[SCM] PostGIS branch master updated. 3.7.0beta1-29-ga76515485
git at osgeo.org
git at osgeo.org
Sat Jul 25 10:37:42 PDT 2026
the project "PostGIS".
via a7651548538b35cc78bfa3a654b31db0a908daae (commit)
via 315484a1f854d265fa03879c624a8687dfc2564a (commit)
via 122e00fa08f0fed8db2fc1f2771f1f442130853a (commit)
from 17935ee71e12df9b315b171d2d080c7a16aa7193 (commit)
revisions in full, below.
commit a7651548538b35cc78bfa3a654b31db0a908daae
Merge: 17935ee71 315484a1f
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Sat Jul 25 10:37:41 2026 -0700
Merge pull request 'Fail early when extension scripts need a newer PostGIS library' (!504) from Komzpa/postgis:codex/create-extension-version-mismatch into master
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/504
commit 315484a1f854d265fa03879c624a8687dfc2564a
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Sat Jul 25 19:03:00 2026 +0400
test: verify complete upgrade pass-through statements
diff --git a/utils/check_create_upgrade_replaced_function_errors.sh b/utils/check_create_upgrade_replaced_function_errors.sh
index cc0fbf075..321c7f917 100644
--- a/utils/check_create_upgrade_replaced_function_errors.sh
+++ b/utils/check_create_upgrade_replaced_function_errors.sh
@@ -18,6 +18,15 @@ SELECT check_upgrade_guard(
'3.7.0dev',
postgis_lib_version()
+SELECT discarded_without_upgrade_pass_through();
+SQL
+cat > "${TMPDIR}/expected-pass-through.sql" <<'SQL'
+-- Upgrade pass-through
+SELECT check_upgrade_guard(
+ '3.7.0dev',
+ postgis_lib_version()
SQL
"${PERL:-perl}" "${srcdir:-.}/create_upgrade.pl" "${TMPDIR}/postgis.sql" > "${TMPDIR}/upgrade.sql"
@@ -32,6 +41,14 @@ grep -Fq \
"retry SELECT postgis_extensions_upgrade()" \
-grep -Fq \
- "SELECT check_upgrade_guard(" \
- "${TMPDIR}/upgrade.sql"
+sed -n \
+ '/^-- Upgrade pass-through$/,/^);$/p' \
+ "${TMPDIR}/upgrade.sql" > "${TMPDIR}/actual-pass-through.sql"
+diff -u \
+ "${TMPDIR}/expected-pass-through.sql" \
+ "${TMPDIR}/actual-pass-through.sql"
+if grep -Fq "discarded_without_upgrade_pass_through" "${TMPDIR}/upgrade.sql"; then
+ echo "ERROR: unmarked top-level statement leaked into upgrade SQL" >&2
+ exit 1
+fi
commit 122e00fa08f0fed8db2fc1f2771f1f442130853a
Date: Fri Jul 24 22:46:59 2026 +0400
Fix CREATE EXTENSION with older PostGIS library
diff --git a/NEWS b/NEWS
index 1a986a230..d0f8c33e2 100644
--- a/NEWS
+++ b/NEWS
@@ -8,6 +8,9 @@ These are only changes since 3.7.0beta1.
