[SCM] PostGIS branch master updated. 3.7.0beta1-64-g631785d88
git at osgeo.org
git at osgeo.org
Mon Jul 27 09:09:52 PDT 2026
the project "PostGIS".
via 631785d88f2a5e01b07ac346a644019bc2cb3ad2 (commit)
via c2edc080522b4e2d464496c9276bfaa4f8ad8fe5 (commit)
from 4db1d75e03357463c86703dc3fad39972d0ac60c (commit)
revisions in full, below.
commit 631785d88f2a5e01b07ac346a644019bc2cb3ad2
Merge: 4db1d75e0 c2edc0805
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Mon Jul 27 09:09:51 2026 -0700
Merge pull request 'Avoid overflowing WKB parser bounds checks' (!552) from Komzpa/postgis:fix-wkb-reader-ubsan into master
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/552
commit c2edc080522b4e2d464496c9276bfaa4f8ad8fe5
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Mon Jul 27 09:44:03 2026 +0400
diff --git a/liblwgeom/cunit/cu_in_wkb.c b/liblwgeom/cunit/cu_in_wkb.c
index 661590504..2d7438c4c 100644
--- a/liblwgeom/cunit/cu_in_wkb.c
+++ b/liblwgeom/cunit/cu_in_wkb.c
@@ -288,6 +288,21 @@ test_wkb_fuzz(void)
CU_ASSERT(g == NULL);
+static void
+test_wkb_in_linestring_zm_count_exceeds_payload(void)
+ const uint8_t wkb[] = {0x01, 0x02, 0x00, 0x00, 0xc0, 0xff, 0xff, 0xff, 0x07};
+ LWGEOM *geom;
+ cu_error_msg_reset();
+ geom = lwgeom_from_wkb(wkb, sizeof(wkb), LW_PARSER_CHECK_NONE);
+ ASSERT_STRING_EQUAL(cu_error_msg, "WKB structure does not match expected size!");
+ CU_ASSERT_PTR_NULL(geom);
static void
test_wkb_in_nurbscurve_count_exceeds_payload(void)
@@ -325,5 +340,6 @@ void wkb_in_suite_setup(void)
PG_ADD_TEST(suite, test_wkb_in_multisurface);
PG_ADD_TEST(suite, test_wkb_in_malformed);
PG_ADD_TEST(suite, test_wkb_fuzz);
+ PG_ADD_TEST(suite, test_wkb_in_linestring_zm_count_exceeds_payload);
PG_ADD_TEST(suite, test_wkb_in_nurbscurve_count_exceeds_payload);
diff --git a/liblwgeom/lwin_wkb.c b/liblwgeom/lwin_wkb.c
index f178e9937..de82d2376 100644
--- a/liblwgeom/lwin_wkb.c
+++ b/liblwgeom/lwin_wkb.c
@@ -49,6 +49,7 @@ typedef struct
int8_t has_srid; /* SRID? */
int8_t error; /* An error was found (not enough bytes to read) */
uint8_t depth; /* Current recursion level (to prevent stack overflows). Maxes at LW_PARSER_MAX_DEPTH */
+ size_t pos_offset; /* Current parse offset from wkb */
const uint8_t *pos; /* Current parse position */
} wkb_parse_state;
@@ -128,13 +129,40 @@ uint8_t* bytes_from_hexbytes(const char *hexbuf, size_t hexsize)
static inline void wkb_parse_state_check(wkb_parse_state *s, size_t next)
- if( (s->pos + next) > (s->wkb + s->wkb_size) )
+ if (next > s->wkb_size || s->pos_offset > s->wkb_size - next)
lwerror("WKB structure does not match expected size!");
s->error = LW_TRUE;
+static inline void
+wkb_parse_state_advance(wkb_parse_state *s, size_t next)
+ s->pos_offset += next;
+ s->pos += next;
+static inline int
+wkb_checked_mul_size(size_t a, size_t b, size_t *result)
+ if (a != 0 && b > SIZE_MAX / a)
+ return LW_FALSE;
+ *result = a * b;
+ return LW_TRUE;
+static inline int
+wkb_checked_add_size(size_t a, size_t b, size_t *result)
+ if (b > SIZE_MAX - a)
+ return LW_FALSE;
+ *result = a + b;
+ return LW_TRUE;
* Resolve a raw WKB type number into the parser state' internal type and flags.
