalledProcessError, subprocess.TimeoutExpired):
+ return {}
+ heads = {}
+ wanted = set(refs)
+ for line in completed.stdout.splitlines():
+ fields = line.split()
+ if len(fields) != 2 or fields[1] not in wanted:
+ continue
+ heads[fields[1].removeprefix("refs/heads/")] = fields[0]
+ return heads
+def cached_success_result(branch, check, cache, cache_heads):
+ if not cache:
+ return None
+ cached = cache["checks"].get((branch["name"], check["name"]))
+ if not cached or cached.get("status") != SUCCESS:
+ return None
+ if cached.get("branch") != branch["name"] or cached.get("check") != check["name"]:
+ return None
+ if cached.get("provider") != check.get("provider"):
+ return None
+ if cached.get("required") != bool(check.get("required", True)):
+ return None
+ revision = cached.get("revision")
+ if not revision or revision != cache_heads.get(branch["name"]):
+ return None
+ result = dict(cached)
+ result.update({
+ "branch": branch["name"],
+ "branch_label": branch["label"],
+ "check": check["name"],
+ "provider": check.get("provider"),
+ "required": bool(check.get("required", True)),
+ "cached": True,
+ "cached_at": cache.get("generated_at"),
+ message = result.get("message") or "successful run"
+ suffix = " (cached; unchanged revision)"
+ result["message"] = message if message.endswith(suffix) else f"{message}{suffix}"
+ return result
def stale_after_hours(config, check):
value = check.get("stale_after_hours", config.get("stale_after_hours"))
if value is None:
@@ -1191,12 +1298,16 @@ def default_concurrency():
return min(32, max(1, os.cpu_count() or 1))
-async def collect_status_async(config, selected_branch=None, include_eol=False, timeout=30):
+async def collect_status_async(config, selected_branch=None, include_eol=False, timeout=30, cache=None):
work = list(branch_checks(config, selected_branch, include_eol))
+ cache_heads = await asyncio.to_thread(resolve_cache_heads, config, work, cache, timeout)
semaphore = asyncio.Semaphore(min(default_concurrency(), max(1, len(work))))
def collect_one(item):
branch, check = item
+ cached = cached_success_result(branch, check, cache, cache_heads)
+ if cached:
+ return apply_staleness(cached, config, check)
provider = PROVIDERS.get(check.get("provider"))
if provider is None:
raise ConfigError(f"unsupported provider for {check['name']}: {check.get('provider')}")
@@ -1213,8 +1324,8 @@ async def collect_status_async(config, selected_branch=None, include_eol=False,
return aggregate(config, results)
-def collect_status(config, selected_branch=None, include_eol=False, timeout=30):
- return asyncio.run(collect_status_async(config, selected_branch, include_eol, timeout))
+def collect_status(config, selected_branch=None, include_eol=False, timeout=30, cache=None):
+ return asyncio.run(collect_status_async(config, selected_branch, include_eol, timeout, cache))
def aggregate(config, results):
@@ -2290,6 +2401,10 @@ def parse_args(argv):
parser.add_argument("--config", default=str(pathlib.Path(__file__).with_suffix(".json")))
parser.add_argument("--format", choices=("terminal", "json", "html"), default="terminal", help="output format")
parser.add_argument("--output-dir", default="ci-status")
+ parser.add_argument(
+ "--cache",
+ help="reuse successful results from this status.json when their revision is still the branch head",
"--atomic-switch",
action="store_true",
@@ -2316,7 +2431,8 @@ def main(argv=None):
args = parse_args(sys.argv[1:] if argv is None else argv)
try:
config = load_config(args.config)
- data = collect_status(config, args.branch, args.include_eol, args.timeout)
+ cache = load_status_cache(args.cache)
+ data = collect_status(config, args.branch, args.include_eol, args.timeout, cache)
if args.format == "html":
write_html_output(data, args.output_dir, atomic_switch=args.atomic_switch)
return 0
diff --git a/utils/test_ci_status.py b/utils/test_ci_status.py
index 0953686a8..877fbc0ae 100644
--- a/utils/test_ci_status.py
+++ b/utils/test_ci_status.py
@@ -1,6 +1,7 @@
import importlib.util
import json
import pathlib
+import subprocess
import tempfile
import unittest
from unittest import mock
@@ -43,6 +44,232 @@ def html_data():
class RequiredFailureHtmlTest(unittest.TestCase):
+ def test_current_success_cache_skips_provider(self):
+ config = {
+ "branches": [{"name": "master", "label": "master"}],
