[SCM] PostGIS branch master updated. 3.7.0beta1-62-g4db1d75e0
Mon Jul 27 09:09:37 PDT 2026
the project "PostGIS".
       via  4db1d75e03357463c86703dc3fad39972d0ac60c (commit)
       via  b76210d7907abc3a7a4bf38b0dbf93194dde36a2 (commit)
      from  05b8993652abbc9894a0435b59573c7ad92636b5 (commit)
revisions in full, below.
commit 4db1d75e03357463c86703dc3fad39972d0ac60c
Merge: 05b899365 b76210d79
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Mon Jul 27 09:09:36 2026 -0700
    Merge pull request 'Guard raster band size calculations' (!556) from Komzpa/postgis:codex/raster-band-size-overflow-20260727 into master
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/556
commit b76210d7907abc3a7a4bf38b0dbf93194dde36a2
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Mon Jul 27 12:04:57 2026 +0400
diff --git a/raster/rt_core/rt_band.c b/raster/rt_core/rt_band.c
index cace34bfc..5d7117744 100644
--- a/raster/rt_core/rt_band.c
+++ b/raster/rt_core/rt_band.c
@@ -11,7 +11,7 @@
  * Copyright (C) 2009-2011 Pierre Racine <pierre.racine at sbf.ulaval.ca>
  * Copyright (C) 2009-2011 Mateusz Loskot <mateusz at loskot.net>
  * Copyright (C) 2008-2009 Sandro Santilli <strk at kbt.io>
- * Copyright (C) 2025 Darafei Praliaskouski <me at komzpa.net>
+ * Copyright (C) 2025-2026 Darafei Praliaskouski <me at komzpa.net>
  * This program is free software; you can redistribute it and/or
  * modify it under the terms of the GNU General Public License
@@ -119,9 +119,10 @@ rt_band_init_value(
 	rt_pixtype pixtype = band->pixtype;
 	uint32_t width = band->width;
 	uint32_t height = band->height;
-	uint32_t numval = width * height;
+	size_t numval = (size_t)width * height;
 	void *mem = band->data.mem;
-	size_t memsize = numval * rt_pixtype_size(pixtype);
+	int pixbytes = rt_pixtype_size(pixtype);
+	size_t memsize;
 	/* initialize to nodataval */
 	int32_t checkvalint = 0;
@@ -129,6 +130,13 @@ rt_band_init_value(
 	double checkvaldouble = 0;
 	float checkvalfloat = 0;
+	if (pixbytes < 1 || numval > SIZE_MAX / (size_t)pixbytes)
+		rterror("rt_band_init_value: Raster dimensions are too large for band initialization");
+		return;
+	memsize = numval * (size_t)pixbytes;
 	/* initialize to zero */
 	if (FLT_EQ(initval, 0.0)) {
 		memset(mem, 0, memsize);
@@ -140,7 +148,7 @@ rt_band_init_value(
 			uint8_t *ptr = mem;
 			uint8_t clamped_initval = rt_util_clamp_to_1BB(initval);
-			for (uint32_t i = 0; i < numval; i++)
+			for (size_t i = 0; i < numval; i++)
 				ptr[i] = clamped_initval;
 			checkvalint = ptr[0];
 			break;
@@ -149,7 +157,7 @@ rt_band_init_value(
 			uint8_t *ptr = mem;
 			uint8_t clamped_initval = rt_util_clamp_to_2BUI(initval);
 			break;
@@ -158,7 +166,7 @@ rt_band_init_value(
 			uint8_t *ptr = mem;
 			uint8_t clamped_initval = rt_util_clamp_to_4BUI(initval);
 			break;
@@ -167,7 +175,7 @@ rt_band_init_value(
 			int8_t *ptr = mem;
 			int8_t clamped_initval = rt_util_clamp_to_8BSI(initval);
 			break;
@@ -176,7 +184,7 @@ rt_band_init_value(
 			uint8_t *ptr = mem;
 			uint8_t clamped_initval = rt_util_clamp_to_8BUI(initval);
 			break;
@@ -185,7 +193,7 @@ rt_band_init_value(
 			int16_t *ptr = mem;
 			int16_t clamped_initval = rt_util_clamp_to_16BSI(initval);
 			break;
@@ -193,7 +201,7 @@ rt_band_init_value(
 		case PT_16BUI: {
 			uint16_t *ptr = mem;
 			uint16_t clamped_initval = rt_util_clamp_to_16BUI(initval);
 			break;
@@ -202,7 +210,7 @@ rt_band_init_value(
 			float clamped_initval = rt_util_clamp_to_16F(initval);
 			uint16_t packed = rt_util_float_to_float16(clamped_initval);
 				ptr[i] = packed;