@@ -283,7 +311,7 @@ static char byte_from_wkb_state(wkb_parse_state *s)
char_value = s->pos[0];
LWDEBUGF(4, "Read byte value: %x", char_value);
- s->pos += WKB_BYTE_SIZE;
+ wkb_parse_state_advance(s, WKB_BYTE_SIZE);
return char_value;
@@ -317,7 +345,7 @@ static uint32_t integer_from_wkb_state(wkb_parse_state *s)
- s->pos += WKB_INT_SIZE;
+ wkb_parse_state_advance(s, WKB_INT_SIZE);
return i;
@@ -349,7 +377,7 @@ static double double_from_wkb_state(wkb_parse_state *s)
- s->pos += WKB_DOUBLE_SIZE;
+ wkb_parse_state_advance(s, WKB_DOUBLE_SIZE);
return d;
@@ -417,7 +445,13 @@ static POINTARRAY* ptarray_from_wkb_state(wkb_parse_state *s)
return ptarray_construct(s->has_z, s->has_m, npoints);
/* Does the data we want to read exist? */
- pa_size = (size_t)npoints * ndims * WKB_DOUBLE_SIZE;
+ if (!wkb_checked_mul_size((size_t)npoints, ndims, &pa_size) ||
+ !wkb_checked_mul_size(pa_size, WKB_DOUBLE_SIZE, &pa_size))
+ s->error = LW_TRUE;
+ lwerror("Pointarray length (%d) is too large", npoints);
+ return NULL;
wkb_parse_state_check(s, pa_size);
if (s->error)
return NULL;
@@ -426,7 +460,7 @@ static POINTARRAY* ptarray_from_wkb_state(wkb_parse_state *s)
if( ! s->swap_bytes )
pa = ptarray_construct_copy_data(s->has_z, s->has_m, npoints, (uint8_t*)s->pos);
- s->pos += pa_size;
+ wkb_parse_state_advance(s, pa_size);
/* Otherwise we have to read each double, separately. */
else
@@ -475,7 +509,7 @@ static LWPOINT* lwpoint_from_wkb_state(wkb_parse_state *s)
/* Otherwise we have to read each double, separately */
else
@@ -833,7 +867,7 @@ static LWNURBSCURVE* lwnurbscurve_from_wkb_state(wkb_parse_state *s)
double *weights = NULL, *knots = NULL;
POINTARRAY *points = NULL;
int all_weights_one = 1;
- size_t pa_size;
+ size_t pa_size, point_payload_size, weights_size, point_tags_size;
static const uint32_t MAXPOINTS = (uint32_t)(UINT_MAX / (WKB_DOUBLE_SIZE * 4));
/* ISO/IEC 13249-3:2016 compliant parsing */
@@ -861,15 +895,27 @@ static LWNURBSCURVE* lwnurbscurve_from_wkb_state(wkb_parse_state *s)
return NULL;
const size_t min_point_size = 2 + (2 + (s->has_z ? 1 : 0) + (s->has_m ? 1 : 0)) * WKB_DOUBLE_SIZE;
- wkb_parse_state_check(s, (size_t)npoints * min_point_size);
+ if (!wkb_checked_mul_size((size_t)npoints, min_point_size, &pa_size))
+ lwerror("WKB NURBSCURVE: control point count (%u) too large", npoints);
+ return NULL;
+ wkb_parse_state_check(s, pa_size);
if (s->error)
return NULL;
ndims = 2 + s->has_z + s->has_m;
- pa_size = (size_t)npoints * ndims * WKB_DOUBLE_SIZE; /* coord */
- pa_size += npoints * sizeof(double); /* weight */
- pa_size += npoints * sizeof(char) * 2; /* endian_byte + weight_byte */
+ if (!wkb_checked_mul_size((size_t)npoints, ndims, &point_payload_size) ||
+ !wkb_checked_mul_size(point_payload_size, WKB_DOUBLE_SIZE, &point_payload_size) ||
+ !wkb_checked_mul_size((size_t)npoints, sizeof(double), &weights_size) ||
+ !wkb_checked_mul_size((size_t)npoints, sizeof(char) * 2, &point_tags_size) ||
+ !wkb_checked_add_size(point_payload_size, weights_size, &pa_size) ||
+ !wkb_checked_add_size(pa_size, point_tags_size, &pa_size))
+ return NULL;
if (s->error)
return NULL;
@@ -1145,6 +1191,7 @@ LWGEOM* lwgeom_from_wkb(const uint8_t *wkb, const size_t wkb_size, const char ch
s.has_srid = LW_FALSE;
s.error = LW_FALSE;
s.pos = wkb;
+ s.pos_offset = 0;
s.depth = 1;
if (!wkb || !wkb_size)
Summary of changes:
liblwgeom/cunit/cu_in_wkb.c | 16 ++++++++++
liblwgeom/lwin_wkb.c | 71 +++++++++++++++++++++++++++++++++++++--------
2 files changed, 75 insertions(+), 12 deletions(-)
hooks/post-receive
