[SCM] PostGIS branch master updated. 3.7.0beta1-35-gbd8b9aaad
Sat Jul 25 13:28:15 PDT 2026
the project "PostGIS".
       via  bd8b9aaad3b776a6891262655f5709b82873f075 (commit)
       via  63bab1fa8c20b82566485f38b883f6c608bc51b2 (commit)
      from  2828d83f168795684505a9191e537c75764c04b1 (commit)
revisions in full, below.
commit bd8b9aaad3b776a6891262655f5709b82873f075
Merge: 2828d83f1 63bab1fa8
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Sat Jul 25 13:28:13 2026 -0700
    Merge pull request 'ci: retire stale badge inventory entries' (!513) from Komzpa/postgis:codex/ci-badge-inventory-audit into master
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/513
commit 63bab1fa8c20b82566485f38b883f6c608bc51b2
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Sun Jul 26 00:17:11 2026 +0400
diff --git a/doc/development/testing/ci.md b/doc/development/testing/ci.md
index 4fce30bf1..1e10da445 100644
--- a/doc/development/testing/ci.md
+++ b/doc/development/testing/ci.md
@@ -106,8 +106,9 @@ Update the inventory when any of these change:
   should have badges.
 Use `utils/ci-trac-line.sh` when maintaining the Trac badge table or a copied
-badge inventory. Fetch or export the current Trac table into a temporary file
-before using `--check` or `--replace`:
+badge inventory. The generated row covers the maintained repository-owned
+status inventory and omits retired mirror badges. Fetch or export the current
+Trac table into a temporary file before using `--check` or `--replace`:
 ```sh
 utils/ci-trac-line.sh 3.7
diff --git a/utils/ci-status.json b/utils/ci-status.json
index 7d7f45853..9d4713c3f 100644
--- a/utils/ci-status.json
+++ b/utils/ci-status.json
@@ -172,21 +172,21 @@
       "provider": "disabled",
       "required": false,
       "status": "retired",
-      "message": "Cirrus coverage was replaced by repository GitHub Actions FreeBSD and macOS workflows."
+      "message": "Cirrus coverage was replaced by repository GitHub Actions FreeBSD and macOS workflows; the retired api.cirrus-ci.com badge endpoint now fails TLS instead of returning a usable status."
       "name": "GitLab mirror",
       "required": false,
-      "message": "The GitLab.com mirror is out of CI minutes, so release gating uses GitHub Actions, Woodie, and Jenkins."
+      "message": "The GitLab.com mirror badge endpoint still resolves, but mirror jobs fail immediately with ci_quota_exceeded, so release gating uses GitHub Actions, Woodie, and Jenkins."
       "name": "INAF GitLab mirror",
       "required": false,
-      "message": "The INAF GitLab mirror is stale and no longer provides a current release-gating signal."
+      "message": "The INAF GitLab mirror badge endpoint still resolves, but its pipelines are stale failed mirror results and no longer provide a current release-gating signal."