* Bug Fixes *
+ - GT-504, Report extension script/library version mismatches before loading
+ functions unavailable in an older library (Darafei Praliaskouski)
* Enhancements *
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 9b19145b9..2cea4c384 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -61,6 +61,81 @@ BEGIN
END
$$ LANGUAGE 'plpgsql';
+CREATE OR REPLACE FUNCTION _postgis_scripts_version_cmp_key(ver text)
+ RETURNS int[]
+ AS $$
+ DECLARE
+ ver_match text[];
+ BEGIN
+ ver_match := pg_catalog.regexp_match(
+ pg_catalog.lower(ver),
+ E'^([0-9]+)\\.([0-9]+)\\.([0-9]+)(dev|alpha|beta|rc)?([0-9]*)([^0-9a-z].*)?$'
+ IF ver_match IS NULL THEN
+ RETURN NULL;
+ END IF;
+ RETURN ARRAY[
+ ver_match[1]::int,
+ ver_match[2]::int,
+ ver_match[3]::int,
+ CASE coalesce(ver_match[4], '')
+ WHEN 'dev' THEN 0
+ WHEN 'alpha' THEN 1
+ WHEN 'beta' THEN 2
+ WHEN 'rc' THEN 3
+ ELSE 4
+ END,
+ CASE coalesce(ver_match[5], '')
+ WHEN '' THEN 0
+ ELSE ver_match[5]::int
+ END
+ EXCEPTION WHEN OTHERS THEN
+ RETURN NULL;
+ END
+ LANGUAGE 'plpgsql' IMMUTABLE STRICT;
+CREATE OR REPLACE FUNCTION postgis_lib_version() RETURNS text
+ AS 'MODULE_PATHNAME'
+ LANGUAGE 'c' IMMUTABLE; -- a new lib will require a new session
+CREATE OR REPLACE FUNCTION _postgis_check_library_version(
+ scripts_version text,
+ library_version text
+ RETURNS boolean
+ AS $$
+ DECLARE
+ scripts_key int[];
+ library_key int[];
+ BEGIN
+ scripts_key := @extschema at ._postgis_scripts_version_cmp_key(scripts_version);
+ library_key := @extschema at ._postgis_scripts_version_cmp_key(library_version);
+ -- Shared-library compatibility follows the major.minor release line.
+ -- Micro versions and postfixes do not establish C-symbol availability.
+ IF library_key[1:2] < scripts_key[1:2]
+ THEN
+ RAISE EXCEPTION
+ 'PostGIS extension scripts version % cannot use older library version %',
+ scripts_version,
+ library_version
+ USING HINT =
+ 'Install matching PostGIS shared-library and extension-script packages, reconnect, and retry.';
+ END IF;
+ RETURN true;
+ END
+SELECT @extschema at ._postgis_check_library_version(
+ POSTGIS_LIB_VERSION,
+ @extschema at .postgis_lib_version()
-- Let the user know about a deprecated signature and its new name, if any
CREATE OR REPLACE FUNCTION _postgis_deprecate(oldname text, newname text, version text)
@@ -3143,52 +3218,12 @@ CREATE OR REPLACE FUNCTION postgis_scripts_installed() RETURNS text
AS _POSTGIS_SQL_SELECT_POSTGIS_SCRIPTS_VERSION
LANGUAGE 'sql' IMMUTABLE;
-CREATE OR REPLACE FUNCTION postgis_lib_version() RETURNS text
- AS 'MODULE_PATHNAME'
- LANGUAGE 'c' IMMUTABLE; -- a new lib will require a new session
-- NOTE: from 1.1.0 to 1.5.x this was the same of postgis_lib_version()
-- NOTE: from 2.0.0 up it includes postgis revision
CREATE OR REPLACE FUNCTION postgis_scripts_released() RETURNS text
-CREATE OR REPLACE FUNCTION _postgis_scripts_version_cmp_key(ver text)
- RETURNS int[]
- AS $$
- DECLARE
- ver_match text[];
- BEGIN
- ver_match := pg_catalog.regexp_match(
- pg_catalog.lower(ver),
- E'^([0-9]+)\\.([0-9]+)\\.([0-9]+)(dev|alpha|beta|rc)?([0-9]*)([^0-9a-z].*)?$'
- IF ver_match IS NULL THEN
- RETURN NULL;
- END IF;
- RETURN ARRAY[
- ver_match[1]::int,
- ver_match[2]::int,
- ver_match[3]::int,
- CASE coalesce(ver_match[4], '')
- WHEN 'dev' THEN 0
- WHEN 'alpha' THEN 1
- WHEN 'beta' THEN 2
- WHEN 'rc' THEN 3
- ELSE 4
- END,
- CASE coalesce(ver_match[5], '')
- WHEN '' THEN 0
- ELSE ver_match[5]::int