+ "checks": [{
+ "name": "Synthetic CI",
+ "provider": "synthetic",
+ "required": True,
+ cached_result = {
+ "branch": "master",
+ "branch_label": "master",
+ "check": "Synthetic CI",
+ "required": True,
+ "status": CI_STATUS.SUCCESS,
+ "revision": "a" * 40,
+ "message": "build 7",
+ cache = CI_STATUS.index_status_cache({
+ "generated_at": "2026-07-25T12:00:00+00:00",
+ "branches": [{
+ "name": "master",
+ "checks": [cached_result],
+ provider = mock.Mock()
+ with (
+ mock.patch.dict(CI_STATUS.PROVIDERS, {"synthetic": provider}),
+ mock.patch.object(
+ CI_STATUS,
+ "resolve_cache_heads",
+ return_value={"master": "a" * 40},
+ data = CI_STATUS.collect_status(config, cache=cache)
+ provider.assert_not_called()
+ result = data["branches"][0]["checks"][0]
+ self.assertEqual(CI_STATUS.SUCCESS, result["status"])
+ self.assertTrue(result["cached"])
+ self.assertEqual("2026-07-25T12:00:00+00:00", result["cached_at"])
+ self.assertEqual("build 7 (cached; unchanged revision)", result["message"])
+ def test_cache_does_not_hide_new_revision_result(self):
+ config = {
+ "checks": [{
+ "required": True,
+ "branches": [{
+ "name": "master",
+ "checks": [{
+ "required": True,
+ live_result = check("Synthetic CI", CI_STATUS.FAILURE)
+ live_result.update({"branch": "master", "branch_label": "master"})
+ provider = mock.Mock(return_value=live_result)
+ with (
+ CI_STATUS,
+ return_value={"master": "b" * 40},
+ provider.assert_called_once()
+ self.assertEqual(CI_STATUS.FAILURE, data["branches"][0]["checks"][0]["status"])
+ def test_cache_rejects_non_success_revisionless_and_changed_provider_results(self):
+ config = {
+ "checks": [{
+ "required": True,
+ branch = config["branches"][0]
+ check_config = config["checks"][0]
+ base = {
+ "required": True,
+ rejected = [
+ {**base, "status": CI_STATUS.FAILURE},
+ {**base, "status": CI_STATUS.IN_PROGRESS},
+ {**base, "status": CI_STATUS.UNKNOWN},
+ {key: value for key, value in base.items() if key != "revision"},
+ {**base, "branch": "stable-3.6"},
+ {**base, "check": "Other CI"},
+ {**base, "provider": "other"},
+ {**base, "required": False},
+ for cached in rejected:
+ with self.subTest(cached=cached):
+ "branches": [{"name": "master", "checks": [cached]}],
+ self.assertIsNone(
+ CI_STATUS.cached_success_result(
+ branch,
+ check_config,
+ cache,
+ {"master": "a" * 40},
+ def test_cache_uses_fresh_remote_head_not_stale_local_ref(self):
+ config = {
+ "checks": [{
+ "required": True,
+ "branches": [{
+ "name": "master",
+ "checks": [{
+ "required": True,
+ with (
+ mock.patch.object(CI_STATUS, "git_commit_distance", return_value=0),
+ CI_STATUS,
+ def test_cache_head_lookup_queries_remote_once_for_all_branches(self):
+ config = {"cache_head_remote": "https://example.test/postgis.git"}
+ branches = [
+ {"name": "master", "label": "master"},
+ {"name": "stable-3.6", "label": "3.6"},
+ work = [(branch, {"name": "Synthetic CI"}) for branch in branches]
+ "branches": [
+ "name": branch["name"],
+ "checks": [{
+ for branch in branches
+ completed = subprocess.CompletedProcess(
+ args=[],
+ returncode=0,
+ stdout=(
+ f"{'a' * 40}\trefs/heads/master\n"
+ f"{'b' * 40}\trefs/heads/stable-3.6\n"
+ stderr="",
+ with mock.patch.object(CI_STATUS.subprocess, "run", return_value=completed) as run:
+ heads = CI_STATUS.resolve_cache_heads(config, work, cache, timeout=7)
+ self.assertEqual({"master": "a" * 40, "stable-3.6": "b" * 40}, heads)
+ run.assert_called_once_with(
+ "git",
+ "ls-remote",
+ "--exit-code",
+ "--heads",
+ "https://example.test/postgis.git",
+ "refs/heads/master",
+ "refs/heads/stable-3.6",
+ check=True,
+ text=True,
+ timeout=7,
+ def test_missing_optional_status_cache_starts_empty(self):
+ with tempfile.TemporaryDirectory() as tmpdir:
+ missing = pathlib.Path(tmpdir) / "status.json"
+ self.assertIsNone(CI_STATUS.load_status_cache(missing))
def test_woodpecker_covers_supported_release_branches(self):
config = json.loads(MODULE_PATH.with_suffix(".json").read_text(encoding="utf-8"))
woodpecker = next(check for check in config["checks"] if check["name"] == "Woodpecker")
Summary of changes:
utils/ci-status.json | 1 +
utils/ci-status.py | 124 +++++++++++++++++++++++++-
utils/test_ci_status.py | 227 ++++++++++++++++++++++++++++++++++++++++++++++++
3 files changed, 348 insertions(+), 4 deletions(-)
hooks/post-receive