 			checkvalfloat = rt_util_float16_to_float(ptr[0]);
 			break;
@@ -210,7 +218,7 @@ rt_band_init_value(
 		case PT_32BSI: {
 			int32_t *ptr = mem;
 			int32_t clamped_initval = rt_util_clamp_to_32BSI(initval);
 			break;
@@ -219,7 +227,7 @@ rt_band_init_value(
 			uint32_t *ptr = mem;
 			uint32_t clamped_initval = rt_util_clamp_to_32BUI(initval);
 			checkvaluint = ptr[0];
 			break;
@@ -228,7 +236,7 @@ rt_band_init_value(
 			float *ptr = mem;
 			float clamped_initval = rt_util_clamp_to_32F(initval);
 			checkvalfloat = ptr[0];
 			break;
@@ -236,7 +244,7 @@ rt_band_init_value(
 		case PT_64BF:
 			double *ptr = mem;
 				ptr[i] = initval;
 			checkvaldouble = ptr[0];
 			break;
diff --git a/raster/rt_core/rt_raster.c b/raster/rt_core/rt_raster.c
index 1c2bbb9f2..9d5fe7c38 100644
--- a/raster/rt_core/rt_raster.c
+++ b/raster/rt_core/rt_raster.c
@@ -493,10 +493,11 @@ rt_raster_generate_new_band(
 	int index
     rt_band band = NULL;
-    int width = 0;
-    int height = 0;
-    int numval = 0;
-    int datasize = 0;
+    uint16_t width = 0;
+    uint16_t height = 0;
+    size_t numval = 0;
+    size_t datasize = 0;
+    int pixbytes = 0;
     int oldnumbands = 0;
     int numbands = 0;
     void * mem = NULL;
@@ -513,8 +514,19 @@ rt_raster_generate_new_band(
     /* Determine size of memory block to allocate and allocate it */
     width = rt_raster_get_width(raster);
     height = rt_raster_get_height(raster);
-    numval = width * height;
-    datasize = rt_pixtype_size(pixtype) * numval;
+    pixbytes = rt_pixtype_size(pixtype);
+    if (pixbytes < 1)
+	    rterror("rt_raster_generate_new_band: Invalid pixel type for band allocation");
+	    return -1;
+    numval = (size_t)width * height;
+    if (numval > UINT32_MAX / (size_t)pixbytes)
+	    rterror("rt_raster_generate_new_band: Raster dimensions are too large for band allocation");
+	    return -1;
+    datasize = numval * (size_t)pixbytes;
     mem = (int *)rtalloc(datasize);
     if (!mem) {
diff --git a/raster/test/cunit/cu_raster_basics.c b/raster/test/cunit/cu_raster_basics.c
index ad68cba9d..e8eac73a7 100644
--- a/raster/test/cunit/cu_raster_basics.c
+++ b/raster/test/cunit/cu_raster_basics.c
@@ -4,6 +4,7 @@
  * Copyright (C) 2012 Regents of the University of California
  *   <bkpark at ucdavis.edu>
+ * Copyright (C) 2026 Darafei Praliaskouski <me at komzpa.net>
@@ -204,6 +205,24 @@ static void test_raster_replace_band(void) {
 	cu_free_raster(raster);
+static void
+test_raster_generate_new_band_size_overflow(void)
+	rt_raster raster;
+	int bandnum;
+	raster = rt_raster_new(UINT16_MAX, UINT16_MAX);
+	CU_ASSERT_PTR_NOT_NULL_FATAL(raster);
+	cu_error_msg_reset();
+	bandnum = rt_raster_generate_new_band(raster, PT_64BF, 0, 0, 0, -1);
+	CU_ASSERT_EQUAL(bandnum, -1);
+	CU_ASSERT_STRING_EQUAL(cu_error_msg,
+			       "rt_raster_generate_new_band: Raster dimensions are too large for band allocation");
+	rt_raster_destroy(raster);
 /* register tests */
 void raster_basics_suite_setup(void);
@@ -215,5 +234,5 @@ void raster_basics_suite_setup(void)
 	PG_ADD_TEST(suite, test_raster_clone);
 	PG_ADD_TEST(suite, test_raster_from_band);
 	PG_ADD_TEST(suite, test_raster_replace_band);
+	PG_ADD_TEST(suite, test_raster_generate_new_band_size_overflow);
Summary of changes:
 raster/rt_core/rt_band.c             | 38 ++++++++++++++++++++++--------------
 raster/rt_core/rt_raster.c           | 24 +++++++++++++++++------
 raster/test/cunit/cu_raster_basics.c | 21 +++++++++++++++++++-
 3 files changed, 61 insertions(+), 22 deletions(-)
hooks/post-receive