diff --git a/utils/ci-trac-line.sh b/utils/ci-trac-line.sh
index c6208be34..769c824d5 100755
--- a/utils/ci-trac-line.sh
+++ b/utils/ci-trac-line.sh
@@ -31,10 +31,7 @@ generate_row()
 || [[Image(https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run/label=bessie&build=last:\${params.reference=refs/heads/${BRANCH}}, link=https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=bessie, alt=status, height="20", title='PG 18.4, GDAL 3.11.5, GEOS 3.14.1')]] || \\
 || [[Image(https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run/label=berrie&build=last:\${params.reference=refs/heads/${BRANCH}}, link=https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=berrie, alt=status, height="20", title='PG 12(branch), GDAL 2.4.0 branch, GEOS 3.7.1')]] || \\
 || [[Image(https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run/label=berrie64&build=last:\${params.reference=refs/heads/${BRANCH}}, link=https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=berrie64, alt=status, height="20", title='PG 12(branch), GDAL 2.4.0 branch, GEOS 3.7.1')]] || \\
-|| [[Image(https://github.com/postgis/postgis/actions/workflows/ci-freebsd.yml/badge.svg?branch=${BRANCH}, link=https://github.com/postgis/postgis/actions/workflows/ci-freebsd.yml?query=branch%3A${BRANCH}, alt=status, height="20", title='FreeBSD')]] || \\
-|| [[Image(https://github.com/postgis/postgis/actions/workflows/ci-macos.yml/badge.svg?branch=${BRANCH}, link=https://github.com/postgis/postgis/actions/workflows/ci-macos.yml?query=branch%3A${BRANCH}, alt=status, height="20", title='macOS')]] || \\
-|| [[Image(https://gitlab.com/postgis/postgis/badges/${BRANCH}/pipeline.svg, link=https://gitlab.com/postgis/postgis/-/commits/${BRANCH}, alt=status, height="20", title='32/64 bit trixie, PG 15, GDAL 2.4.0, GEOS 3.7.1, PROJ 5.2.0')]] || \\
-|| [[Image(https://www.ict.inaf.it/gitlab/postgis/postgis/badges/master/pipeline.svg?ref=refs/heads/${BRANCH}, link=https://www.ict.inaf.it/gitlab/postgis/postgis/-/commits/${BRANCH}, alt=inaf/${BRANCH})]] ||
+|| [[Image(https://github.com/postgis/postgis/actions/workflows/codeql.yml/badge.svg?branch=${BRANCH}, link=https://github.com/postgis/postgis/actions/workflows/codeql.yml?query=branch%3A${BRANCH}, alt=status, height="20", title='CodeQL')]] ||
 EOF
diff --git a/utils/test_ci_status.py b/utils/test_ci_status.py
index 877fbc0ae..c22a04fa7 100644
--- a/utils/test_ci_status.py
+++ b/utils/test_ci_status.py
@@ -286,6 +286,31 @@ class RequiredFailureHtmlTest(unittest.TestCase):
             woodpecker["branches"],
+    def test_retired_badges_record_current_non_gating_reason(self):
+        config = json.loads(MODULE_PATH.with_suffix(".json").read_text(encoding="utf-8"))
+        serialized = json.dumps(config)
+        self.assertNotIn("bessie32", serialized.lower())
+        checks = {check["name"]: check for check in config["checks"]}
+        self.assertIn("api.cirrus-ci.com", checks["Cirrus CI"]["message"])
+        self.assertIn("fails TLS", checks["Cirrus CI"]["message"])
+        self.assertIn("ci_quota_exceeded", checks["GitLab mirror"]["message"])
+        self.assertIn("badge endpoint still resolves", checks["GitLab mirror"]["message"])
+        self.assertIn("stale failed mirror results", checks["INAF GitLab mirror"]["message"])
+    def test_trac_row_helper_does_not_generate_retired_badges(self):
+        script = MODULE_PATH.with_name("ci-trac-line.sh")
+        row = subprocess.check_output([str(script), "3.7"], text=True)
+        self.assertNotIn("bessie32", row.lower())
+        self.assertNotIn("api.cirrus-ci.com", row)
+        self.assertNotIn("gitlab.com/postgis/postgis/badges", row)
+        self.assertNotIn("www.ict.inaf.it/gitlab/postgis/postgis/badges", row)
+        self.assertNotIn("ci-freebsd.yml", row)
+        self.assertNotIn("ci-macos.yml", row)
+        self.assertIn("codeql.yml", row)
     def test_apply_staleness_labels_passed_and_failed_results(self):
         config = {
             "stale_after_hours": 168,
Summary of changes:
 doc/development/testing/ci.md |  5 +++--
 utils/ci-status.json          |  6 +++---
 utils/ci-trac-line.sh         |  5 +----
 utils/test_ci_status.py       | 25 +++++++++++++++++++++++++
 4 files changed, 32 insertions(+), 9 deletions(-)
hooks/post-receive