- END
- EXCEPTION WHEN OTHERS THEN
- RETURN NULL;
- END
- LANGUAGE 'plpgsql' IMMUTABLE STRICT;
CREATE OR REPLACE FUNCTION postgis_geos_version() RETURNS text
diff --git a/regress/core/postgis_full_version.sql b/regress/core/postgis_full_version.sql
index 5cbc5d9ed..4cbba626f 100644
--- a/regress/core/postgis_full_version.sql
+++ b/regress/core/postgis_full_version.sql
@@ -1,5 +1,38 @@
BEGIN;
+SELECT 'matching_library',
+ _postgis_check_library_version('3.7.0beta1', '3.7.0beta1');
+SELECT 'newer_library',
+ _postgis_check_library_version('3.6.4', '3.7.0beta1');
+SELECT 'dev_library_with_prerelease_scripts',
+ _postgis_check_library_version('3.7.0beta1', '3.7.0dev');
+SELECT 'dev_library_with_final_scripts',
+ _postgis_check_library_version('3.7.0', '3.7.0dev');
+SELECT 'dev_scripts_with_final_library',
+ _postgis_check_library_version('3.7.0dev', '3.7.0');
+SELECT 'same_minor_micro_versions',
+ _postgis_check_library_version('3.7.1', '3.7.0');
+SELECT 'same_minor_official_suffixes',
+ _postgis_check_library_version('3.7.0beta1', '3.7.0alpha1');
+DO $$
+DECLARE
+ error_hint text;
+BEGIN
+ PERFORM _postgis_check_library_version('3.7.0beta1', '3.6.4');
+EXCEPTION WHEN raise_exception THEN
+ GET STACKED DIAGNOSTICS error_hint = PG_EXCEPTION_HINT;
+ RAISE NOTICE '%', SQLERRM;
+ RAISE NOTICE 'HINT: %', error_hint;
+END
DO $$
BEGIN
IF NOT EXISTS (
diff --git a/regress/core/postgis_full_version_expected b/regress/core/postgis_full_version_expected
index 8e3e2c8cd..56d2c9a3b 100644
--- a/regress/core/postgis_full_version_expected
+++ b/regress/core/postgis_full_version_expected
@@ -1,3 +1,12 @@
+matching_library|t
+newer_library|t
+dev_library_with_prerelease_scripts|t
+dev_library_with_final_scripts|t
+dev_scripts_with_final_library|t
+same_minor_micro_versions|t
+same_minor_official_suffixes|t
+NOTICE: PostGIS extension scripts version 3.7.0beta1 cannot use older library version 3.6.4
+NOTICE: HINT: Install matching PostGIS shared-library and extension-script packages, reconnect, and retry.
topology_old_scripts|t
topology_newer_scripts|t
raster_newer_scripts|t
index df9ebe224..cc0fbf075 100644
@@ -13,6 +13,11 @@ cat > "${TMPDIR}/postgis.sql" <<'SQL'
CREATE OR REPLACE FUNCTION ST_Test(geometry, float8 DEFAULT 0.0) RETURNS geometry
AS 'MODULE_PATHNAME', 'ST_Test'
LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE;
+ '3.7.0dev',
SQL
@@ -26,3 +31,7 @@ grep -Fq \
grep -Fq \
+grep -Fq \
+ "SELECT check_upgrade_guard(" \
diff --git a/utils/create_upgrade.pl b/utils/create_upgrade.pl
index 22d24a52d..14959cfa0 100644
--- a/utils/create_upgrade.pl
+++ b/utils/create_upgrade.pl
@@ -197,6 +197,25 @@ while(<INPUT>)
next;
+ # Preserve explicitly marked top-level statements that must run in both
+ # install and upgrade scripts.
+ if ( $comment =~ /^\-\- Upgrade pass-through\s*$/m )
+ print $comment;
+ print;
+ while ( !/;\s*$/ )
+ $_ = <INPUT>;
+ die "ERROR: unterminated upgrade pass-through statement\n"
+ if !defined;
+ print;
+ $comment = '';
+ next;
# Allow through deprecations from postgis_drop.sql
@@ -1067,4 +1086,3 @@ BEGIN
END
LANGUAGE 'plpgsql';
Summary of changes:
NEWS | 3 +
postgis/postgis.sql.in | 115 ++++++++++++++-------
regress/core/postgis_full_version.sql | 33 ++++++
regress/core/postgis_full_version_expected | 9 ++
...heck_create_upgrade_replaced_function_errors.sh | 26 +++++
utils/create_upgrade.pl | 20 +++-
6 files changed, 165 insertions(+), 41 deletions(-)
hooks/post-receive
