[SCM] PostGIS branch master updated. 3.7.0beta1-31-g27401e11d
git at osgeo.org
git at osgeo.org
Sat Jul 25 12:59:26 PDT 2026
the project "PostGIS".
via 27401e11d8fa480fd15943d86b07868a1b2469ec (commit)
via 93ff644491c0bf66d40969d22315b8268c2e60fa (commit)
from a7651548538b35cc78bfa3a654b31db0a908daae (commit)
revisions in full, below.
commit 27401e11d8fa480fd15943d86b07868a1b2469ec
Merge: a76515485 93ff64449
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Sat Jul 25 12:59:25 2026 -0700
Merge pull request 'test: run NEWS checker through POSIX shell' (!509) from Komzpa/postgis:codex/msys-check-news-portability into master
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/509
commit 93ff644491c0bf66d40969d22315b8268c2e60fa
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Sat Jul 25 23:48:26 2026 +0400
diff --git a/utils/test_check_news.py b/utils/test_check_news.py
index 093126115..da364cb68 100644
--- a/utils/test_check_news.py
+++ b/utils/test_check_news.py
@@ -1,10 +1,12 @@
#!/usr/bin/env python3
import os
+import shutil
import subprocess
import tempfile
import textwrap
import unittest
+from unittest import mock
from pathlib import Path
@@ -29,6 +31,30 @@ PostGIS 3.9.0
+def msys_shell_path(path):
+ text = str(path)
+ if os.name == "nt":
+ text = text.replace("\\", "/")
+ if len(text) >= 3 and text[1] == ":" and text[2] == "/":
+ return f"/{text[0].lower()}{text[2:]}"
+ return text
+def posix_shell():
+ shell = shutil.which("sh")
+ if shell is None:
+ raise unittest.SkipTest("NEWS unit tests require a POSIX sh on PATH")
+ return shell
+def check_news_command(script, repo, base_ref=None):
+ command = [posix_shell(), msys_shell_path(script)]
+ if base_ref is not None:
+ command.append(f"--base-ref={base_ref}")
+ command.append(msys_shell_path(repo))
+ return command
class NewsFixture:
def __init__(self):
self.temporary_directory = tempfile.TemporaryDirectory()
@@ -60,16 +86,12 @@ class NewsFixture:
def check_news(self, base_ref=None, environment_base_ref=None):
- command = [str(CHECK_NEWS)]
- if base_ref is not None:
- command.append(f"--base-ref={base_ref}")
- command.append(str(self.repo))
environment = os.environ.copy()
environment.pop("NEWS_CHECK_BASE_REF", None)
if environment_base_ref is not None:
environment["NEWS_CHECK_BASE_REF"] = environment_base_ref
return subprocess.run(
- command,
+ check_news_command(CHECK_NEWS, self.repo, base_ref),
env=environment,
text=True,
capture_output=True,
@@ -291,11 +313,11 @@ class NewsValidationTest(unittest.TestCase):
).stdout.strip(),
result = subprocess.run(
- str(CHECK_NEWS),
- "--base-ref=refs/news-check/target",
- str(clone),
+ CHECK_NEWS,
+ clone,
+ "refs/news-check/target",
text=True,
@@ -308,5 +330,29 @@ class NewsValidationTest(unittest.TestCase):
self.assertIn("does not resolve to a commit", result.stdout)
+class NewsShellInvocationTest(unittest.TestCase):
+ def test_check_news_command_uses_posix_shell_interpreter(self):
+ command = check_news_command(CHECK_NEWS, Path("/tmp/news-repo"), "main")
+ # On a native Windows interpreter the script path is rewritten for the
+ # MSYS2 shell, so compare against the same translation the command uses.
+ self.assertEqual(posix_shell(), command[0])
+ self.assertEqual(msys_shell_path(CHECK_NEWS), command[1])
+ self.assertEqual("--base-ref=main", command[2])
+ self.assertEqual("/tmp/news-repo", command[3])
+ def test_native_windows_paths_are_rewritten_for_msys_shell(self):
+ with mock.patch("os.name", "nt"):
+ self.assertEqual(
+ "/d/a/postgis/postgis",
+ msys_shell_path(r"D:\a\postgis\postgis"),
+ def test_missing_posix_shell_is_reported_as_unittest_skip(self):
+ with mock.patch("shutil.which", return_value=None):
+ with self.assertRaisesRegex(unittest.SkipTest, "POSIX sh"):
+ check_news_command(CHECK_NEWS, Path("/tmp/news-repo"))
if __name__ == "__main__":
unittest.main()
Summary of changes:
utils/test_check_news.py | 66 ++++++++++++++++++++++++++++++++++++++++--------
1 file changed, 56 insertions(+), 10 deletions(-)
hooks/post-receive
