[SCM] PostGIS branch master updated. 3.7.0beta1-33-g2828d83f1
Sat Jul 25 13:00:22 PDT 2026
the project "PostGIS".
       via  2828d83f168795684505a9191e537c75764c04b1 (commit)
       via  40aeacee02de887eb4460c316793f7c81df4e9d9 (commit)
      from  27401e11d8fa480fd15943d86b07868a1b2469ec (commit)
revisions in full, below.
commit 2828d83f168795684505a9191e537c75764c04b1
Merge: 27401e11d 40aeacee0
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Sat Jul 25 13:00:21 2026 -0700
    Merge pull request 'ci: retry Docker build image pulls' (!510) from Komzpa/postgis:codex/ci-docker-pull-retry into master
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/510
commit 40aeacee02de887eb4460c316793f7c81df4e9d9
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Sat Jul 25 23:49:16 2026 +0400
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index 990cae333..e62f529bf 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -51,8 +51,28 @@ jobs:
     - name: 'Prepare Image'
       run: |
         set -e
+        retry() {
+          max_attempts="$1"
+          delay="$2"
+          shift 2
+          attempt=1
+          while true; do
+            "$@" && return 0
+            status="$?"
+            if test "$attempt" -ge "$max_attempts"; then
+              echo "Command failed after ${attempt} attempts: $*"
+              return "$status"
+            fi
+            echo "Command failed with exit code ${status}; retrying in ${delay}s (${attempt}/${max_attempts}): $*"
+            sleep "$delay"
+            attempt=$((attempt + 1))
+          done
         uname -a
-        echo "FROM postgis/postgis-build-env:${{ matrix.ci.tag }}" > Dockerfile
+        build_image="postgis/postgis-build-env:${{ matrix.ci.tag }}"
+        retry 3 15 docker pull "${build_image}"
+        echo "FROM ${build_image}" > Dockerfile
         if test "${{ matrix.ci.mode }}" = "garden"; then
           echo "USER root" >> Dockerfile
           echo "RUN apt-get update && apt-get install -y --no-install-recommends python3 proj-bin && rm -rf /var/lib/apt/lists/*" >> Dockerfile
@@ -61,7 +81,7 @@ jobs:
         fi
         echo "ADD --chown=postgres:postgres . /src/postgis" >> Dockerfile
         echo "CMD bash ci/github/run_${{ matrix.ci.mode }}.sh" >> Dockerfile
-        docker build -t pgtest .
+        docker build --pull=false -t pgtest .
     - name: 'Build & Test'
       run: |
Summary of changes:
 .github/workflows/ci.yml | 24 ++++++++++++++++++++++--
 1 file changed, 22 insertions(+), 2 deletions(-)
hooks/post-receive
